C5S-24.000-12-50100-X1 数据手册
Ltr
Revisions
Date
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Electrical Specifications:
Frequency Range
Fundamental
Third Overtone
Mode of Oscillation
Frequency Tolerance at 25°C
Frequency Stability over Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging per Year
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
8.000 to 150.000
8.000 to 52.000
40.000 to 150.000
±50
±100
-40 to +125
-55 to +150
±3
10 to 32 and Series Resonance
7.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
PPM Max
ºC
PPM Max
pF
Ohm
uW Typ
M Ohm
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
8.000 to 10.000
150
Fundamental
10.100 to 12..000
90
Fundamental
12.100 to 15.000
70
Fundamental
15.100 to 30.000
50
Fundamental
30.100 to 52.000
30
Fundamental
40.000 to 52.000
100
Third Overtone
52.100 to 80.000
100
Third Overtone
80.100 to 150.000
80
Third Overtone
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: April 18, 2008
Microprocessor Crystal Unit
Automotive Temperature Range
5.0 x 3.2 millimeter Surface Mount
General Product Specification
Part Number:
C5S X1 Series
www.aker-usa.com
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
P/N:
www.aker-usa.com
C5S X1 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C5S X1 Series
How to build a Part Number:
Series
Package
C
5S
Parameter
5.0 x 3.2 mm
Frequency
8.000 to 150.000
MHz
Load Capacitance
10
12
16
18
S
Frequency Tolerance
Frequency Stability
50
100
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±50 PPM
±100 PPM
Mode of Oscillation
See Notes
3
Fundamental
Third Overtone
Temperature Range
X1
-40 to +125 ºC
Packaging
R
Tape and Reel
Part Number Example:
C5S-40.000-18-50100-X1-R
C5S: 5.0 x 3.2 mm SMD Seam Sealed Package
40.000 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
X1: -40 to +125º C Automotive Temperature Range
R: Tape and Reel Packaging
Notes:
1- Fundamental mode does not need to be included in Part Number description.
2- Othe Load Capacitances are availble than those listed in Part Number table above.
3- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
4- Quantities less than 1000 are shipped bulk in ESD pouches.
5- Specification subject to change without notice
Page:
4/4
P/N:
C5S X1 Series
www.aker-usa.com
C5S-24.000-12-50100-X1 价格&库存
很抱歉,暂时无法提供与“C5S-24.000-12-50100-X1”相匹配的价格&库存,您可以联系我们找货
