C7S-20.000-12-3030-X 数据手册
Specification Title:
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC
All dimensions are millimeters.
CAD:
Review:
Appr:
Page:
Microprocessor Crystal Unit
Low Profile
7.0 x 5.0 millimeter Surface Mount - 4 Pad
General Product Specification
TCR
EG
JL
1/4
Date: August 01, 2022
Series Name: C7S Series
Electrical Specifications:
Frequency Range
6.000 to 133.000
Mode of Oscillation
Fundamental
6.000 to 50.000
Third Overtone
40.000 to 133.00
Standard
MHz
MHz
±30
±25
Frequency Tolerance at 25°C
±20
Optional
PPM Max
±15
±10
Standard
±50
±100
±30
Frequency Stability over
Temperature Range
±25
Optional
PPM Max
±20
±15
±10*
Standard
-20 to +70
Extended
Operating Temperature Range
-40 to +85
-40 to +125
Storage Temperature Range
-55 to +125
Aging
±3
PPM Max/Year
Load Capacitance
6 to 47 and Series Resonance
Shunt Capacitance
7.0
Equivalent Series Resistance(ESR)
See ESR Table
Ohm
100
uW Max
500 at 100 Vdc ± 15 Vdc
M Ohm
Drive Level
Insulation Resistance
pF
Frequency Range and ESR Values:
Frequency Range in
MHz
ESR Ohm Max
Mode of Operation
Frequency Range in
MHz
ESR Ohm Max
Mode of Operation
6.000 to 7.999
70
Fundamental
40.000 to 50.000
Fundamental
8.000 to 9.999
40
Fundamental
40.000 to 51.999
70
Third Overtone
10.000 to 11.999
35
Fundamental
52.000 to 79.999
65
Third Overtone
12.000 to 19.999
30
Fundamental
80.000 to 133.000
60
Third Overtone
20.000 to 39.999
25
Fundamental
Ltr
Revisions
RoHS Compliant
Pb - Lead Free
www.aker-usa.com
Date
Appr
Mechanical Outline:
C eram ic B ase
M etal L id
5.0 ± 0.15
7.0 ± 0.15
#4
#3
AKER
#1
#2
1.1 M ax.
4.6
5.9
#4
#3
1.0
1.4
2.54
#2
2.54
#1
1.7
1.2
#2:G N D
#4:G N D
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
P/N:
www.aker-usa.com
C7S Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C7S Series
How to build a Part Number:
Series
Package
C
7S
Parameter
7.0 x 5.0 mm - 4 Pad
Frequency
6.000 to 133.000
MHz
Load Capacitance
10
12
16
18
S
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Standard
Frequency Tolerance
Option
Standard
Frequency Stability
Option
30
25
10
50
100
30
25
10
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM
±50PPM
±100PPM
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM*
Mode of Oscillation
See Notes
3
Standard
Option
Temperature Range
Option
Option
See Notes
X
X1
X2
Fundamental
Third Overtone
-20 to +70 ℃
-40 to +85 ℃
-40 to +125 ℃
-40 to +105 ℃
Packaging
M
R
250pcs Reel
1000pcs Reel
Part Number Example:
C7S-64.000-18-3050-3-R
C7S- 7.0 x 5.0 mm SMD Seam Seal Package - 4 pad
64.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Third Overtone Mode
-10 to +70° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Fundamental mode does not need to be included in Part Number description.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration.
Page:
4/4
P/N:
www.aker-usa.com
C7S Series
C7S-20.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C7S-20.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
