C3E-24.000-10-3050-X-R 数据手册
Specification Title:
Microprocessor Crystal Unit
Low Profile
3.2 x 2.5 millimeter Surface Mount - 4 Pad
General Product Specification
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC
All dimensions are millimeters.
CAD:
Review:
Appr:
Page:
TCR
EG
JL
1/4
Series Name: C3E Series
Date: August 01, 2022
Electrical Specifications:
Frequency Range
8.000 to 150.000
Mode of Oscillation
Fundamental
8.000 to 64.000
Third Overtone
60.000 to 150.00
Standard
MHz
MHz
±30
±50
Frequency Tolerance at 25°C
PPM Max
(Note 1)
±20
Optional
±15
±10
Standard
±50
±100
±30
Frequency Stability over
Temperature Range
PPM Max
(Note 1)
±25
Optional
±20
±15
±10*
Standard
Operating Temperature Range
-20 to +70
Extended
-40 to +85
-40 to +125
Storage Temperature Range
-55 to +125
Aging
±3
PPM Max/Year
Load Capacitance
6 to 47 and Series Resonance
Shunt Capacitance
3.0
Equivalent Series Resistance(ESR)
See ESR Table
Ohm
100
uW Max
500 at 100 Vdc ± 15 Vdc
M Ohm
Drive Level
Insulation Resistance
pF
Frequency Range and ESR Values:
Frequency Range in
MHz
ESR Ohm Max
Mode of Operation
Frequency Range in
ESR Ohm Max
MHz
Mode of Operation
8.000 to 9.999
500
Fundamental
60.000 to 99.999
150
Third Overtone
10.000 to 11.999
150
Fundamental
100.000 to 124.999
100
Third Overtone
12.000 to 15.999
80
Fundamental
125.000 to 150.000
80
Third Overtone
16.000 to 19.999
60
Fundamental
20.000 to 24.999
50
Fundamental
25.000 to 49.999
40
Fundamental
50.000 to 64.000
30
Fundamental
Ltr
Revisions
RoHS Compliant
Pb - Lead Free
www.aker-usa.com
Date
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
P/N:
www.aker-usa.com
C3E Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C3E Series
How to build a Part Number:
Series
Package
C
3E
Parameter
3.2 x 2.5 mm - 4 Pad
Frequency
8.000 to 150.000
MHz
Load Capacitance
7
10
12
16
18
S
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Standard
Frequency
Tolerance
(Note 1)
Option
Standard
Frequency Stability
(Note 1)
Option
30
25
10
50
100
30
25
10
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM
±50PPM
±100PPM
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM*
Mode of Oscillation
See Notes
3
Standard
Option
Temperature Range
Option
Option
See Notes
X
X1
X2
Fundamental
Third Overtone
-20 to +70 ℃
-40 to +85 ℃
-40 to +125 ℃
-40 to +105 ℃
Packaging
M
R
R3
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C3E-24.000-18-3050-X-R
C3E- 3.2 x 2.5 mm SMD Seam Seal Crystal Unit - 4 Pad
24.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Fundamental Mode
X: -40 to +85° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Fundamental mode does not need to be included in part number description
4- Quantities less than 250pcs are shipped in tape only.
5- Specification subject to change without notice.
Page:
4/4
P/N:
www.aker-usa.com
C3E Series
C3E-24.000-10-3050-X-R 价格&库存
很抱歉,暂时无法提供与“C3E-24.000-10-3050-X-R”相匹配的价格&库存,您可以联系我们找货
