C5S-10.000-12-50100-X1
    AKER(安碁科技)
    AKER - C5S-10.000-12-50100-X1 - CRYSTAL, 10MHZ, 12PF, 5MM X 3.2MM
C5S-10.000-12-50100-X1 数据手册
Ltr Revisions Date RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Electrical Specifications: Frequency Range Fundamental Third Overtone Mode of Oscillation Frequency Tolerance at 25°C Frequency Stability over Temperature Range Operating Temperature Range Storage Temperature Range Aging per Year Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 8.000 to 150.000 8.000 to 52.000 40.000 to 150.000 ±50 ±100 -40 to +125 -55 to +150 ±3 10 to 32 and Series Resonance 7.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz PPM Max ºC PPM Max pF Ohm uW Typ M Ohm Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 8.000 to 10.000 150 Fundamental 10.100 to 12..000 90 Fundamental 12.100 to 15.000 70 Fundamental 15.100 to 30.000 50 Fundamental 30.100 to 52.000 30 Fundamental 40.000 to 52.000 100 Third Overtone 52.100 to 80.000 100 Third Overtone 80.100 to 150.000 80 Third Overtone Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: April 18, 2008 Microprocessor Crystal Unit Automotive Temperature Range 5.0 x 3.2 millimeter Surface Mount General Product Specification Part Number: C5S X1 Series www.aker-usa.com Appr Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: April 18, 2008 P/N: www.aker-usa.com C5S X1 Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: April 18, 2008 P/N: www.aker-usa.com C5S X1 Series How to build a Part Number: Series Package C 5S Parameter 5.0 x 3.2 mm - Frequency 8.000 to 150.000 MHz - Load Capacitance 10 12 16 18 20 32 S Frequency Tolerance Frequency Stability 50 100 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±50 PPM ±100 PPM - Mode of Oscillation See Notes 3 Fundamental Third Overtone - Temperature Range X1 -40 to +125 ºC - Packaging R Tape and Reel Part Number Example: C5S-40.000-18-50100-X1-R C5S: 5.0 x 3.2 mm SMD Seam Sealed Package 40.000 MHz Nominal Frequency 18 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability X1: -40 to +125º C Automotive Temperature Range R: Tape and Reel Packaging Notes: 1- Fundamental mode does not need to be included in Part Number description. 2- Othe Load Capacitances are availble than those listed in Part Number table above. 3- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 4- Quantities less than 1000 are shipped bulk in ESD pouches. 5- Specification subject to change without notice Page: 4/4 Date: April 18, 2008 P/N: C5S X1 Series www.aker-usa.com
C5S-10.000-12-50100-X1 价格&库存
很抱歉,暂时无法提供与“C5S-10.000-12-50100-X1”相匹配的价格&库存,您可以联系我们找货
