C3E-24.576-12-50100-X1 数据手册
Ltr
Date
Revisions
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Electrical Specifications:
Frequency Range
12.000 to 52.000
Mode of Oscillation
Fundamental
Frequency Tolerance at 25°C
±50
Frequency Stability over Temperature Range
±100
Operating Temperature Range
-40 to +125
Storage Temperature Range
-55 to +150
Aging per Year
±3
Load Capacitance
7 to 32 and Series Resonance
Shunt Capacitance
5.0
Equivalent Series Resistance (ESR)
PPM Max
ºC
PPM Max
pF
See ESR Table
Ohm
100
uW Max
500 at at 100 Vdc ± 15 Vdc
M Ohm
Drive Level
Insulation Resistance
MHz
12.000 to 52.000
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
12.000 to 29.900
100
Fundamental
30.000 to 52.000
50
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: April 15, 2008
Microprocessor Crystal Unit
Automotive Temperature Range
2.5 x 3.2 millimeter Surface Mount
General Product Specification
Part Number:
C3E X1 Series
www.aker-usa.com
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: June 10, 2006
P/N:
www.aker-usa.com
C3E X1 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C3E X1 Series
How to build a Part Number:
Series
Package
C
3E
Parameter
3.2 x 2.5 mm
Frequency 12.000 to 52.000
MHz
Load Capacitance
7
10
12
16
18
S
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Frequency Tolerance
Frequency Stability
50
100
±50 PPM
±100 PPM
Temperature Range
X
-40 to +125 ºC
Packaging
R
Tape and Reel
Part Number Example:
C3E-32.768-18-50100-X1-R
C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit
32.768 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
Fundamental Mode
X1: -40 to +125° C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces.
2- Quantities less than 3000 are shipped bulk in ESD pouches.
3- Specification subject to change without notice.
Page:
4/4
P/N:
www.aker-usa.com
C3E X1 Series
C3E-24.576-12-50100-X1 价格&库存
很抱歉,暂时无法提供与“C3E-24.576-12-50100-X1”相匹配的价格&库存,您可以联系我们找货
