C6S-25.000-12-3030-X 数据手册
Specification Title:
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC
All dimensions are millimeters.
CAD:
Review:
Appr:
Page:
Microprocessor Crystal Unit
Low Profile
5.0 x 3.2 millimeter Surface Mount - 4 Pad
General Product Specification
TCR
EG
JL
1/4
Date: August 01, 2022
Series Name: C5S Series
Electrical Specifications:
Frequency Range
8.000 to 133.000
Mode of Oscillation
Fundamental
8.000 to 54.000
Third Overtone
40.000 to 133.00
Standard
MHz
MHz
±30
±50
Frequency Tolerance at 25°C
±20
Optional
PPM Max
±15
±10
Standard
±50
±100
±30
Frequency Stability over
Temperature Range
±25
Optional
PPM Max
±20
±15
±10*
Operating Temperature Range
Standard
-20 to +70
Extended
-40 to +85
-40 to +125
Storage Temperature Range
-55 to +125
Aging
±3
PPM Max/Year
Load Capacitance
6 to 47 and Series Resonance
Shunt Capacitance
7.0
Equivalent Series Resistance(ESR)
See ESR Table
Ohm
100
uW Max
500 at 100 Vdc ± 15 Vdc
M Ohm
Drive Level
Insulation Resistance
pF
Frequency Range and ESR Values:
Frequency Range in
MHz
ESR Ohm Max
Mode of Operation
8.000 to 9.999
10.000 to 11.999
12.000 to 15.999
16.000 to 19.999
20.000 to 49.999
50.000 to 54.000
60
45
35
30
25
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Ltr
Frequency Range in
ESR Ohm Max
MHz
40.000 to 59.999
60.000 to 133.000
Revisions
RoHS Compliant
Pb - Lead Free
www.aker-usa.com
70
60
Mode of Operation
Third Overtone
Third Overtone
Date
Appr
Mechanical Outline:
5.0 ± 0.15
Ceramic Base
3.2 ± 0.15
#4
Metal Lid
#3
AKER
#1
#2
1.0 Max.
2.6
3.8
#2
#4
#3
1.4
0.9
1.4
2.3
#1
1.2
#2:GND #4:GND
1.6
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
P/N:
www.aker-usa.com
C5S Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C5S Series
How to build a Part Number:
Series
Package
C
5S
Parameter
5.0 x 3.2 mm - 4 Pad
Frequency
8.000 to 133.000
MHz
Load Capacitance
6
10
12
16
18
S
6 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Standard
Frequency Tolerance
Option
Standard
Frequency Stability
Option
30
25
10
50
100
30
25
10
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM
±50PPM
±100PPM
±30PPM
±25PPM
±20PPM
±15PPM
±10PPM*
Mode of Oscillation
See Notes
3
Standard
Option
Temperature Range
Option
Option
See Notes
X
X1
X2
Fundamental
Third Overtone
-20 to +70 ℃
-40 to +85 ℃
-40 to +125 ℃
-40 to +105 ℃
Packaging
M
R
250pcs Reel
1000pcs Reel
Part Number Example:
C5S-40.000-3050-X-R
C5S: 5.0 x 3.2 mm SMD Seam Sealed Package - 4 Pad
40.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
X: -40 to +85º C Extended Temperature Range
R: Tape and Reel Packaging
Notes:
1- Fundamental mode does not need to be included in Part Number description.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Other Load Capacitances are availble other than those listed in Part Number table above.
3- Product is shipped in Tape and Reel configuration.
4- Quantities less than 250pcs are shipped in tape
5- Specification subject to change without notice
Page:
4/4
P/N:
www.aker-usa.com
C5S Series
C6S-25.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C6S-25.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
