C2E-24.000-12-3030-X 数据手册
Ltr
Revisions
Date
RoHS Compliant
Pb - Lead Free
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Standard
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Operating Temperature Range
Standard
Extended
Storage Temperature Range
Aging per Year
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
16.000 to 50.000
16.000 to 50.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10
-10 to +70
-40 to +85
-55 to +125
±3
7 to 32 and Series Resonance
5.0
See ESR Table
100
MHz
PPM Max
(Note 1)
PPM Max
(Note 1)
ºC
PPM Max
pF
Ohms
uW Typ
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
16.000 to 29.999
100
Fundamental
30.000 to 50.000
70
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: June 9, 2006
Microprocessor Crystal Unit
Low Profile
2.0 x 2.5 millimeter Surface Mount
General Product Specification
Part Number:
C2E Series
www.aker-usa.com
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: June 9, 2006
P/N:
www.aker-usa.com
C2E Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: June 9, 2006
P/N:
www.aker-usa.com
C2E Series
How to build a Part Number:
Series
Package
C
2E
Parameter
2.0 x 2.5 mm
Frequency
16.000 to 50.000
MHz
Load Capacitance
7
10
12
16
18
S
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Standard
Frequency Tolerance
(Note 1)
Option
Standard
Frequency Stability
(Note 1)
Option
30
25
10
50
30
25
10
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM
Standard
Temperature Range
Option
See Notes
X
-10 to +70 ºC
-40 to +85 ºC
Packaging
R
Tape and Reel
Part Number Example:
C2E-50.000-18-3050-R
C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit
50.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Fundamental Mode
-10 to +70° C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces.
4- Quantities less than 3000 are shipped bulk in ESD pouches.
5- Specification subject to change without notice.
Page:
4/4
Date: June 9, 2006
P/N:
www.aker-usa.com
C2E Series
C2E-24.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C2E-24.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
