CAA-16.000-18-3050-X 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Revisions
Date
Appr
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Third Overtone
Standard
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
Optional
Standard
Extended
3.200 to 70.000
3.200 to 32.768
24.576 to 70.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10
-20 to +70
-40 to +85
-55 to +125
±5 first year
±3 thereafter
10 to 32 and Series Resonance
7.0
See ESR Table
1.0
500 at at 100 Vdc ± 15 Vdc
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: April 30, 2006
Quartz Crystal
Surface Mount
HC-49/U-S SMD Package
General Product Specification
Part Number:
CAA Series
www.aker-usa.com
MHz
MHZ
PPM Max
PPM Max
ºC
PPM Max/Year
pF
pF Max
Ohms
mW Max
M Ohm
Frequency Range vs. ESR Values:
Frequency Range in MHz
3.200 to 3.500
3.510 to 3.999
4.000 to 5.999
6.000 to 7.999
8.000 to 9.999
10.000 to 15.999
16.000 to 32.768
24.576 to 70.000
ESR Ohms Max
300
200
120
80
60
50
40
80
Mode of Operation
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental-Third Overtone
Mechanical Outline:
Marking
3.8 Max
10.3 Max
H
0.65 Typ
Height (H):
Standard - 4.6 Max
Option - 3.2 Max
1.02 Max
0.38 Min
4.8 Max
3.81 Max
13.5 Max
Dimensions are millimeters.
PCB Solder Pad Layout:
Page:
2/4
P/N:
CAA Series
www.aker-usa.com
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
CAA Series
How to build a Part Number:
Series
Package
C
AA
Parameter
HC-49/U-S SMD
3.200 to 70.000
Frequency
MHz
Load Capacitance
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
10
12
16
18
S
Standard
Frequency Tolerance
Option
Standard
Frequency Stability
Option
30
25
10
50
30
25
10
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM
Mode of Oscillation
See Notes
3
Standard
Temperature Range
Option
See Notes
X
Package Height Standard
Option
See Notes
32
Packaging
See Notes
R
Fundamental
Third Overtone
-20 to +70 ºC
-40 to +85 ºC
4.6
3.2
Bulk
Tape and Reel
Part Number Example:
CAA-24.000-18-3050-R
CAA: HC-49/U-S SMD Package
24.000 MHz Nominal Frequency
18pF Load Capacitance
3050: ±30 PPM Tolerance and ±50 PPM Stability
Fundamental Mode
-20 to +70°C Temperature Range
Standard Height - 4.6 mm
R: Tape and Reel Packaging
Notes:
1- Standard Temperature Range, Package Height (4.6mm), and Fundamental Mode do not
need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
4- Quantities less than 1000 are shipped bulk. 100 pieces in ESD bags.
5- Specification subject to change without notice.
Page:
4/4
P/N:
www.aker-usa.com
CAA Series
CAA-16.000-18-3050-X 价格&库存
很抱歉,暂时无法提供与“CAA-16.000-18-3050-X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 65+3.44074
- 125+3.36367
- 国内价格
- 5+3.51572
- 65+3.44074
- 125+3.36367
- 国内价格
- 250+2.77217
- 1250+2.49516
