C3E-24.000-12-3030-X
    AKER(安碁科技)
    AKER - C3E-24.000-12-3030-X - Crystal, 24 MHz, SMD, 3.4mm x 2.7mm, 30 ppm, 12 pF, 30 ppm, C3E
C3E-24.000-12-3030-X 数据手册
Ltr Revisions Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range Mode of Oscillation Fundamental Standard Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Standard Extended Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 12.000 to 52.000 12.000 to 52.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10 -10 to +70 -40 to +85 -55 to +125 ±3 7 to 32 and Series Resonance 5.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz MHZ PPM Max (Note 1) PPM Max (Note 1) ºC PPM Max/Year pF Ohm uW Max M Ohm Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 12.000 to 29.900 100 Fundamental 30.000 to 52.000 50 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: June 10, 2006 Microprocessor Crystal Unit Low Profile 2.5 x 3.2 millimeter Surface Mount General Product Specification Part Number: C3E Series www.aker-usa.com Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: June 10, 2006 P/N: www.aker-usa.com C3E Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: June 10, 2006 P/N: www.aker-usa.com C3E Series How to build a Part Number: Series Package C 3E Parameter 3.2 x 2.5 mm - Frequency 12.000 to 52.000 MHz - Load Capacitance 7 10 12 16 18 20 32 S 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - Standard Frequency Tolerance (Note 1) Option Standard Frequency Stability (Note 1) Option 30 25 20 15 10 50 30 25 20 15 10 ±30 PPM ±25 PPM ±20 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±20 PPM ±15 PPM ±10 PPM - Temperature Range Standard Extended See Notes X Packaging R -10 to +70 ºC -40 to +85 ºC Tape and Reel Part Number Example: C3E-32.768-18-3050-X-R C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit 32.768 MHz Nominal Frequency 18 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability Fundamental Mode X: -40 to +85° C Temperature Range R: Tape and Reel Packaging Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces. 4- Quantities less than 3000 are shipped bulk in ESD pouches. 5- Specification subject to change without notice. Page: 4/4 Date: June 10, 2006 P/N: www.aker-usa.com C3E Series
C3E-24.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C3E-24.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
  • 65+8.66223
  • 125+8.47687
库存:1435
  • 5+8.85801
  • 65+8.66223
  • 125+8.47687
库存:1435
  • 250+5.38708
  • 1250+5.27878
库存:1435
