C2E-16.000-12-3030-X
    AKER(安碁科技)
    AKER - C2E-16.000-12-3030-X - Crystal, 16 MHz, SMD, 2.5mm x 2mm, 30 ppm, 12 pF, 30 ppm, C2E
C2E-16.000-12-3030-X 数据手册
Ltr Revisions Date RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range Mode of Oscillation Fundamental Standard Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Operating Temperature Range Standard Extended Storage Temperature Range Aging per Year Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level 16.000 to 50.000 16.000 to 50.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10 -10 to +70 -40 to +85 -55 to +125 ±3 7 to 32 and Series Resonance 5.0 See ESR Table 100 MHz PPM Max (Note 1) PPM Max (Note 1) ºC PPM Max pF Ohms uW Typ Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 16.000 to 29.999 100 Fundamental 30.000 to 50.000 70 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: June 9, 2006 Microprocessor Crystal Unit Low Profile 2.0 x 2.5 millimeter Surface Mount General Product Specification Part Number: C2E Series www.aker-usa.com Appr Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: June 9, 2006 P/N: www.aker-usa.com C2E Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: June 9, 2006 P/N: www.aker-usa.com C2E Series How to build a Part Number: Series Package C 2E Parameter 2.0 x 2.5 mm - Frequency 16.000 to 50.000 MHz - Load Capacitance 7 10 12 16 18 20 32 S 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - Standard Frequency Tolerance (Note 1) Option Standard Frequency Stability (Note 1) Option 30 25 20 15 10 50 30 25 20 15 10 ±30 PPM ±25 PPM ±20 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±20 PPM ±15 PPM ±10 PPM - Standard Temperature Range Option See Notes X -10 to +70 ºC -40 to +85 ºC - Packaging R Tape and Reel Part Number Example: C2E-50.000-18-3050-R C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit 50.000 MHz Nominal Frequency 18 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability Fundamental Mode -10 to +70° C Temperature Range R: Tape and Reel Packaging Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces. 4- Quantities less than 3000 are shipped bulk in ESD pouches. 5- Specification subject to change without notice. Page: 4/4 Date: June 9, 2006 P/N: www.aker-usa.com C2E Series
C2E-16.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C2E-16.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
