C3E-32.000-12-3030-X 数据手册
Ltr
Revisions
Date
Appr
RoHS Compliant
Pb - Lead Free
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Standard
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
12.000 to 52.000
12.000 to 52.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10
-10 to +70
-40 to +85
-55 to +125
±3
7 to 32 and Series Resonance
5.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
MHZ
PPM Max
(Note 1)
PPM Max
(Note 1)
ºC
PPM Max/Year
pF
Ohm
uW Max
M Ohm
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
12.000 to 29.900
100
Fundamental
30.000 to 52.000
50
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: June 10, 2006
Microprocessor Crystal Unit
Low Profile
2.5 x 3.2 millimeter Surface Mount
General Product Specification
Part Number:
C3E Series
www.aker-usa.com
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: June 10, 2006
P/N:
www.aker-usa.com
C3E Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: June 10, 2006
P/N:
www.aker-usa.com
C3E Series
How to build a Part Number:
Series
Package
C
3E
Parameter
3.2 x 2.5 mm
Frequency
12.000 to 52.000
MHz
Load Capacitance
7
10
12
16
18
S
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
Standard
Frequency Tolerance
(Note 1)
Option
Standard
Frequency Stability
(Note 1)
Option
30
25
10
50
30
25
10
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM
Temperature Range
Standard
Extended
See Notes
X
Packaging
R
-10 to +70 ºC
-40 to +85 ºC
Tape and Reel
Part Number Example:
C3E-32.768-18-3050-X-R
C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit
32.768 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Fundamental Mode
X: -40 to +85° C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces.
4- Quantities less than 3000 are shipped bulk in ESD pouches.
5- Specification subject to change without notice.
Page:
4/4
Date: June 10, 2006
P/N:
www.aker-usa.com
C3E Series
C3E-32.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C3E-32.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
