C5S-16.000-12-3030-X
    AKER(安碁科技)
    AKER - C5S-16.000-12-3030-X - Crystal, 16 MHz, SMD, 5mm x 3.2mm, 30 ppm, 12 pF, 30 ppm, C5S
C5S-16.000-12-3030-X 数据手册
RoHS Compliant Pb - Lead Free Ltr Date Revisions Electrical Specifications: Nominal Frequency 16.0000 MHz Mode of Oscillation Fundamental - Frequency Tolerance at 25°C ±30 Frequency Stability over Temperature Range ±30 Operating Temperature Range (Extended) -40 to +85 Storage Temperature Range -55 to +125 PPM Max ºC Aging per Year ±3 Load Capacitance 12 Shunt Capacitance (Maximum) 7 Equivalent Series Resistance (ESR) 50 Ohms Max Drive Level 100 Typ - 500 Max uW Solder Reflow Characteristics +260 for 10 s Max ºC PPM Max pF Mechanical Specifications: Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TR Review: SL Appr: AL Page: 1/1 Date: Jan. 16, 2008 Quartz Crystal Unit 5 x 3.2 mm SMD Product Specification Farnell Order Code: 1538843 Part Number: C5S-16.000-12-3030-X www.aker-usa.com Appr
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为2.5V至5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收38kHz的红外信号,并将其转换为电信号输出。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的红外遥控。
7. 封装信息:EL817采用SOP-8封装。
C5S-16.000-12-3030-X 价格&库存
很抱歉,暂时无法提供与“C5S-16.000-12-3030-X”相匹配的价格&库存,您可以联系我们找货
