C7S-16.000-12-50100-X1
    AKER(安碁科技)
    AKER - C7S-16.000-12-50100-X1 - Crystal, 16 MHz, SMD, 7mm x 5mm, 100 ppm, 12 pF, 50 ppm, C7S X1
C7S-16.000-12-50100-X1 数据手册
Ltr Revisions Date RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Electrical Specifications: Frequency Range 6.000 to 133.000 Fundamental 6.000 to 48.000 Mode of Oscillation Third Overtone 40.000 to 133.000 Frequency Tolerance at 25°C ±50 Frequency Stability over Temperature Range ±100 Operating Temperature Range -40 to +125 Storage Temperature Range -55 to +150 Aging per Year ±3 Load Capacitance 10 to 32 and Series Resonance Shunt Capacitance 7.0 Equivalent Series Resistance (ESR) See ESR Table Drive Level 100 Insulation Resistance 500 at at 100 Vdc ± 15 Vdc MHz PPM Max ºC PPM Max pF Ohm uW Typ M Ohm Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 6.000 to 10.000 110 Fundamental 10.100 to 12.000 60 Fundamental 12.100 to 20.000 45 Fundamental 20.100 to 48.000 30 Fundamental 40.000 to 52.000 80 Fundamental 52.100 to 133.000 60 Third Overtone Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: April 18, 2008 Microprocessor Crystal Unit Automotive Temperature Range 5 x 7 millimeter Surface Mount - 4 Pad General Product Specification Part Number: C7S X1 Series www.aker-usa.com Appr Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: April 18, 2006 P/N: www.aker-usa.com C7S X1 Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: April 18, 2008 P/N: www.aker-usa.com C7S X1 Series How to build a Part Number: Series Package C 7S Parameter 5.0 x 7.0 mm - Frequency 6.000 to 133.000 MHz - Load Capacitance 10 12 16 18 20 32 S Frequency Tolerance Frequency Stability 50 100 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±50 PPM ±100 PPM - Mode of Oscillation See Notes 3 Temperature Range X1 Fundamental Third Overtone -40 to +125 ºC - Packaging R Tape and Reel Part Number Example: C7S-64.000-18-50100-3-X1-R C7S- 5 x 7 mm SMD Seam Seal Package - 4 pad 64.000 MHz Nominal Frequency 18 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability Third Overtone Mode X1: -40 to +125° C Automotive Temperature Range R: Tape and Reel Packaging Notes: 1- Fundamental mode does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: April 18, 2008 P/N: www.aker-usa.com C7S X1 Series
C7S-16.000-12-50100-X1 价格&库存
很抱歉,暂时无法提供与“C7S-16.000-12-50100-X1”相匹配的价格&库存,您可以联系我们找货
