49S-011059-FX4X15
49S-011059-FX4X15
    AKER(安碁科技)
    HC49S
    无源晶振 HC49S
49S-011059-FX4X15 数据手册
Customer Name : Customer P/N : Frequency : 11.059200 AKER Approved P/N : 49S-011059-FX4X15 AKER MPN : 49S-011059-FX4X15 REVISION : A0 ISSUED DATE : 2019/10/30 APPROVED CHECKED Earnest MHz PREPARED Kiku APPROVED BY CUSTOMER AKER TECHNOLOGY CO., LTD. ADDRESS : No.11-3, Jianguo Rd., Tanzi Dist., Taichung City 427, Taiwan TEL:886-4-25335978 FAX : 886-4-25336011 Web: www.aker.com.tw RoHS compliant Customer P/N AKER Approved P/N 49S-011059-FX4X15 APPROVED Earnest SHEET 1 OF 5 PREPARED Kiku REV. A0 Revison Date Reviser A0 2019/10/30 Kiku Revised contents Initial Released *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Customer P/N AKER Approved P/N 49S-011059-FX4X15 APPROVED Earnest SHEET 2 OF 5 PREPARED Kiku REV. A0 HC-49US CRYSTAL SPECIFICATION 1 . ELECTRICAL CHARACTERISTICS (1) Standard atmospheric conditions Unless otherwise specified , the standard range of atmospheric conditions for making measurement and tests are as follow : Ambient temperature : 25±5°C Relative humidity : 40%~70% If there is any doubt about the results , measurement shall be made within the following limits : Ambient temperature : 25±3°C Relative humidity : 40%~70% (2) Measurement Equipment : SAUNDERS 350A (Measured FL) (3) Cutting Model : AT CUT (4) Oscillation Model : Fundamental Parameters Symbol Electrical Specification Min. Typ. Max. Notes Unit Nominal Frequency FL 11.059200 MHz Load Capacitance CL 20 pF Frequency Tolerance -30 ~ 30 ppm At 25°C ± 3°C Frequency Stability -30 ~ 30 ppm Related to 25 °C 100 uW Drive Level DL Operating Temperature Range -40 ~ 85 °C Storage Temperature Range -55 ~ 125 °C Effective Series Resistance RR 50 Ω Shunt Capacitance C0 7 pF Motional Capacitance C1 N/A Ratio Of Capacitance r N/A Aging Rate Insulation Resistance -3 500 ~ fF C0/C1 3 ppm First Year MOhms At DC 100V *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Customer P/N AKER Approved P/N 49S-011059-FX4X15 APPROVED Earnest SHEET 3 OF 5 PREPARED Kiku REV. A0 2 . MARKING AKER Logo and Frequency A11.059 FB3k? Type and Date Code Type and Date Code F B 3 k ? Oscillation Load Frequency Date Code Production Mode Code Capacitance Tolerance Code Code Line Code Oscillation Mode Code Code Oscillation Mode F AT Cut / Fundamental T AT Cut / 3rd Overtone B BT Cut / Fundamental Frquency Tolerance Code Code Tolerance Code ±20 ppm 1 6 ±25 ppm 2 9 ±30 ppm 0 3 ±15 ppm 5 Load Capacitance Code Code CL Code P S Series Q A 16 B 20 R C 30 T D 18 U E 32 V F 12 W G 22 X H 27 Y I 10 Z J 14 a K 15 b L 25 c M 9 d N 13 Date Code Year 2017 2021 2025 2029 Month JAN A FEB B MAR C APR D MAY E JUN F JUL G AUG H SEP J OCT K NOV L DEC M CL 4 39 12.5 8 33 7 6 17 8.5 19.5 21.5 24 35 37 2018 2022 2026 2030 N P Q R S T U V W X Y Z Tolerance ±50 ppm ±10 ppm ±100 ppm 2019 2023 2027 2031 a b c d e f g h j k l m 2020 2024 2028 2032 n p q r s t u v w x y z *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Customer P/N AKER Approved P/N 49S-011059-FX4X15 APPROVED Earnest SHEET 4 OF 5 PREPARED Kiku REV. A0 3 . DIMENSIONS : ( Unit : mm ) 5.0 Max. 11.5 Max. 3.8 Max. 3.7 Max. 13.2 ± 1.0 0.45 ± 0.15 4.88 ± 0.25 4 . WAVE SOLDERING PROFILE 10 sec Max. Temperature(°C) 260°C(Max.) 150°C 120°C Time(sec) *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Customer P/N AKER Approved P/N 49S-011059-FX4X15 APPROVED Earnest SHEET 5 OF 5 PREPARED Kiku REV. A0 5 . RELIABILITY SPECIFICATION No Test Item 1 Drop Test Test Methods Performance Free drop from 50 cm height onto a hard wooden board for 3 times 2 Mechanical Shock 3 Vibration 1000 G, 0.5 msec, 3 times for each direction ( X, Y, Z ) To satisfy the electrical characteristics Frequency range : 20 ~ 2000 Hz Amplitude : 1.52 mm / 20G Sweep time : 20 minutes Test time for each direction : 2 Hours ( Total 6 Hours ) 4 Gross Leak Alcohol, Test Pressure : > -40cm-Hg 2 5 Fine Leak 5 kgf /cm Helium bombing for 2 Hours 6 Solderability Temperature : 260℃ ± 5℃ Immersion time : 5 ± 1 seconds 7 Resistance To Soldering Heat No bubbles stream ≤10-8atm.cc./sec 90% min. coverage of new solder Solder pot test Test temperature : 260℃ ± 5℃ Test time : 10 ± 1 seconds 8 High Temperature + 125 ℃ ± 3 ℃ for 500 ± 12 Hours Storage 9 Low Temperature - 55 ℃ ± 3 ℃ for 500 ± 12 Hours Storage 10 Temperature Cycle Total 100 cycles of the following temperature cycle 1 cycle 125° C ± 3° C To satisfy the electrical characteristics 25° C ± 3° C -55° C ± 3° C 15 min. 11 High Temperature 15 min. 85℃ ± 5℃, RH 85% ± 5%, 500 ± 12 Hours And Humidity *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.*
49S-011059-FX4X15 价格&库存
很抱歉,暂时无法提供与“49S-011059-FX4X15”相匹配的价格&库存,您可以联系我们找货
