C7S-16.384-12-50100-X1 数据手册
Ltr
Revisions
Date
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Electrical Specifications:
Frequency Range
6.000 to 133.000
Fundamental
6.000 to 48.000
Mode of Oscillation
Third Overtone
40.000 to 133.000
Frequency Tolerance at 25°C
±50
Frequency Stability over Temperature Range
±100
Operating Temperature Range
-40 to +125
Storage Temperature Range
-55 to +150
Aging per Year
±3
Load Capacitance
10 to 32 and Series Resonance
Shunt Capacitance
7.0
Equivalent Series Resistance (ESR)
See ESR Table
Drive Level
100
Insulation Resistance
500 at at 100 Vdc ± 15 Vdc
MHz
PPM Max
ºC
PPM Max
pF
Ohm
uW Typ
M Ohm
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
6.000 to 10.000
110
Fundamental
10.100 to 12.000
60
Fundamental
12.100 to 20.000
45
Fundamental
20.100 to 48.000
30
Fundamental
40.000 to 52.000
80
Fundamental
52.100 to 133.000
60
Third Overtone
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: April 18, 2008
Microprocessor Crystal Unit
Automotive Temperature Range
5 x 7 millimeter Surface Mount - 4 Pad
General Product Specification
Part Number:
C7S X1 Series
www.aker-usa.com
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: April 18, 2006
P/N:
www.aker-usa.com
C7S X1 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
P/N:
www.aker-usa.com
C7S X1 Series
How to build a Part Number:
Series
Package
C
7S
Parameter
5.0 x 7.0 mm
Frequency 6.000 to 133.000
MHz
Load Capacitance
10
12
16
18
S
Frequency Tolerance
Frequency Stability
50
100
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±50 PPM
±100 PPM
Mode of Oscillation
See Notes
3
Temperature Range
X1
Fundamental
Third Overtone
-40 to +125 ºC
Packaging
R
Tape and Reel
Part Number Example:
C7S-64.000-18-50100-3-X1-R
C7S- 5 x 7 mm SMD Seam Seal Package - 4 pad
64.000 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
Third Overtone Mode
X1: -40 to +125° C Automotive Temperature Range
R: Tape and Reel Packaging
Notes:
1- Fundamental mode does not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
3- Quantities less than 1000 are shipped bulk in ESD pouches.
4- Specification subject to change without notice.
Page:
4/4
P/N:
www.aker-usa.com
C7S X1 Series
C7S-16.384-12-50100-X1 价格&库存
很抱歉,暂时无法提供与“C7S-16.384-12-50100-X1”相匹配的价格&库存,您可以联系我们找货
