C20200-14
C20200-14
    ITG
    Radial,Vertical-4 Leads
    CMC 2.5MH 12.5A 2LN TH
C20200-14 数据手册
C20200 Series 1. Special Features: • • • • • • • Single wire wound. Excellent EMI suppression capability over wide frequency spectrum. High current capacity. Dielectric strength:1500Vrms. Coil mount on UL94-V0 rated plastic header. Fixed pin spacing allow easy PCB insertion. Operating temperature: -55 to +105℃. 2. Mechanical Dimension (Unit:mm): A B B 1 F 2 2 Front View Side View C20200-17 YYWW E1 3 Back View 4 Marking 4 3 Back View Bottom View C20200-01 ~ C20200-03 E2 E1 2 3 1 4 E2 E2 E1 C20200-03 YYWW 3 5.0¡ Ó 1.0 3 2 Side View Marking 1 4 2 3 E2 F 2 Front View 5.0¡ Ó 1.0 1 D D A E1 Bottom View C20200-04 ~ C20200-23 3. Electrical Specification: ITG Part Number L(mH)Min. Irate(A) @1KHz Max. DCR(Ω) Dim. A Dim. B Dim. D Dim. E1 Dim. E2 Dim. F Max. Max. Max. Max. ±0.40 ±0.40 ±0.10 C20200-01 4.00 1.70 0.173 19.30 12.50 22.86 15.24 6.35 1.00 C20200-02 C20200-03 C20200-04 C20200-05 C20200-06 C20200-07 C20200-08 C20200-09 C20200-10 C20200-11 C20200-12 C20200-13 2.50 1.00 10.00 7.00 5.00 2.00 1.00 30.00 20.00 12.00 8.00 5.00 2.40 4.80 2.40 2.80 3.70 6.60 10.00 2.30 1.00 4.00 5.60 8.90 0.090 0.022 0.170 0.120 0.070 0.022 0.010 0.330 0.210 0.110 0.055 0.022 19.30 19.30 30.48 30.48 30.48 30.48 30.48 34.29 34.29 34.29 36.83 36.83 12.50 12.50 15.50 15.50 15.50 15.50 15.50 20.60 20.60 20.60 20.60 20.60 22.86 22.86 30.48 30.48 30.48 30.48 30.48 36.83 36.83 36.83 36.83 38.10 15.24 15.24 20.32 20.32 20.32 20.32 20.32 22.86 22.86 22.86 22.86 22.86 6.35 6.35 10.16 10.16 10.16 10.16 10.16 15.24 15.24 15.24 15.24 15.24 1.00 1.00 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 Notes: Irate is defined as the applied current level that causes an approx. 35 ℃ temperature rise without force air flow. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 3. Electrical Specification: ITG Part Number L(mH)Min. Irate(A) DCR(Ω) @1KHz Max. Dim. A Dim. B Dim. D Dim. E1 Dim. E2 Dim. F Max. Max. Max. Max. ±0.40 ±0.40 ±0.10 C20200-14 2.50 12.50 0.011 36.83 20.60 38.10 22.86 15.24 1.27 C20200-15 C20200-16 C20200-17 C20200-18 C20200-19 C20200-20 C20200-21 C20200-22 C20200-23 C20200-24 1.20 50.00 36.00 7.30 4.00 2.40 1.00 0.50 0.60 3.00 16.00 2.30 2.90 9.30 14.50 17.00 20.00 14.00 25.00 13.00 0.006 0.450 0.300 0.032 0.012 0.008 0.007 0.005 0.0036 0.011 38.10 41.90 41.90 43.18 45.00 45.00 45.00 38.10 47.00 45.00 20.60 20.60 20.60 20.60 23.10 23.50 23.50 22.00 24.00 21.50 38.86 42.50 42.50 42.50 42.50 41.91 41.91 38.86 41.91 44.00 22.86 22.86 22.86 22.86 30.48 30.48 30.48 22.86 30.48 22.86 15.24 15.24 15.24 15.24 17.78 17.78 17.78 15.24 17.78 15.24 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 1.27 Notes: Irate is defined as the applied current level that causes an approx. 35 ℃ temperature rise without force air flow. 4. Impedance vs Frequency Curve of C20200 Series : C20200-01 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-02 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 0.01 0.1 1 Frequency(MHz) ● Common mode 10 Differential mode 1 100 0.1 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-03 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-04 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 Common mode 0.01 0.1 1 10 Differential mode 1 0.1 0.001 100 0.01 Frequency(MHz) C20200-05 100000 1000 1000 Impedance(Ω) 10000 100 100 10 Common mode Common mode Differential mode 1 0.01 0.1 1 Frequency(MHz) ● 10 100 10 0.1 0.001 1 C20200-06 100000 10000 Impedance(Ω) 0.1 Frequency(MHz) 10 Differential mode 1 100 0.1 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-07 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-08 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 Common mode 0.01 0.1 1 10 Differential mode 1 0.1 0.001 100 0.01 Frequency(MHz) C20200-09 100000 1000 1000 Impedance(Ω) 10000 100 100 10 Common mode Common mode Differential mode 1 0.01 0.1 1 Frequency(MHz) ● 10 100 10 0.1 0.001 1 C20200-10 100000 10000 Impedance(Ω) 0.1 Frequency(MHz) 10 Differential mode 1 100 0.1 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-11 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-12 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 Common mode 0.01 0.1 1 10 Differential mode 1 0.1 0.001 100 0.01 Frequency(MHz) C20200-13 100000 1000 1000 Impedance(Ω) 10000 100 100 10 Common mode Common mode Differential mode 1 0.01 0.1 1 Frequency(MHz) ● 10 100 10 0.1 0.001 1 C20200-14 100000 10000 Impedance(Ω) 0.1 Frequency(MHz) 10 Differential mode 1 100 0.1 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-15 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-16 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 Common mode 0.01 0.1 1 10 Differential mode 1 0.1 0.001 100 0.01 Frequency(MHz) C20200-17 100000 1000 1000 Impedance(Ω) 10000 100 100 10 Common mode Common mode Differential mode 1 0.01 0.1 1 Frequency(MHz) ● 10 100 10 0.1 0.001 1 C20200-18 100000 10000 Impedance(Ω) 0.1 Frequency(MHz) 10 Differential mode 1 100 0.1 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-19 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-20 100000 100 100 10 10 Common mode Differential mode 1 0.1 0.001 Common mode 0.01 0.1 1 10 Differential mode 1 0.1 0.001 100 0.01 Frequency(MHz) C20200-21 100000 0.1 1 10 100 Frequency(MHz) C20200-22 100000 10000 10000 1000 Impedance(Ω) Impedance(Ω) 1000 100 100 10 1 Common mode Differential mode 1 0.1 0.001 0.01 0.1 1 Frequency(MHz) ● 10 10 Common mode Differential mode 0.1 100 0.01 0.001 0.01 0.1 1 10 100 Frequency(MHz) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. C20200 Series 4. Impedance vs Frequency Curve of C20200 Series : C20200-23 100000 10000 1000 1000 Impedance(Ω) 10000 Impedance(Ω) C20200-24 100000 100 100 10 1 1 Common mode Differential mode 0.1 0.01 0.001 0.01 0.1 1 10 10 Common mode Differential mode 0.1 100 Frequency(MHz) 0.01 0.001 0.01 0.1 1 10 100 Frequency(MHz) Test setup : Common Mode ● Differential Mode ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: May 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
C20200-14 价格&库存
很抱歉,暂时无法提供与“C20200-14”相匹配的价格&库存,您可以联系我们找货
