A331-1-C2A7M
A331-1-C2A7M
    CAMOZZI
A331-1-C2A7M 数据手册
Cap 2-B-ING.qxd 25-03-2005 A 7:59 Pagina 16 S E R I E S Catalogue 2005 - 2006 2 Directly operated solenoid valves Series A SOLENOID VALVES AND PNEUMATIC VALVES 2/2 way, 3/2 way monostable, bistable (with magnetic memory) Ports M5, G1/8, cartridge ø 4 The Series A solenoid valves are of the directly operated type and can be used with dry or lubricated air. They are available in the 2/2 and 3/2-way versions with normally closed (N.C.) or normally open (N.O.) operations. They are also supplied in versions which differ with respect to the body type, the threaded ports and the orifice, as indicated in the tables for each type, in order to satisfy various operating and installation requirements. The electromagnet (or solenoid) is separate and can be easily and rapidly replaced without interfering with the pressurised part of the valve. This series of solenoid valves has different types of solenoids which can be interchanged on the same mechanical part. The choice of solenoid determines the performance of the solenoid valve (consumption and pressure). GENERAL DATA Construction Valve group Materials Ports Installation Temperature poppet-type 2/2, 3/2-way / pos. N.C. or N.O. body OT58 (nickel - plated) or technopolymer - other parts: stainless steel, NBR seals M5, G1/8, cartridge ø 4 in any position 0 ÷ 60°C (with dry air -20°C) PNEUMATIC DATA Operating pressure bar (see table) Nominal flowrate Nominal diameter Fluid Qn ( see table) ø ( see table) filtered air, without lubrication* * If lubricated air is used, it is recommended to use ISOVG3 oil. The lubrication should never be interrupted. 2.04 001 The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. Cap 2-B-ING.qxd 25-03-2005 7:59 Pagina 17 S E R I E S Catalogue 2005 - 2006 A 2 CODING OF SERIES A SOLENOID VALVES A331-0C2-U77 SOLENOID VOLTAGE BODY DESIGN 1 = base (24 x 24 mm) interface rotatable through 360° 2 = base (24 x 24 mm) fixed interface 3 = threaded body 4 = rapid exhaust body 5 = base with ISO standard interface, fixed body in technopolymer 6 = base (16 x 16 mm) interface rotatable through 360° A = single manifold B = 2 - part manifold C = 3 - part manifold D = 4 - part manifold E = 5 - part manifold F = 6 - part manifold G = 7 - part manifold H = 8 - part manifold K = 9 - part manifold L = 10 - part manifold M = 11 - part manifold N = 12 - part manifold P = 13 - part manifold R = 14 - part manifold S = 15 - part manifold B C D E F H K N° OF PORTS 2 = 2 way 3 = 3 way K1* J 1 2 3 4 6 7 FUNCTION 1 = NC (normally closed) 2 = NO (normally open) 3 = NO in line 71* 9 10 24V AC 50/60Hz 48V AC 50/60Hz 110V AC 50/60Hz 230V AC 50/60Hz 380V AC 50/60Hz 24V 50/60Hz 12V D.C. 110V AC 50/60Hz 125V AC 50/60Hz 110V AC 50/60Hz 125V AC 50/60Hz 230V AC 50/60Hz 240V AC 50/60Hz 6V DC 12V DC 24V DC 48V DC 110V DC 24V DC 48V AC 50/60 Hz 24V DC 48V AC 50/60Hz 48V DC 110V DC U70 7VA 3,5VA 3,1W 4,3VA 5,5VA 4,3VA 5,5VA 3,5VA 4VA 5,1W 5W 5W 5,3W 4,2W 3,1W 3,5VA 3,1W 3,5VA 3,1W 3,2W G70 7VA 3,5VA 3,1W 4,3VA 5,5VA 4,3VA 5,5VA 3,5VA 4VA 5,1W 5W 5W 5,3W 4,2W 3,1W 3,5VA 3,1W 3,5VA 3,1W 3,2W A80 5VA 5VA 5VA 4W 4W - H80 5,5VA 5,5VA 5,5VA 5,5VA 5,5W - *Only for valve models N.O. in line SOLENOID DIMENSIONS 7 = 22 x 22 8 = 30 x 30 9 = 22 x 58 PORTS 0 1 3 1 M5 G1/8 M5 4 M5 rotatable O-Ring interface fixed B O-Ring interface C cartridge ø 4 (only manifold) A 2 M5 G1/8 G1/8 male G1/8 male (with manual override) 3 M5 M5 M5 M5 ENCAPSULATING MATERIAL G = nylon U = PET A8 = PPS H8 = PA6 VO M5 M5 M5 BODY MATERIAL 2 = OT58/Aluminium 3 = technopolymer NOMINAL DIAMETER C = ø1,5 D = ø2 E = ø2,5 The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. G90 4/2W - SOLENOID VALVES AND PNEUMATIC VALVES SERIES 2.04 002 Cap 2-B-ING.qxd 25-03-2005 7:59 Pagina 18 S E R I E S A Catalogue 2005 - 2006 2 Functioning 2/2 SOLENOID VALVES AND PNEUMATIC VALVES For vacuum applications connect the vacuum in “2” 2.04 003 N.C. Mod. A321-1C2 A321-0C2 A321-1D2 A321-1E2 Solenoids of 3 W working pressure (bar) min max -0,9 8 -0,9 8 -0,9 4 -0,9 1 Solenoids of 4-5 W working pressure (bar) min max -0,9 15 -0,9 15 -0,9 9 -0,9 6 Solenoids of 3 W working pressure (bar) min max 2 10 2 10 Solenoids of 4-5 W working pressure (bar) min max -0,9 10 -0,9 10 N.O. Mod. A322-0C2 A322-1C2 Functioning 3/2 For vacuum applications connect the vacuum in “1” N.C. Mod. A331-1C2 A331-0C2 AA31-0C2 AA31-CC2 A331-3C2 A331-4C2 A631-AC2 A231-BC2 A131-AC2 A431-1C2 A531-BC2 Solenoids of 3 W working pressure (bar) min max 2 10 2 10 2 10 2 10 2 10 2 10 2 10 2 10 2 10 2 10 2 10 Solenoids of 4-5 W working pressure (bar) min max -0,9 10 -0,9 10 -0,9 10 -0,9 10 -0,9 10 -0,9 10 -0,9 10 -0,9 10 -0,9 10 2 10 -0,9 10 Solenoids of 3 W working pressure (bar) min max -0,9 6 -0,9 6 0 10 0 10 0 8 0 10 0 10 0 8 0 8 0 8 Solenoids of 4-5 W working pressure (bar) min max -0,9 6 -0,9 6 N.O. Mod. A332-1C2 A332-0C2 A333-0C2 A333-1C2 AA31-0C3 AA33-0C2 A333-CC2 AA33-0C3 AA31-CC3 AA31-CC3 The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. Cap 2-B-ING.qxd 25-03-2005 7:59 Pagina 19 S E R I E S Catalogue 2005 - 2006 A 2 2/2 and 3/2-way solenoid valves Mod. A32... and Mod. A33.. G1/8 M5 Mod. A321-0C2-000 A321-1C2-000 A321-1D2-000 A321-1E2-000 A322-0C2-000 A322-1C2-000 A331-0C2-000 A331-1C2-000 A332-0C2-000 A332-1C2-000 A333-0C2-000* A333-1C2-000 Thread port M5 G1/8 G1/8 G1/8 M5 G1/8 M5 G1/8 M5 G1/8 M5 G1/8 Function 2/2 N.C. 2/2 N.C. 2/2 N.C. 2/2 N.C. 2/2 N.O. 2/2 N.O. 3/2 N.C. 3/2 N.C. 3/2 N.O. 3/2 N.O. 3/2 N.O. in line 3/2 N.O in line orifice Ø mm 1.5 1.5 2 2.5 1.8 1.8 1.5 1.5 1.5 1.5 1.5 1.5 Qn Nl/min 60 60 100 100 140 96 60 66 45 50 *= For the use of N.O. valves in line, use the coil model U771 or U7K1 or G771 or G7H1. 3/2-way solenoid valve 3/2 Mod. AA31... The 3/2 - way solenoid valves for manifold assembly are available in the N.C. (normally closed) version, with 1/8" ports at the manifold inlet, and may be used with M5 threading or with a dia. 4 cartridge. These solenoid valves are provided with a manual override protected against accidental operation and may be bistable or monostable. The body is supplied complete with O-ring and screws. AA** - OC3 Mod. AA31-0C2-000* AA31-CC2-000* AA31-OC3-000* AA33-OC2-000* AA33-CC2-000* AA33-OC3-000* AA31-CC3-000* AA33-CC3-000* G1/8 AA** - OC2 Inlet/outlet Function G1/8 M5 G1/8 ø4 G1/8 M5 G1/8 M5 G1/8 ø4 G1/8 M5 G1/8 ø4 G1/8 ø4 3/2 N.C. 3/2 N.C. 3/2 N.C. 3/2 N.O. in line 3/2 N.O. in line 3/2 N.O. in line 3/2 N.C. 3/2 N.O. in line Orifice Ø mm 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 Int. Man. Bistable yes yes yes no no no yes no Qn Nl/min 62 62 62 62 62 62 62 62 SOLENOID VALVES AND PNEUMATIC VALVES The 2/2 and 3/2 - way solenoid valves, for individual assembly, are available for normally closed or normally open operation. The ports on the body may be G1/8 or M5, while the outlet which is provided is always M5. *choose solenoid required. The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. 2.04 004 Cap 2-B-ING.qxd 25-03-2005 7:59 A Pagina 20 S E R I E S Catalogue 2005 - 2006 2 SOLENOID VALVES AND PNEUMATIC VALVES 3/2 - way solenoid valve Mod. A43... The 3/2 - way NC solenoid valve, with G1/8 ports, incorporates a rapid exhaust valve. This feature allows not only the dimensions to be reduced, but also the exhaust time to be reduced. It is particularly suitable for operating small single-acting cylinders and pressurising small compressed air containers. G1/8 Mod. A431-1C2-000* Thread port G1/8 Function Orifice ø mm 1.5 N.C. Qn Nl/min 70 o*choose solenoid required 3/2 - way solenoid valve Mod. A33... The 3/2-way NC solenoid valve has been designed principally for two very important applications: the actuation of small single-acting cylinders and the operation of pneumatic valves with very low operating pressures. The body has an outlet with a G1/8 male thread which can be screwed directly onto the component to be operated. The inlet port is MS threaded. G1/8 Mod. A331-3C2-000* A331-4C2-000* Inlet/outlet Function M5 / G1/8 M5 / G1/8 N.C. N.C. Orifice ø mm 1.5 1.5 Int. Man. Bistable no yes Qn Nl/min 55 55 *choose solenoid required. 2.04 005 The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. Cap 2-B-ING.qxd 25-03-2005 7:59 Pagina 21 S E R I E S Catalogue 2005 - 2006 A 2 3/2 - way solenoid valve Mod. A63... Mod. A631-AC2-000* Interface Function OR N.C. Orifice ø mm 1.5 Qn Nl/min Orifice ø mm 1.5 Qn Nl/min 70 *choose solenoid required. 3/2 - way solenoid valve Mod. A53... The 3/2 - way N.C. solenoid valve, which has an interface fixed at 90°C relative to the axis, has been designed so as to be mounted on valves with an ISO interface. The interface is interchangeable with all ISO version. These solenoid valves are equipped with a manual override for bistable and monostable operation. Exists only with plastic body. Mod. A531-BC2-000* Interface Function OR N.C. SOLENOID VALVES AND PNEUMATIC VALVES only on request. The 3/2 - way NC solenoid valve, which has a rotating interface, is designed to be mounted directly onto machine parts by two screws. A sealing action is ensured by two concentric O-rings which allow the body to be adjusted through 360°. These solenoid valves are provided with a manual override for bistable or monostable operation. 70 *choose solenoid required. The company reserves the right to vary models and dimensions without notice. These products are designed for industrial applications and are not suitable for sale to the general public. 2.04 006
A331-1-C2A7M 价格&库存
很抱歉,暂时无法提供与“A331-1-C2A7M”相匹配的价格&库存,您可以联系我们找货
