RoHS
Compliant
SPECIFICATION FOR APPROVAL
File No.: Q/FRK 0.GS.E.C31-C11
Product Name
Metallized polypropylene film capacitor(dipped)
Product Type:
CBB21
Product Code
C31
Customer
Customer Code
Issue Date
Approved by Customer
Xiamen Faratronic Co. Ltd.
Drafted
Checked
Approved
厦门法拉电子股份有限公司
地址: 中国厦门市海沧区新园路 99 号
Add: No.99 Xinyuan Road, Haicang District, Xiamen, China
TEL:
FAX:
Mail:
Http:
Export business
0086-592-6208609 6208608
0086-592-6208557
Vivian@faratronic.com.cn
Donny@faratronic.com.cn
james@faratronic.com.cn
www.faratronic.com.cn
HK office : Faratronic (HK) Co. Ltd.
0852-2898 9168
0852-2898 9683
hkoffice@faratronic.com.hk
kolin@faratronic.com.hk
www.faratronic.com
*.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as
commercial purposes without permission.
Page 1 of 11
CBB21
Version history
Current version
Date
Author
Page 2 of 11
Change description
CBB21
■ Outline Drawing
Forming Lead Shapes
II
III
I
P ≥ F
0mm≤P-F≤3mm
IV
P < F
3mm1.0μF)
IR: 50 of the rated value
There shall be no evidence of
deterioration and the marking shall be
legible.
C/C 5(relative to the initial
value)
Increase of tg 0.002
C/C 5(relative to the initial value)
Increase of tg:
0.004 (10kHz, C1.0μF)
0.004 (1kHz, C>1.0μF)
Measuring capacitance at test point b,
d, f:
Characteristic at lower category
temperature -40˚C:
0(Cb-Cd)/Cd+3%
Characteristic at upper category
temperature +85˚C:
-3.25%(Cf-Cd)/Cd 0
Increase of tg:
0.005 (10kHz, C1.0μF)
0.005 (1kHz, C>1.0μF)
Temperature:40˚C 2˚C
2
Humidity: 93 3 %RH
Duration: 21days
Temperature: +85℃
Voltage: 1.25×UR(50Hz)
Duration: 1 000h
Static method:
The capacitors should be kept at the
following temperature in turn:
a.(+20±2) ˚C
b.(–40±2) ˚C
d.(20±2) ˚C
f.(+85±2) ˚C
g.(+20±2) ˚C
Times: 10 000
Duration of charging: 0.5s
Duration of discharging: 0.5s
Charging voltage: rated voltage
Charging resistance: 220/CR()
Discharging resistance:
R=10/CR() or 20(whichever is
the greater)
CR: rated capacitance (μF)
■ Quality ensuring test (before shipment):
Inspection item(each batch)
Appearance inspection
Dimensions
Capacitance
Tangent of the loss angle
Dielectric strength
Insulation resistance
Solderability
Inspection level (GB 2828)
IL
AQL
S-4
1.5
II
0.65
S-3
2.5
Page 9 of 11
CBB21
Marking
P≤10.0mm
P>10.0mm
■ Taping for dipped-type capacitor
▲ Outline Drawing
Fig.1
Fig 2
▲ Taping Dimensions(mm)
Dimensions (mm)
Technology
index title
Code
Taping type
Part number AmmoDigit12-15
pack
P=5.0
P=7.5
P=10.0
P=15.0
Tolerance
Fig 1
Fig 1
Fig 2
Fig 2
A21A
A31A
A41E
A61E
Taping pitch
P3
12.7
12.7
25.4
25.4
±1.0
Feed hole pitch
P0
12.7
12.7
12.7
12.7
±0.3
Center of wire
P1
3.85
2.60
7.7
5.2
±0.7
Center of body
P2
6.35
6.35
12.7
12.7
±1.3
Pitch of taping
wire
Component
alignment
Height of crankle
from tape center
Height of
component from
tape center
F**
5.0
7.5
10.0
15.0
+0.8
-0.2
△S
±2.0
H
20.0
20.0
20.0
20.0
±1.0
H0
16.0
16.0
16.0
16.0
±0.5
Carrier tape width
W
18.0
18.0
18.0
18.0
+1.0
-0.5
Hold down tape
width
W0
10min
10min
10min
10min
Hole position
W1
9.0
9.0
9.0
9.0
+0.75
-0.5
W2
3max
3max
3max
3max
D0
4.0
4.0
4.0
4.0
±0.3
t
0.7
0.7
0.7
0.7
±0.2
Hold down tape
sition
Feed hole dia.
Tape thickness
Page 10 of 11
Note: * P0=15mm is also available;
** F can be other lead spacing;
CBB21
■ Packing box sizes(mm)
1. Out packing box for bulk
2. Inner packing box for bulk
3. Box sizes for Ammo-pack
Page 11 of 11
很抱歉,暂时无法提供与“C312J105JB2C000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.94850
- 10+2.51860
- 30+2.18770
- 100+1.99740
- 600+1.90240
- 国内价格
- 1+3.76920
- 10+3.03480
- 30+2.72160
- 200+2.00880
- 400+1.84810
- 1000+1.74766
