C352T105J6SC350
C352T105J6SC350
    FARATRONIC(法拉)
    插件,P=15mm
    薄膜电容 径向
C352T105J6SC350 数据手册
 MKP25 Metallized polypropylene film capacitor (Box-type) ■ Outline Drawing W±0.4, H±0.4, T±0.4 ■ Features ● Metallized polypropylene structure. ● Excellent electric property. ● Plastic case (UL94 V-0), Epoxy resin sealing. ■ Typical Applications ● As intermediate circuit capacitors for SMPS、Electronic Ballast、inverter(i.e. DC-link, DC-filter and P.F.C) ■ Specifications Reference Standard GB/T 10190(IEC 60384-16) Climatic Category 40/105/56 Rated Temperature 85℃ Operating Temperature Range -40℃~105℃ (+85℃ to +105℃: decreasing factor 1.25% per ℃ for UR) Rated Voltage 450Vdc, 520Vdc, 630Vdc Capacitance Range 0.022μF~22μF Capacitance Tolerance 5(J), 10 (K), 20 (M) Voltage Proof 1.6UR (5s) Dissipation Factor ≤15×10 -4 (20℃, 1kHz) Insulation Resistance R ≥ 100 000M, RCN ≥ 30 000s, Maximum Pulse Rise Time(dV/dt) If the working voltage(U) is lower th an the rated voltage(UR),the capacitor c an be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is o btain by multiplying the right value wit h UR/U. P P CN≤0.33F CN0.33F (20℃,100V,1min) Max dV/dt(V/us) ——Miniature version UR(V) Max dV/dt(V/us) P=10.0 P=15.0 P=22.5 P=27.5 P=10.0 P=15.0 P=22.5 P=27.5 450 100 65 35 20 300 200 100 80 520 120 80 60 40 350 220 150 100 630 200 160 70 50 400 300 180 120  MKP25 ■ Part number system The 18 digits part number is formed as follow: 1 2 C 3 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 5 Digit 1 to 3 Series code C35=MKP25 Digit 4 to 5 D.C. rated voltage: 2S=450V Digit 6 to 8 2T=520V 2J=630V Rated capacitance value For example: 103=10×103pf=0.01uF Digit 9 Capacitance tolerance J=±5%, K=±10%, M=±20% Digit 10 Pitch 4=10.0mm 6=15.0mm 9=22.5mm B=27.5mm Digit 11 Internal use Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table1 Lead form and packaging code Digit 12 Digit 13 Digit 14 code explanation code explanation code A ammo-pack 4 6 F=10.0mm F=15.0mm 0 code explanation C S straight lead “C” in the figure above 00 45 35 32 standard lead length (18mm~26mm) lead length 4.5mm lead length 3.5mm lead length 3.2mm explanation straight Digit 15 code explanation 5 P3=25.4mm;H=18.5mm (For pitch=10/15mm) 0 Length tolerance ±0.5mm Or standard length 2 Length tolerance ±0.3mm  MKP25 ■ Dimensions (mm) ---Miniature version (Small sizes+ Segmented metallized-film design) 450Vdc CN (F) W H T P ±0.4 ±0.4 ±0.4 ±0.4 d 520Vdc Part number W H T P CN d (F) ±0.4 ±0.4 ±0.4 ±0.4 630Vdc Part number CN (F) W H T P ±0.4 ±0.4 ±0.4 ±0.4 d Part number 0.12 13.0 9.0 4.0 10 0.6 C352S124-4S****+++ 0.082 13.0 9.0 4.0 10 0.6 C352T823-4S****+++ 0.056 13.0 9.0 4.0 10 0.15 13.0 9.0 4.0 10 0.6 C352S154-4S****+++ 0.10 13.0 9.0 4.0 10 0.6 C352T104-4S****+++ 0.068 13.0 9.0 4.0 10 0.6 C352J563-4S****+++ 0.6 C352J683-4S****+++ 0.18 13.0 11.0 5.0 10 0.6 C352S184-4S****+++ 0.12 13.0 11.0 5.0 10 0.6 C352T124-4S****+++ 0.082 13.0 11.0 5.0 10 0.6 C352J823-4S****+++ 0.22 13.0 11.0 5.0 10 0.6 C352S224-4S****+++ 0.15 13.0 11.0 5.0 10 0.6 C352T154-4S****+++ 0.10 13.0 11.0 5.0 10 0.6 C352J104-4S****+++ 0.27 13.0 12.0 6.0 10 0.6 C352S274-4S****+++ 0.18 13.0 12.0 6.0 10 0.6 C352T184-4S****+++ 0.12 13.0 12.0 6.0 10 0.6 C352J124-4S****+++ 0.33 13.0 12.0 6.0 10 0.6 C352S334-4S****+++ 0.22 13.0 12.0 6.0 10 0.6 C352T224-4S****+++ 0.15 13.0 12.0 6.0 10 0.6 C352J154-4S****+++ 0.39 13.0 13.0 7.0 10 0.6 C352S394-4S****+++ 0.27 13.0 13.0 7.0 10 0.6 C352T274-4S****+++ 0.18 13.0 13.0 7.0 10 0.6 C352J184-4S****+++ 0.47 13.0 13.0 7.0 10 0.6 C352S474-4S****+++ 0.33 13.0 13.0 7.0 10 0.6 C352T334-4S****+++ 0.22 13.0 13.0 7.0 10 0.6 C352J224-4S****+++ 0.56 13.0 14.0 8.0 10 0.6 C352S564-4S****+++ 0.39 13.0 14.0 8.0 10 0.6 C352T394-4S****+++ 0.27 13.0 14.0 8.0 10 0.6 C352J274-4S****+++ 0.68 13.0 14.0 8.0 10 0.6 C352S684-4S****+++ 0.47 13.0 14.0 8.0 10 0.6 C352T474-4S****+++ 0.33 13.0 14.0 8.0 10 0.6 C352J334-4S****+++ 0.22 17.5 11.0 5.0 15 0.6 C352S224-6S****+++ 0.27 17.5 11.0 5.0 15 0.6 C352T274-6S****+++ 0.18 17.5 11.0 5.0 15 0.6 C352J184-6S****+++ 0.33 17.5 11.0 5.0 15 0.6 C352S334-6S****+++ 0.33 17.5 11.0 5.0 15 0.6 C352T334-6S****+++ 0.22 17.5 11.0 5.0 15 0.6 C352J224-6S****+++ 0.39 17.5 11.0 5.0 15 0.6 C352S394-6S****+++ 0.39 17.5 12.0 6.0 15 0.6 C352T394-6S****+++ 0.27 17.5 12.0 6.0 15 0.6 C352J274-6S****+++ 0.47 17.5 11.0 5.0 15 0.6 C352S474-6S****+++ 0.47 17.5 12.0 6.0 15 0.6 C352T474-6S****+++ 0.33 17.5 12.0 6.0 15 0.6 C352J334-6S****+++ 0.56 17.5 12.0 6.0 15 0.6 C352S564-6S****+++ 0.56 17.5 12.0 7.0 15 0.6 C352T564-6S****+++ 0.39 17.5 12.0 7.0 15 0.6 C352J394-6S****+++ 0.68 17.5 12.0 7.0 15 0.6 C352S684-6S****+++ 0.68 17.5 13.5 7.5 15 0.6 C352T684-6S****+++ 0.47 17.5 13.5 7.5 15 0.6 C352J474-6S****+++ 0.82 17.5 12.0 7.0 15 0.6 C352S824-6S****+++ 0.82 17.5 14.0 8.0 15 0.6 C352T824-6S****+++ 0.56 17.5 14.0 8.0 15 0.6 C352J564-6S****+++ 1.0 17.5 13.5 7.5 15 0.6 C352S105-6S****+++ 1.0 17.5 14.5 8.5 15 0.6 C352T105-6S****+++ 0.68 17.5 14.5 8.5 15 0.6 C352J684-6S****+++ 1.2 17.5 14.0 8.0 15 0.6 C352S125-6S****+++ 1.2 17.5 16.0 10.0 15 0.8 C352T125-6S****+++ 0.82 17.5 16.0 10.0 15 08 C352J824-6S****+++ 1.5 17.5 16.0 10.0 15 0.8 C352S155-6S****+++ 1.5 17.5 19.0 11.0 15 0.8 C352T155-6S****+++ 1.0 17.5 16.0 10.0 15 0.8 C352J105-6S****+++ 1.8 17.5 16.0 10.0 15 0.8 C352S185-6S****+++ 0.68 26.5 15.0 22.5 0.8 C352T684-9S****+++ 1.2 17.5 19.0 15 0.8 C352J125-6S****+++ 6.0 11.0 2.2 17.5 19.0 11.0 15 0.8 C352S225-6S****+++ 0.82 26.5 15.0 6.0 22.5 0.8 C352T824-9S****+++ 0.47 26.5 15.0 6.0 22.5 0.8 C352J474-9S****+++ 1.0 26.5 15.0 6.0 22.5 0.8 C352S105-9S****+++ 1.0 26.5 16.0 7.0 22.5 0.8 C352T105-9S****+++ 0.56 26.5 15.0 6.0 22.5 0.8 C352J564-9S****+++ 1.2 26.5 15.0 6.0 22.5 0.8 C352S125-9S****+++ 1.2 26.5 16.0 7.0 22.5 0.8 C352T125-9S****+++ 0.68 26.5 16.0 7.0 22.5 0.8 C352J684-9S****+++ 1.5 26.5 16.0 7.0 22.5 0.8 C352S155-9S****+++ 1.5 26.5 17.0 8.5 22.5 0.8 C352T155-9S****+++ 0.82 26.5 16.0 7.0 22.5 0.8 C352J824-9S****+++ 1.8 26.5 16.0 7.0 22.5 0.8 C352S185-9S****+++ 1.8 26.5 17.0 8.5 22.5 0.8 C352T185-9S****+++ 1.0 26.5 17.0 8.5 22.5 0.8 C352J105-9S****+++ 2.2 26.5 17.0 8.5 22.5 0.8 C352S225-9S****+++ 2.2 26.5 18.5 10.0 22.5 0.8 C352T225-9S****+++ 1.2 26.5 17.0 8.5 22.5 0.8 C352J125-9S****+++ 2.7 26.5 17.0 8.5 22.5 0.8 C352S275-9S****+++ 2.7 26.5 18.5 10.0 22.5 0.8 C352T275-9S****+++ 1.5 26.5 18.5 10.0 22.5 0.8 C352J155-9S****+++ 3.3 26.5 18.5 10.0 22.5 0.8 C352S335-9S****+++ 3.3 26.5 20.0 11.0 22.5 0.8 C352T335-9S****+++ 1.8 26.5 18.5 10.0 22.5 0.8 C352J185-9S****+++ 3.9 26.5 18.5 10.0 22.5 0.8 C352S395-9S****+++ 3.9 26.5 22.0 12.0 22.5 0.8 C352T395-9S****+++ 2.2 26.5 20.0 11.0 22.5 0.8 C352J225-9S****+++ 4.7 26.5 20.0 11.0 22.5 0.8 C352S475-9S****+++ 4.7 26.5 24.5 15.5 22.5 0.8 C352T475-9S****+++ 2.7 26.5 22.0 12.0 22.5 0.8 C352J275-9S****+++ 5.6 26.5 22.0 12.0 22.5 0.8 C352S565-9S****+++ 5.6 26.5 24.5 15.5 22.5 0.8 C352T565-9S****+++ 3.3 26.5 24.5 15.5 22.5 0.8 C352J335-9S****+++ 6.8 26.5 24.5 15.5 22.5 0.8 C352S685-9S****+++ 2.2 32.0 18.0 9.0 27.5 0.8 C352T225-BS****+++ 3.9 26.5 24.5 15.5 22.5 0.8 C352J395-9S****+++ 8.2 26.5 24.5 15.5 22.5 0.8 C352S825-9S****+++ 2.7 32.0 18.0 9.0 27.5 0.8 C352T275-BS****+++ 1.8 32.0 18.0 3.3 32.0 18.0 9.0 27.5 0.8 C352S335-BS****+++ 3.3 32.0 20.0 11.0 27.5 0.8 C352T335-BS****+++ 2.2 32.0 20.0 11.0 27.5 0.8 C352J225-BS****+++ 3.9 32.0 18.0 9.0 27.5 0.8 C352S395-BS****+++ 3.9 32.0 20.0 11.0 27.5 0.8 C352T395-BS****+++ 2.7 32.0 20.0 11.0 27.5 0.8 C352J275-BS****+++ 4.7 32.0 20.0 11.0 27.5 0.8 C352S475-BS****+++ 4.7 32.0 22.0 13.0 27.5 0.8 C352T475-BS****+++ 3.3 32.0 22.0 13.0 27.5 0.8 C352J335-BS****+++ 5.6 32.0 20.0 11.0 27.5 0.8 C352S565-BS****+++ 5.6 32.0 22.0 13.0 27.5 0.8 C352T565-BS****+++ 3.9 32.0 22.0 13.0 27.5 0.8 C352J395-BS****+++ 6.8 32.0 22.0 13.0 27.5 0.8 C352S685-BS****+++ 6.8 32.0 24.5 15.0 27.5 0.8 C352T685-BS****+++ 4.7 32.0 24.5 15.0 27.5 0.8 C352J475-BS****+++ 8.2 32.0 24.5 15.0 27.5 0.8 C352S825-BS****+++ 8.2 32.0 24.5 15.0 27.5 0.8 C352T825-BS****+++ 5.6 32.0 28.0 17.0 27.5 0.8 C352J565-BS****+++ 10.0 32.0 24.5 15.0 27.5 0.8 C352S106-BS****+++ 10.0 32.0 28.0 17.0 27.5 0.8 C352T106-BS****+++ 6.8 32.0 29.0 19.0 27.5 0.8 C352J685-BS****+++ 12.0 32.0 28.0 17.0 27.5 0.8 C352S126-BS****+++ 12.0 32.0 33.0 18.0 27.5 0.8 C352T126-BS****+++ 8.2 32.0 29.0 19.0 27.5 0.8 C352J825-BS****+++ 9.0 27.5 0.8 C352J185-BS****+++ 15.0 32.0 33.0 18.0 27.5 0.8 C352S156-BS****+++ 15.0 32.0 37.0 22.0 27.5 0.8 C352T156-BS****+++ 10.0 32.0 37.0 22.0 27.5 0.8 C352J106-BS****+++ 18.0 32.0 37.0 22.0 27.5 0.8 C352S186-BS****+++ 18.0 32.0 37.0 22.0 27.5 0.8 C352T186-BS****+++ 12.0 32.0 37.0 22.0 27.5 0.8 C352J126-BS****+++ 22.0 32.0 37.0 22.0 27.5 0.8 C352S226-BS****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% 2. “****”=lead form and packaging code (refer to table 1)  MKP25 ■ Dimensions (mm) 450Vdc W H T P CN (F) ±0.4 ±0.4 ±0.4 ±0.4 d 520Vdc Part number W H T P CN d (F) ±0.4 ±0.4 ±0.4 ±0.4 630Vdc Part number W H T P CN (F) ±0.4 ±0.4 ±0.4 ±0.4 d Part number 0.068 13.0 9.0 4.0 10.0 0.6 C352S683-40****+++ 0.047 13.0 9.0 4.0 10.0 0.6 C352T473-40****+++ 0.022 13.0 9.0 4.0 10.0 0.082 13.0 9.0 4.0 10.0 0.6 C352S823-40****+++ 0.056 13.0 9.0 4.0 10.0 0.6 C352T563-40****+++ 0.027 13.0 9.0 4.0 10.0 0.6 C352J223-40****+++ 0.6 C352J273-40****+++ 0.10 13.0 11.0 5.0 10.0 0.6 C352S104-40****+++ 0.068 13.0 9.0 4.0 10.0 0.6 C352T683-40****+++ 0.033 13.0 9.0 4.0 10.0 0.6 C352J333-40****+++ 0.12 13.0 11.0 5.0 10.0 0.6 C352S124-40****+++ 0.082 13.0 11.0 5.0 10.0 0.6 C352T823-40****+++ 0.039 13.0 9.0 4.0 10.0 0.6 C352J393-40****+++ 0.15 13.0 12.0 6.0 10.0 0.6 C352S154-40****+++ 0.1 13.0 11.0 5.0 10.0 0.6 C352T104-40****+++ 0.047 13.0 11.0 5.0 10.0 0.6 C352J473-40****+++ 0.18 13.0 12.0 6.0 10.0 0.6 C352S184-40****+++ 0.12 13.0 12.0 6.0 10.0 0.6 C352T124-40****+++ 0.056 13.0 11.0 5.0 10.0 0.6 C352J563-40****+++ 0.22 13.0 13.0 7.0 10.0 0.6 C352S224-40****+++ 0.15 13.0 12.0 6.0 10.0 0.6 C352T154-40****+++ 0.068 13.0 11.0 5.0 10.0 0.6 C352J683-40****+++ 0.27 13.0 13.0 7.0 10.0 0.6 C352S274-40****+++ 0.18 13.0 13.0 7.0 10.0 0.6 C352T184-40****+++ 0.082 13.0 12.0 6.0 10.0 0.6 C352J823-40****+++ 0.33 13.0 14.0 8.0 10.0 0.6 C352S334-40****+++ 0.22 13.0 13.0 7.0 10.0 0.6 C352T224-40****+++ 0.10 13.0 12.0 6.0 10.0 0.6 C352J104-40****+++ 0.10 17.5 9.5 5.0 15.0 0.6 C352S104-6A****+++ 0.27 13.0 14.0 8.0 10.0 0.6 C352T274-40****+++ 0.12 13.0 13.0 7.0 10.0 0.6 C352J124-40****+++ 0.12 17.5 11.0 5.0 15.0 0.6 C352S124-6A****+++ 0.033 17.5 11.0 5.0 15.0 0.6 C352T333-6A****+++ 0.15 13.0 13.0 7.0 10.0 0.6 C352J154-40****+++ 0.15 17.5 11.0 5.0 15.0 0.6 C352S154-6A****+++ 0.039 17.5 11.0 5.0 15.0 0.6 C352T393-6A****+++ 0.18 13.0 14.0 8.0 10.0 0.6 C352J184-40****+++ 0.18 17.5 11.0 5.0 15.0 0.6 C352S184-6A****+++ 0.047 17.5 11.0 5.0 15.0 0.6 C352T473-6A****+++ 0.068 17.5 11.0 5.0 15.0 0.6 C352J683-6A****+++ 0.22 17.5 11.0 5.0 15.0 0.6 C352S224-6A****+++ 0.056 17.5 11.0 5.0 15.0 0.6 C352T563-6A****+++ 0.082 17.5 11.0 5.0 15.0 0.6 C352J823-6A****+++ 0.27 17.5 12.0 6.0 15.0 0.6 C352S274-6A****+++ 0.068 17.5 11.0 5.0 15.0 0.6 C352T683-6A****+++ 0.10 17.5 11.0 5.0 15.0 0.6 C352J104-6A****+++ 0.33 17.5 12.0 6.0 15.0 0.6 C352S334-6A****+++ 0.082 17.5 11.0 5.0 15.0 0.6 C352T823-6A****+++ 0.12 17.5 11.0 5.0 15.0 0.6 C352J124-6A****+++ 0.39 17.5 13.5 7.5 15.0 0.6 C352S394-6A****+++ 0.1 17.5 11.0 5.0 15.0 0.6 C352T104-6A****+++ 0.15 17.5 12.0 6.0 15.0 0.6 C352J154-6A****+++ 0.47 17.5 13.5 7.5 15.0 0.6 C352S474-6A****+++ 0.12 17.5 11.0 5.0 15.0 0.6 C352T124-6A****+++ 0.18 17.5 12.0 6.0 15.0 0.6 C352J184-6A****+++ 0.56 17.5 13.5 7.5 15.0 0.6 C352S564-6A****+++ 0.15 17.5 11.0 5.0 15.0 0.6 C352T154-6A****+++ 0.22 17.5 13.5 7.5 15.0 0.6 C352J224-6A****+++ 0.68 17.5 16.0 10.0 15.0 0.8 C352S684-60****+++ 0.18 17.5 11.0 5.0 15.0 0.6 C352T184-6A****+++ 0.27 17.5 13.5 7.5 15.0 0.6 C352J274-6A****+++ 0.82 17.5 16.0 10.0 15.0 0.8 C352S824-60****+++ 0.22 17.5 12.0 6.0 15.0 0.6 C352T224-6A****+++ 0.33 17.5 14.5 8.5 15.0 0.8 C352J334-60****+++ 1.0 17.5 19.0 11.0 15.0 0.8 C352S105-60****+++ 0.27 17.5 12.0 6.0 15.0 0.6 C352T274-6A****+++ 0.39 17.5 16.0 10.0 15.0 0.8 C352J394-60****+++ 0.27 26.5 15.0 6.0 22.5 0.6 C352S274-9A****+++ 0.33 17.5 13.5 7.5 15.0 0.6 C352T334-6A****+++ 0.47 17.5 16.0 10.0 15.0 0.8 C352J474-60****+++ 0.33 26.5 15.0 6.0 22.5 0.6 C352S334-9A****+++ 0.39 17.5 13.5 7.5 15.0 0.6 C352T394-6A****+++ 0.56 17.5 19.0 11.0 15.0 0.8 C352J564-60****+++ 0.39 26.5 15.0 6.0 22.5 0.6 C352S394-9A****+++ 0.47 17.5 14.5 8.5 15.0 0.8 C352T474-60****+++ 0.68 17.5 19.0 11.0 15.0 0.8 C352J684-60****+++ 0.47 26.5 15.0 6.0 22.5 0.6 C352S474-9A****+++ 0.56 17.5 16.0 10.0 15.0 0.8 C352T564-60****+++ 0.15 26.5 15.0 6.0 22.5 0.6 C352J154-9A****+++ 0.56 26.5 16.0 7.0 22.5 0.6 C352S564-9A****+++ 0.68 17.5 16.0 10.0 15.0 0.8 C352T684-60****+++ 0.18 26.5 15.0 6.0 22.5 0.6 C352J184-9A****+++ 0.68 26.5 16.0 7.0 22.5 0.6 C352S684-9A****+++ 0.82 17.5 19.0 11.0 15.0 0.8 C352T824-60****+++ 0.22 26.5 15.0 6.0 22.5 0.6 C352J224-9A****+++ 0.82 26.5 16.0 7.0 22.5 0.6 C352S824-9A****+++ 1.0 17.5 19.0 11.0 15.0 0.8 C352T105-60****+++ 0.27 26.5 15.0 6.0 22.5 0.6 C352J274-9A****+++ 1.0 26.5 17.0 8.5 22.5 0.8 C352S105-90****+++ 0.18 26.5 15.0 6.0 22.5 0.6 C352T184-9A****+++ 0.33 26.5 15.0 6.0 22.5 0.6 C352J334-9A****+++ 1.2 26.5 18.5 10.0 22.5 0.8 C352S125-90****+++ 0.22 26.5 15.0 6.0 22.5 0.6 C352T224-9A****+++ 0.39 26.5 16.0 7.0 22.5 0.6 C352J394-9A****+++ 1.5 26.5 18.5 10.0 22.5 0.8 C352S155-90****+++ 0.27 26.5 15.0 6.0 22.5 0.6 C352T274-9A****+++ 0.47 26.5 16.0 7.0 22.5 0.6 C352J474-9A****+++ 1.8 26.5 22.0 12.0 22.5 0.8 C352S185-90****+++ 0.33 26.5 15.0 6.0 22.5 0.6 C352T334-9A****+++ 0.56 26.5 17.0 8.5 22.5 0.8 C352J564-90****+++ 0.68 32.0 18.0 9.0 27.5 0.8 C352S684-B0****+++ 0.39 26.5 15.0 6.0 22.5 0.6 C352T394-9A****+++ 0.68 26.5 17.0 8.5 22.5 0.8 C352J684-90****+++ 0.82 32.0 18.0 9.0 27.5 0.8 C352S824-B0****+++ 0.47 26.5 15.0 6.0 22.5 0.6 C352T474-9A****+++ 0.82 26.5 18.5 10.0 22.5 0.8 C352J824-90****+++ 1.0 32.0 18.0 9.0 27.5 0.8 C352S105-B0****+++ 0.56 26.5 16.0 7.0 22.5 0.6 C352T564-9A****+++ 1.0 26.5 18.5 10.0 22.5 0.8 C352J105-90****+++ 1.2 32.0 18.0 9.0 27.5 0.8 C352S125-B0****+++ 0.68 26.5 16.0 7.0 22.5 0.6 C352T684-9A****+++ 1.2 26.5 22.0 12.0 22.5 0.8 C352J125-90****+++ 1.5 32.0 18.0 9.0 27.5 0.8 C352S155-B0****+++ 0.82 26.5 17.0 8.5 22.5 0.8 C352T824-90****+++ 0.27 32.0 18.0 9.0 27.5 0.8 C352J274-B0****+++ 1.8 32.0 20.0 11.0 27.5 0.8 C352S185-B0****+++ 1.0 26.5 18.5 10.0 22.5 0.8 C352T105-90****+++ 0.33 32.0 18.0 9.0 27.5 0.8 C352J334-B0****+++ 2.2 32.0 20.0 11.0 27.5 0.8 C352S225-B0****+++ 1.2 26.5 18.5 10.0 22.5 0.8 C352T125-90****+++ 0.39 32.0 18.0 9.0 27.5 0.8 C352J394-B0****+++ 2.7 32.0 22.0 13.0 27.5 0.8 C352S275-B0****+++ 1.5 26.5 22.0 12.0 22.5 0.8 C352T155-90****+++ 0.47 32.0 18.0 9.0 27.5 0.8 C352J474-B0****+++ 3.3 32.0 22.0 13.0 27.5 0.8 C352S335-B0****+++ 1.8 26.5 22.0 12.0 22.5 0.8 C352T185-90****+++ 0.56 32.0 18.0 9.0 27.5 0.8 C352J564-B0****+++ 3.9 32.0 24.5 15.0 27.5 0.8 C352S395-B0****+++ 0.27 32.0 18.0 9.0 27.5 0.8 C352T274-B0****+++ 0.68 32.0 18.0 9.0 27.5 0.8 C352J684-B0****+++ 4.7 32.0 33.0 18.0 27.5 0.8 C352S475-B0****+++ 0.33 32.0 18.0 9.0 27.5 0.8 C352T334-B0****+++ 0.82 32.0 18.0 9.0 27.5 0.8 C352J824-B0****+++ 5.6 32.0 33.0 18.0 27.5 0.8 C352S565-B0****+++ 0.39 32.0 18.0 9.0 27.5 0.8 C352T394-B0****+++ 1.0 32.0 20.0 11.0 27.5 0.8 C352J105-B0****+++ 6.8 32.0 33.0 18.0 27.5 0.8 C352S685-B0****+++ 0.47 32.0 18.0 9.0 27.5 0.8 C352T474-B0****+++ 1.2 32.0 20.0 11.0 27.5 0.8 C352J125-B0****+++ 8.2 32.0 33.0 18.0 27.5 0.8 C352S825-B0****+++ 0.56 32.0 18.0 9.0 27.5 0.8 C352T564-B0****+++ 1.5 32.0 22.0 13.0 27.5 0.8 C352J155-B0****+++ 0.68 32.0 18.0 9.0 27.5 0.8 C352T684-B0****+++ 1.8 32.0 22.0 13.0 27.5 0.8 C352J185-B0****+++ 0.82 32.0 18.0 9.0 27.5 0.8 C352T824-B0****+++ 2.2 32.0 24.5 15.0 27.5 0.8 C352J225-B0****+++ 1.0 32.0 18.0 9.0 27.5 0.8 C352T105-B0****+++ 2.7 32.0 28.0 14.0 27.5 0.8 C352J275-B0****+++ 1.2 32.0 18.0 9.0 27.5 0.8 C352T125-B0****+++ 3.3 32.0 33.0 18.0 27.5 0.8 C352J335-B0****+++ 1.5 32.0 20.0 11.0 27.5 0.8 C352T155-B0****+++ 3.9 32.0 33.0 18.0 27.5 0.8 C352J395-B0****+++ 1.8 32.0 20.0 11.0 27.5 0.8 C352T185-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% 2. “****”=lead form and packaging code (refer to table 1) 2.2 32.0 22.0 13.0 27.5 0.8 C352T225-B0****+++ 2.7 32.0 24.5 15.0 27.5 0.8 C352T275-B0****+++ 3.3 32.0 28.0 14.0 27.5 0.8 C352T335-B0****+++ 3.9 32.0 28.0 14.0 27.5 0.8 C352T395-B0****+++ 4.7 32.0 33.0 18.0 27.5 0.8 C352T475-B0****+++ 5.6 32.0 33.0 18.0 27.5 0.8 C352T565-B0****+++ 6.8 32.0 33.0 18.0 27.5 0.8 C352T685-B0****+++  MKP25 ■ Max. Current (Ir.m.s.) versus Frequency – Miniature version NOTE: 1.sinusoidal wave-form, environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm. 2. The series product is only recommended to use in DC-filter or DC-blocking circuits. It means the voltage applied to the capacitors must be unidirectional ripple voltage. The typical voltage curve is as follows reference. If you have any questions for this note, please feel free to contact with our technical engineer. Here: V1≥0, V2≤UR, Irms=2 π f×C×(V2 -V1)/ 2 UR is the rated voltage of the capacitor  MKP25 ■ Max. Current (Ir.m.s.) versus Frequency NOTE: 1.sinusoidal wave-form, environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm. 2. The series product is only recommended to use in DC-filter or DC-blocking circuits. It means the voltage applied to the capacitors must be unidirectional ripple voltage. The typical voltage curve is as follows reference. If you have any questions for this note, please feel free to contact with our technical engineer. Here: V1≥0, V2≤UR, Irms  2πfC(V2  V1 )/ 2 UR is the rated voltage of the capacitor  MKP25 ■ Test Method And Performance No. Item 1 Solderability Initial measurement Performance Good quality of tinning Test method(IEC 60384-16) Solder temperature: 245˚C 5˚C Immersion time: 2.0s0.5s Capacitance Tg: 1kHz,C1.0F 10kHz,C1.0F Tension: 10N(0.6φd0.8) 20N(φd=1.0) Bend: 5N(0.6φd0.8) 10N(φd=1.0) The terminals shall be bent 2 times in each direction. Solder temperature:260˚C5˚C Immersion time: 10s1s There shall be no visible damage Terminal strength 2 Resistance to solder heat Final measurement Initial measurement Rapid change of temperature Vibration There shall be no visible damage C/C 3(relative to the initial value) Increase of tg: 0.004 (10kHz,C1.0μF) 0.004 (1kHz, C>1.0μF) Capacitance Tg: 1kHz,C1.0F 10kHz,C1.0F There shall be no evidence of deterioration. There shall be deterioration. no evidence of 3 Bump Final measurement Initial measurement 4 Climate sequence Dry heat Damp heat, Cyclic Cold Low air pressure Damp heat, Cyclic other Final measurement There shall be no evidence of deterioration. C/C 3(relative to the initial value) Increase of tg: 0.004 (10kHz,C1.0μF) 0.004 (1kHz, C>1.0μF) IR:  50 of the rated value Capacitance Tg: 1kHz,C1.0F 10kHz,C1.0F A=-40˚C, B =+105˚C 5 cycles Duration: t=30min Amplitude 0.75mm or acceleration 98m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz.Three directions, 2h for each direction, total 6h. 4 000 times, Acceleration: 390m/s2,Pulse duration, 6ms +105℃, 16h Test Db, Severity: b, the first cycle There shall be no permanent breakdown, flashover or other harmful deformation when applying UR at the last 1 minute. Applying UR for 1 minute after 15 minutes the test finished. There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: 0.005 (C1.0μF,10kHz) 0.005(C>1.0μF,1kHz) I.R.:  50 of the rated value -40℃, 2h 15℃~35℃, 8.5kPa, 1h Test Db, Severity b, the other cycles,  MKP25 No. Item 5 Damp heat steady state 6 Endurance 7 Charging and discharging Performance Test method(IEC 60384-16) There shall be no visible damage, Temperature:40˚C 2˚C legible marking 2 Humidity: 93  3 %RH C/C 5(relative to the initial Duration: 56 days value) Increase of tg:0.002 (1kHz) I.R.:  50 of the rated value There shall be no visible damage, Temperature: +85℃ legible marking Voltage: 1.25×UR C/C 5(relative to the initial Duration: 1 000h value) Increase of tg: 0.004 (10kHz,C1.0μF) 0.004 (1kHz, C>1.0μF) I.R.:  50 of the rated value C/C 5(relative to the initial Times: 10 000 Duration of charging: 0.5s value) Duration of discharging: 0.5s ncrease of tg: Charging voltage: rated voltage UR 0.005 (C1.0μF,10kHz) Charging resistance: 220/CN() 0.005(C>1.0μF,1kHz) Discharging resistance: I.R.:  50 of the rated value UR÷CN÷dv/dt() CN: rated capacitance (μF) dv/dt value: see P2 ■ Quality ensuring test (before shipment): Inspection item(each batch) Inspection level (GB 2828) IL AQL II 1.5 II 0.65 S-3 2.5 Appearance inspection Dimensions Capacitance Tangent of the loss angle Dielectric strength Insulation resistance Solderability ■ Marking  ■ MKP25 Taping specification for box-type capacitors ▲ Outline Drawing Fig.1 P=5.0、7.5mm Fig.2 P=10.0、15.0mm ▲ Taping Dimensions(mm) Technology index Code title Taping type — Part number AmmoDigit12-15 pack Taping pitch P3 Feed hole pitch P0 ▲ Packing Quantity Dimensions P=5.0 P=7.5 P=10.0 P=15.0 Tolerance Fig 1 Fig 1 Fig2 Fig 2 A201 A301 A405 A605 12.7 12.7 12.7 12.7 25.4 12.7 25.4 12.7 ±1.0 ±0.3 —— Center of wire P1 3.85 2.6 7.7 5.2 ±0.7 Center of body Pitch of taping wire Component alignment Height of component from tape center P2 6.35 6.35 12.7 12.7 F** 5.0 7.5 10.0 15.0 ±1.3 +0.6 -0.1 △S 0 0 0 0 ±2.0 H*** 18.5 18.5 18.5 18.5 ±0.5 W 18.0 18.0 18.0 18.0 +1.0 -0.5 W0 6min 10min 10min 10min —— W1 9.0 9.0 9.0 9.0 ±0.5 W2 3max 3max 3max 3max —— D0 t 4.0 0.7 4.0 0.7 4.0 0.7 4.0 0.7 ±0.2 ±0.2 Carrier tape width Hold down tape width Hole position Hold down tape sition Feed hole dia. Tape thickness ■ Packing box sizes(mm) 1. Out packing box for bulk 3. Box sizes for Ammo-pack Pitch (mm) 5.0 7.5 10.0/ 15.0 15.0 Box thickness T(mm) 2.5 3.5 4.5 5.0 6.0 3.5 4.0 5.0 6.0 4.0 5.0 6.0 7.5 8.5 10.0 11.0 Ammo-pack (pcs/box) Domestic Export 2500 1 700 1 400 1 200 1 000 2 000 1 500 1 300 1 000 800 1 700 1 500 1 200 1 000 750 600 500 400 350 300 250 1 500 1 350 1 050 850 650 500 450 350 300 250 220 Note: * P0=15mm is also available; **F can be other lead spacing; ***H=16.5mm is available; 2. Inner packing box for bulk
C352T105J6SC350 价格&库存
很抱歉,暂时无法提供与“C352T105J6SC350”相匹配的价格&库存,您可以联系我们找货
