C312E474J6SC000
C312E474J6SC000
    FARATRONIC(法拉)
    插件,P=15mm
    薄膜电容 径向
C312E474J6SC000 数据手册
RoHS Compliant SPECIFICATION FOR APPROVAL File No.: Q/FRK 0.GS.E.C31-C11 Product Name Metallized polypropylene film capacitor(dipped) Product Type: CBB21 Product Code C31 Customer Customer Code Issue Date Approved by Customer Xiamen Faratronic Co. Ltd. Drafted Checked Approved 厦门法拉电子股份有限公司 Xiamen Faratronic Co. Ltd. 地址: 中国厦门市海沧区新园路 99 号 Add: No.99 Xinyuan Road, Haicang District, Xiamen, China TEL: FAX: Mail: Http: Export business 0086-592-6208609 6208608 0086-592-6208557 Vivian@faratronic.com.cn Donny@faratronic.com.cn james@faratronic.com.cn www.faratronic.com.cn HK office : Faratronic (HK) Co. Ltd. 0852-2898 9168 0852-2898 9683 hkoffice@faratronic.com.hk kolin@faratronic.com.hk www.faratronic.com *.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as commercial purposes without permission. Page 1 of 11  CBB21 Version history Current version Date Author Page 2 of 11 Change description  CBB21 Metallized polypropylene film capacitor(dipped) ■ Outline Drawing Forming Lead Shapes II III I P ≥ F 0mm≤P-F≤3mm IV P < F 3mm1.0μF) IR:  50 of the rated value There shall be no evidence of deterioration and the marking shall be legible. C/C  5(relative to the initial value) Increase of tg 0.002 IR: 50 of the rated value C/C 5(relative to the initial value) Increase of tg: 0.004 (10kHz, C1.0μF) 0.004 (1kHz, C>1.0μF) IR:  50 of the rated value Measuring capacitance at test point b, d, f: Characteristic at lower category temperature -40˚C: 0(Cb-Cd)/Cd+3% Characteristic at upper category temperature +85˚C: -3.25%(Cf-Cd)/Cd 0 C/C 5(relative to the initial value) Increase of tg: 0.005 (10kHz, C1.0μF) 0.005 (1kHz, C>1.0μF) IR:  50 of the rated value Temperature:40˚C 2˚C 2 Humidity: 93  3 %RH Duration: 21days Temperature: +85℃ Voltage: 1.25×UR(50Hz) Duration: 1 000h Static method: The capacitors should be kept at the following temperature in turn: a.(+20±2) ˚C b.(–40±2) ˚C d.(20±2) ˚C f.(+85±2) ˚C g.(+20±2) ˚C Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s Charging voltage: rated voltage Charging resistance: 220/CR() Discharging resistance: R=10/CR() or 20(whichever is the greater) CR: rated capacitance (μF) ■ Quality ensuring test (before shipment): Inspection item(each batch) Appearance inspection Dimensions Capacitance Tangent of the loss angle Dielectric strength Insulation resistance Solderability Inspection level (GB 2828) IL AQL S-4 1.5 II 0.65 S-3 2.5 Page 9 of 11  CBB21 ■ Marking P≤10.0mm P>10.0mm ■ Taping for dipped-type capacitor ▲ Outline Drawing Fig.1 Fig 2 ▲ Taping Dimensions(mm) Dimensions (mm) Technology index title Code Taping type — Part number AmmoDigit12-15 pack P=5.0 P=7.5 P=10.0 P=15.0 Tolerance Fig 1 Fig 1 Fig 2 Fig 2 —— A21A A31A A41E A61E Taping pitch P3 12.7 12.7 25.4 25.4 ±1.0 Feed hole pitch P0 12.7 12.7 12.7 12.7 ±0.3 Center of wire P1 3.85 2.60 7.7 5.2 ±0.7 Center of body P2 6.35 6.35 12.7 12.7 ±1.3 Pitch of taping wire Component alignment Height of crankle from tape center Height of component from tape center F** 5.0 7.5 10.0 15.0 +0.8 -0.2 △S 0 0 0 0 ±2.0 H 20.0 20.0 20.0 20.0 ±1.0 H0 16.0 16.0 16.0 16.0 ±0.5 Carrier tape width W 18.0 18.0 18.0 18.0 +1.0 -0.5 Hold down tape width W0 10min 10min 10min 10min —— Hole position W1 9.0 9.0 9.0 9.0 +0.75 -0.5 W2 3max 3max 3max 3max —— D0 4.0 4.0 4.0 4.0 ±0.3 t 0.7 0.7 0.7 0.7 ±0.2 Hold down tape sition Feed hole dia. Tape thickness Page 10 of 11 Note: * P0=15mm is also available; ** F can be other lead spacing;  CBB21 ■ Packing box sizes(mm) 1. Out packing box for bulk 2. Inner packing box for bulk 3. Box sizes for Ammo-pack Page 11 of 11
C312E474J6SC000 价格&库存
很抱歉,暂时无法提供与“C312E474J6SC000”相匹配的价格&库存,您可以联系我们找货
