C242J222J20C000
C242J222J20C000
    FARATRONIC(法拉)
    插件,P=5mm
    2.2NF ±5% 630V
C242J222J20C000 数据手册
 C24 CL23B Series Box-type metallized polyester film capacitor (Stacked version) ■ Outline Drawing ■ ● ● ● Features Metallized polyester film, stacked construction Plastic case(UL94 V-0) ,Epoxy resin sealing High dv/dt ability ■ ● ● ● Typical Applications: By-passing, blocking, coupling, decoupling, Pulse logic, timing, compact fluorescent lamps. Inverter for LCD monitors, automotive DC motor suppression ■ Specifications Reference Standard GB 7332(IEC 60384-2) Climatic Category 55/125/56 Rated temperature Rated Voltage 85℃ -55℃~125℃ (+85℃ to +125℃: decreasing factor 1.25% per ℃ for UR ) 50/63V, 100V, 250V, 400V, 500V, 630V,700V Capacitance Range 0.0010μF ~ 2.2μF Capacitance Tolerance ±5%(J), ±10%(K), ±20%(M) Voltage Proof 1.4UR(5s) Operating temperature Dissipation Factor Frequency 1kHz 10kHz 100kHz UR>100V Insulation Resistance UR≤100V UR (V) Maximum Pulse Rise Time(dV/dt) If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U. 50/63 100 250 400 500 630 700 Page 3 of 15 CN ≤ 0.1μF CN > 0.1μF ≤1.0% ≤1.0% ≤1.5% ≤1.5% ≤3.0% ≥3 0000MΩ, CN≤0.33μF (20℃,100V,1min) ≥10 000s, CN>0.33μF ≥15 000MΩ, CN≤0.33μF ≥5 000s, 0.33μF1μF dV/dt (V/μs) pattern I pattern II 250 75 300 85 400 100 600 150 700 200 800 250  C24 CL23B Series ■ Part number system The 18 digits part number is formed as follow: C24 Pattern I (High performance) 1 2 3 C 2 4 4 5 6 7 8 9 10 11 2 12 13 14 15 16 17 18 0 C24 Pattern II (Reduced size) 1 2 3 C 2 4 Digit 1 to 3 4 5 6 7 8 9 10 11 2 12 13 14 15 16 17 18 S Series code C24=CL23B Digit 4 to 5 DC rated voltage 1H=50V 1J=63V 2A=100V 2E=250V 2G=400V 2H=500V 2J=630V 1V=700V Digit 6 to 8 Rated capacitance value For example : 103=10×103pF=0.01uF Digit 9 Capacitance tolerance J=±5%,K=±10%, M=±20% Digit 10 Lead pitch 2=5.0 Digit 11 Internal use S=pattern II Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table 1 lead dimensions and packaging code Digit 12 Digit 13 Digit 14 Digit 15 code explanation code explanation code explanation code A ammo-pack 2 F=5.0mm 0 straight 1 each cap. among two consecutive holes P3=12.7mm,H=18.5mm (For pitch=5.0mm) C straight lead “C”in the figure above code explanation 0 Length tolerance ±0.5mm Or standard length 00 standard lead length (18mm~22mm) 45 lead length 4.5mm Page 4 of 15 explanation  C24 CL23B Series ■ Dimensions(mm) Capacitor Thickness: T Dimension Tolerance (W, H, T) ≤3.5 >3.5 ±0.2 ±0.4 Pattern II (Reduced size) 50Vdc (30Vac)/63Vdc (40Vac) # 100 Vdc (63Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.15 7.2 6.5 2.5 5.0 0.5 C241J154-2S****+++ 0.10 7.2 6.5 2.5 5.0 0.5 C242A104-2S****+++ 0.18 7.2 6.5 2.5 5.0 0.5 C241J184-2S****+++ 0.12 7.2 6.5 2.5 5.0 0.5 C242A124-2S****+++ 0.22 7.2 6.5 2.5 5.0 0.5 C241J224-2S****+++ 0.15 7.2 7.5 3.5 5.0 0.5 C242A154-2S****+++ 0.27 7.2 6.5 2.5 5.0 0.5 C241J274-2S****+++ 0.18 7.2 7.5 3.5 5.0 0.5 C242A184-2S****+++ 0.33 7.2 7.5 3.5 5.0 0.5 C241J334-2S****+++ 0.22 7.2 7.5 3.5 5.0 0.5 C242A224-2S****+++ 0.39 7.2 7.5 3.5 5.0 0.5 C241J394-2S****+++ 0.27 7.2 9.5 4.5 5.0 0.6 C242A274-2S****+++ 0.47 7.2 7.5 3.5 5.0 0.5 C241J474-2S****+++ 0.33 7.2 9.5 4.5 5.0 0.6 C242A334-2S****+++ 0.56 7.2 9.5 4.5 5.0 0.6 C241J564-2S****+++ 0.39 7.2 9.5 4.5 5.0 0.6 C242A394-2S****+++ 0.68 7.2 9.5 4.5 5.0 0.6 C241J684-2S****+++ 0.47 7.2 10.0 5.0 5.0 0.6 C242A474-2S****+++ 0.82 7.2 9.5 4.5 5.0 0.6 C241J824-2S****+++ 0.56 7.2 10.0 5.0 5.0 0.6 C242A564-2S****+++ 1.0 7.2 10.0 5.0 5.0 0.6 C241J105-2S****+++ 0.68 7.2 11.0 6.0 5.0 0.6 C242A684-2S****+++ 1.5 7.2 11.0 6.0 5.0 0.6 C241J155-2S****+++ 0.82 7.2 11.0 6.0 5.0 0.6 C242A824-2S****+++ 2.2 7.2 11.0 6.0 5.0 0.6 C241J225-2S****+++ 1.0 7.2 11.0 6.0 5.0 0.6 C242A105-2S****+++ 250 Vdc (140Vac) 400 Vdc (160Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.022 7.2 6.5 2.5 5.0 0.5 C242E223-2S****+++ 0.0056 7.2 6.5 2.5 5.0 0.5 C242G562-2S****+++ 0.027 7.2 6.5 2.5 5.0 0.5 C242E273-2S****+++ 0.0068 7.2 6.5 2.5 5.0 0.5 C242G682-2S****+++ 0.033 7.2 6.5 2.5 5.0 0.5 C242E333-2S****+++ 0.0082 7.2 6.5 2.5 5.0 0.5 C242G822-2S****+++ 0.039 7.2 7.5 3.5 5.0 0.5 C242E393-2S****+++ 0.010 7.2 6.5 2.5 5.0 0.5 C242G103-2S****+++ 0.047 7.2 7.5 3.5 5.0 0.5 C242E473-2S****+++ 0.012 7.2 6.5 2.5 5.0 0.5 C242G123-2S****+++ 0.056 7.2 7.5 3.5 5.0 0.5 C242E563-2S****+++ 0.015 7.2 7.5 3.5 5.0 0.5 C242G153-2S****+++ 0.068 7.2 7.5 3.5 5.0 0.5 C242E683-2S****+++ 0.018 7.2 7.5 3.5 5.0 0.5 C242G183-2S****+++ 0.082 7.2 9.5 4.5 5.0 0.6 C242E823-2S****+++ 0.022 7.2 7.5 3.5 5.0 0.5 C242G223-2S****+++ 0.10 7.2 9.5 4.5 5.0 0.6 C242E104-2S****+++ 0.027 7.2 7.5 3.5 5.0 0.5 C242G273-2S****+++ 0.12 7.2 9.5 4.5 5.0 0.6 C242E124-2S****+++ 0.033 7.2 9.5 4.5 5.0 0.6 C242G333-2S****+++ 0.15 7.2 10.0 5.0 5.0 0.6 C242E154-2S****+++ 0.039 7.2 9.5 4.5 5.0 0.6 C242G393-2S****+++ 0.18 7.2 11.0 6.0 5.0 0.6 C242E184-2S****+++ 0.047 7.2 9.5 4.5 5.0 0.6 C242G473-2S****+++ 0.22 7.2 11.0 6.0 5.0 0.6 C242E224-2S****+++ 0.051 7.2 10.0 5.0 5.0 0.6 C242G513-2S****+++ 0.056 7.2 11.0 6.0 5.0 0.6 C242G563-2S****+++ 0.068 7.2 11.0 6.0 5.0 0.6 C242G683-2S****+++ 0.082 7.2 11.0 6.0 5.0 0.6 C242G823-2S****+++ 0.10 7.2 11.0 6.0 5.0 0.6 C242G104-2S****+++ Note: 1. 2. 3. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% “****”=lead form and packing code (refer to table 1). “#” when the rated voltage is 50Vdc,the digit 4~5 is 1H. Page 5 of 15  C24 CL23B Series Pattern II (Reduced size) 500 Vdc/630(220Vac)# 700 Vdc (250Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.0018 7.2 6.5 2.5 5.0 0.5 C242J182-2S****+++ 0.0010 7.2 6.5 2.5 5.0 0.5 C241V102-2S****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C242J222-2S****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C241V122-2S****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C242J272-2S****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C241V152-2S****+++ 0.0033 7.2 6.5 2.5 5.0 0.5 C242J332-2S****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C241V182-2S****+++ 0.0039 7.2 6.5 2.5 5.0 0.5 C242J392-2S****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C241V222-2S****+++ 0.0047 7.2 6.5 2.5 5.0 0.5 C242J472-2S****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C241V272-2S****+++ 0.0056 7.2 7.5 3.5 5.0 0.5 C242J562-2S****+++ 0.0033 7.2 7.5 3.5 5.0 0.5 C241V332-2S****+++ 0.0068 7.2 7.5 3.5 5.0 0.5 C242J682-2S****+++ 0.0039 7.2 7.5 3.5 5.0 0.5 C241V392-2S****+++ 0.0082 7.2 7.5 3.5 5.0 0.5 C242J822-2S****+++ 0.0047 7.2 7.5 3.5 5.0 0.5 C241V472-2S****+++ 0.010 7.2 7.5 3.5 5.0 0.5 C242J103-2S****+++ 0.0056 7.2 7.5 3.5 5.0 0.5 C241V562-2S****+++ 0.012 7.2 9.5 4.5 5.0 0.6 C242J123-2S****+++ 0.0068 7.2 7.5 3.5 5.0 0.5 C241V682-2S****+++ 0.015 7.2 9.5 4.5 5.0 0.6 C242J153-2S****+++ 0.0082 7.2 9.5 4.5 5.0 0.6 C241V822-2S****+++ 0.018 7.2 9.5 4.5 5.0 0.6 C242J183-2S****+++ 0.010 7.2 9.5 4.5 5.0 0.6 C241V103-2S****+++ 0.022 7.2 10.0 5.0 5.0 0.6 C242J223-2S****+++ 0.012 7.2 9.5 4.5 5.0 0.6 C241V123-2S****+++ 0.027 7.2 11.0 6.0 5.0 0.6 C242J273-2S****+++ 0.015 7.2 10.0 5.0 5.0 0.6 C241V153-2S****+++ 0.033 7.2 11.0 6.0 5.0 0.6 C242J333-2S****+++ 0.018 7.2 11.0 6.0 5.0 0.6 C241V183-2S****+++ 0.022 7.2 11.0 6.0 5.0 0.6 C241V223-2S****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% 2. “****”=lead dimensions and packing mode code (refer to table 1). 3. “#” when the rated voltage is 500Vdc,the digit 4~5 is 2H. Page 6 of 15  C24 CL23B Series Pattern I (High performance) 50Vdc (30Vac)/63Vdc (40Vac) # 100 Vdc (63Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.0010 7.2 6.5 2.5 5.0 0.5 C241J102-20****+++ 0.0010 7.2 6.5 2.5 5.0 0.5 C242A102-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C241J122-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C242A122-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C241J152-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C242A152-20****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C241J182-20****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C242A182-20****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C241J222-20****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C242A222-20****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C241J272-20****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C242A272-20****+++ 0.0033 7.2 6.5 2.5 5.0 0.5 C241J332-20****+++ 0.0033 7.2 6.5 2.5 5.0 0.5 C242A332-20****+++ 0.0039 7.2 6.5 2.5 5.0 0.5 C241J392-20****+++ 0.0039 7.2 6.5 2.5 5.0 0.5 C242A392-20****+++ 0.0047 7.2 6.5 2.5 5.0 0.5 C241J472-20****+++ 0.0047 7.2 6.5 2.5 5.0 0.5 C242A472-20****+++ 0.0056 7.2 6.5 2.5 5.0 0.5 C241J562-20****+++ 0.0056 7.2 6.5 2.5 5.0 0.5 C242A562-20****+++ 0.0068 7.2 6.5 2.5 5.0 0.5 C241J682-20****+++ 0.0068 7.2 6.5 2.5 5.0 0.5 C242A682-20****+++ 0.0082 7.2 6.5 2.5 5.0 0.5 C241J822-20****+++ 0.0082 7.2 6.5 2.5 5.0 0.5 C242A822-20****+++ 0.010 7.2 6.5 2.5 5.0 0.5 C241J103-20****+++ 0.010 7.2 6.5 2.5 5.0 0.5 C242A103-20****+++ 0.012 7.2 6.5 2.5 5.0 0.5 C241J123-20****+++ 0.012 7.2 6.5 2.5 5.0 0.5 C242A123-20****+++ 0.015 7.2 6.5 2.5 5.0 0.5 C241J153-20****+++ 0.015 7.2 6.5 2.5 5.0 0.5 C242A153-20****+++ 0.018 7.2 6.5 2.5 5.0 0.5 C241J183-20****+++ 0.018 7.2 6.5 2.5 5.0 0.5 C242A183-20****+++ 0.022 7.2 6.5 2.5 5.0 0.5 C241J223-20****+++ 0.022 7.2 6.5 2.5 5.0 0.5 C242A223-20****+++ 0.027 7.2 6.5 2.5 5.0 0.5 C241J273-20****+++ 0.027 7.2 6.5 2.5 5.0 0.5 C242A273-20****+++ 0.033 7.2 6.5 2.5 5.0 0.5 C241J333-20****+++ 0.033 7.2 6.5 2.5 5.0 0.5 C242A333-20****+++ 0.039 7.2 6.5 2.5 5.0 0.5 C241J393-20****+++ 0.039 7.2 6.5 2.5 5.0 0.5 C242A393-20****+++ 0.047 7.2 6.5 2.5 5.0 0.5 C241J473-20****+++ 0.047 7.2 6.5 2.5 5.0 0.5 C242A473-20****+++ 0.056 7.2 6.5 2.5 5.0 0.5 C241J563-20****+++ 0.056 7.2 6.5 2.5 5.0 0.5 C242A563-20****+++ 0.068 7.2 6.5 2.5 5.0 0.5 C241J683-20****+++ 0.068 7.2 6.5 2.5 5.0 0.5 C242A683-20****+++ 0.082 7.2 6.5 2.5 5.0 0.5 C241J823-20****+++ 0.082 7.2 6.5 2.5 5.0 0.5 C242A823-20****+++ 0.10 7.2 6.5 2.5 5.0 0.5 C241J104-20****+++ 0.10 7.2 7.5 3.5 5.0 0.5 C242A104-20****+++ 0.12 7.2 6.5 2.5 5.0 0.5 C241J124-20****+++ 0.12 7.2 9.5 4.5 5.0 0.6 C242A124-20****+++ 0.15 7.2 7.5 3.5 5.0 0.5 C241J154-20****+++ 0.15 7.2 9.5 4.5 5.0 0.6 C242A154-20****+++ 0.18 7.2 7.5 3.5 5.0 0.5 C241J184-20****+++ 0.18 7.2 9.5 4.5 5.0 0.6 C242A184-20****+++ 0.22 7.2 7.5 3.5 5.0 0.5 C241J224-20****+++ 0.22 7.2 10.0 5.0 5.0 0.6 C242A224-20****+++ 0.27 7.2 9.5 4.5 5.0 0.6 C241J274-20****+++ 0.27 7.2 10.0 5.0 5.0 0.6 C242A274-20****+++ 0.33 7.2 9.5 4.5 5.0 0.6 C241J334-20****+++ 0.33 7.2 11.0 6.0 5.0 0.6 C242A334-20****+++ 0.39 7.2 9.5 4.5 5.0 0.6 C241J394-20****+++ 0.39 7.2 11.0 6.0 5.0 0.6 C242A394-20****+++ 0.47 7.2 10.0 5.0 5.0 0.6 C241J474-20****+++ 0.47 7.2 11.0 6.0 5.0 0.6 C242A474-20****+++ 0.56 7.2 10.0 5.0 5.0 0.6 C241J564-20****+++ 0.56 7.2 11.0 6.0 5.0 0.6 C242A564-20****+++ 0.68 7.2 11.0 6.0 5.0 0.6 C241J684-20****+++ 0.82 7.2 11.0 6.0 5.0 0.6 C241J824-20****+++ 1.0 7.2 11.0 6.0 5.0 0.6 C241J105-20****+++ Note: 1. 2. 3. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% “****”=lead form and packing code (refer to table 1). “#” when the rated voltage is 50Vdc,the digit 4~5 is 1H. Page 7 of 15  C24 CL23B Series Pattern I (High performance) 250 Vdc (160Vac) 400 Vdc (200Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.0010 7.2 6.5 2.5 5.0 0.5 C242E102-20****+++ 0.0010 7.2 6.5 2.5 5.0 0.5 C242G102-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C242E122-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C242G122-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C242E152-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C242G152-20****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C242E182-20****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C242G182-20****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C242E222-20****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C242G222-20****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C242E272-20****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C242G272-20****+++ 0.0033 7.2 6.5 2.5 5.0 0.5 C242E332-20****+++ 0.0033 7.2 6.5 2.5 5.0 0.5 C242G332-20****+++ 0.0039 7.2 6.5 2.5 5.0 0.5 C242E392-20****+++ 0.0039 7.2 6.5 2.5 5.0 0.5 C242G392-20****+++ 0.0047 7.2 6.5 2.5 5.0 0.5 C242E472-20****+++ 0.0047 7.2 6.5 2.5 5.0 0.5 C242G472-20****+++ 0.0056 7.2 6.5 2.5 5.0 0.5 C242E562-20****+++ 0.0056 7.2 7.5 3.5 5.0 0.5 C242G562-20****+++ 0.0068 7.2 6.5 2.5 5.0 0.5 C242E682-20****+++ 0.0068 7.2 7.5 3.5 5.0 0.5 C242G682-20****+++ 0.0082 7.2 6.5 2.5 5.0 0.5 C242E822-20****+++ 0.0082 7.2 7.5 3.5 5.0 0.5 C242G822-20****+++ 0.010 7.2 6.5 2.5 5.0 0.5 C242E103-20****+++ 0.010 7.2 7.5 3.5 5.0 0.5 C242G103-20****+++ 0.012 7.2 6.5 2.5 5.0 0.5 C242E123-20****+++ 0.012 7.2 9.5 4.5 5.0 0.6 C242G123-20****+++ 0.015 7.2 6.5 2.5 5.0 0.5 C242E153-20****+++ 0.015 7.2 9.5 4.5 5.0 0.6 C242G153-20****+++ 0.018 7.2 6.5 2.5 5.0 0.5 C242E183-20****+++ 0.018 7.2 9.5 4.5 5.0 0.6 C242G183-20****+++ 0.022 7.2 7.5 3.5 5.0 0.5 C242E223-20****+++ 0.022 7.2 10.0 5.0 5.0 0.6 C242G223-20****+++ 0.027 7.2 7.5 3.5 5.0 0.5 C242E273-20****+++ 0.027 7.2 11.0 6.0 5.0 0.6 C242G273-20****+++ 0.033 7.2 7.5 3.5 5.0 0.5 C242E333-20****+++ 0.033 7.2 11.0 6.0 5.0 0.6 C242G333-20****+++ 0.039 7.2 7.5 3.5 5.0 0.5 C242E393-20****+++ 0.039 7.2 11.0 6.0 5.0 0.6 C242G393-20****+++ 0.047 7.2 9.5 4.5 5.0 0.6 C242E473-20****+++ 0.047 7.2 11.0 6.0 5.0 0.6 C242G473-20****+++ 0.056 7.2 9.5 4.5 5.0 0.6 C242E563-20****+++ 0.068 7.2 9.5 4.5 5.0 0.6 C242E683-20****+++ 0.082 7.2 10.0 5.0 5.0 0.6 C242E823-20****+++ 0.10 7.2 10.0 5.0 5.0 0.6 C242E104-20****+++ 0.12 7.2 11.0 6.0 5.0 0.6 C242E124-20****+++ 0.15 7.2 11.0 6.0 5.0 0.6 C242E154-20****+++ Note: 1. 2. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% “****”=lead form and packing code (refer to table 1). Page 8 of 15  C24 CL23B Series Pattern I (High performance) 500 Vdc (220Vac) 630 Vdc (220Vac) CN (F) W H T P d Part number CN (F) W H T P d Part number 0.0010 7.2 6.5 2.5 5.0 0.5 C242H102-20****+++ 0.0010 7.2 6.5 2.5 5.0 0.5 C242J102-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C242H122-20****+++ 0.0012 7.2 6.5 2.5 5.0 0.5 C242J122-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C242H152-20****+++ 0.0015 7.2 6.5 2.5 5.0 0.5 C242J152-20****+++ 0.0018 7.2 6.5 2.5 5.0 0.5 C242H182-20****+++ 0.0018 7.2 7.5 3.5 5.0 0.5 C242J182-20****+++ 0.0022 7.2 6.5 2.5 5.0 0.5 C242H222-20****+++ 0.0022 7.2 7.5 3.5 5.0 0.5 C242J222-20****+++ 0.0027 7.2 6.5 2.5 5.0 0.5 C242H272-20****+++ 0.0027 7.2 7.5 3.5 5.0 0.5 C242J272-20****+++ 0.0033 7.2 7.5 3.5 5.0 0.5 C242H332-20****+++ 0.0033 7.2 7.5 3.5 5.0 0.5 C242J332-20****+++ 0.0039 7.2 7.5 3.5 5.0 0.5 C242H392-20****+++ 0.0039 7.2 7.5 3.5 5.0 0.5 C242J392-20****+++ 0.0047 7.2 7.5 3.5 5.0 0.5 C242H472-20****+++ 0.0047 7.2 9.5 4.5 5.0 0.6 C242J472-20****+++ 0.0056 7.2 7.5 3.5 5.0 0.5 C242H562-20****+++ 0.0056 7.2 9.5 4.5 5.0 0.6 C242J562-20****+++ 0.0068 7.2 9.5 4.5 5.0 0.6 C242H682-20****+++ 0.0068 7.2 9.5 4.5 5.0 0.6 C242J682-20****+++ 0.0082 7.2 9.5 4.5 5.0 0.6 C242H822-20****+++ 0.0082 7.2 9.5 4.5 5.0 0.6 C242J822-20****+++ 0.010 7.2 9.5 4.5 5.0 0.6 C242H103-20****+++ 0.010 7.2 10.0 5.0 5.0 0.6 C242J103-20****+++ 0.012 7.2 9.5 4.5 5.0 0.6 C242H123-20****+++ 0.012 7.2 11.0 6.0 5.0 0.6 C242J123-20****+++ 0.015 7.2 10.0 5.0 5.0 0.6 C242H153-20****+++ 0.015 7.2 11.0 6.0 5.0 0.6 C242J153-20****+++ 0.018 7.2 11.0 6.0 5.0 0.6 C242H183-20****+++ 0.018 7.2 11.0 6.0 5.0 0.6 C242J183-20****+++ 0.022 7.2 11.0 6.0 5.0 0.6 C242H223-20****+++ 0.027 7.2 11.0 6.0 5.0 0.6 C242H273-20****+++ Note: 1. 2. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5% “****”=lead form and packing code (refer to table 1). Page 9 of 15  C24 CL23B Series ■ MAX. VOLTAGE(Vr.m.s) VERSUS FREQUENCY Pattern II (Reduced sized) Note: sinusoidal wave-form、environment temperature≤85℃,internal temperature rise △T=15℃, p (pitch) in mm.. Page 10 of 15  C24 CL23B Series ■ MAX. VOLTAGE(Vr.m.s) VERSUS FREQUENCY Pattern I (High performance) Note: sinusoidal wave-form、environment temperature≤85℃,internal temperature rise △T=15℃, p (pitch) in mm.. Page 11 of 15  C24 CL23B Series ■ Test Method And Performance Item Performance J(5), K(10), M(20) 2 Capacitance tolerance Tangent of the loss angle Test method GB/T 7332 (IEC60384-2) 1kHz, 3UR(Vrms)max. 3 Dielectric strength tan0.010(1kHz) tan0.015(10kHz) tan0.030(100kHz, C100V ≥3 0000MΩ, CN≤0.33μF ≥10 000s , CN>0.33μF, Good quality of tinning UR100V, Charging voltage 10V UR100V, Charging voltage 100V 20˚C, measuring after applying voltage for 1 minute No. 1 Insulation resistance 4 5 Solderability Initial measurement Capacitance, Tan(10kHz) There shall be no visible damage Terminal strength 6 Resistance to solder heat Final measurement 7 Component’s resistance o f solvents Initial measurement Rapid change of tempera ture There shall be no visible damage C/C 2(relative to the initial value) Increase of tan:0.003(10kHz) The dimensions shall reach the requirement of Table 1, and the change of capacitor weight shall not beyond 1%. A=-55˚C, B =+125˚C 5 cycles, Duration: t=30min There shall be no evidence of deterioration. Amplitude 0.75mm or acceleration 98m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz.Three directions, 2h foreach direction, total 6h. 4 000 times, Acceleration: 390m/s2,Pulse duration, 6ms There shall be no evidence of deterioration. Bump 9 Initial Solvent: Industrial isopropanol. Solvent temperature:23˚C±5˚C Immersion time:5min±0.5min Reverting time:48h There shall be no evidence of deterioration. 8 climate sequence Tension Ua1: Pull: d=0.5mm,5N; d=0.6mm,10N Bend Ub: The pull of bend: d=0.5mm, 2.5N d=0.6mm, 5N The terminals shall be bent 2 times in each direction. Solder temperature:260˚C5˚C Immersion time: 10s1s Capacitance, Tan(10kHz) Vibration Final measurement Solder temperature:245˚C5˚C Immersion time: 2.0s0.5s C/C 5(relative to the initial value) Increase of tan: 0.003 (10kHz) IR:  50 of the rated value Capacitance, Tan(10kHz) measurement Dry heat +125℃,16h Page 12 of 15  C24 CL23B Series No. Item Performance Damp heat, Cyclic Cold Low air pressure 9 10 11 12 13 climate sequence (continue) Damp heat, cyclic other Final measu rement Damp heat steady state Endurance Temperature characteristic Charging and discharging Test method GB/T 7332 (IEC60384-2) Test Db, Severity: b, the first cycle -55℃, 2h There shall be no permanent break down, flashover or other harmful deformation when applying UR at the last 1 minute. 15℃~35℃,8.5kPa, 1h, Test Db, Severity b, the other cycles, Applying UR for 1 minute after the test finished. There shall be no evidence of deterioration and the marking shall be legible. C/C 5(relative to the initial value) Increase of tan: 0.005(10kHz) IR: 50 of the rated value There shall be no evidence of deterioration and the marking shall be legible. C/C  5(relative to the initial value) Increase of tan 0.005(10kHz) IR: 50 of the rated value There shall be no evidence of deterioration and the marking shall be legible. C/C  5(relative to the initial value) Increase of tan: 0.003 (10kHz) IR: 50 of the rated value Measuring capacitance at test point b, d, f: Characteristic at lower category temperature -55˚C: -10%(Cb-Cd)/Cd0% Characteristic at upper category temperature +125˚C: 0%(Cf-Cd)/Cd +18% I.R. (test at point f ): UR100V: 15MΩ (C0.33μF) 5s (C>0.33μF) UR>100V: 30MΩ (C0.33μF) 10s (C>0.33μF) C/C 5(relative to the initial value) Increase of tan: 0.003 (10kHz, C1.0μF) 0.002 (1kHz, C>1.0μF) IR:  50 of the rated value Page 13 of 15 Temperature:40˚C 2˚C 2 Humidity: 93  3 %RH Duration: 56 days Temperature: +85℃ Voltage: 1.25 UR Duration: 2 000h or Temperature: +125℃ Voltage: 1.25×Uc (Uc=0.5UR) Duration: 2 000h Static method:The Capacitors should be kept at the following temperature in turn: a(20±2) ˚C, b(–55±3) ˚C, d(20±2) ˚C,f(+125±2) ˚C, g(20±2) ˚C Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s Charging voltage: rated voltage Charging resistance: 220/CN() Discharging resistance: R=10/CN() or 20(whichever is the greater) CN: rated capacitance (μF)  C24 CL23B Series ■ Quality ensuring test (before shipment): Inspection level (GB/T 2828.1) Inspection item(each batch) IL AQL S-4 1.5 II 0.65 S-3 2.5 Appearance inspection Dimensions Capacitance Tangent of the loss angle Dielectric strength Insulation resistance Solderability ■ Marking ■ Taping specification for box-type capacitor ▲Outline Drawing Fig 1 Page 14 of 15  C24 CL23B Series ▲ Taping Dimensions(mm) ▲ Packing Quantity Dimensions Technology index title Code P=5.0 Taping type Part number Digit12-15 Taping pitch — Ammopack P3 Fig 1 Tolerance Box thinkness T(mm) Domestic Export 5.0 2.5 3.5 4.5 5.0 6.0 2 500 1 700 1 400 1 200 1 000 2 000 1 500 1 300 1 000 800 —— A201 12.7 ±1.0 Feed hole pitch P0 12.7 ±0.3 Center of wire P1 3.85 ±0.7 Center of body P2 6.35 ±1.3 Pitch of taping wire F 5.0 +0.6 -0.1 Component alignment △S 0 ±2.0 Height of component from tape center H 18.5 ±0.5 Carrier tape width W 18.0 +1.0 -0.5 Hold down tape width W0 6min —— Hole position W1 9.0 ±0.5 Hold down tape sition W2 3max —— Feed hole dia. D0 4.0 ±0.2 Tape thickness t 0.7 ±0.2 ■ Packing box sizes(mm) 1. Out packing box for bulk 2. Inner packing box for bulk 3. Box sizes for Ammo-pack Page 15 of 15 Ammo-pack (pcs/box) Pitch (mm)
C242J222J20C000 价格&库存
很抱歉,暂时无法提供与“C242J222J20C000”相匹配的价格&库存,您可以联系我们找货
