气候类别 / 阻燃等级
Climatic Category/Passive Flammability Category
40/110/56/B
工作温度范围 Operating Temperature Range
-40℃  ̄ +110℃
额定电压 Rated Voltage (UR)
305Vac/275Vac, 50/60Hz
最大额定电源电压 Max rated supply mains voltage
250Vac, 50/60Hz
电容量范围 Capacitance Range
0.033μF  ̄ 0.47μF
电容量偏差 Capacitance Tolerance
±10%(K), ±20%(M)
耐电压 Voltage Proof
绝缘电阻 Insulation Resistance
损耗角正切 Dissipation Factor (tanδ)
注 :1. 如果需要用到承载一定纹波电流场合,建议选用 C6A 等专
用的滤波电容器;如有疑问,请与我司技术工程师联系;
2. 若用于户外或长期湿度较大场合,建议选用防潮设计。
引线之间 Between Terminals:
4.3UR(dc),2s
极壳之间 Between Terminals To Case:
2 120Vac, 1min
R ≥ 15 000MΩ, CN ≤ 0.33μF
RCN ≥ 5 000s, CN > 0.33μF (20℃ ,100V, 1min)
0.033μF ≤ CN < 0.47μF
≤ 10 x 10-4(1kHz,20℃ )
≤ 20 x 10-4(10kHz,20℃ )
CN = 0.47μF
≤ 20 x 10-4(1kHz,20℃ )
≤ 40 x 10-4(10kHz,20℃ )
If used in application which has ripple current applied, recommend to use AC filter series: C6A etc;
If have any questions please contact our technical engineer for more detail;
For outdoor or severe humidity condition application, recommend to use THB series.
147
很抱歉,暂时无法提供与“C42P2473K4SC330”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55404
- 50+0.43643
- 150+0.37768
- 500+0.32454
- 2500+0.28923
- 5000+0.27162
