C43Q1104K9SC000
C43Q1104K9SC000
    FARATRONIC(法拉)
    CAP-26.5X8.5MM_TM
    特性:能够承受过电压应力。具备出色的主动和被动阻燃能力。应用:广泛应用于跨线、旁路、天线耦合干扰抑制电路等
C43Q1104K9SC000 数据手册
RoHS Compliant SPECIFICATION FOR APPROVAL File No.: Q/FRK 0.GS.E.C43-C15 Product Name Metallized Polypropylene Film Interference Suppression Capacitor (Class Y2,300Vac) Product Type MKP63 Product Code C43 Customer Customer Code Issue Date Approved by Customer Xiamen Faratronic Co. Ltd. Drafted Checked Approved 厦门法拉电子股份有限公司 Xiamen Faratronic Co. Ltd. 地址: 中国厦门市海沧区新园路 99 号 Add: No.99 Xinyuan Road, Haicang District, Xiamen, China TEL: FAX: Mail: Http: Export business 0086-592-6208609 6208608 0086-592-6208557 Vivian@faratronic.com.cn Donny@faratronic.com.cn james@faratronic.com.cn www.faratronic.com.cn HK office : Faratronic (HK) Co. Ltd. 0852-2898 9168 0852-2898 9683 hkoffice@faratronic.com.hk kolin@faratronic.com.hk www.faratronic.com *.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as commercial purposes without permission. Page 1 of 10  MKP63 Version history Current version Date Author Change description Page 2 of 10  MKP63 Metallized polypropylene film interference suppression capacitor(Class Y2, 300Vac) ■Outline Drawing W±0.4, H±0.4, T±0.4 W±0.4, H±0.4, T±0.4 Arc-bottom Square-bottom ■ Features ● Withstanding overvoltage stressing ● Excellent active and passive flame resistant abilities ● Widely used in across-the-line, line-by-pass, antenna Coupling interference suppression circuit, etc. ■ Safety Approvals ● CQC ● ENEC-SEMKO ● UL/CUL ● KC IEC 60384-14:2005, Y2, 300Vac, 0.001F~1.0F , 40/110/56/B Certificate No.: CQC04001009958 EN 60384-14:2013, Y2, 300Vac, 0.001F~1.0F, 40/110/56/B Certificate No.: SE/0366-2C UL60384-14:2014, CSA E60384-14:09, Y2, 300Vac, 0.001F1.0F, 40/110/56/B File No.: E186600, CN: FOWX2/8 K60384-14(2006-12) , Y2, 300Vac, 0.001F~0.10F, 40/110/56/B Certificate No.: SU03060-12005 ■ Specifications Class Climatic Category / Passive Flammability Category Operating Temperature Range Class Y2 Rated Voltage (UR) 300Vac, 50/60Hz Maximum continuous DC voltage Capacitance Range 1 500Vdc Capacitance Tolerance 10(K), 20(M) Voltage Proof Insulation Resistance Dissipation Factor 40/110/56/B -40℃ ~ +110℃ 0.0010F~1.0F Between Terminals: 2 000Vac(2s) or 4 000Vdc(2s) CN≤0.33F 3 700Vdc(2s) CN0.33F Between Termianls To Case: 2 500Vac(1min) R≥15 000M , CN≤0.33F (20℃, 100V ,1min) RCN≥5 000s, CN0.33F ≤3010-4(1kHz,20℃) ≤4010-4(10kHz,20℃) Page 3 of 10  MKP63 ■ Part number system The 18 digits part number is formed as follow: 1 2 3 C 4 3 4 5 Digit 1 to 3 6 7 8 9 10 11 1 2 1 3 14 1 5 1 6 1 7 1 8 Series code C43=MKP63 Digit 4 to 5 A.C. rated voltage Q1=300V Digit 6 to 8 Rated capacitance value For example : 103=10×103 pF= 0.01μF Digit 9 Capacitance tolerance K=±10%, M=±20% Digit 10 Pitch 3=7.5mm 4=10mm 6=15mm 9=22.5mm B=27.5mm F=37.5mm Digit 11 Internal use Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table 1 Lead form and packaging code Digit 12 code A explanation ammo-pack C straight lead “C” in the figure above D Insulated stranded leads E M Insulated solid leads Digit 13 code 3 4 6 mounting foot F=7.5mm F=10.0mm F=15.0mm explanation code 0 Straight 1 5 explanation 00 45 35 32 standard lead length (18mm~26mm) lead length 4.5mm lead length 3.5mm lead length 3.2mm 35mm 100mm 120mm 200mm Digit 15 code code C5 K0 K2 Insulated leads L0 and box with explanation Digit 14 0 2 explanation each cap. among two consecutive holes P3=12.7mm,H=18.5mm (For P=7.5mm) P3=25.4mm;H=18.5mm (For pitch=10/15mm) (Detail parameter refer to page 11) Length tolerance ±0.5mm or standard length Length tolerance ±0.3mm Note 1:This length includes the stripping parts. 1 Length tolerance -5 mm~0 mm 2 Length tolerance 0 mm~+5 mm Note 2:Normally, for P ≥ 27.5 Caps can choice Insulated leads. 3 Length tolerance 0 mm~+10mm 4 Length tolerance ±5 mm Page 4 of 10  MKP63 ■ Dimensions(mm) 300Vac 300Vac CN W H T P d Part number (F) ±0.4 ±0.4 ±0.4 ±0.4 0.0010 10.5 9.0 4.0 7.5 0.6 C43Q1102-30****+++ 0.0012 10.5 9.0 4.0 7.5 0.6 C43Q1122-30****+++ 0.0015 10.5 9.0 4.0 7.5 0.6 C43Q1152-30****+++ 0.0018 10.5 9.0 4.0 7.5 0.6 C43Q1182-30****+++ 0.0022 10.5 9.0 4.0 7.5 0.6 C43Q1222-30****+++ 0.0027 10.5 9.0 4.0 7.5 0.6 C43Q1272-30****+++ 0.0033 10.5 11.0 5.0 7.5 0.6 C43Q1332-30****+++ 0.0039 10.5 11.0 5.0 7.5 0.6 C43Q1392-30****+++ 0.0047 10.5 12.0 6.0 7.5 0.6 C43Q1472-30****+++ 0.0056 10.5 12.0 6.0 7.5 0.6 C43Q1562-30****+++ 0.0010 13.0 9.0 4.0 10.0 0.6 C43Q1102-40****+++ 0.0012 13.0 9.0 4.0 10.0 0.6 C43Q1122-40****+++ 0.0015 13.0 9.0 4.0 10.0 0.6 C43Q1152-40****+++ 0.0018 13.0 9.0 4.0 10.0 0.6 C43Q1182-40****+++ 0.0022 13.0 9.0 4.0 10.0 0.6 C43Q1222-40****+++ 0.0027 13.0 9.0 4.0 10.0 0.6 C43Q1272-40****+++ 0.0033 13.0 9.0 4.0 10.0 0.6 C43Q1332-40****+++ 0.0039 13.0 9.0 4.0 10.0 0.6 C43Q1392-40****+++ 0.0047 13.0 11.0 5.0 10.0 0.6 C43Q1472-40****+++ 0.0056 13.0 11.0 5.0 10.0 0.6 C43Q1562-41****+++ 0.0068 13.0 11.0 5.0 10.0 0.6 C43Q1682-41****+++ 0.0068 13.0 7.5 9.5 10.0 0.6 C43Q1682-4C****+++ 0.0082 13.0 12.0 6.0 10.0 0.6 C43Q1822-40****+++ 0.010 13.0 12.0 6.0 10.0 0.6 C43Q1103-40****+++ 0.015 13.0 12.0 6.0 10.0 0.6 C43Q1153-4S****+++ 0.0022 17.5 9.5 5.0 15.0 0.6 C43Q1222-60****+++ 0.0027 17.5 9.5 5.0 15.0 0.6 C43Q1272-61****+++ 0.0033 17.5 9.5 5.0 15.0 0.6 C43Q1332-61****+++ 0.0039 17.5 9.5 5.0 15.0 0.6 C43Q1392-61****+++ 0.0047 17.5 9.5 5.0 15.0 0.6 C43Q1472-61****+++ 0.0056 17.5 9.5 5.0 15.0 0.6 C43Q1562-61****+++ 0.0068 17.5 9.5 5.0 15.0 0.6 C43Q1682-61****+++ 0.0082 17.5 9.5 5.0 15.0 0.6 C43Q1822-61****+++ 0.010 17.5 9.5 5.0 15.0 0.6 C43Q1103-6S****+++ 0.012 17.5 11.0 5.0 15.0 0.6 C43Q1123-6S****+++ 0.015 17.5 11.0 5.0 15.0 0.6 C43Q1153-6S****+++ 0.018M 17.5 11.0 5.0 15.0 0.6 C43Q1183M6S****+++ 0.018K 17.5 12.0 6.0 15.0 0.6 C43Q1183K6S****+++ 0.022 17.5 12.0 6.0 15.0 0.6 C43Q1223-6S****+++ 0.027M 17.5 12.0 6.0 15.0 0.6 C43Q1273M6S****+++ 0.027K 17.5 12.0 7.0 15.0 0.6 C43Q1273K6S****+++ 0.033 17.5 13.5 7.5 15.0 0.6 C43Q1333-6S****+++ 0.033 17.5 12.5 9.0 15.0 0.6 C43Q1333-6A****+++ 0.039 17.5 13.5 7.5 15.0 0.6 C43Q1393-6S****+++ 0.039 17.5 12.5 9.0 15.0 0.6 C43Q1393-6A****+++ 0.047 17.5 14.5 8.5 15.0 0.6 C43Q1473-6S****+++ 0.047 17.5 12.0 13.0 15.0 0.8 C43Q1473-6C****+++ 0.056 17.5 16.0 10.0 15.0 0.8 C43Q1563-6S****+++ 0.068 17.5 16.0 10.0 15.0 0.8 C43Q1683-6S****+++ 0.082 17.5 19.0 11.0 15.0 0.8 C43Q1823-6S****+++ 0.033 26.5 15.0 6.0 22.5 0.8 C43Q1333-90****+++ 0.039 26.5 15.0 6.0 22.5 0.8 C43Q1393-90****+++ 0.047 26.5 15.0 6.0 22.5 0.8 C43Q1473-9S****+++ 0.056 26.5 15.0 6.0 22.5 0.8 C43Q1563-9S****+++ 0.068M 26.5 15.0 6.0 22.5 0.8 C43Q1683M9S****+++ 0.068K 26.5 16.0 7.0 22.5 0.8 C43Q1683K9S****+++ 0.082 26.5 16.0 7.0 22.5 0.8 C43Q1823-9S****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10% 2. “****”=lead form and packaging mode code (refer to table 1) 3. “★” = Arc bottom of the outer shell. CN (F) 0.10 0.12 0.15 0.18 0.22 0.27 0.33 0.33 0.39M 0.10 0.12 0.15 0.15 0.18 0.22 0.22M ★0.22K 0.27M 0.27K 0.33M 0.33K 0.33K ★0.33M 0.39 0.39 0.47M 0.47M 0.47K 0.47K ★0.47 0.56 0.56 0.68M 0.68K 0.68 ★0.68 ★0.82M 0.82M 0.82K 1.0 0.33 0.39M 0.39K 0.47 0.47 0.56 0.56 0.68M 0.68M 0.68K 0.68M 0.82 0.82 1.0M 1.0K Page 5 of 10 W ±0.4 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 41.0 41.0 41.0 41.0 42.0 41.0 42.0 41.0 42.0 41.0 42.0 41.0 42.0 41.0 41.0 H ±0.4 17.0 17.0 18.5 20.0 22.0 23.0 24.5 29.5 29.5 18.0 18.0 18.0 12.0 20.0 20.0 12.0 12.0 20.0 22.0 22.0 25.0 24.5 12.0 24.5 28.0 24.5 28.0 30.0 28.0 16.0 30.0 28.0 29.0 30.0 33.0 18.5 18.5 33.0 37.0 37.0 22.0 22.0 24.0 24.0 15.0 26.0 28.0 26.0 28.0 30.0 15.0 30.0 19.0 32.0 33.5 T ±0.4 8.5 8.5 10.0 11.0 12.0 13.5 15.5 14.5 14.5 9.0 9.0 9.0 18.0 11.0 11.0 18.0 22.0 11.0 13.0 13.0 13.0 15.0 22.0 15.0 14.0 15.0 14.0 16.0 17.0 27.5 16.0 17.0 19.0 21.0 18.0 31.0 31.0 18.0 22.0 22.0 11.0 11.0 13.0 13.0 24.0 15.0 14.0 15.0 14.0 16.0 24.0 16.0 24.0 17.0 18.5 P ±0.4 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 d Part number 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 C43Q1104-9S****+++ C43Q1124-9S****+++ C43Q1154-9S****+++ C43Q1184-9S****+++ C43Q1224-9S****+++ C43Q1274-9S****+++ C43Q1334-9S****+++ C43Q1334-9A****+++ C43Q1394M9S****+++ C43Q1104-B0****+++ C43Q1124-B0****+++ C43Q1154-BS****+++ C43Q1154-BC****+++ C43Q1184-BS****+++ C43Q1224-BS****+++ C43Q1224MBC****+++ C43Q1224KBC****+++ C43Q1274MBS****+++ C43Q1274KBS****+++ C43Q1334MBS****+++ C43Q1334KBS****+++ C43Q1334KBA****+++ C43Q1334MBC****+++ C43Q1394-BA****+++ C43Q1394-BS****+++ C43Q1474MBA****+++ C43Q1474MBS****+++ C43Q1474KBS****+++ C43Q1474KBA****+++ C43Q1474-BC****+++ C43Q1564-BS****+++ C43Q1564-BA****+++ C43Q1684MBA****+++ C43Q1684KBA****+++ C43Q1684-BS****+++ C43Q1684-BC****+++ C43Q1824MBC****+++ C43Q1824MBS****+++ C43Q1824KBS****+++ C43Q1105-BS****+++ C43Q1334-FS****+++ C43Q1394MFS****+++ C43Q1394KFS****+++ C43Q1474-FS****+++ C43Q1474-FC****+++ C43Q1564-FS****+++ C43Q1564-FA****+++ C43Q1684MFA****+++ C43Q1684MFS****+++ C43Q1684KFS****+++ C43Q1684MFC****+++ C43Q1824-FS****+++ C43Q1824-FC****+++ C43Q1105MFS****+++ C43Q1105KFS****+++  MKP63 ■ Maximum permissible voltage change per unit of time Rated Voltage (Vac) P=7.5mm P=10mm P=15mm P=22.5mm P=27.5mm P=37.5mm 300 800 800 600 500 400 300 Max dV/dt(V/us) at 425Vdc Note: 1. Rated voltage pulse slope (dV/dt)R at rated voltage. 2. If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U. ■ Impedance Vs. Frequency TYPICAL GRAPHS Z=f(f) Typical values ■ Quality ensuring test (before shipment): Inspection item(each batch) Inspection level (GB/T 2828.1,ISO2859-1) IL AQL II 1.5 II 0.25 S-3 2.5 Appearance inspection Dimensions Capacitance Tangent of the loss angle Dielectric strength Insulation resistance Solderability Page 6 of 10  MKP63 ■ Test Method And Performance No. Item 1 4.5 Solderability 2 4.3 Terminal strength 3 4.4 Resistance to solder heat 4 4.20 Solvent resistance of the marking 4.2 Initial measurement Good quality of tinning Solder temperature: 245˚C 5˚C Immersion time: 2.0s0.5s There shall be no visible damage Tense: 0.50d≤0.80, 10N 0.80d≤1.25, 20N Bend: 0.50d≤0.80, 5N 0.80d≤1.25, 10N The terminals shall be bent 2 times in each direction There shall be no visible damage C/C 5(relative to the initial value) Solder temperature:260˚C5˚C Immersion time: 10s1s The marking shall be legible Solvent: Industrial isopropanol. Solvent temperature:23˚C±5˚C Dipping time: 5min0.5min Condition: scrub Scrub material: absorbent cotton Reverting time: No Capacitance, Tg 5 cycles There shall be no evidence of deterioration. TA=-40˚C, TB =+110˚C Duration: t=30min 4.7 Vibration There shall be no evidence of deterioration. Amplitude 0.75mm or acceleration 100m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz.Three directions, 2h foreach direction, total 6h. 4.8 Bump There shall be no evidence of deterioration. 4 000 times, Acceleration: 400m/s2, Pulse duration, 6ms 4.6 Rapid change of temperature 5 Test Method (IEC 60384-14) Performance Final measurement There shall be no visible damage C/C 5(relative to the initial value) Initial measurement +110℃, 16h Dry heat Damp heat, Cyclic Test Db, Severity: b, the first cycle -40℃, 2h Cold 6 4.11 Climate sequence Damp heat, cyclic other Final measurement Test Db, Severity b, the other cycles, There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: 0.008 (10kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value Page 7 of 10  MKP63 No. 7 8 9 Test Method (IEC 60384-14) Item Performance 4.12 Damp heat steady state There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: 0.008 (10kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value Temperature:40˚C 2˚C Humidity: 933RH Duration: 56 days 4.13 Impulse voltage There are three or more waveforms which indicate that no self-heating breakdown have occurred when it is monitored by the monitor Each individual capacitor shall be subjected to 24 impulses of the same polarity (when any three successive impulses are shown by the monitor to have a wave form indicating that no self-healing breakdown have taken place the impulses can be stopped), the time between impulses shall not be less than 10s, and the peak value of the voltage impulse: 5.0kV 4.14 Endurance There shall be no visible damage, legible marking C/C10(relative to the initial value) Increase of tg: 0.008 (10kHz) Dielectric strength : There shall be no breakdown or flashover I.R. :  50 of the rated value +110˚C, 1.7URVa.c. 1 000h The voltage shall be subjected to 1 000Vrms for 0.1s every one hour during test. Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s 10 11 4.15 Charging and discharging 4.17 Passive flammability C/C 10(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) I.R.:  50 of the rated value The flaming time of each capacitor shall not go beyond 10s after it is taken apart from the flame. Drop of each capacitor caused by flame shall not fire the tissue below. Page 8 of 10 Charging voltage: 2 UR Vd.c. Charging resistance: 220/CN() or the current ≤1.0A (whichever is the minor) Discharging resistance: 2UR R () dU CN  dt CN: Capacitance (F) dU/dt(V/us) : 100V/s Needle flame test The category of flammability: B Expose time: 1 time Capacitor Volume Exposing time 250
C43Q1104K9SC000 价格&库存
很抱歉,暂时无法提供与“C43Q1104K9SC000”相匹配的价格&库存,您可以联系我们找货
