RoHS
Compliant
SPECIFICATION FOR APPROVAL
File No.: Q/FRK 0.GS.E.C82-C11
Product Name
Double sided metallized polypropylene film capacitor(Box-type)
Product Type
MMKP82
Product Code
C82
Customer
Customer Code
Issue Date
Approved by Customer
Xiamen Faratronic Co. Ltd.
Drafted
Checked
Approved
厦门法拉电子股份有限公司
地址: 中国厦门市海沧区新园路 99 号
Add: No.99 Xinyuan Road, Haicang District, Xiamen, China
TEL:
FAX:
Mail:
Http:
Export business
0086-592-6208609 6208608
0086-592-6208557
Vivian@faratronic.com.cn
Donny@faratronic.com.cn
james@faratronic.com.cn
www.faratronic.com.cn
HK office : Faratronic (HK) Co. Ltd.
0852-2898 9168
0852-2898 9683
hkoffice@faratronic.com.hk
kolin@faratronic.com.hk
www.faratronic.com
*.The specification are the property of Xiamen Faratronic Co,Ltd and shall not be copied or used as
commercial purposes without permission.
Page 1 of 16
MMKP82
Version history
Current version
Date
Author
Page 2 of 16
Change description
MMKP82
Double sided metallized polypropylene film capacitor (Box-type)
■ Outline Drawing
W±0.4, H±0.4, T±0.4
■ Features
● Double sided metallized polypropylene structure
● Low loss and small inherent temperature rise
● Negative temperature coefficient of capacitance
● Excellent active and passive flame resistant abilities
■ Typical Application
● Widely used in high voltage, high frequency and pulse circuit
● Electronic ballasts and compact lamps
● SNUBBER and SCR commutating circuits
■ Specifications
Reference Standard
Climatic Category
Rated Temperature
Operating Temperature Range
GB/T 10190 (IEC 60384-16)
40/105/56
85℃ for UR (dc); 75℃ for UR (ac)
-40℃~105℃
(+85℃ to +105℃: decreasing factor 1.25% per ℃ for UR (dc))
(+75℃ to +105℃: decreasing factor 1.35% per ℃ for UR (ac))
Rated Voltage
250V, 400V, 630V, 1 000V, 1 600V, 2 000V
Capacitance Range
Capacitance Tolerance
Voltage Proof
Dissipation Factor
0.00022F~3.9F
2 (G), 3 (H), 5 (J), 10 (K), 20 (M)
1.60UR (5s)
≤10×10-4 (1kHz, 20℃)
Insulation Resistance
R≥100 000M , CN≤0.33μF
RCN≥30 000s,
CN>0.33μF
Maximum Pulse Rise Time(dV/dt):
If the working voltage(U) is lower
than the rated voltage(UR),the
capacitor can be worked at a higher
dV/dt. In this case, the maximum
allowed dV/dt is obtain by
multiplying the right value with U R/
U.
UR(V)
250
400
630
1 000
1 600
2 000
P=7.5
1 200
1 800
3 200
6 000
Page 3 of 16
P=10.0
1 000
1 500
3 200
6 000
(20℃, 100V,1min)
dV/dt(V/us)
P=15.0
P=22.5
550
250
900
500
2 500
1 500
3 300
2 100
6 000
3 000
10 000
5 000
P=27.5
200
300
900
1 000
2 000
2 200
MMKP82
■ Part number system
The 18 digits part number is formed as follow:
1
2
3
C
8
2
Digit 1 to 3
4
5
6
7
8
9 10 11
12 13 14 15 16 17 18
Series code
C82=MMKP82
Digit 4 to 5
D.C. rated voltage
2E=250V 2G=400V 2J=630V
3A=1000V 3C=1600V 3D=2000V
Digit 6 to 8
Rated capacitance value
For example : 103=10×103 pF= 0.01μF
Digit 9
Capacitance tolerance
G=±2%, H=±3%
J=±5%, K=±10%, M=±20%
Digit 10
Pitch
3=7.5mm 4=10mm 6=15mm
9=22.5mm B=27.5mm
Digit 11
Internal use
Digit 12 to 15 Lead form and packaging code
Digit 16 to 18
Internal use
Table1 Lead form and packaging code
Digit 12
Digit 13
Digit 14
code
explanation
code
explanation
code
A
ammo-pack
3
4
6
F=7.5mm
F=10.0mm
F=15.0mm
C
straight
lead
“C” in the
figure above
code
00
45
35
32
explanation
standard lead length
(18mm~26mm)
lead length 4.5mm
lead length 3.5mm
lead length 3.2mm
explanation
straight
Digit 15
code
explanation
1
Each cap. among two consecutive holes
P3=12.7mm,H=18.5mm (For pitch=7.5mm)
5
P3=25.4mm;H=18.5mm (For pitch=10/15mm)
Length tolerance ±0.5mm
Or standard length
2
Length tolerance ±0.3mm
Page 4 of 16
MMKP82
■ Dimensions(mm)
250Vdc(180Vac)
250Vdc(180Vac)
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.0068
10.5
9.0
4.0
7.5
0.6
C822E682-30****+++
0.22
26.5
15.0
6.0
22.5
0.8
C822E224-90****+++
0.0082
10.5
9.0
4.0
7.5
0.6
C822E822-30****+++
0.27
26.5
15.0
6.0
22.5
0.8
C822E274-90****+++
0.010
10.5
9.0
4.0
7.5
0.6
C822E103-30****+++
0.33
26.5
15.0
6.0
22.5
0.8
C822E334-90****+++
0.012
10.5
9.0
4.0
7.5
0.6
C822E123-30****+++
0.39
26.5
16.0
7.0
22.5
0.8
C822E394-90****+++
0.015
10.5
9.0
4.0
7.5
0.6
C822E153-30****+++
0.47
26.5
16.0
7.0
22.5
0.8
C822E474-90****+++
0.018
10.5
9.0
4.0
7.5
0.6
C822E183-30****+++
0.56
26.5
17.0
8.5
22.5
0.8
C822E564-90****+++
0.022
10.5
9.0
4.0
7.5
0.6
C822E223-30****+++
0.68
26.5
18.5
10.0
22.5
0.8
C822E684-90****+++
0.027
10.5
11.0
5.0
7.5
0.6
C822E273-30****+++
0.82
26.5
18.5
10.0
22.5
0.8
C822E824-90****+++
0.033
10.5
11.0
5.0
7.5
0.6
C822E333-30****+++
1.0
26.5
22.0
12.0
22.5
0.8
C822E105-90****+++
0.039
10.5
12.0
6.0
7.5
0.6
C822E393-30****+++
0.82
32.0
18.0
9.0
27.5
0.8
C822E824-B0****+++
0.047
10.5
12.0
6.0
7.5
0.6
C822E473-30****+++
1.0
32.0
20.0
11.0
27.5
0.8
C822E105-B0****+++
0.027
13.0
9.0
4.0
10.0
0.6
C822E273-40****+++
1.2
32.0
20.0
11.0
27.5
0.8
C822E125-B0****+++
0.033
13.0
9.0
4.0
10.0
0.6
C822E333-40****+++
1.5
32.0
22.0
13.0
27.5
0.8
C822E155-B0****+++
0.039
13.0
9.0
4.0
10.0
0.6
C822E393-40****+++
1.8
32.0
24.5
15.0
27.5
0.8
C822E185-B0****+++
0.047
13.0
11.0
5.0
10.0
0.6
C822E473-40****+++
2.2
32.0
24.5
15.0
27.5
0.8
C822E225-B0****+++
0.056
13.0
11.0
5.0
10.0
0.6
C822E563-40****+++
2.7
32.0
33.0
18.0
27.5
0.8
C822E275-B0****+++
0.068
13.0
12.0
6.0
10.0
0.6
C822E683-40****+++
3.3
32.0
33.0
18.0
27.5
0.8
C822E335-B0****+++
0.082
13.0
12.0
6.0
10.0
0.6
C822E823-40****+++
3.9
32.0
33.0
18.0
27.5
0.8
C822E395-B0****+++
0.068
17.5
11.0
5.0
15.0
0.8
C822E683-60****+++
0.082
17.5
11.0
5.0
15.0
0.8
C822E823-60****+++
0.10
17.5
11.0
5.0
15.0
0.8
C822E104-60****+++
0.12
17.5
12.0
6.0
15.0
0.8
C822E124-60****+++
0.15
17.5
12.0
6.0
15.0
0.8
C822E154-60****+++
0.18
17.5
13.5
7.5
15.0
0.8
C822E184-60****+++
0.22
17.5
13.5
7.5
15.0
0.8
C822E224-60****+++
0.27
17.5
14.5
8.5
15.0
0.8
C822E274-60****+++
0.33
17.5
16.0
10.0
15.0
0.8
C822E334-60****+++
0.39
17.5
16.0
10.0
15.0
0.8
C822E394-60****+++
Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2%
2. “****”=lead form and packaging code (refer to table 1)
Page 5 of 16
MMKP82
■ Dimensions(mm)
400Vdc(250Vac)@
400Vdc(250Vac)@
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.0027
10.5
9.0
4.0
7.5
0.6
C822G272-30****+++
0.033
17.5
11.0
5.0
15.0
0.8
C822G333-60****+++
0.0033
10.5
9.0
4.0
7.5
0.6
C822G332-30****+++
0.039
17.5
11.0
5.0
15.0
0.8
C822G393-60****+++
0.0039
10.5
9.0
4.0
7.5
0.6
C822G392-30****+++
0.047
17.5
11.0
5.0
15.0
0.8
C822G473-60****+++
0.0047
10.5
9.0
4.0
7.5
0.6
C822G472-30****+++
0.056
17.5
11.0
5.0
15.0
0.8
C822G563-60****+++
0.0056
10.5
9.0
4.0
7.5
0.6
C822G562-30****+++
0.068
17.5
12.0
6.0
15.0
0.8
C822G683-60****+++
0.0068
10.5
9.0
4.0
7.5
0.6
C822G682-30****+++
0.082
17.5
12.0
6.0
15.0
0.8
C822G823-60****+++
0.0082
10.5
9.0
4.0
7.5
0.6
C822G822-30****+++
0.10
17.5
13.5
7.5
15.0
0.8
C822G104-60****+++
0.010
10.5
9.0
4.0
7.5
0.6
C822G103-30****+++
0.12
17.5
13.5
7.5
15.0
0.8
C822G124-60****+++
0.012
10.5
9.0
4.0
7.5
0.6
C822G123-30****+++
0.15
17.5
14.5
8.5
15.0
0.8
C822G154-60****+++
0.015
10.5
11.0
5.0
7.5
0.6
C822G153-30****+++
0.18
17.5
16.0
10.0
15.0
0.8
C822G184-60****+++
0.018
10.5
11.0
5.0
7.5
0.6
C822G183-30****+++
0.22
17.5
16.0
10.0
15.0
0.8
C822G224-60****+++
0.022
10.5
12.0
6.0
7.5
0.6
C822G223-30****+++
0.27
17.5
19.0
11.0
15.0
0.8
C822G274-60****+++
0.027
10.5
12.0
6.0
7.5
0.6
C822G273-30****+++
0.12
26.5
15.0
6.0
22.5
0.8
C822G124-90****+++
0.010
13.0
9.0
4.0
10.0
0.6
C822G103-40****+++
0.15
26.5
15.0
6.0
22.5
0.8
C822G154-90****+++
0.012
13.0
9.0
4.0
10.0
0.6
C822G123-40****+++
0.18
26.5
15.0
6.0
22.5
0.8
C822G184-90****+++
0.015
13.0
9.0
4.0
10.0
0.6
C822G153-40****+++
0.22
26.5
16.0
7.0
22.5
0.8
C822G224-90****+++
0.018
13.0
9.0
4.0
10.0
0.6
C822G183-40****+++
0.27
26.5
17.0
8.5
22.5
0.8
C822G274-90****+++
0.022
13.0
9.0
4.0
10.0
0.6
C822G223-40****+++
0.33
26.5
17.0
8.5
22.50
0.8
C822G334-90****+++
0.027
13.0
11.0
5.0
10.0
0.6
C822G273-40****+++
0.39
26.5
18.5
10.0
22.5
0.8
C822G394-90****+++
0.033
13.0
11.0
5.0
10.0
0.6
C822G333-40****+++
0.47
26.5
18.5
10.0
22.5
0.8
C822G474-90****+++
0.039
13.0
12.0
6.0
10.0
0.6
C822G393-40****+++
0.56
26.5
22.0
12.0
22.5
0.8
C822G564-90****+++
0.047
13.0
12.0
6.0
10.0
0.6
C822G473-40****+++
0.68
26.5
22.0
12.0
22.5
0.8
C822G684-90****+++
0.39
32.0
18.0
9.0
27.5
0.8
C822G394-B0****+++
0.47
32.0
18.0
9.0
27.5
0.8
C822G474-B0****+++
0.56
32.0
20.0
11.0
27.5
0.8
C822G564-B0****+++
0.68
32.0
20.0
11.0
27.5
0.8
C822G684-B0****+++
0.8
0.82
32.0
22.0
13.0
27.5
1.0
32.0
24.5
15.0
27.5
0.8
C822G105-B0****+++
1.2
32.0
24.5
15.0
27.5
0.8
C822G125-B0****+++
1.5
32.0
33.0
18.0
27.5
0.8
C822G155-B0****+++
1.8
32.0
33.0
18.0
27.5
0.8
C822G185-B0****+++
3. “@” Not suitable for across-the-line applications. Pls refer to the Interference Suppression Capacitor.
Page 6 of 16
C822G824-B0****+++
MMKP82
■ Dimensions(mm)
630Vdc(400Vac)
630Vdc(400Vac)
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.00068
10.5
9.0
4.0
7.5
0.6
C822J681-30****+++
0.039
17.5
12.0
6.0
15.0
0.8
C822J393-60****+++
0.00082
10.5
9.0
4.0
7.5
0.6
C822J821-30****+++
0.047
17.5
12.0
6.0
15.0
0.8
C822J473-60****+++
0.0010
10.5
9.0
4.0
7.5
0.6
C822J102-30****+++
0.056
17.5
13.5
7.5
15.0
0.8
C822J563-60****+++
0.0012
10.5
9.0
4.0
7.5
0.6
C822J122-30****+++
0.068
17.5
14.5
8.5
15.0
0.8
C822J683-60****+++
0.0015
10.5
9.0
4.0
7.5
0.6
C822J152-30****+++
0.082
17.5
14.5
8.5
15.0
0.8
C822J823-60****+++
0.0018
10.5
9.0
4.0
7.5
0.6
C822J182-30****+++
0.10
17.5
16.0
10.0
15.0
0.8
C822J104-60****+++
0.0022
10.5
9.0
4.0
7.5
0.6
C822J222-30****+++
0.12
17.5
19.0
11.0
15.0
0.8
C822J124-60****+++
0.0027
10.5
9.0
4.0
7.5
0.6
C822J272-30****+++
0.047
26.5
15.0
6.0
22.5
0.8
C822J473-90****+++
0.0033
10.5
9.0
4.0
7.5
0.6
C822J332-30****+++
0.056
26.5
15.0
6.0
22.5
0.8
C822J563-90****+++
0.0039
10.5
9.0
4.0
7.5
0.6
C822J392-30****+++
0.068
26.5
15.0
6.0
22.5
0.8
C822J683-90****+++
0.0047
10.5
9.0
4.0
7.5
0.6
C822J472-30****+++
0.082
26.5
15.0
6.0
22.5
0.8
C822J823-90****+++
0.0056
10.5
9.0
4.0
7.5
0.6
C822J562-30****+++
0.10
26.5
15.0
6.0
22.5
0.8
C822J104-90****+++
0.0068
10.5
11.0
5.0
7.5
0.6
C822J682-30****+++
0.12
26.5
16.0
7.0
22.5
0.8
C822J124-90****+++
0.0082
10.5
11.0
5.0
7.5
0.6
C822J822-30****+++
0.15
26.5
17.0
8.5
22.5
0.8
C822J154-90****+++
0.010
10.5
12.0
6.0
7.5
0.6
C822J103-30****+++
0.18
26.5
17.0
8.5
22.5
0.8
C822J184-90****+++
0.012
10.5
12.0
6.0
7.5
0.6
C822J123-30****+++
0.22
26.5
18.5
10.0
22.5
0.8
C822J224-90**** +++
0.0039
13.0
9.0
4.0
10.0
0.6
C822J392-40****+++
0.27
26.5
22.0
12.0
22.5
0.8
C822J274-90****+++
0.0047
13.0
9.0
4.0
10.0
0.6
C822J472-40****+++
0.33
26.5
22.0
12.0
22.5
0.8
C822J334-90****+++
0.0056
13.0
9.0
4.0
10.0
0.6
C822J562-40****+++
0.39
26.5
22.0
12.0
22.5
0.8
C822J394-90****+++
0.0068
13.0
9.0
4.0
10.0
0.6
C822J682-40****+++
0.15
32.0
18.0
9.0
27.5
0.8
C822J154-B0****+++
0.0082
13.0
9.0
4.0
10.0
0.6
C822J822-40****+++
0.18
32.0
18.0
9.0
27.5
0.8
C822J184-B0****+++
0.010
13.0
11.0
5.0
10.0
0.6
C822J103-40****+++
0.22
32.0
18.0
9.0
27.5
0.8
C822J224-B0****+++
0.012
13.0
11.0
5.0
10.0
0.6
C822J123-40****+++
0.27
32.0
18.0
9.0
27.5
0.8
C822J274-B0****+++
0.015
13.0
12.0
6.0
10.0
0.6
C822J153-40****+++
0.33
32.0
20.0
11.0
27.5
0.8
C822J334-B0****+++
0.018
13.0
12.0
6.0
10.0
0.6
C822J183-40****+++
0.39
32.0
20.0
11.0
27.5
0.8
C822J394-B0****+++
0.012
17.5
11.0
5.0
15.0
0.8
C822J123-60****+++
0.47
32.0
22.0
13.0
27.5
0.8
C822J474-B0****+++
0.015
17.5
11.0
5.0
15.0
0.8
C822J153-60****+++
0.56
32.0
22.0
13.0
27.5
0.8
C822J564-B0****+++
0.018
17.5
11.0
5.0
15.0
0.8
C822J183-60****+++
0.68
32.0
24.5
15.0
27.5
0.8
C822J684-B0****+++
0.022
17.5
11.0
5.0
15.0
0.8
C822J223-60****+++
0.82
32.0
28.0
14.0
27.5
0.8
C822J824-B0****+++
0.027
17.5
11.0
5.0
15.0
0.8
C822J273-60****+++
1.0
32.0
33.0
18.0
27.5
0.8
C822J105-B0****+++
0.033
17.5
12.0
6.0
15.0
0.8
C822J333-60****+++
1.2
32.0
33.0
18.0
27.5
0.8
C822J125-B0****+++
Page 7 of 16
MMKP82
■ Dimensions(mm)
1 000Vdc(600Vac)
1 000Vdc(600Vac)
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.00047
10.5
9.0
4.0
7.5
0.6
C823A471-30****+++
0.0082
17.5
11.0
5.0
15.0
0.8
C823A822-60****+++
0.00056
10.5
9.0
4.0
7.5
0.6
C823A561-30****+++
0.010
17.5
11.0
5.0
15.0
0.8
C823A103-60****+++
0.00068
10.5
9.0
4.0
7.5
0.6
C823A681-30****+++
0.012
17.5
11.0
5.0
15.0
0.8
C823A123-60****+++
0.00082
10.5
9.0
4.0
7.5
0.6
C823A821-30****+++
0.015
17.5
11.0
5.0
15.0
0.8
C823A153-60****+++
0.0010
10.5
9.0
4.0
7.5
0.6
C823A102-30****+++
0.018
17.5
13.5
7.5
15.0
0.8
C823A183-60****+++
0.0012
10.5
11.0
5.0
7.5
0.6
C823A122-30****+++
0.022
17.5
13.5
7.5
15.0
0.8
C823A223-60****+++
0.0015
10.5
11.0
5.0
7.5
0.6
C823A152-30****+++
0.027
17.5
14.5
8.5
15.0
0.8
C823A273-60****+++
0.0018
10.5
11.0
5.0
7.5
0.6
C823A182-30****+++
0.033
17.5
14.5
8.5
15.0
0.8
C823A333-60****+++
0.0022
10.5
11.0
5.0
7.5
0.6
C823A222-30****+++
0.039
17.5
16.0
10.0
15.0
0.8
C823A393-60****+++
0.0027
10.5
12.0
6.0
7.5
0.6
C823A272-30****+++
0.047
17.5
19.0
11.0
15.0
0.8
C823A473-60****+++
0.0033
10.5
12.0
6.0
7.5
0.6
C823A332-30****+++
0.027
26.5
15.0
6.0
22.5
0.8
C823A273-90****+++
0.0010
13.0
9.0
4.0
10.0
0.6
C823A102-40****+++
0.033
26.5
15.0
6.0
22.5
0.8
C823A333-90****+++
0.0012
13.0
9.0
4.0
10.0
0.6
C823A122-40****+++
0.039
26.5
15.0
6.0
22.5
0.8
C823A393-90****+++
0.0015
13.0
9.0
4.0
10.0
0.6
C823A152-40****+++
0.047
26.5
16.0
7.0
22.5
0.8
C823A473-90****+++
0.0018
13.0
9.0
4.0
10.0
0.6
C823A182-40****+++
0.056
26.5
16.0
7.0
22.5
0.8
C823A563-90****+++
0.0022
13.0
9.0
4.0
10.0
0.6
C823A222-40****+++
0.068
26.5
17.0
8.5
22.5
0.8
C823A683-90****+++
0.0027
13.0
9.0
4.0
10.0
0.6
C823A272-40****+++
0.082
26.5
18.5
10.0
22.5
0.8
C823A823-90****+++
0.0033
13.0
9.0
4.0
10.0
0.6
C823A332-40****+++
0.10
26.5
18.5
10.0
22.5
0.8
C823A104-90****+++
0.0039
13.0
11.0
5.0
10.0
0.6
C823A392-40****+++
0.12
26.5
22.0
12.0
22.5
0.8
C823A124-90****+++
0.0047
13.0
11.0
5.0
10.0
0.6
C823A472-40****+++
0.15
26.5
22.0
12.0
22.5
0.8
C823A154-90****+++
0.0056
13.0
12.0
6.0
10.0
0.6
C823A562-40****+++
0.10
32.0
18.0
9.0
27.5
0.8
C823A104-B0****+++
0.0068
13.0
12.0
6.0
10.0
0.6
C823A682-40****+++
0.12
32.0
20.0
11.0
27.5
0.8
C823A124-B0****+++
0.15
32.0
20.0
11.0
27.5
0.8
C823A154-B0****+++
0.18
32.0
22.0
13.0
27.5
0.8
C823A184-B0****+++
0.22
32.0
22.0
13.0
27.5
0.8
C823A224-B0****+++
0.27
32.0
24.5
15.0
27.5
0.8
C823A274-B0****+++
0.33
32.0
28.0
14.0
27.5
0.8
C823A334-B0****+++
0.39
32.0
33.0
18.0
27.5
0.8
C823A394-B0****+++
0.47
32.0
33.0
18.0
27.5
0.8
C823A474-B0****+++
Page 8 of 16
MMKP82
■ Dimensions(mm)
1 600Vdc(650Vac)
1 600Vdc(650Vac)
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.00068
17.5
11.0
5.0
15.0
0.8
C823C681-60****+++
0.015
26.5
15.0
6.0
22.5
0.8
C823C153-90****+++
0.00082
17.5
11.0
5.0
15.0
0.8
C823C821-60****+++
0.018
26.5
15.0
6.0
22.5
0.8
C823C183-90****+++
0.0010
17.5
11.0
5.0
15.0
0.8
C823C102-60****+++
0.022
26.5
15.0
6.0
22.5
0.8
C823C223-90****+++
0.0012
17.5
11.0
5.0
15.0
0.8
C823C122-60****+++
0.027
26.5
15.0
6.0
22.5
0.8
C823C273-90****+++
0.0015
17.5
11.0
5.0
15.0
0.8
C823C152-60****+++
0.033
26.5
16.0
7.0
22.5
0.8
C823C333-90****+++
0.0018
17.5
11.0
5.0
15.0
0.8
C823C182-60****+++
0.039
26.5
17.0
8.5
22.5
0.8
C823C393-90****+++
0.0022
17.5
11.0
5.0
15.0
0.8
C823C222-60****+++
0.047
26.5
18.5
10.0
22.5
0.8
C823C473-90****+++
0.0027
17.5
11.0
5.0
15.0
0.8
C823C272-60****+++
0.056
26.5
18.5
10.0
22.5
0.8
C823C563-90****+++
0.0033
17.5
11.0
5.0
15.0
0.8
C823C332-60****+++
0.068
26.5
22.0
12.0
22.5
0.8
C823C683-90****+++
0.0039
17.5
11.0
5.0
15.0
0.8
C823C392-60****+++
0.082
26.5
22.0
12.0
22.5
0.8
C823C823-90****+++
0.0047
17.5
11.0
5.0
15.0
0.8
C823C472-60****+++
0.039
32.0
18.0
9.0
27.5
0.8
C823C393-B0****+++
0.0056
17.5
11.0
5.0
15.0
0.8
C823C562-60****+++
0.047
32.0
18.0
9.0
27.5
0.8
C823C473-B0****+++
0.0068
17.5
11.0
5.0
15.0
0.8
C823C682-60****+++
0.056
32.0
18.0
9.0
27.5
0.8
C823C563-B0****+++
0.0082
17.5
12.0
6.0
15.0
0.8
C823C822-60****+++
0.068
32.0
18.0
9.0
27.5
0.8
C823C683-B0****+++
0.010
17.5
12.0
6.0
15.0
0.8
C823C103-60****+++
0.082
32.0
20.0
11.0
27.5
0.8
C823C823-B0****+++
0.012
17.5
13.5
7.5
15.0
0.8
C823C123-60****+++
0.10
32.0
20.0
11.0
27.5
0.8
C823C104-B0****+++
0.015
17.5
13.5
7.5
15.0
0.8
C823C153-60****+++
0.12
32.0
22.0
13.0
27.5
0.8
C823C124-B0****+++
0.018
17.5
14.5
8.5
15.0
0.8
C823C183-60****+++
0.15
32.0
24.5
15.0
27.5
0.8
C823C154-B0****+++
0.022
17.5
14.5
8.5
15.0
0.8
C823C223-60****+++
0.18
32.0
24.5
15.0
27.5
0.8
C823C184-B0****+++
0.027
17.5
16.0
10.0
15.0
0.8
C823C273-60****+++
0.22
32.0
33.0
18.0
27.5
0.8
C823C224-B0****+++
0.033
17.5
19.0
11.0
15.0
0.8
C823C333-60****+++
0.27
32.0
33.0
18.0
27.5
0.8
C823C274-B0****+++
0.33
32.0
33.0
18.0
27.5
0.8
C823C334-B0****+++
Note: 1. “-”=capacitance tolerance code, M=±20%, K=±10%,J=±5%, H=±3%, G=±2%
Page 9 of 16
MMKP82
■ Dimensions(mm)
2 000Vdc(700Vac)
2 000Vdc(700Vac)
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
CN
(F)
W
±0.4
H
±0.4
T
±0.4
P
±0.4
d
±0.05
Part number
0.00022
17.5
11.0
5.0
15.0
0.8
C823D221-60****+++
0.0010
26.5
15.0
6.0
22.5
0.8
C823D102-90****+++
0.00027
17.5
11.0
5.0
15.0
0.8
C823D271-60****+++
0.0012
26.5
15.0
6.0
22.5
0.8
C823D122-90****+++
0.00033
17.5
11.0
5.0
15.0
0.8
C823D331-60**** +++
0.0015
26.5
15.0
6.0
22.5
0.8
C823D152-90****+++
0.00039
17.5
11.0
5.0
15.0
0.8
C823D391-60****+++
0.0018
26.5
15.0
6.0
22.5
0.8
C823D182-90****+++
0.00047
17.5
11.0
5.0
15.0
0.8
C823D471-60****+++
0.0022
26.5
15.0
6.0
22.5
0.8
C823D222-90****+++
0.00056
17.5
11.0
5.0
15.0
0.8
C823D561-60****+++
0.0027
26.5
15.0
6.0
22.5
0.8
C823D272-90****+++
0.00068
17.5
11.0
5.0
15.0
0.8
C823D681-60****+++
0.0033
26.5
15.0
6.0
22.5
0.8
C823D332-90****+++
0.00082
17.5
11.0
5.0
15.0
0.8
C823D821-60****+++
0.0039
26.5
15.0
6.0
22.5
0.8
C823D392-90****+++
0.0010
17.5
11.0
5.0
15.0
0.8
C823D102-60****+++
0.0047
26.5
15.0
6.0
22.5
0.8
C823D472-90****+++
0.0012
17.5
11.0
5.0
15.0
0.8
C823D122-60****+++
0.0056
26.5
15.0
6.0
22.5
0.8
C823D562-90****+++
0.0015
17.5
11.0
5.0
15.0
0.8
C823D152-60****+++
0.0068
26.5
15.0
6.0
22.5
0.8
C823D682-90****+++
0.0018
17.5
11.0
5.0
15.0
0.8
C823D182-60****+++
0.0082
26.5
15.0
6.0
22.5
0.8
C823D822-90****+++
0.0022
17.5
11.0
5.0
15.0
0.8
C823D222-60****+++
0.010
26.5
15.0
6.0
22.5
0.8
C823D103-90****+++
0.0027
17.5
11.0
5.0
15.0
0.8
C823D272-60****+++
0.012
26.5
15.0
6.0
22.5
0.8
C823D123-90****+++
0.0033
17.5
12.0
6.0
15.0
0.8
C823D332-60****+++
0.015
26.5
16.0
7.0
22.5
0.8
C823D153-90****+++
0.0039
17.5
12.0
6.0
15.0
0.8
C823D392-60****+++
0.018
26.5
16.0
7.0
22.5
0.8
C823D183-90****+++
0.0047
17.5
12.0
6.0
15.0
0.8
C823D472-60****+++
0.022
26.5
17.0
8.5
22.5
0.8
C823D223-90****+++
0.0056
17.5
13.5
7.5
15.0
0.8
C823D562-60****+++
0.027
26.5
18.5
10.0
22.5
0.8
C823D273-90****+++
0.0068
17.5
13.5
7.5
15.0
0.8
C823D682-60****+++
0.033
26.5
18.5
10.0
22.5
0.8
C823D333-90****+++
0.0082
17.5
14.5
8.5
15.0
0.8
C823D822-60****+++
0.039
26.5
22.0
12.0
22.5
0.8
C823D393-90****+++
0.010
17.5
16.0
10.0
15.0
0.8
C823D103-60****+++
0.047
26.5
22.0
12.0
22.5
0.8
C823D473-90****+++
0.012
17.5
16.0
10.0
15.0
0.8
C823D123-60****+++
0.022
32.0
18.0
9.0
27.5
0.8
C823D223-B0****+++
0.015
17.5
19.0
11.0
15.0
0.8
C823D153-60****+++
0.027
32.0
18.0
9.0
27.5
0.8
C823D273-B0****+++
0.033
32.0
18.0
9.0
27.5
0.8
C823D333-B0****+++
0.039
32.0
20.0
11.0
27.5
0.8
C823D393-B0****+++
0.047
32.0
20.0
11.0
27.5
0.8
C823D473-B0****+++
0.056
32.0
22.0
13.0
27.5
0.8
C823D563-B0****+++
0.068
32.0
22.0
13.0
27.5
0.8
C823D683-B0****+++
0.082
32.0
24.5
15.0
27.5
0.8
C823D823-B0****+++
0.10
32.0
28.0
14.0
27.5
0.8
C823D104-B0****+++
0.12
32.0
33.0
18.0
27.5
0.8
C823D124-B0****+++
0.15
32.0
33.0
18.0
27.5
0.8
C823D154-B0****+++
Page 10 of 16
MMKP82
■ MAX. VOLTAGE(Vr.m.s) VERSUS FREQUENCY
Note: sinusoidal wave-form, environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm..
Page 11 of 16
MMKP82
■ MAX. CURRENT(Ir.m.s) VERSUS FREQUENCY
Note: sinusoidal wave-form,environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm.
Page 12 of 16
MMKP82
■ Test Method And Performance
No.
Item
Performance
1
Solderability
Initial measurement
Test method(IEC 60384-16)
Solder temperature: 245˚C 5˚C
Immersion time: 2.0s0.5s
Good quality of tinning
Capacitance
Tg: 1kHz,C1.0F
10kHz,C1.0F
There shall be no visible damage
Terminal strength
2
Resistance to solder
heat
Final measurement
Initial measurement
Rapid change of
temperature
Vibration
There shall be no visible damage, legible
marking
C/C 2(relative to the initial value)
Increase of tg:
0.002 (10kHz,C1.0μF)
0.002 (1kHz, C>1.0μF)
Capacitance
Tg(10kHz)
There shall
deterioration.
There shall
deterioration.
be
no
evidence
of
be
no
evidence
of
3
Bump
Final measurement
Initial
measurement
There shall be no evidence of
deterioration.
Increase of tg:
0.002 (10kHz)
IR: 50 of the rated value
Capacitance
Tg: 10kHz
Climate
sequence
Amplitude 0.75mm or acceleration
98m/s2 (whichever is the smaller
severity), f: 10Hz to 500Hz.Three
directions, 2h for each direction, total 6h.
4 000 times, Acceleration: 390m/s2,Pulse
duration, 6ms
Test Db, Severity: b, the first cycle
-40℃, 2h
Cold
4
A=-40˚C, B =+105˚C 5 cycles
Duration: t=30min
+105℃, 16h
Dry heat
Damp
heat, Cyclic
Low
air
pressure
Damp
heat,
cyclic
other
Final
measurement
Tense: 0.50d≤0.80, 10N
0.80d≤1.25, 20N
Bend: 0.50d≤0.80, 5N
0.80d≤1.25, 10N
The terminals shall be bent 2 times in
each direction
Solder temperature:260˚C5˚C
Immersion time: 10s1s
There shall be no permanent breakdown,
flashover or other harmful deformation
when applying UR at the last 1 minute.
Applying UR for 1 minute after 15
minutes the test finished .
legible marking
C/C 3(relative to the initial
value)
Increase of tg:0.003(10kHz)
I.R.: 50 of the rated value
Page 13 of 16
15℃~35℃, 8.5kPa, 1h
Test Db, Severity b, the other cycles,
MMKP82
No.
5
Item
Damp heat steady state
6
Endurance
7
Temperature
characteristic
8
9
Performance
legible marking
C/C 5(relative to the initial
value)
Increase of tg:0.002 (10kHz)
legible marking
value)
Increase of tg:0.0015 (10kHz)
Measuring capacitance at test point b, d,
f:
Characteristic
at
lower
category
temperature -40˚C:
0(Cb-Cd)/Cd+3
Characteristic
at
upper
category
temperature +105˚C:
-4(Cf-Cd)/Cd0
I.R. (test at point f ):
IR2500M
CR≤0.33μF
IR750s
CR>0.33μF
C/C 5(relative to the initial value)
increase of tg:0.005 (10kHz)
Charging and
discharging
Passive flammability
The flaming time of each capacitor shall
not go beyond 30s after it is taken apart
from the flame. Drop of each capacitor
caused by flame shall not fire the tissue
below
Temperature:40˚C 2˚C
2
Humidity: 93 3 %RH
Duration: 56 days
Temperature: +85℃
Voltage: 1.25×UR(50Hz)
Duration: 1 000h
Static method: The Capacitors should be
kept at the following temperature in turn:
a(20±2) ˚C, b(–40±3) ˚C, d(20±2) ˚C,
f(105±2) ˚C, g(20±2) ˚C
Times: 10 000
Duration of charging: 0.5s
Duration of discharging: 0.5s
Charging voltage: rated voltage UR
Charging resistance: 220/CR()
Discharging
resistance:
UR÷CR÷dV/dt()
CR: rated capacitance (μF)
dV/dt value: see page9 table
IEC 695-2-2
Needle flame test
The category of passive flammability:
C , Expose time in flame : 1 time
Capacitor volume Exposing time
V250mm3
5s
250mm310mm
Taping specification for box-type capacitors
▲ Outline Drawing
Fig.2 P=10.0、15.0mm
Fig.1 P=5.0、7.5mm
▲ Taping Dimensions(mm)
Technology index
title
Code
Taping type
Part number AmmoDigit12-15
pack
Taping pitch
P3
Feed hole pitch
P0
▲ Packing Quantity
Dimensions
P=5.0
P=7.5
P=10.0
P=15.0 Tolerance
Fig 1
Fig 1
Fig2
Fig 2
A201
A301
A405
A605
12.7
12.7
12.7
12.7
25.4
12.7
25.4
12.7
±1.0
±0.2
Center of wire
P1
3.85
2.6
7.7
5.2
±0.7
Center of body
Pitch of taping
wire
Component
alignment
Height of
component from
tape center
P2
6.35
6.35
12.7
12.7
5.0
7.5
10.0
15.0
±1.3
+0.6
-0.1
△S
±2.0
H***
18.5
18.5
18.5
18.5
±0.5
W
18.0
18.0
18.0
18.0
+1.0
-0.5
W0
6min
10min
10min
10min
W1
9.0
9.0
9.0
9.0
±0.5
W2
3max
3max
3max
3max
D0
t
4.0
0.7
4.0
0.7
4.0
0.7
4.0
0.9
±0.2
±0.2
Carrier tape width
Hold down tape
width
Hole position
Hold down tape
sition
Feed hole dia.
Tape thickness
F
Pitch
(mm)
5.0
7.5
10.0/
15.0
15.0
Box
thinkness
T(mm)
2.5
3.5
4.5
5.0
6.0
3.5
4.0
5.0
6.0
4.0
5.0
6.0
7.5
8.5
10.0
11.0
Ammo-pack
(pcs/box)
Domestic
Export
2500
1 700
1 400
1 200
1 000
2 000
1 500
1 300
1 000
800
1 700
1 500
1 200
1 000
750
600
500
400
350
300
250
1 500
1 300
1 000
800
650
500
450
350
300
250
200
Note: * P0=15mm is also available;
Page 15 of 16
**F can be other lead spacing;
***H=16.5mm is available;
MMKP82
■ Packing box sizes(mm)
1. Out packing box for bulk
2. Inner packing box for bulk
3. Box sizes for Ammo-pack
Page 16 of 16
