C42Q2225K9AC000
C42Q2225K9AC000
    FARATRONIC(法拉)
    插件,P=22.5mm
    2.2UF ±10% 305V 等级:X2
C42Q2225K9AC000 数据手册
气候类别 / 阻燃等级 Climatic Category/Passive Flammability Category 工作温度范围 Operating Temperature Range 额定电压 Rated Voltage (UR) 电容量范围 Capacitance Range 电容量偏差 Capacitance Tolerance 耐电压 Voltage Proof 绝缘电阻 Insulation Resistance   损耗角正切 Dissipation Factor(tanδ) 注 : 1. 推荐用于电网额定电压不超过 250VAC 场合;       2. 如果需要用到承载一定纹波电流场合,建议选用 C6A 等专                 用的滤波电容器;如有疑问,请与我司技术工程师联系;       3. 若用于户外或长期湿度较大场合,建议选用防潮设计。 110 40/110/56/B -40℃  ̄ +110℃ 305Vac/275Vac, 50/60Hz 0.0010μF  ̄ 25.0μF ±10%(K), ±20%(M) 引线之间 Between Terminals: 4.3UR(Vdc), 2s 极壳之间 Between Terminals To Case: 2 120Vac, 1min R ≥ 15 000MΩ,   CN ≤ 0.33μF (20℃ ,100V, 1min) RCN ≥ 5 000s,      CN  > 0.33μF     ≤ 20 x 10-4(1kHz,20℃ ) ≤ 20 x 10-4(10kHz,20℃ ) 0.0010μF ≤ CN < 0.010μF 0.010μF ≤ CN < 0.47μF ≤ 10 x 10-4(1kHz,20℃ ) ≤ 20 x 10-4(10kHz,20℃ ) -4 0.47μF ≤ CN ≤ 1.0μF ≤ 20 x 10 (1kHz,20℃ ) ≤ 40 x 10-4(10kHz,20℃ ) 1.0μF < CN ≤ 10.0μF ≤ 30 x 10-4(1kHz,20℃ ) ------------- 10.0μF < CN ≤ 50.0μF ≤ 40 x 10-4(1kHz,20℃ ) ------------- Recommend for max rated supply mains voltage 250Vac application; If used in application which has ripple current applied, recommend to use AC filter series: C6A etc; If have any questions please contact our technical engineer for more detail; For outdoor or severe humidity condition application, recommend to use THB series.
C42Q2225K9AC000 价格&库存
很抱歉,暂时无法提供与“C42Q2225K9AC000”相匹配的价格&库存,您可以联系我们找货
C42Q2225K9AC000
  • 1+5.70770
  • 10+4.60490
  • 30+4.03630
库存:645
C42Q2225K9AC000
  • 1+5.55380
  • 10+4.50140
  • 30+3.97010
库存:14
