C37
Version history
Current
version
Date
Author
Change description
Page 2 of 11
C37
Metallized polypropylene film capacitor(Dipped)
■ Outline Drawing
Forming Lead Shapes
II
III
I
1B
2B
IV
0B
P ≥ F
P < F
0mm≤P-F≤3mm
3mm1.0μF,1kHz)
IR: 50 of the rated value
R
Damp heat,
Cyclic other
Final
measurement
Test method(IEC 60384-16)
Solder temperature: 245˚C 5˚C
Immersion time: 2.0s0.5s
R
15℃~35℃, 8.5kPa, 1h
R
R
Page 9 of 11
Test Db, Severity b, the other cycles,
C37
No.
Item
Damp heat
steady state
5
6
Endurance
Charging and
discharging
7
Performance
There shall be no visible damage,
legible marking
C/C 5(relative to the initial
value)
Increase of tan:0.002 (1kHz)
legible marking
value)
Increase of tan:
0.004 (10kHz,C1.0μF)
0.004 (1kHz, C>1.0μF)
value)
Increase of tan:
0.005 (C1.0μF,10kHz)
0.005(C>1.0μF,1kHz)
Temperature:40˚C 2˚C
2
Humidity: 93 3 %RH
Duration: 56 days
Temperature: +85℃
Voltage: 1.25×UR
Duration: 1 000h
Times: 10 000
Duration of charging: 0.5s
Duration of discharging: 0.5s
Charging voltage: rated voltage U R
Charging resistance: 220/C N ()
Discharging resistance: U R ÷C N ÷dv/dt()
C N : rated capacitance (μF)
dv/dt value: see P2
R
R
R
R
R
R
R
R
R
■ Quality ensuring test (before shipment):
Inspection level (GB/T 2828.1)
Inspection item(each batch)
Appearance inspection
Dimensions
IL
AQL
S-4
1.5
II
0.65
S-3
2.5
Capacitance
Tangent of the loss angle
Dielectric strength
Insulation resistance
Solderability
■ Marking
Page 10 of 11
C37
■ Taping for dipped-type capacitor
▲ Outline Drawing
Fig 2
Fig.1
▲ Taping Dimensions(mm)
Technology
index title
Taping type
Code
Part number AmmoDigit12-15
pack
P=5.0
P=7.5
Dimensions (mm)
P=10.0
P=15.0
Fig 1
Fig 1
Fig 2
Fig 2
A21A
A31A
A41E
A61E
Tolerance
Taping pitch
P3
12.7
12.7
25.4
25.4
±1.0
Feed hole pitch
P0
12.7
12.7
12.7
12.7
±0.3
R
R
Center of wire
P1
3.85
2.60
7.7
5.2
±0.7
Center of body
P2
6.35
6.35
12.7
12.7
±1.3
Pitch of taping wire
F **
5.0
7.5
10.0
15.0
+0.8
-0.2
Component
alignment
Height of crankle
from tape center
Height of
component from
tape center
△S
±2.0
H
20.0
20.0
20.0
20.0
±1.0
H0
16.0
16.0
16.0
16.0
±0.5
Carrier tape width
W
18.0
18.0
18.0
18.0
+1.0
-0.5
Hold down tape
width
W0
10min
10min
10min
10min
Hole position
W1
9.0
9.0
9.0
9.0
+0.75
-0.5
W2
3max
3max
3max
3max
D0
4.0
4.0
4.0
4.0
±0.3
t
0.7
0.7
0.7
0.7
±0.2
Hold down tape
sition
Feed hole dia.
Tape thickness
R
R
P
R
R
R
R
R
■ Packing box sizes(mm)
1. Out packing box for bulk
2. Inner packing box for bulk
3. Box sizes for Ammo-pack
Page 11 of 11
Note: * P 0 =15mm is also available;
R
R
** F can be other lead spacing;
很抱歉,暂时无法提供与“C372S275JB0C000”相匹配的价格&库存,您可以联系我们找货
