DF1-136UWY-3
DF1-136UWY-3
    XKB(中国星坤)
    检测开关 操作寿命10万次
DF1-136UWY-3 数据手册
3.40[0.130] 13.60[0 3.70[0.150]±0.05 .535]±1 .0 Technical Parameters 1.Electrical Rating: 0.1A 125/250VAC 3A/12VDC;0.1A/48VDC 2.Electrical lifetime:100 000 3.Mechanical lifetime:100 000 4.Contact Resistance:≤100mΩ 5.Operating force:2.5N MAX 6.Pretravel:0.3~1.0mm 7.Withstand Voltage:Feet and Feet 500V/5S/5mA Feet and Shell 1500/5S/5mA 8.Insulation Resistance:≥100MΩ(Test Voltage 500VDC) 9.Proof Tracking Index(PTI):175V 10.Ambient temperature:85° 2.60[0.102] 5.00[0.200] 9.50[0.370]±0.10 2-Ø2.20[0.090] 5.40[0.213] 14.70[0.580] 140.00[5.510]±5.0 2-15.00[0.590] Hook welding is adopted Waterproof grade:IP67 Circuit diagram 2-Ø2.50[0.100] 1 2 24AWG RED 24AWG Black C NO 2P White X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED units: tolerance: X.X X.XX X.XXX PA66 seal ring Silica gel base 3 Brass+PA66 4 According to sincerity POM 5 Contact moving plate C5191+AgNi10 6 Strut SUS301-H DSND DATE SCALE: N/A MODEL TYPE: mm DWN DATE VIEW: ±0.2mm ±0.1mm ±0.05mm CHKD DATE UNIT: mm/in APPD DATE UNSPECIFIED TOLERANCES www.helloxkb.cn Rubber shell DWG NO.: SIZE: A4 XKB INDUSTRIAL PRECISION CO.,LIMITED Microswitch PART NO.: WEIGHT 1.0g DF1-136UWY-3 SHEET 1/1 REVISION A0
DF1-136UWY-3 价格&库存
很抱歉,暂时无法提供与“DF1-136UWY-3”相匹配的价格&库存,您可以联系我们找货
