C37 USB
C37 USB
    OPTICON
    OPTICON - C37 USB - Black USB Barcode CCD Scanner
C37 USB 数据手册
Cabled scanners C37 Barcode CCD scanner Related products OPL7836 • Cabled device • Barcode laser scanner • RS232, Keyboard Wedge, USB OPR2001 • Cabled device • Barcode laser scanner • RS232, Keyboard Wedge, USB • With stand OPR3001 • Cabled device • Barcode laser scanner • RS232, Keyboard Wedge, USB Basic Product Specifications C37_002 Regulatory & Safety • Product compliance: CE, FCC, VCCI, RoHS Operating indicators • Visual: 1 LED (red/green/orange) • Non-visual: Buzzer Enclosed items • Power supply 100-240V/0.5A, 50/60 Hz, 6V/2A (for RS232) Operating keys • Entry options: 1 scan key Communication • RS232: DB9 PTF connector with external power supply • Keyboard Wedge: MiniDIN6 F/M connector • USB: Ver. 1.1, HID/VCP, USB-A connector Models • Interface versions: RS232, Keyboard Wedge, USB • Color versions: Black, White Power • Voltage requirement: 5V ± 10% (Keyboard Wedge and USB), 6V (min. 4.5, max. 6.6V) (RS232) Barcode scanner Optics • Light source: 630 nm red LED • Scan method: CCD linear Sensor 2500 Pixels • Scan rate: 200 scans/sec • Trigger mode: Manual, auto-trigger • Reading pitch angle: -30 to 0°, 0 to +30° • Reading skew angle: -70 to -20°, 20 to +70° • Reading tilt angle: -25 to 0°, 0 to +25° • Curvature: R>15 mm (EAN8), R>20 mm (EAN13) • Min. resolution at PCS 0.9: 0.125 mm / 5 mil • Depth of field: At PCS 0.9, Code 39 0 - 15 mm / 0 - 0.59 in Supported Symbologies • Barcode (1D): JAN/UPC/EAN incl. add on, Codabar/ NW-7, Code 11, Code 39, Code 93, Code 128, GS1-128 (EAN-128), GS1 DataBar (RSS), IATA, Industrial 2of5, Interleaved 2of5, ISBN-ISSM-ISSN, Matrix 2of5, MSI/ Plessey, S-Code, Telepen, Tri-Optic, UK/Plessey • Postal code: Chinese Post, Korean Postal Authority code Durability • Temperature in operation: 0 to 50 °C / 32 to 122 °F • Temperature in storage: -20 to 60 °C / -14 to 140 °F • Humidity in operation: 5 - 95% (non-condensing) • Humidity in storage: 5 - 95% (non-condensing) • Ambient light immunity: Fluoresecent 10,000 lx max, Incandescent 10,000 lx max • Drop test: 1.5 m / 5 ft drop onto concrete surface • Vibration test: 10 - 100 Hz with 2G for 1 hour • Protection rate: IP 42 Physical • Dimensions (w x h x d): 75 x 150 x 53 mm / 2.95 x 5.91 x 2.09 in • Weight body: Ca. 90 g / 3.2 oz (excl. cable) • Case: ABS, Black, White Copyright Opticon. All rights reserved. This information is subject to change without prior notice. For availability, contact your local representative. - The Netherlands: Hoofddorp - France: Issy Les Moulineaux - Germany: Dietzenbach - Italy: Castel Maggiore (BO) - Spain: Valencia - Sweden: Järfälla - United Kingdom: Luton, Bedfordshire - U.S.A.: Renton, WA - Japan: Warabi City - Taiwan: Taipei - P.R.China: Shanghai - Australia: Kariong - Brazil: São Paulo Opticon Sensors Europe B.V European headquarters Opaallaan 35 2132 XV Hoofddorp The Netherlands phone: +31 (0)23-5692700 fax: +31 (0)23-5638266 email: sales@opticon.com internet: www.opticon.com W W W . O P T I C O N . C O M
C37 USB 价格&库存
很抱歉,暂时无法提供与“C37 USB”相匹配的价格&库存,您可以联系我们找货
