CABLE 305M
CABLE 305M
    PHILEX
    PHILEX CABLE - CABLE 305M - WIRE HOOKUP, UL1061, 18AWG, WHITE, 305M
CABLE 305M 数据手册
80°C 300V UL1061 18#(16/0.254TA) SP-1061-18AWG Product Description z z z z z z z z Rated temperature: 80°C Rated voltage : 300 volts Tinned copper conductor PVC Insulation Uniform insulation thickness of wire to ensure easy stripping and cutting Pass UL VW-1 flame test & CSA FT1 Uniform insulation thickness of wire to ensure easy stripping and cutting For use in electronic instrumentation z z z z z z z z Cross Section Cable Construction Conductor Insulation AWG Nom. cross Section Strand construction Stranded diameter (Ref.) Material Average thickness Min. point thickness Outer diameter Cable Specification Test item Max. Conductor DC resistance At 20°C Tensile test at room temp. Aging test Heat shock test 121±1°C 1h 18AWG 0.811mm2 16/0.254TA±0.008mm 1.17mm PVC 0.26mm 0.21mm 1.70±0.03mm Specification 23.3 ohm/km Tensile strength (Mpa) Insulation 10.3 Elongation Insulation 100% Tensile strength Insulation 70% unaged Insulation 65% unaged Elongation No cracks or splits PHILEX HONG KONG CO.,LTD REV.0 80°C 300V UL1061 18#(16/0.254TA) Deformation test 250g 121±1°C 1h Cold bend test -10±1°C 4h Flame test Spark test SP-1061-18AWG REV.0 Max. 50% No cracks or splits Pass UL VW-1 3.0+0.3/-0 (kv) Test method: UL 1581 Remark Any conductors having diameter of any strand less than the specified minimum value accepted if CMA (circular mils area) or conductor resistance specified is not exceed. PHILEX HONG KONG CO.,LTD
CABLE 305M 价格&库存
很抱歉,暂时无法提供与“CABLE 305M”相匹配的价格&库存,您可以联系我们找货
