CANFDNET-400U
CANFDNET-400U
    ZLG(致远电子)
    CANFD总线转以太网模块
CANFDNET-400U 数据手册
CANFDNET-400U 用户手册 User Manual CANFD 总线转以太网模块产品 UM01010101 1.0.00 类别 内容 关键词 CANFD-BUS 报文转发 以太网 摘要 产品使用指南 Data:2019/03/11 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 修订历史 版本 日期 原因 V1.00 2020/05/13 创建文档 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 2 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 目 录 1. 产品简介................................................................................................................... 1 1.1 1.2 产品概述 ................................................................................................................... 1 产品特性 ................................................................................................................... 1 1.2.1 强大的硬件 ....................................................................................................... 1 1.2.2 完善的功能 ....................................................................................................... 1 1.2.3 典型应用 ........................................................................................................... 2 2. 产品规格................................................................................................................... 3 2.1 2.2 2.3 电气参数 ................................................................................................................... 3 工作温度 ................................................................................................................... 3 防护等级 ................................................................................................................... 3 3. 机械尺寸................................................................................................................... 4 4. 产品硬件接口说明................................................................................................... 6 4.1 4.2 4.3 4.4 4.5 4.6 4.7 面板布局 ................................................................................................................... 6 状态指示灯 ............................................................................................................... 6 按键........................................................................................................................... 7 电源接口 ................................................................................................................... 7 CANFD-bus 接口 ..................................................................................................... 7 以太网接口 ............................................................................................................... 9 车载以太网接口 ....................................................................................................... 9 5. 快速使用................................................................................................................. 11 设备连接 ................................................................................................................. 11 软件安装 ................................................................................................................. 11 打开设备配置工具 ................................................................................................. 11 设备搜索 ................................................................................................................. 12 设备基本配置 ......................................................................................................... 13 5.5.1 配置网络参数 ................................................................................................. 13 5.5.2 配置 CAN(FD)通道参数................................................................................ 14 5.5.3 配置 CAN(FD)转以太网参数 ........................................................................ 14 5.5.4 下载配置 ......................................................................................................... 15 5.6 连接 ZCANPRO ..................................................................................................... 16 5.1 5.2 5.3 5.4 5.5 6. 免责声明................................................................................................................. 18 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 1 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 1. 产品简介 产品概述 1.1 CANFDNET-400U 是 广 州 致 远 电 子 有 限 公 司 开 发 的 高 性 能 工 业 级 以 太 网 与 CAN(FD)-bus 的数据转换设备,它内部集成了 4 路 CAN(FD)-bus 接口、1 路 Ethernet 接口, 1 路车载双线以太网接口,自带成熟稳定的 TCP/IP 协议栈,用户利用它可以轻松完成 CAN(FD)-bus 网络和以太网网络的互连互通,进一步拓展 CAN(FD)-bus 网络的范围。 CANFDNET-400U 为工业级产品,可以工作在-40℃~85℃的温度范围内。它具有一路 100M/1000M 自适应以太网接口,一路 10M/100M 车载双线以太网接口,4 路 CAN(FD)口通 信最高波特率为 5Mbps,具有 TCP Server,TCP Client,UDP 等多种工作模式,通过配置软 件用户可以灵活的设定相关配置参数。 产品特性 1.2 1.2.1          1.2.2  强大的硬件 高速双核 A9+FPGA 处理器; 100M/1000M 自适用以太网接口,2KV 电磁隔离; 车载双线以太网,满足 100Base-T1 规范 4 路 CAN(FD)口,2.5kVDC 耐压隔离; 额定供电电压范围 9V~48V 直流; 工作温度:-40℃~85℃; 湿度:5% - 95% RH,无凝露; 坚固的金属外壳,SECC 金属 (1.1 mm); 专为工业环境设计。 完善的功能 CAN(FD)接口功能支持:  支持波特率 40K~5Mbps,波特率可任意设置;  支持不同控制器类型:CAN、CANFD ISO 或 CANFD Non-ISO;  支持软件终端电阻开关;  支持报文过滤功能;  支持毫秒级报文定时发送;  支持总线利用率上报;   报文发送缓冲区可设置,用户可以在实时性与大容量缓冲之间选择最合适的平 衡; 多种工作模式支持:  工作模式:TCP Server、TCP Client、UDP;  支持最多 4 个 TCP Server,每个 Server 最多支持 16 连接;或支持最多 16 个 TCP Client 或 UDP 连接;  每种模式可选择指定 CAN(FD)通道报文、错误报文上传,可灵活应用在各种 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 1 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册    1.2.3           User Manual 场合;  TCP Server/Client 模式连接内设 TCP 保活机制,保证 TCP 连接可靠;  TCP Client 模式下,网络断开后将自动重连,可靠地建立 TCP 连接;  UDP 模式下,支持组播,IP 段等操作,以支持多用户同时控制多个 CAN(FD) 通道;  支持 TCP/IP 协议包括 IP、ARP、ICMP、UDP、DHCP、DNS、TCP;  灵活的 CAN(FD)封包设置,满足用户各种封包需求;  通讯协议开放,并提供二次开发接口函数库(支持 Windows、Linux 平台); 可使用配置工具对工作参数进行配置,并提供二次开发接口函数库(支持 Windows、 Linux 平台) ; 支持车载以太网与以太网的 TCP/UDP 数据转换; 支持本地的系统固件升级。 典型应用 高铁列车运行故障检测与排查 地铁列车运行故障检测与排查 列控系统运行故障检测与排查 风力发电机 CANFD 通讯异常检测 传统汽车与新能源汽车多路 CANFD 通讯记录与故障分析 船舶 CANFD 通讯故障检测与排查 煤矿 CANFD 通讯异常分析 电梯运行故障检测与排查 工程机械运行故障检测与排查 航空航天器及配套设备运行检测与故障排查 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 2 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 2. 产品规格 2.1 电气参数 表 2.1 电气参数 额定值 参数名称 条件 工作电压 功耗 2.2 单位 最小值 典型值 最大值 9 4.2 12 5.1 48 8.6 直流 V W 工作温度 表 2.2 工作温度 额定值 参数名称 工作温度 存储温度 2.3 单位 最小值 典型值 最大值 -40 -40 - 85 85 ℃ ℃ 防护等级 表 2.3 防护等级-静电放电抗扰度试验(IEC61000-4-2) 接口 测试等级 测试电压(KV) 测试结果 备注 电源 Level 4 6 Class A 接触放电 CANFD 总线 Level 4 6 Class A 接触放电 以太网 Level 4 6 Class A 接触放电 按键、指示灯 Level 4 15 Class A 空气放电 表 2.4 防护等级-电快速瞬变脉冲群抗扰度试验(IEC61000-4-4) 接口 测试等级 测试电压(KV) 测试结果 备注 电源 Level 3 2 Class A 容性耦合 CANFD 总 线 Level 3 1 Class B 容性耦合 以太网 Level 3 2 Class A 容性耦合 表 2.5 防护等级-浪涌(冲击)试验(IEC61000-4-5) 接口 电源 CANFD 总 线 以太网 测试等级 测试电压(kV) 测试结果 备注 Level 3 1 Class A 线-线 Level 3 2 Class A 线-地 Level 3 1 Class B 线-线 Level 3 2 Class B 线-地 Level 3 1 Class A 线-线 Level 3 2 Class A 线-地 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 3 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 3. 机械尺寸 机械尺寸如下图所示(单位:mm) 图 3.1 主机尺寸图一 图 3.2 主机尺寸图二 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 4 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 3.3 安装方式 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 5 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 4. 产品硬件接口说明 本节介绍 CANFDDTU-400 系列设备硬件接口信息。 4.1 面板布局 设备面板布局如图 4.1 所示。 图 4.1 面板布局 4.2 状态指示灯 表 4.1 标识 功能 PWR 电源指示灯 SYS LAN0 系统指示灯 以太网指示灯 车载以太网指 LAN1 示灯 LED 状态指示灯 状态 状态描述 闪烁描述 灭 设备未上电 - 红色 设备正常上电 - 绿灯闪烁 系统运行中 红色常亮 设备复位重启中 - 灭 以太网无连接 - 绿色常亮 以太网已连接 - 绿色闪烁 应用有数据收发 200ms 周期闪烁 红色闪烁 收到的数据解析错误 200ms 周期闪烁 灭 以太网无连接 - 绿色常亮 以太网已连接 - 绿色闪烁 应用有数据传输 200ms 周期闪烁- 100ms 周期,亮 2 次 后,等 500ms ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 6 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 CAN0~ CAN3 4.3 User Manual 灭 通道未打开 - CAN 通道指示 绿色常亮 通道已打开 - 灯 绿色闪烁 CAN 通道正常收发数据 200ms 周期闪烁 红色闪烁 CAN 总线出错 200ms 周期闪烁 按键 设备提供了一个按键作为 RST,用于复位设备和恢复出厂设置。 表 4.2 复位按键功能 标识 功能 复位设备(点按) RST/DEF 4.4 设备恢复出厂设置(5s) 电源接口 设备电源输入额定电压为直流 9~48V,外壳标识为“DC 9~48V”。接口的物理形式为 5.08 端子,接口示意图、信号定义、接口规格如表 4.3 表 4.4 表 4.5 所示。 表 4.3 电源接口 类型 示意图 5.08 端子 表 4.4 5.08 端子信号定义 接口类型 功能接口 信号定义 信号描述 5.08 接口 V+ 电源正极 √ V- 电源负极 √ 电源 表 4.5 电源接口规格 额定值 参数名称 工作电压 功耗 4.5 条件 单位 直流 最小值 典型值 最大值 9 12 5.1 48 V W CANFD-bus 接口 设备提供了 4 路隔离 CANFD-Bus 接口。外壳标识为“CAN0” 、 “CAN1”、 “CAN2” 、 “CAN3” 。接口的物理形式为 DB9 端子,接口示意图、信号定义、接口规格如表 4.6 表 4.7 表 4.8 所示。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 7 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 表 4.6 引脚定义 类型 示意图 引脚定义 表 4.7 信号定义 功能接口 CANFD0~CANFD3 信号定义 信号描述 CANFD_L CANFD 数据收发差分反相信号 CANFD_GND CANFD 隔离地 CANFD_H CANFD 数据收发差分正相信号 7 CANFD_FG 屏蔽地 5 NC 不连接 1、4、8、9 表 4.8 最小值 通讯波特率 节点数 隐性电平(逻辑 1) 差分电平 2 3、6 CANFD-Bus 接口规格 参数 显性电平(逻辑 0) 引脚序号 典型值 最大值 单位 bps pcs 3.5 1.5 2.5 2.5 2 0 1M 110 4.5 2 3 3 3.1 0.05 18 +100 5k CANFDH CANFDL CANFDH CANFDL 显性(逻辑 0) 隐性(逻辑 1) 2.75 0.5 2 2 1.2 -0.5 -18 -100 3500 总线引脚最大耐压 总线瞬时电压 隔离电压(直流) V V 图 4.2 高速 CANFD 典型网络连接示意图 CANFD 总线采用平衡传输。ISO11898-2 规定:在高速 CANFD 网络中,需要在网络终 端节点处接入 120Ω终端电阻,用于消除总线上的信号反射,避免信号失真。高速 CANFD 网络拓扑如图 4.2 所示。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 8 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 该设备内置 120Ω终端电阻,可通过 ZCANPRO 中的网络配置工具来配置该终端电阻接 通或断开。详细操作请参照 5.5.2 章节。 注:总线通讯距离、通讯速率与现场应用相关,可根据实际应用和参考相关标准设计。 CANFD-Bus 电缆可以使用普通双绞线、屏蔽双绞线或标准总线通信电缆。远距离通讯时, 终端电阻值需要根据通讯距离以及线缆阻抗和节点数量选择合适值。 4.6 以太网接口 设备提供了 1 路以太网接口,接口物理形式为 RJ45 或 M12 端子(并联关系,PHY 为 一路) ,实现设备与 PC 机间的通讯。该接口 100/1000M 规范,接口示意图、信号定义如表 4.9。 表 4.9 以太网接口示意图 类型 示意图 RJ45 端子 M12 端子 4.7 车载以太网接口 设备提供了 1 路车载以太网接口,满足 OPEN Alliance BroadR-Reach 规范,接口物理形 式为 OPEN 端子,实现车载以太网通讯。该接口满足 10/100M 规范,接口示意图、信号定 义如表 4.10、表 4.11、图 4.3 所示。 表 4.10 车载以太网接口示意图 类型 示意图 5.08 端子 表 4.11 信号定义 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 9 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 功能接口 信号定义 信号描述 User Manual 引脚序号 P LAN1 数据收发差分正相信号 1 N LAN1 数据收发差分反相信号 2 LAN1 图 4.3 车载以太网典型网络连接示意图 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 10 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 5. 快速使用 5.1 设备连接 按照“产品硬件接口说明”章节中的接口说明连接好硬件,给设备上电即可让设备启动 运行。 5.2 软件安装 双击启动“ZCANPRO_Setup_Vxx.xx.xx.exe”ZCANPRO 安装包,按照安装指引安装软 件,安装完成后,启动“ZCANPRO”软件。 5.3 打开设备配置工具 , 启动 ZACNPRO 后会弹出“设备管理”界面如图 5.1 所示,点击右上角的关闭按钮(“x”) 关闭“设备管理” 。 图 5.1 设备管理界面 点击 ZCANPRO 上方工具栏的“工具”选项,在弹出的列表中点击“网络设备配置工 具” ,如图 5.2 所示;打开“网络设备配置工具”如图 5.3 所示。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 11 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 5.2 打开网络设备配置工具 图 5.3 网络设备配置工具 5.4 设备搜索 点击“网络设备配置”工具左上方的“搜索设备”选项,开始搜索网络内的 CANFDNET 设备,等待搜索结束后,在设备列表中会显示连接在网络上的设备。点击具体的设备,可以 在配置工具的右边查看或修改当前设备的配置信息。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 12 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 5.4 网络设备配置工具界面 5.5 设备基本配置 设备在首次使用时需要根据需求,配置对应通道参数、网络参数和 CAN(FD)转以太网 参数。 5.5.1 配置网络参数 CANFDNET 设备在使用“转发以太网”功能时,要求设备和 PC 之间处于同一个网段中, 以确保 TCP/UDP 连接能正常通信。根据需要修改“通用以太网”配置项。 图 5.5 “通用以太网”配置项 1. 配置 DHCP 使能选项: 根据需要决定是否使能 DHCP 自动获取 IP 功能, 使能 DHCP 自动获取 IP 后,需要在网络上有 DHCP 服务器设备才能成功获取 IP 地址等相关信 息。 2. 配置 IP:配置设备的 IP 地址。 3. 配置子网掩码:指明设备 IP 所在的子网。 4. 配置网关:设备的网关地址。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 13 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 5.5.2 配置 CAN(FD)通道参数 CANFDNET 设备有 4 个 CAN(FD)通道,每个通道都需要独立配置。 根据需要修改“CANx 配置”配置项。 图 5.6 CAN 通道配置界面 1. 选择控制器类型:通道设备通道接入总线的协议标准。 2. 选择工作模式:正常模式和只听模式;通道工作在只听模式时,控制器不会往总线 上发送数据(包括应答位) 。 3. 选择波特率:通道工作在 CAN 模式下,只需要配置“仲裁域波特率”即可,按需 选择波特率;通道工作在 CANFD 模式下,需要另外配置“数据域波特率”;当波 特率列表中的选项均不符合需求时,可以使用自定义波特率,在波特率计算器中计 算波特率的参数后,将结果复制到“自定义波特率”配置项中。 4. 选择终端电阻使能:根据总线上的阻抗匹配情况决定是否需要使能终端电阻,使能 终端电阻后,会在总线上并联接入一个 120 欧姆的电阻;接入终端电阻后,会改变 总线上的阻抗情况,如果不清楚是否需要接入,建议不使能。 5.5.3 配置 CAN(FD)转以太网参数 CANFDNET 设备支持 16 路以太网转发配置功能,点击“CAN(FD)转以太网”选项会 弹出“CAN(FD)转以太网”配置界面。 图 5.7 “CAN(FD)转以太网”选项 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 14 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 5.8 “CAN(FD)转以太网”配置界面 1. 配置工作模式:设定设备工作的模式,可以设定“TCP 服务器”、“TCP 客户端” 和“UDP”三种模式。 2. 配置本地端口:设定设备的本地端口,设为 0 时由系统默认分配。 3. 配置目标地址:当工作在 TCP 服务器时,不需要配置目标地址,工作在其他模式 时,目标地址为远程 TCP 服务器或 UDP 的地址。 4. 配置目标端口:当工作在 TCP 服务器时,不需要配置目标端口,工作在其他模式 时,目标地址为远程 TCP 服务器或 UDP 监听的端口号。 5. 使能转发配置:配置完参数后,将当前配置项最左侧的复选框选中即可。 5.5.4 下载配置 修改完配置参数后,在配置项“密码操作”的“当前密码”选项框中输入密码(默认: 88888) 如图 5.9 所示,点击配置参数界面上方的“提交更改”按钮即可将配置下载到设备 中,修改配置成功后,会提示“修改成功”,如图 5.10 所示。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 15 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 5.9 输入设备密码 图 5.10 修改成功提示 5.6 连接 ZCANPRO 退出“网络设备配置工具”后,回到 ZCANPRO 软件,点击上方选项栏中的“设备管 理” ,会进入“设备管理”界面,在“类型”下拉列表中选择“CANFDNET-400U-XXX”, 具体设备需要与 5.5.3 配置 CAN(FD)转以太网参数章节中配置的工作模式相匹配。点击“打 开设备” 。 图 5.11 ZCANPRO 打开设备 打开设备后,点击“启动” ,在启动界面中,按照 5.5.3 配置 CAN(FD)转以太网参数章 节中配置的参数设置后,点击“确认”后,即可按照 ZCANPRO 的使用方法收发 CAN(FD) 数据。 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 16 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 图 5.12 启动设备 ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 17 CANFDNET-400U 高性能四通道 CANFD 总线转以太网转换器用户手册 User Manual 6. 免责声明 本着为用户提供更好服务的原则,广州立功科技股份有限公司(下称“立功科技”)在 本手册中将尽可能地为用户呈现详实、准确的产品信息。但介于本手册的内容具有一定的时 效性,立功科技不能完全保证该文档在任何时段的时效性与适用性。立功科技有权在没有通 知的情况下对本手册上的内容进行更新,恕不另行通知。为了得到最新版本的信息,请尊敬 的用户定时访问立功科技官方网站或者与立功科技工作人员联系。感谢您的包容与支持! ©2019 Guangzhou ZLG Microelectronics Technology Corp.,Ltd. 18
CANFDNET-400U 价格&库存
很抱歉,暂时无法提供与“CANFDNET-400U”相匹配的价格&库存,您可以联系我们找货
