FC114P2/AA-PA907
FC114P2/AA-PA907
    POSITRONIC(宝西)
    POSITRONIC - FC114P2/AA-PA907 - Rectangular Power Contact, PCS Series, Gold Plated Contacts, Copper ...
FC114P2/AA-PA907 数据手册
SCORPION MODULAR POWER, SIGNAL CONNECTORS ■ The most versatile modular power/signal connector on the planet ■ Rated up to 100 amperes per contact plus ability to add signal contacts and a variety of accessories ■ Venting options for improved air cooling ■ Blank modules for greater creepage and clearance for higher voltage needs ■ Unique locking systems for blind mating, float mount and cable connector options THE SCIENCE OF CERTAINTY® M015 Rev A 19/10 an Amphenol company Positronic Scorpion General Information Scorpion brings a unique approach to modular connector design that is only available from Positronic. Scorpion provides the flexibility to configure the connector to meet your specifications. The difference is how Positronic builds the final connector, using our innovative tooling and injection molding process. The result is a Scorpion with solid body and machined contacts, ready to perform. Trust the Scorpion to deliver The Science of Certainty TECH SPECS GENERAL ELECTRICAL Part Number Prefix SP Working Voltage (rms) 100 V to 1000 V Performance Level Industrial Mil/aero Initial Contact Resistance Power Signal 0.2 mΩ*1 5 mΩ Qualifications UL #E49351*1 Contact Current Rating*2 Power Signal Up to 100A*1 3A*3 *1 Partial UL certification only. Contact Technical Sales for specific connector qualifications and for UL status of Hyperboloid contacts. *1 Value established using high conductivity alloy *2 See page 9-10 for temperature rise curves Hyperboloid contacts 0.60 [0.0236] rated *3 to 4A MATERIAL Insulator Material Polyester MECHANICAL Insulator Color Blue Contact Style Flammability Rating UL94 V-0 Fixed Removable Contact Material Copper alloy Female Contact Design Contact Plating Gold flash 0.76μm Au (min) 1.27μm Au (min) Open entry Closed entry Mating Cycles*1 Up to 1000 * Hyperboloid contacts up to 100,000 1 ENVIRONMENTAL Operating Temperature connectpositronic.com 2 -55 to 125ºC THE SCIENCE OF CERTAINTY Positronic Scorpion General Information OVERALL LENGTH (OAL) HOW TO CALCULATE OAL Overall Length (OAL) of a connector is the sum of all the modules’ length. Refer to example below for OAL maximum calculation. See page 6-8 for individual module dimensions. OAL up to 101.00 [3.976] Option from Body Style (pg 6) 2 or 7 Option will be provided according to 1st Body Style chosen Options from Module Layouts (pg 6-8) Y ■ ■ ■ ■ ■ ■ ■ N5 Y U K R E D N X A Scorpion part number can be a maximum of 30 characters. If the connector configuration exceeds this number, please contact Technical Sales for a special part number for your unique requirement. Pinout sequence may not be continuous. Contact Technical Sales for more information. Contact Technical Sales for connector length exceeding 101.00 [3.976]. For connectors offering both fixed solder and crimp contacts, contact Technical Sales. Alignment bar is only available for size 16, size 18, size 22, and hyperboloid Ø0.60 [0.0236] right angle contacts. PosiBand contacts available for size 12, 16, 18 and 22. If there are more than 36 signal pins in one connector, customer will need to take note of the tolerances and alignment issues. PICMG® logo is a registered trademark of the PCI Industrial Computers Manufacturers Group. Positronic is proud to participate in PICMG 3.8. The Scorpion series was chosen as the PICMG 3.8 power connector. THE SCIENCE OF CERTAINTY 3 connectpositronic.com Positronic Scorpion General Information CREATE A PART Mating connector part numbers will have the same letters in the same order. Female connector modules are placed right to left; Male modules are placed left to right when viewed from their mating faces. SP • • 1 UU 1 M Series SP Scorpion Body Style For more information, refer to page 6 Skip this step, if no end modules are required *1 Blind Mating 1 Blind mating, 3.80 [0.150] misalignment 2 Blind mating, 2.00 [0.079] misalignment 7 Blind mating, 2.00 [0.079] misalignment (use for code 0, BS or N in Mounting Options step) 8 Extreme blind mating, up to 3.90 [ 0.154] misalignment, up to 5º angular misalignment Latching System 3 Locking latch, use with female free cable to male cable 4 Locking latch, use with male free cable to female panel mount (wire or PCB) 5 Locking latch, use with female free cable to male panel mount (wire or PCB) Jackscrews 6 For use with jackscrew system *1 If using a backshell on this connector, you must choose N5 in Layout step as first and last modules and skip the Body Style step. Consult Technical Sales for backshell availability for connector without end modules. • Layout For more information, refer to pages 7-8 One or more modules can be selected in this section to create desired contact layout Contact Module U (1) #4 contact R (1) #8 contact S (2) #8 contacts E (2) #12 contacts Y (4) #12 contacts A (1) #16 contacts B (2) #16 contacts C (4) #16 contacts D (8) #16 contacts X (3) #18 contacts Z (6) #18 contacts H (4) #22 contacts J (8) #22 contacts K (12) #22 contacts T (24) #22 contacts • Termination 1 3 38 93 938 4 48 Hyperboloid V (10) Hyperboloid Ø0.60 [0.0236]*1 W (20) Hyperboloid Ø0.60 [0.0236]*1 Keying 0 Keying module Blank module N Spacer/blank N2 Spacer/blank N3 Spacer/blank N4 Spacer/blank N5 Spacer/blank*2 *1 Unique high density contact design with machined pin diameter Ø0.60 [0.0236], *2 for straight and right angle (90°) PCB mount only. Contact Technical Sales for availability of crimp terminal. For a backshell application, use code N5 next to each body style module. For more information, refer to page 8 Wire, order contacts separately*1 Straight solder Straight solder, high conductivity power contacts Straight press-fit, for use with PCB not thinner than 2.29 [0.090]*2 Straight press-fit, for use with PCB not thinner than 2.29 [0.090], high conductivity power contacts*2 Right angle solder Right angle solder, high conductivity power contacts *1 To order contacts separately, see pages 11-13 for contact part numbers. *2 For contacts size 8, 12, 16, 18 and 22 only. Contact Technical Sales for press-fit tooling part number. • Contact Gender M F S Male pin Female socket, open and closed entry signal contacts Female socket, PosiBand closed entry signal contacts connectpositronic.com 4 THE SCIENCE OF CERTAINTY Positronic Scorpion General Information CREATE A PART 0 B 9 1 /AA Environmental Compliance RoHS 5/6 (< 4% lead) /AA Contact Plating Wire, order contacts separately Gold flash over 1.27μm Ni (nominal) over Cu Gold flash over 1.27μm Ni (nominal) over Cu, solder coat tails*1 0.76μm Au (min) over 1.27μm Ni (nominal) over Cu 0.76μm Au (min) over 1.27μm Ni (nominal) over Cu, solder coat tails*1 1.27μm Au (min) over 1.27μm Ni (nominal) over Cu 1.27μm Au (min) over 1.27μm Ni (nominal) over Cu, solder coat tails*1 1 A1 A2 C1 C2 D1 D2 • • *1 Not for use with code 93 or 938 in Termination step. For more information, refer to page 15 0 9 Optional Features Not vented Vented for improved cooling*1 • *1 Not for use with module A in Layout step or with signal contacts. For more information, refer to pages 14-15 Mounting Options & Locking Systems None Angle brackets, clearance hole*1 Angle brackets, boardlocks*1 Angle brackets, threaded*1 Angle brackets, fixed female jackposts*1 Angle brackets, boardlocks, fixed female jackposts*1 Boardlocks*2 Boardlocks, fixed female jackposts Rotating male jackscrews Fixed female jackposts Backshell*3 Backshell, rotating male jackscrews *3 0 B LN BS TB TLN N TN E T W WE • *1 For use with right angle PCB mount using code 4 or 48 in Termination step. *2 For use with straight and right angle PCB mount using code 3, 38, 4 or 48 in Termination step. *3 For use with two N5 spacer modules in Layout step, one spacer will be needed on each end of connector. For more information, refer to page 14 0 1 2 82 821 822 823 824 83 831 832 833 834 None 2-56 threaded insert*1 4-40 threaded insert*2 Float mount, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*3 Float mount, 2-56 threaded insert, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*1 Float mount, 4-40 threaded insert, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*2 Float mount, 2-56 threaded insert, 1.20 [0.047] per side, 1.50 [0.059] panel thickness *4 Float mount, 4-40 threaded insert, 1.20 [0.047] per side, 1.50 [0.059] panel thickness*2 Float mount, 2.30 [0.091] panel thickness*3 Float mount, 2-56 threaded insert, 0.60 [0.024] per side, 2.30 [0.091] panel thickness*1 Float mount, 4-40 threaded insert, 0.60 [0.024] per side, 2.30 [0.091] panel thickness*2 Float mount, 2-56 threaded insert, 1.20 [0.047] per side, 2.30 [0.091] panel thickness*4 Float mount, 4-40 threaded insert, 1.20 [0.047] per side, 2.30 [0.091] panel thickness*2 Panel Mount • *1 For use with code 1 or 2 in Body Style step. *2 For use with code 8 in Body Style step. *3 For use with code 1, 2, 4 or 5 in Body Style step, contact Technical Sales for more floating options. *4 For use with code 1 in Body Style step, contact Technical Sales for more floating options. THE SCIENCE OF CERTAINTY 5 connectpositronic.com Positronic Scorpion General Information BODY STYLE Scale 1:1 For the sake of brevity, only the left side of the end module face view is shown. MALE FEMALE B A B B B A B B B B FEATURE Male 14.60 [0.575] 8.26 [0.325]*1 Blind mating Female 14.60 [0.575] 8.26 [0.325]*1 Blind mating Male 14.60 [0.575] 5.00 [0.197]*1 Blind mating Female 14.60 [0.575] 5.00 [0.197]*1 Blind mating Male 14.60 [0.575] Female 14.60 [0.575] Male 14.60 [0.575] 9.50 [0.374]*1 Blind mating Female 14.60 [0.575] 9.50 [0.374]*1 Blind mating Male 14.60 [0.575] 4.00 [0.157]*1 Latching system Female 14.60 [0.575] 2.80 [0.110]*1 Latching system Male 14.60 [0.575] 4.76 [0.157] Latching system Female 14.60 [0.575] 5.00 [0.197]*1 Latching system Male 14.60 [0.575] 5.00 [0.197]*1 Latching system Female 14.60 [0.575] 2.80 [0.110]*1 Latching system Male 14.60 [0.575] 9.20 [0.362]*1 Jackscrew Female 14.60 [0.575] 9.20 [0.362]*1 Jackscrew Images below are shown for reference only, not shown at 1:1 scale. 4.50 [0.177]*1 Blind mating 4.50 [0.177]*1 Blind mating 8 A B B 3 A B B A B 7 A A A 2 A A GENDER 1 A A CODE 4 A B B 5 A A B A B A 6 *1 Double dimension for OAL. Dimension shown is only for one module, but connector will be provided with two modules, one left and one right. connectpositronic.com 6 THE SCIENCE OF CERTAINTY Positronic Scorpion General Information MODULE LAYOUTS*1 Scale 1:1 *1 All modules shown are male modules. Contact Technical Sales for availability of other modules. CONTACT MODULES CODE SIZE A B CONTACT MODULES B #4 14.60 [0.575] 14.20 [0.559] A R #8 14.60 [0.575] 9.40 [0.370] A S #8 14.60 [0.575] 18.80 [0.740] A E #12 14.60 [0.575] 5.90 [0.232] A Y #12 14.60 [0.575] 11.80 [0.465] A 3.80 [0.150] Z #18 14.60 [0.575] 7.60 [0.299] H #22 14.60 [0.575] 2.70 [0.106] J #22 14.60 [0.575] 5.40 [0.213] K #22 14.60 [0.575] 8.10 [0.319] T #22 14.60 [0.575] 16.20 [0.638] B B A 14.60 [0.575] B B A #18 B B A X B B A B B B A A B U A SIZE CODE A #16 14.60 [0.575] 4.96 [0.195] B #16 14.60 [0.575] 4.96 [0.195] C #16 14.60 [0.575] 9.92 [0.391] A B A B A Contact Size Chart B A #4 D #16 14.60 [0.575] #8 #12 #16 #18 #22 0.60mm 19.84 [0.781] All Positronic products utilize solid, machined contacts. THE SCIENCE OF CERTAINTY 7 connectpositronic.com Positronic Scorpion General Information MODULE LAYOUTS Scale 1:1 HYPERBOLOID MODULES 0.60 [0.0236] A CODE B BLANK MODULES B CODE A B B V A 14.60 [0.575] 4.40 [0.173] A N 14.60 [0.575] 1.62 [0.064] N2 14.60 [0.575] 2.00 [0.079] N3 14.60 [0.575] 3.46 [0.136] N4 14.60 [0.575] 4.88 [0.192] N5 14.60 [0.575] 5.60 [0.220] B B W A 14.60 [0.575] 8.80 [0.346] A B KEYING MODULE A CODE B A B 0 A 14.60 [0.575] 11.80 [0.465] B A Contact Size Chart #4 #8 #12 #16 #18 B #22 0.60mm A All Positronic products utilize solid, machined contacts. CONTACT TERMINATIONS DIMENSIONS For the sake of brevity, only the Male single row size 8 contact modules are shown. Dimension shown apply for all contacts regardless of size and gender. STRAIGHT SOLDER RIGHT ANGLE SOLDER 3.80 [0.150] 3.80 [0.150] PRESS-FIT*1 5.72 [0.225] *1 For information of suggested straight mount PCB hole sizes, please visit our website to download SK 6370. connectpositronic.com 8 THE SCIENCE OF CERTAINTY Positronic Scorpion General Information MATING DIMENSIONS 24.70 [0.972] 25.50 [1.004] 23.20 [0.913] Straight PCB mount (Male) to Panel Mount Crimp (Female) Panel Mount Crimp (Male) to Panel Mount Crimp (Female) Right Angle Board Mount (Male) to Straight PCB Mount (Female) 26.30 [1.035] 22.40 [0.882] 20.10 [0.791] Straight PCB Mount (Male) to Straight PCB Mount (Female) Right Angle Board Mount (Male) to Panel Mount Crimp (Female) Right Angle Board Mount (Male) to Right Angle Board Mount (Female) TEMPERATURE RISE CURVES Tested per IEC Publication 60512-3, Test 5a A A Current (A) B Current (A) Current (A) A B Size 16 Temperature rise (°C) Size 18 Temperature rise (°C) B Size 16 Temperature rise (°C) A Developed with (6) #18 high conductivity contacts seated in code Z modules. A Developed with (2) #16 high conductivity contacts seated in code B modules. A Developed with (8) #16 high conductivity contacts seated in code CC modules. B Developed with (6) #18 standard conductivity contacts seated in code Z modules. B Developed with (2) #16 standard conductivity contacts seated in code B modules. B Developed with (8) #16 standard conductivity contacts seated in code CC modules. THE SCIENCE OF CERTAINTY 9 connectpositronic.com Positronic Scorpion General Information TEMPERATURE RISE CURVES Tested per IEC Publication 60512-3, Test 5a A A B Current (A) Current (A) B Size 12 Temperature rise (°C) Size 12 Temperature rise (°C) A Developed with (2) #12 high conductivity contacts seated in code E modules. A Developed with (10) #12 high conductivity contacts seated in code EYY modules. B Developed with (2) #12 standard conductivity contacts seated in code E modules. B Developed with (10) #12 standard conductivity contacts seated in code EYY modules. A A Current (A) Current (A) B B Size 4 Temperature rise (°C) Size 8 Temperature rise (°C) A Developed with (2) #8 high conductivity contacts seated in code RR modules. A Developed with (2) #4 high conductivity contacts seated in code UU modules. B Developed with (2) #8 standard conductivity contacts seated in code RR modules. B Developed with (2) #4 standard conductivity contacts seated in code UU modules. connectpositronic.com 10 THE SCIENCE OF CERTAINTY Positronic Scorpion General Information CONTACTS*1 *1 Contact Technical Sales for more details on additional contact sizes, material, finishes, and termination styles. SC Standard conductivity contacts HC High conductivity contacts REMOVABLE CRIMP CONTACTS PART NUMBER Size Female Contact Style Gender Stranded AWG [mm2] FC0404N2 SC #4 Female Closed entry #4 [25.0] FC0404N2S HC #4 Female Closed entry #4 [25.0] MC0404N SC #4 Male n/a #4 [25.0] MC0404NS HC #4 Male n/a #4 [25.0] FC4008DS HC #8 Female Closed entry #8 [10.0] FC4008DS-PA781 HC #8 Female Closed entry #8 [10.0] FC4010D SC #8 Female Closed entry #10 [5.3] FC4010D-PA781 SC #8 Female Closed entry #10 [5.3] FC4010DS HC #8 Female Closed entry #10 [5.3] FC4010DS-PA781 HC #8 Female Closed entry #10 [5.3] FC4012D SC #8 Female Closed entry #12 [4.0] FC4012D-PA781 SC #8 Female Closed entry #12 [4.0] FC4012DS HC #8 Female Closed entry #12 [4.0] FC4012DS-PA781 HC #8 Female Closed entry #12 [4.0] FC4016D SC #8 Female Closed entry #16 [1.5] FC4016D-PA781 SC #8 Female Closed entry #16 [1.5] FC4016DS HC #8 Female Closed entry #16 [1.5] FC4016DS-PA781 HC #8 Female Closed entry #16 [1.5] MC4008DS HC #8 Male n/a #8 [10.0] MC4008DS-PA781 HC #8 Male n/a #8 [10.0] MC4010D SC #8 Male n/a #10 [5.3] MC4010D-PA781 SC #8 Male n/a #10 [5.3] MC4010DS HC #8 Male n/a #10 [5.3] MC4010DS-PA781 HC #8 Male n/a #10 [5.3] MC4012D SC #8 Male n/a #12 [4.0] MC4012D-PA781 SC #8 Male n/a #12 [4.0] MC4012DS HC #8 Male n/a #12 [4.0] MC4012DS-PA781 HC #8 Male n/a #12 [4.0] MC4016D SC #8 Male n/a #16 [1.5] MC4016D-PA781 SC #8 Male n/a #16 [1.5] MC4016DS HC #8 Male n/a #16 [1.5] MC4016DS-PA781 HC #8 Male n/a #16 [1.5] FC1210P2 SC #12 Female Closed entry #10 [6.0] FC1210P2S HC #12 Female Closed entry #10 [6.0] FC1212P2 SC #12 Female Closed entry #12 [4.0] FC1212P2S HC #12 Female Closed entry #12 [4.0] Sequential Mate First First First First First First First First First First First First First First MC1210N-PA563 SC #12 Male n/a #10 [6.0] First MC1210NS-PA563 HC #12 Male n/a #10 [6.0] First MC1210N SC #12 Male n/a #10 [6.0] MC1210NS HC #12 Male n/a #10 [6.0] MC1212N-PA563 SC #12 Male n/a #12 [4.0] First MC1212NS-PA563 HC #12 Male n/a #12 [4.0] First MC1212N SC #12 Male n/a #12 [4.0] MC1212NS HC #12 Male n/a #12 [4.0] THE SCIENCE OF CERTAINTY 11 connectpositronic.com Positronic Scorpion General Information CONTACTS*1 *1 Contact Technical Sales for more details on additional contact sizes, material, finishes, and termination styles. SC Standard conductivity contacts HC High conductivity contacts REMOVABLE CRIMP CONTACTS PART NUMBER Size Gender Female Contact Style Stranded AWG [mm2] #12 [4.0] Sequential Mate FC112P2-PA907 SC #16 Female Closed entry FC112P2S-PA907 HC #16 Female Closed entry #12 [4.0] FC114P2-PA907 SC #16 Female Closed entry #14-16 [2.5-1.5] FC116P2-PA907 SC #16 Female Closed entry #16-18-20 [1.5-1.0-0.5] FC120P2-PA907 SC #16 Female Closed entry #20-22-24 [0.5-0.3-0.25] MC112N-133.5 SC #16 Male n/a #12 [4.0] First MC112NS-133.5 HC #16 Male n/a #12 [4.0] First MC112N SC #16 Male n/a #12 [4.0] MC112NS HC #16 Male n/a #12 [4.0] MC114N-133.5 SC #16 Male n/a #14-16 [2.5-1.5] MC114N SC #16 Male n/a #14-16 [2.5-1.5] MC116N-133.5 SC #16 Male n/a #16-18-20 [1.5-1.0-0.5] MC116N SC #16 Male n/a #16-18-20 [1.5-1.0-0.5] MC120N-133.5 SC #16 Male n/a #20-22-24 [0.5-0.3-0.25] MC120N SC #16 Male n/a #20-22-24 [0.5-0.3-0.25] FC1816P2 SC #18 Female Closed entry #16-18 [1.5-1.0] FC1816P2S HC #18 Female Closed entry #16-18 [1.5-1.0] FC1820P2 SC #18 Female Closed entry #20 [0.5] FC1820P2S HC #18 Female Closed entry #20 [0.5] MC1816N-PA561 SC #18 Male n/a #16-18 [1.5-1.0] First MC1816NS-PA561 HC #18 Male n/a #16-18 [1.5-1.0] First MC1816N SC #18 Male n/a #16-18 [1.5-1.0] MC1816NS HC #18 Male n/a #16-18 [1.5-1.0] MC1820N-PA561 SC #18 Male n/a #20 [0.5] First MC1820NS-PA561 HC #18 Male n/a #20 [0.5] First MC1820N SC #18 Male n/a #20 [0.5] MC1820NS HC #18 Male n/a #20 [0.5] FC422P9 SC #22 Female Closed entry #22-26 [0.3-0.12] MC422N9 SC #22 Male n/a #22-26 [0.3-0.12] MC422N9-PA1116*1 SC #22 Male n/a #22-26 [0.3-0.12] First First First *1 For use with alignment insert. NON-REMOVABLE CRIMP CONTACTS PART NUMBER Size Gender Female Contact Style Stranded AWG [mm2] FC422T-PA908 SC #22 Female Closed entry #22-26 [0.3-0.12] MC422T-PA908 SC #22 Male n/a #22-26 [0.3-0.12] NON-REMOVABLE HYPERBOLOID CRIMP CONTACTS PART NUMBER Size Gender Female Contact Style Stranded AWG [mm2] FC3124T SC 0.60 [0.0236] Female Closed entry #24-28 [0.25-0.08] MC3124T SC 0.60 [0.0236] Male n/a #24-28 [0.25-0.08] connectpositronic.com 12 THE SCIENCE OF CERTAINTY Positronic Scorpion General Information CONTACTS*1 *1 Contact Technical Sales for more details on additional contact sizes, material, finishes, and termination styles. SC Standard conductivity contacts HC High conductivity contacts REMOVABLE CONTACTS, BUS BAR INTERNAL THREADS PART NUMBER Size Gender Female Contact Style Thread Scale 1:1 Female SPFIT04M SC #4 Female Closed entry M5 x 0.8 SPFIT04MS HC #4 Female Closed entry M5 x 0.8 SPFIT04S SC #4 Female Closed entry 10-24 UNC 2B SPFIT04SS HC #4 Female Closed entry 10-24 UNC 2B SPMIT04M SC #4 Male n/a M5 x 0.8 SPMIT04MS HC #4 Male n/a M5 x 0.8 SPMIT04S SC #4 Male n/a 10-24 UNC 2B SPMIT04SS HC #4 Male n/a 10-24 UNC 2B Male REMOVABLE CONTACTS, BUS BAR EXTERNAL THREADS PART NUMBER Size Gender Female Contact Style Thread Scale 1:1 Female SPFET04M SC #4 Female Closed entry M5 x 0.8 SPFET04MS HC #4 Female Closed entry M5 x 0.8 SPFET04S SC #4 Female Closed entry 10-24 UNC 2A SPFET04SS HC #4 Female Closed entry 10-24 UNC 2A SPMET04M SC #4 Male n/a M5 x 0.8 SPMET04MS HC #4 Male n/a M5 x 0.8 SPMET04S SC #4 Male n/a 10-24 UNC 2A SPMET04SS HC #4 Male n/a 10-24 UNC 2A Male REMOVABLE CONTACTS, RIGHT ANGLE THREAD FOR RING TERMINAL PART NUMBER Size Gender Female Contact Style Thread Stranded AWG [mm2] SPFRA04M SC #4 Female Closed entry M5 x 0.8 #10 [5.3] SPFRA04MS HC #4 Female Closed entry M5 x 0.8 #10 [5.3] SPFRA04S SC #4 Female Closed entry 10-24 UNC 2B #10 [5.3] SPFRA04SS HC #4 Female Closed entry 10-24 UNC 2B #10 [5.3] SPMRA04M SC #4 Male n/a M5 x 0.8 #10 [5.3] SPMRA04MS HC #4 Male n/a M5 x 0.8 #10 [5.3] SPMRA04S SC #4 Male n/a 10-24 UNC 2B #10 [5.3] SPMRA04SS HC #4 Male n/a 10-24 UNC 2B #10 [5.3] Scale 1:1 Female Male THE SCIENCE OF CERTAINTY 13 connectpositronic.com Positronic Scorpion Accessories ACCESSORIES PCB MOUNT B BS LN Angle brackets, clearance hole*1 Angle brackets, threaded*1 Angle brackets, boardlocks*1 *1 For use with right angle PCB mount using code 4 or 48 in Termination step. N *2 For use with straight and right angle PCB mount using code 3, 38, 4 or 48 in Termination step. Boardlocks*2 CODE MATERIALS B, BS, LN Brass with tin plate N Copper alloy with tin plate PANEL MOUNT 1 2-56 threaded insert*1 2 4-40 threaded insert*2 82 Float mount, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*3 823 Float mount, 2-56 threaded insert, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*1 Float mount, 2-56 threaded insert, 1.20 [0.047] per side, 1.50 [0.059] panel thickness *4 831 833 Float mount, 2-56 threaded insert, 0.60 [0.024] per side, 2.30 [0.091] panel thickness*1 Float mount, 2-56 threaded insert, 1.20 [0.047] per side, 2.30 [0.091] panel thickness*4 822 824 Float mount, 4-40 threaded insert, 0.60 [0.024] per side, 1.50 [0.059] panel thickness*2 Float mount, 4-40 threaded insert, 1.20 [0.047] per side, 1.50 [0.059] panel thickness*2 832 834 Float mount, 4-40 threaded insert, 0.60 [0.024] per side, 2.30 [0.091] panel thickness*2 Float mount, 4-40 threaded insert, 1.20 [0.047] per side, 2.30 [0.091] panel thickness*2 *1 For use with code 1 or 2 in Body Style step. *2 For use with code 8 in Body Style step. *3 For use with code 1, 2, 4 or 5 in Body Style step, contact Technical Sales for more floating options. *4 For use with code 1 in Body Style step, contact Technical Sales for more floating options. 83 CODE Float mount, 2.30 [0.091] panel thickness*3 connectpositronic.com 821 MATERIALS 1, 2 Brass 82, 83, 821, 822, 823, 824, 831, 832, 833, 834 Steel with zinc plate 14 THE SCIENCE OF CERTAINTY Positronic Scorpion Accessories ACCESSORIES JACKPOST/JACKSCREW SYSTEMS TB TLN Angle brackets, fixed female jackposts*1 Angle brackets, boardlocks, fixed female jackposts*1 TN Boardlocks, fixed female jackposts *1 For use with right angle PCB mount using code 4 or 48 in Termination step. E T Rotating male jackscrews Fixed female jackposts MATERIALS BACKSHELL Screw Steel with zinc plate Jackpost, hex nut and lock washer Stainless steel, passivated Knobs Aluminum, yellow anodized VENTING FEATURES W WE Backshell*1 Backshell, rotating male jackscrews*1 Venting feature is a outlet hole enabling air cooling onto a power contact. In compliance with UL 1977, section 10.2 accessibility of live parts. 0 Not vented 9 *1 For use with two N5 spacer modules in Layout step, one spacer will be needed on each end of connector. Vented for improved cooling*1 MATERIALS Backshell Glass-filled polyester, UL94 V-0, blue Screws Steel, zinc plate with chromate seal Cable clamp Steel with nickel plate Cable clamp screws Brass, zinc plate with chromate seal *1 Not for use with module A in Layout step or with signal contacts. THE SCIENCE OF CERTAINTY 15 connectpositronic.com Positronic Scorpion Online See connectpositronic.com/Scorpion for all other Scorpion-related information including: ✔ ✔ ✔ ✔ ✔ Footprints Tooling Product updates Detailed dimensions 2D/3D drawings All dimensional tolerances are ± 0.38 [0.015], unless otherwise specified: ±0.03 mm [0.001 inches] for male contact mating diameters; ±0.08 mm [0.003 inches] for contact termination diameters; ±0.13 mm [0.005 inches] for all other diameters; ±0.38 mm [0.015 inches] for all other dimensions. Dimensions are in millimeter [inches]. All dimensions are subject to change. Product pictures may not be identical in appearance to actual production parts. Information in this catalog is proprietary to Positronic and its subsidiaries. Positronic believes the data contained herein to be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in whole or in part. Products described within this catalog may be protected by one or more of the following US patents: #4,900,261* #6,835,079 * #5,255,580 #7,115,002 Patented in Canada, 1992 The following trademarks are owned by Positronic Industries, Inc.: Positronic Industries, Inc.®, Positronic®, Connector Excellence®, P+ logo®, PosiBand®, PosiShop®, Optik-D™, and The Science of Certainty®. The color blue as it appears on various connectors is a trademark of Positronic Industries, Inc., Registered in U.S. Patent and Trademark Office. #5,329,697 #8,944,697 #6,260,268 #9,304,263 Other patents pending Federal Supply Code for Manufacturers Positronic Industries: 28198 Positronic Industries SAS: FA7Y0 Positronic Asia PTE LTD: QB952 Positronic | Americas Positronic | Europe Positronic | Asia Sales Offices 423 N Campbell Ave 46 route d’Engachies 3014A Ubi Rd 1 #07-01 Positronic has local sales Springfield MO 65806 USA F-32020 Auch Cedex 9 France Singapore 408703 representation all over the world. +1 800 641 4054 +33 5 6263 4491 +65 6842 1419 For the nearest sales office visit info@connectpositronic.com contact@connectpositronic.com singapore@connectpositronic.com www.connectpositronic.com/sales connectpositronic.com THE SCIENCE OF CERTAINTY
FC114P2/AA-PA907 价格&库存
很抱歉,暂时无法提供与“FC114P2/AA-PA907”相匹配的价格&库存,您可以联系我们找货
