DF04M3N/AA
DF04M3N/AA
    POSITRONIC(宝西)
    POSITRONIC - DF04M3N/AA - Rectangular Power Connector, 4 Contacts, DF Series, PCB Mount, Through Hol...
DF04M3N/AA 数据手册
DRAGONFLY HIGH DENSITY POWER & SIGNAL ■ Cost effective high density power & signal solution ■ Current rating up to 20A per contact ■ Integral locking latch mechanism THE SCIENCE OF CERTAINTY® M012 20/06 Positronic Dragonfly General Information Dragonfly connectors are designed for staging a with versatile combination of power and signal solutions in a compact design. Dragonfly series also offers PCB mount, panel mount and cable connections in a small form factor design utilizing high-reliability, high-retention and high cycle life precision machined contacts. Trust the Dragnfly to deliver The Science of Certainty in cost-sensitive, power and signal applications. TECH SPECS GENERAL MECHANICAL Part Number Prefix DF Performance Level Industrial Qualifications UL Contact Style Fixed Removable Contact Termination Crimp Contact Straight solder Straight press-fit Right angle solder Female Contact Design Signal Power Open entry Closed entry Mating Cycles Open entry #20 Closed entry #16 Closed entry*1 500 1000 10,000 MATERIAL Insulator Material Nylon Insulator Color Green Black Flammability Rating UL 94V-0 Contact Material Copper alloy Contact Plating Gold flash *1 See chart on page 3 ENVIRONIMENTAL ELECTRICAL Operating Temperature Working Voltage (rms) Signal Power 333 V 500 V Initial Contact Resistance Signal Power*1 5 mΩ 3 mΩ Contact Current Rating Signal*1 Power up to 7.5 A up to 20 A -55 to 125ºC *1 Values established using standard conductivity alloy To download detailed product information, visit www.connectpositronic.com/Dragonfly/ProductSpecs connectpositronic.com 1 THE SCIENCE OF CERTAINTY Positronic Dragonfly General Information CONTACT LAYOUTS Scale 1:1 Contact Size Chart #16 03 04 07 10 16 #20 #22 All Positronic products utilize solid, machined contacts. DIMENSIONS For the sake of brevity, only basic dimensions of the free cable male is shown here. Full dimensional detail is available in the respective product drawings. C LAYOUT Termination A B C 03 Cable Connector 26.20 [1.031] 7.20 [.283] 28.00 [1.102] 04 Cable Connector 26.20 [1.032] 7.20 [.283] 17.80 [.701] 07, 10 and 16 Cable Connector 23.00 [.906] 11.00 [.433] 25.00 [.984] B A CREATE A PART DF 03 M 0 0 /AA Environmental Compliance Series • • DF /AA Dragonfly RoHS 5/6 (< 4% lead) Accessories *1 Layout • 03 04 07 10 16 0 B BN N P W1 W2 (3) #16 * (2) #16, (2) #22 (7) #16 (10) #20 (16) #22 * only available for code '0' Termination None Angle brackets Angle brackets, boardlocks • Boardlocks *2 Panel mount Backshell, modular opening Backshell, top opening, wide body Contact Gender *1 For suggested straight mount pcb holes sizes of compliant M F *2 For all straight PCB mount versions and DF04 code 4 right press-fit connectors, please consult Technical Sales • Male pin Female socket angle PCB version only) Termination • 0 3 31 4 41 42 93 98 Wire, order contacts separately Straight solder, for version 04, 07, 10 and 16 only * Straight solder, for female connectors of version 10 only Right angle solder, for version 04, 07, 10 and 16 only * Right angle solder, for female connectors of version 10 only Right angle solder, for version 04 male only, uses longer insulator Straight press-fit, for versions 04 and 07 only * Straight press-fit, for versions 10 and 16 only * For code 3, 4 & 93: Size 16 & 20 are closed entry contacts; Size 22 is open entry contacts connectpositronic.com 2 THE SCIENCE OF CERTAINTY Positronic Dragonfly General Information CONTACTS Contact Technical Sales for crimp contact part numbers not listed here. Size Gender Female Contact Style Stranded AWG [mm2] FC112N2/AA #16 Female Closed entry #12 [4.0] MC112N/AA #16 Male n/a #12 [4.0] PART NUMBER FC114N2/AA #16 Female Closed entry #14-16 [2.5-1.5] MC114N/AA #16 Male n/a #14-16 [2.5-1.5] FC116N2/AA #16 Female Closed entry #16-18 [1.5-1.0] MC116N/AA #16 Male n/a #16-18 [1.5-1.0] FC120N2/AA #16 Female Closed entry #20-24 [.5-.25] MC120N/AA #16 Male n/a #20-24 [.5-.25] FC718N7/AA #20 Female Open entry #18 [1.0] FC718N2/AA #20 Female Closed entry #18 [1.0] MC718N/AA #20 Male n/a #18 [1.0] FC720N7/AA #20 Female Open entry #20-24 [.5-.25] FC720N2/AA #20 Female Closed entry #20-24 [.5-.25] MC720N/AA #20 Male n/a #20-24 [.5-.25] FC422N8/AA #22 Female Closed entry #22-26 [.3-.14] MC422N/AA #22 Male n/a #22-28 [.3-.08] TEMPERATURE RISE CURVES & CONTACT MATING PERFORMANCE Tested per IEC Publication 60512-3, Test 5a Tested per IEC Publication 60512-2, Test 2b A B C Current (A) Current (A) Mechanical mating Mating by hand Temperature rise (°C) A Developed with DF04 connectors and AWG 12 wires. B Developed with DF07 connectors and AWG 12 wires. C Developed with DF10 connectors and AWG 18 wires. All power contacts under load. connectpositronic.com Size 16 contact mating performance Above curves developed using DF07 connectors fully populated with size 16 contacts with 10,000 mating cycles. This information is supplied for reference. Contact wear and change in contact resistance may vary from one application to another. Contact Technical Sales to discuss details. 3 THE SCIENCE OF CERTAINTY Positronic Dragonfly Accessories PANEL MOUNT OPTION For male crimp connectors only Panel Cutout B C LAYOUT A B C ØD 03 7.76 [.306] 24.00 [.945] 18.52 [.729] 2.44 [.096] 07, 10, 16 14.40 [.567] 35.00 [1.378] 28.60 [1.126] 3.50 [.138] A 2x ØD Panel Flange Male crimp connector Suggested installation of connector to panel with screws and nuts. (Screws and nuts shown for reference only) Flange Dimensions (for 07, 10 and 16 layouts) 42.00 [1.654] 2.00 [.079] 35.00 [1.378] MATERIAL 2.50 [0.098] 14.10 [.555] 21.00 [.827] Nylon, UL 94V-0 Flange supplied installed Flange 2x ø3.20 [.126] BACKSHELL For version 07, 10 and 16 W1 - Top and side opening Side opening Top opening MATERIALS 16.00 [.630] 25.40 [1.000] 2X Cable openings 11.84 [.466] x 8.00 [.315] (for reference only) 38.20 [1.504] Backshell Polypropylene, UL 94V-0, black Cable clamp Steel with nickel plate Screws Steel with nickel plate or black oxide W2 - Top opening (For larger wire bundle) Cable clamp Backshell MATERIALS 15.90 [.626] 28.50 [1.122] Backshell Top opening 16.50 [.650] x 9.00 [.354] (for reference only) 40.00 [1.575] THE SCIENCE OF CERTAINTY 4 Nylon, UL 94V-0, black Cable clamp Steel with nickel plate Screws Steel with nickel plate or black oxide connectpositronic.com Positronic Dragonfly Online See connectpositronic.com/Dragonfly for all other Dragonfly-related information including: 4 4 4 4 4 Footprints Tooling Product updates Detailed dimensions 2D/3D drawings All dimensional tolerances are ± 0.38 [0.015], unless otherwise specified: ±0.03 mm [0.001 inches] for male contact mating diameters; ±0.08 mm [0.003 inches] for contact termination diameters; ±0.13 mm [0.005 inches] for all other diameters; ±0.38 mm [0.015 inches] for all other dimensions. Dimensions are in millimeter [inches]. All dimensions are subject to change. Product pictures may not be identical in appearance to actual production parts. Information in this catalog is proprietary to Positronic and its subsidiaries. Positronic believes the data contained herein to be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in whole or in part. Products described within this catalog may be protected by one or more of the following US patents: #4,900,261* #6,835,079 * #5,255,580 #7,115,002 Patented in Canada, 1992 #5,329,697 #8,944,697 #6,260,268 #9,304,263 Other patents pending The following trademarks are owned by Positronic Industries, Inc.: Positronic Industries, Inc.®, Positronic®, Connector Excellence®, P+ logo®, PosiBand®, PosiShop®, Optik-D™, and The Science of Certainty®. The color blue as it appears on various connectors is a trademark of Positronic Industries, Inc., Registered in U.S. Patent and Trademark Office. Positronic | Americas Positronic | Europe Positronic | Asia Sales Offices 423 N Campbell Ave 46 route d’Engachies 3014A Ubi Rd 1 #07-01 Positronic has local sales Springfield MO 65806 USA F-32020 Auch Cedex 9 France Singapore 408703 representation all over the world. +1 800 641 4054 +33 5 6263 4491 +65 6842 1419 For the nearest sales office visit info@connectpositronic.com contact@connectpositronic.com singapore@connectpositronic.com www.connectpositronic.com/sales connectpositronic.com THE SCIENCE OF CERTAINTY
DF04M3N/AA 价格&库存
很抱歉,暂时无法提供与“DF04M3N/AA”相匹配的价格&库存,您可以联系我们找货
