D25000ANVL0/AA
D25000ANVL0/AA
    POSITRONIC(宝西)
    POSITRONIC - D25000ANVL0/AA - D Sub Backshell, D Series, DB, 180°, Aluminium Body
D25000ANVL0/AA 数据手册
LIGHTWEIGHT ALUMINUM BACKSHELLS FOR USE WITH D-SUB CONNECTORS Positronic Lightweight Aluminum Backshells ensure highperformance connections and a long life in the field. Built for mission-critical applications, these backshells provide an excellent combination of size, weight, performance and protection. Choose from one of our three standard designs ■ ■ ■ ■ Internal Grounding Wide Aperture Quick Disconnect Lock or Jackscrews All Shell Sizes or a custom solution to meet your needs. Trust Positronic to deliver The Science of Certainty. THE SCIENCE OF CERTAINTY® M019 20/04 Positronic Lightweight Aluminum Backshells GROUND SCREWS SPACIOUS INTERIOR • Sized and spaced for use with 6.35mm [.250 inch] diameter ring terminals • Shape maximizes internal area which facilitates harness assembly • Ground shelf height and ground screw length allow for stacking of ring terminals • No obstruction behind any portion of the connector body allows backshell to be used with Combo-D connectors • Holes are pre-tapped for ease of installation • Ground screws are located outside the exiting wire path to facilitate wire routing • Ground holes are tapped through to the outside which provide for optional external grounding APERTURE / STRAIN RELIEF • Appropriate for high density wire bundles using twisted, shielded pairs • Cable clamps can be “spooned” to provide strain relief for small wire bundle • Wide form factor allows the user to easily meet bend radius requirements LOCKING SYSTEM • Available with jackscrews or quick disconnect locking device THUMB GRIPS • Grip facilitates installation and removal in tight spaces TECH SPECS MATERIAL AND FINISHES ELECTRICAL Backshell & Cable Clamps Aluminum; aluminum with electroless nickel plate; aluminum with yellow anodize; aluminum with yellow chromate conversion. Zinc content is 1% maximum. Range of Operation, Calculated Method Jackscrews & Screws Steel with nickel plate; brass with zinc plate and chromate seal; brass, with 1.27μm min Au over Cu. Stainless steel options available, contact Technical Sales. MECHANICAL Actuation Lock System Steel with nickel plate 2 GHz minimum Ground Screws Can accept up to 6.35mm [.250 inch] diameter ring terminal. Locking System Jackscrews or quick disconnect locking device. ENVIRONMENTAL Operating Temperature connectpositronic.com 2 -55 to 125ºC THE SCIENCE OF CERTAINTY Positronic Talon General Information Positronic Lightweight Aluminum Backshells A AS AL Z Y X STRAIGHT EXIT mm [inches] INTERNAL GROUND SCREWS Shell Size Locking System E, E6, or E7 Y DIMENSION Z DIMENSION WEIGHT (grams) [ounces] *0 Locking System E, E6, or E7 Locking System T2, VL, or V3 Locking System E, E6, or E7 4 1 2 1 2 4 4 2 3 2 3 4 4 3 3 2 4, 5, 6 6 6 4 4 2 1 38.71 [1.524] 30.96 [1.219] 38.72 [1.524] 30.96 [1.219] 32.33 [1.273] 2 47.04 [1.852] 39.29 [1.547] 47.07 [1.852] 39.29 [1.547] 40.64 [1.600] 3 60.76 [2.392] 53.19 [2.094] 60.76 [2.392] 53.19 [2.094] 54.61 [2.150] 4, 6*0 77.22 [3.040] 69.49 [2.736] 77.22 [3.040] 69.49 [2.736]*0 71.12 [2.800] 5 74.83 [2.946] 67.11 [2.642] 74.83 [2.946] 67.11 [2.642] 68.60 [2.701] 1 53.09 [2.090] 50.08 [2.000] 55.84 [2.198] 50.92 [2.005] 35.05 [1.380] 2 53.09 [2.090] 50.08 [2.000] 62.91 [2.477] 59.96 [2.361] 37.85 [1.490] 3 53.09 [2.090] 50.08 [2.000] 62.85 [2.474] 59.96 [2.361] 37.85 [1.490] 4, 5, 6*0 59.44 [2.340] 57.15 [2.250] 74.07 [2.916] 73.17 [2.881] 37.85 [1.490] 1, 2, 3, 4 15.65 [.616] 14.88 [.586] 15.65 [.616] 14.88 [.586] 15.65 [.616] 5 18.47 [.727] 17.70 [.697] 18.47 [.727] 17.70 [.697] 18.47 [.727] *0 20.07 [.790] 19.30 [.760] 20.07 [.790] 19.30 [.760] 20.07 [.790] 1 9.19 [.362] x 12.27 [.483] 9.19 [.362] x 11.51 [.453] 9.19 [.362] x 12.27 [.483] 9.19 [.362] x 11.51 [.453] 8.64 [.340] x 11.98 [.471] 2 17.53 [.690] x 12.27 [.483] 17.53 [.690] x 11.51 [.453] 17.53 [.690] x 12.27 [.483] 17.53 [.690] x 11.51 [.453] 10.21 [.402] x 12.27 [.483]  3 17.53 [.690] x 12.27 [.483]  17.53 [.690] x 11.51 [.453]  17.53 [.690] x 12.27 [.483] 17.53 [.690] x 11.51 [.453] 18.42 [.725] x 12.27 [.483]  4 31.55 [1.242] x 12.27 [.483]    31.55 [1.242] x 11.51 [.453] 31.52 [1.241] x 12.27 [.483]  31.52 [1.241] x 11.51 [.453]  31.52 [1.241] x 12.27 [.483]  5 31.55 [1.242] x 15.09 [.594] 31.55 [1.242] x 14.33 [.564] 31.52 [1.241] x 15.09 [.594] 31.52 [1.241] x 14.33 [.564] 31.44 [1.238] x 15.09 [.594] 6*0 31.55 [1.242] x 16.69 [.657]  31.55 [1.242] x 15.93 [.627] 31.52 [1.241] x 16.69 [.657] 31.52 [1.241] x 15.93 [.627] 31.52 [1.241] x 16.69 [.657] 1 30.54 [1.08]*1 40.50 [1.43]*2 28.03 [0.99]*1 39.11 [1.38]*2 20.55 [0.72]*1 2  37.44 [1.32]*1  45.24 [1.60]*2  37.47 [1.32]*1  50.39 [1.78]*2 27.71 [0.98]*1 3 *1  45.92 [1.62] *2  55.22 [1.95] *1  50.81 [1.79] *2  63.19 [2.23] 33.19 [1.17]*1 4  62.06 [2.19]*1  71.60 [2.53]*2  71.24 [2.51]*1 87.81 [3.10]*2 40.64 [1.43]*1 5 *1  63.94 [2.26] *2  74.00 [2.61] *1  73.56 [2.59] *2  91.80 [3.24] 41.11 [1.45]*1 6*0  68.44 [2.41]*1 69.34 [2.44]*3  78.88 [2.78]*1  91.11 [3.21]*3 44.75 [1.58]*1 1 CONTACT ARRANGEMENT COMPATIBILITY Locking System T2, VL, or V3 4 6 MAX CABLE OPENING STRAIGHT EXIT, LOW-PROFILE 1 *0 X DIMENSION SIDE EXIT Std-D:9, 5W1,2WK2; High-D:15,8W2 Std-D:9, 5W1,2WK2; High-D:15,8W2 Std-D: 9; High-D: 15 2 Std-D:15, 3W3,3WK3,7W2,11W1; High-D:26, 19W1 Std-D:15, 3W3,3WK3,7W2,11W1; High-D:26, 19W1 Std-D: 15; High-D: 26 3 Std-D:25, 5W5,9W4,13W3,17W2,21W1; High-D:44, 15W4 Std-D:25, 5W5,9W4,13W3,17W2,21W1; High-D:44, 15W4 Std-D: 25; High-D: 44 4 Std-D:37, 8W8,13W6,17W5,21WA4,25W3,27W2; High-D:62, 45W2 Std-D:37, 8W8,13W6,17W5,21WA4,25W3,27W2; High-D:62, 45W2 Std-D: 37; High-D: 62 5 Std-D:50, 24W7,36W4,43W2,47W1; High-D:78 Std-D:50, 24W7,36W4,43W2,47W1; High-D:78 Std-D: 50; High-D: 78 6*0 Std-D:46W4; High-D:104 Std-D:46W4; High-D:104 High-D: 104 = VL/V3 option does not apply for Shell size 6. | *1=Weight for 'E' Jackscrew configuration, contact techincal sales for 'E6' and 'E7" | THE SCIENCE OF CERTAINTY 3 *2 = Weight for 'VL' lock lever, contact technical sales for 'T2' and 'V3' | *3 = Weight for 'T2' jackscrew connectpositronic.com Positronic Lightweight Aluminum Backshells CREATE A PART For additional information on accessories listed in Mounting Options, Backshell Style and Locking Systems, see our D-sub Accessories Catalog Contact Technical Sales to include a Lightweight Aluminum Backshell as part of your Positronic connector kit part number. D 9 0 0 0 ASN E 0 /AA Series Environmental Compliance • D • D-Sub /AA Layout Material & Finish per Backshell Style Selection • 9 15 25 37 50 104 RoHS Compliant • Shell size 1 Shell size 2 Shell size 3 Shell size 4 Shell size 5 Shell size 6 0 G Material & Finish per Backshell Style Selection For any standard plating, replaces nickel plated steel hardware with Brass, 0.000050 inch 1.27 µ [0.000050 inch] gold over copper plate Locking Systems • Contact Gender E E6 E7 T2 VL V3 • 0 Termination • 0 Rotating male jackscrews, slotted thumbscrews Rotating male jackscrews/rotating female jackpost Rotating Female Jackpost Fixed female jackposts, washer set Lock lever Lock tabs, use with free cable or front panel mount connectors Mounting Options • Backshells Style • 0 BACKSHELL TYPE A Straight Exit AS Side Exit AL Low Profile 1.1 MATERIAL & FINISH OPTIONS Backshell & Cable Clamp Finish 1.2 Hardware Material & Finish Standard Platings N Nickel Steel with nickel plate C No finish Steel with nickel plate Optional Platings A B *1 Anodize Steel with nickel plate Anodize Brass with zinc plate and chromate seal D *1 No finish Brass with zinc plate and chromate seal I Yellow chromate conversion Steel with nickel plate J *1 Yellow chromate conversion Brass with zinc plate and chromate seal *1 Offered only with T2, E, E6, and E7 locking system options All dimensional tolerances are ± 0.38 [0.015], unless otherwise specified: ±0.03 mm [0.001 inches] for male contact mating diameters; ±0.08 mm [0.003 inches] for contact termination diameters; ±0.13 mm [0.005 inches] for all other diameters; ±0.38 mm [0.015 inches] for all other dimensions. Dimensions are in millimeter [inches]. All dimensions are subject to change. Product pictures may not be identical in appearance to actual production parts. Information in this catalog is proprietary to Positronic and its subsidiaries. Positronic believes the data contained herein to be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in whole or in part. Products described within this catalog may be protected by one or more of the following US patents: #4,900,261* #6,835,079 * The following trademarks are owned by Positronic Industries, Inc.: Positronic Industries, Inc.®, Positronic®, Connector Excellence®, P+ logo®, PosiBand®, PosiShop®, Optik-D™, and The Science of Certainty®. The color blue as it appears on various connectors is a trademark of Positronic Industries, Inc., Registered in U.S. Patent and Trademark Office. #5,255,580 #7,115,002 Patented in Canada, 1992 #5,329,697 #8,944,697 #6,260,268 #9,304,263 Other patents pending Federal Supply Code for Manufacturers Positronic Industries: 28198 Positronic Industries SAS: FA7Y0 Positronic Asia PTE LTD: QB952 Positronic | Americas Positronic | Europe Positronic | Asia Sales Offices 423 N Campbell Ave Springfield MO 65806 USA +1 800 641 4054 info@connectpositronic.com 46 route d’Engachies F-32020 Auch Cedex 9 France +33 5 6263 4491 contact@connectpositronic.com 3014A Ubi Rd 1 #07-01 +65 6842 1419 Singapore 408703 singapore@connectpositronic.com Positronic has local sales representation all over the world. For the nearest sales office visit www.connectpositronic.com/sales connectpositronic.com THE SCIENCE OF CERTAINTY
D25000ANVL0/AA 价格&库存
很抱歉,暂时无法提供与“D25000ANVL0/AA”相匹配的价格&库存,您可以联系我们找货
