D50000J00/AA
D50000J00/AA
    POSITRONIC(宝西)
D50000J00/AA 数据手册
ACCESSORIES FOR USE WITH D-SUB CONNECTORS THE SCIENCE OF CERTAINTY® M016 20/04 TABLE OF CONTENTS Backshells Backshells quick reference guide 1 ALUMINUM BACKSHELLS Positronic builds premium power and signal connectors for a variety of industries. But every product delivers a single outcome: Certainty. Driven by the mission-critical needs of our customers, we’ve gone to school on the subject for over 50 years. We approach it with Material & finish quick reference options A series DIECAST / METAL BACKSHELLS Hardware quick reference options G series H series 2 3-8 9 10-13 14 PLASTIC / COMPOSIT BACKSHELLS Hardware quick reference options J series L series 15 16 16 Z series 17 Y series 18 Locking Systems scientific discipline – honing the fusion of raw Jackscrew systems material, engineering ingenuity, and precision Jackscrew systems coding device Quick disconnect locking system 19 19-20 20 manufacturing to push the next limits of reliability. Mounting Options And with every new project, our curiosity is reignited. How will certainty be achieved in your system, with its own unique demands? The answers have graced the most formidable missions of our time, from the fires of super-sonic flight to the merciless scapes of Mars. WHAT CAN YOU BE CERTAIN ABOUT? • • Rock-solid reliability Clearance hole / float mounts 21 Swaged spacers 21 Swaged spacer with boardlock 22 Swaged locknut 22 Swaged plastic mounting brackets 22 Right angle brackets 23 Boardlocks and Inductors Ferrite inductor bar / beads 24 Boardlocks 24 Other Options Blind mate system 25 • • Maximum design flexibility flexibility Flared connector housing (shell) 25 • • High efficiency, efficiency, low heat performance In-line crimp splice 25 Cul-de-sac style inside wall mount 26 Enclosure wall mount sealing plate 26 Outside wall enclousure mount 26 Interfacial seal / rear grommets 27 Sealing plugs 27 Protective cover 28 EMI/RFI protective cover 28 Machined aluminum mounting plate 29 Other sealed D-Sub connector options 29 • • Responsive, knowledgeable support THE SCIENCE OF CERTAINTY ® Positronic D-Sub Accessories Backshells BACKSHELLS QUICK REFERENCE A AL AS G H J L Y Z TECHNICAL CHARACTERISTICS Backshell Code Material Finish Cable Clamp (Material, finish) Hardware (Material, finish) Unique Attributes Page AN* aluminum nickel aluminum, nickel steel with nickel plate top opening, light weight, EMI 4-5 ALN* aluminum nickel aluminum, nickel steel with nickel plate top opening, light weight, EMI, low profile 8 ASN* aluminum nickel aluminum, nickel steel with nickel plate side opening, light weight, EMI 6-7 zinc, die cast modular opening, EMI/RFI metal 10-13 steel, zinc plate with chromate seal similar to SAE AS85049/48 14 G zinc, die cast H steel J glass-filled polyester, UL94 V-0 steel, nickel plate top opening, for vibration applications 16 L glass-filled polyester, UL94 V-0 steel, nickel plate side opening, for vibration applications 16 Y composite polyester, UL94 V-0 steel, nickel plate for size 50 backshell only. steel with zinc plate and chromate seal or tin plate; stainless steel, passivated. EMI/RFI composite. Attenuation: 40+ decibels. Sizes 50 & 104 only 18 Z composite polyester, UL94 V-0 steel with zinc plate and chromate seal or tin plate; stainless steel, passivated. modular opening, EMI/RFI composite. Attenuation: 40+ decibels. 17 * zinc plate with chromate seal See ‘Material & Finish Options’ chart on page 2 for additional options THE SCIENCE OF CERTAINTY 1 connectpositronic.com Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELL, QUICK REFERENCE A* * AL* AS* See chart below for ‘Material & Finish Options’ MATERIAL & FINISH OPTIONS Code N Backshell & Cable Clamp Finish Nickel Hardware Type Hardware Material & Finish T2 E E6 E7 VL V3 ✓ ✓ ✓ ✓ ✓ ✓ Steel with nickel plate ✓ ✓ Steel with nickel plate OPTIONAL MATERIAL & FINISHES A Anodize ✓ ✓ ✓ ✓ B Anodize ✓ ✓ ✓ ✓ C No finish ✓ ✓ ✓ ✓ D No finish ✓ ✓ ✓ ✓ I Yellow chromate conversion ✓ ✓ ✓ ✓ J Yellow Chromate conversion ✓ ✓ ✓ ✓ Brass with zinc plate and chromate seal ✓ ✓ Steel with nickel plate Brass with zinc plate and chromate seal ✓ ✓ Steel with nickel plate Brass with zinc plate and chromate seal Custom Machined Aluminum Backshells Available! Contact Technical Sales for details. connectpositronic.com 2 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS This product has been designed for use in applications as a lightweight, EMI backshell for D-subminiature connectors. The features of the product are outlined below. Please contact technical sales for pricing and additional options. GROUND SCREWS APERTURE / STRAIN RELIEF • Sized and spaced for use with 6.35mm [.250 inch] diameter ring terminals • Appropriate for high density wire bundles using twisted, shielded pairs • Ground shelf height and ground screw length allow for stacking of ring terminals • Cable clamps can be “spooned” to provide strain relief for small wire bundle • Holes are pre-tapped for ease of installation • Wide form factor allows the user to easily meet bend radius requirements • Ground screws are located outside the exiting wire path to facilitate wire routing • Ground holes are tapped through to the outside which provide for optional external grounding SPACIOUS INTERIOR • Shape maximizes internal area which facilitates harness assembly THUMB GRIP • Grip facilitates installation and removal in tight spaces LOCKING SYSTEM • Available with jackscrews or quick disconnect locking device • No obstructions behind any portion of the connector body allows backshell to be used with Combo-D connectors TECH SPECS ENVIRONIMENTAL MATERIAL AND FINISHES Backshell & Cable Clamps Aluminum; aluminum with electroless nickel plate; aluminum with yellow anodize; aluminum with yellow chromate conversion. Zinc content is 1% maximum. Jackscrews & Screws Steel with nickel plate; brass with zinc plate and chromate seal; brass, with 1.27μm min Au over Cu. Stainless steel options available, contact Technical Sales. Actuation Lock System Operating Temperature WEIGHT CHART *1 Backshell Size D*2000ANVL Ounces [grams] D*2000ANE Ounces [grams] 9 1.43 [40.50] 1.08 [30.54] 15 1.60 [45.24] 1.32 [37.44] 25 1.95 [55.22] 1.62 [45.92] 37 2.53 [71.60] 2.19 [62.06] 50 2.61 [74.00] 2.26 [63.94] 104 n/a 2.41 [68.44] Steel with nickel plate ELECTRICAL Range of Operation, Calculated Method 2 GHz minimum. MECHANICAL Ground Screws Can accept up to 6.35mm [.250 inch] diameter ring terminal. Locking System Jackscrews or quick disconnect locking device THE SCIENCE OF CERTAINTY -55 to 125ºC *1 Contact Technical Sales for weights on T2, E6, E7 and V3 hardware options. *2 Designates backshell size in part number. All hardware in a backshell assembly including cable clamps, screws, etc. 3 connectpositronic.com Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS For use with code E, E6 or E7 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. A Backshell, aluminum, top opening*1 G Nominal cable opening 3.81 [.150] H Cable opening J Cable clamp A backshell shown with E option 2X 2.41 [.095] hex socket B A K C Number of internal grounding screws D E6 shown for reference F E A backshell shown with E6 option E6 shown for reference E6 shown for reference A backshell shown with E7 option PART NUMBER Connector / Contact Arrangement Compatibility Shell Size A B C D E F G H (Min) (Max) J K D9000AN*1E0*2 D9000AN*1E60*2 D9000AN*1E70*2 Std-D: 9 High-D: 15 Combo-D: 5W1, 2WK2 Combo-D High-D: 8W2 1 23.06 [.908] 15.65 [.616] 53.09 [2.090] 45.47 [1.790] 38.71 [1.524] 24.99 [.984] 9.19 [.362] 6.10 [.240]*3 12.27 [.483] 1.27 [.050] 4 D15000AN*1E0*2 D15000AN*1E60*2 D15000AN*1E70*2 Std-D: 15 High-D: 26 Combo-D: 3W3, 3WK3, 7W2, 11W1 Combo-D High-D: 19W1 2 31.39 [1.236] 15.65 [.616] 53.09 [2.090] 45.47 [1.790] 47.04 [1.852] 33.32 [1.312] 17.53 [.690] 8.89 [.350]*3 12.27 [.483] 2.54 [.100] 4 D25000AN*1E0*2 D25000AN*1E60*2 D25000AN*1E70*2 Std-D: 25 High-D: 44 Combo-D: 5W5, 9W4, 13W3, 17W2, 21W1 Combo-D High-D: 15W4 3 42.06 [1.656] 15.65 [.616] 53.09 [2.090] 45.47 [1.790] 60.76 [2.392] 47.04 [1.852] 17.53 [.690] 8.89 [.350]*3 12.27 [.483] 2.54 [.100] 4 D37000AN*1E0*2 D37000AN*1E60*2 D37000AN*1E70*2 Std-D: 37 High-D: 62 Combo-D: 8W8, 13W6, 17W5, 21WA4, 25W3, 27W2 Combo-D High-D: 45W2 4 58.52 [2.304] 15.65 [.616] 59.44 [2.340] 51.82 [2.040] 77.22 [3.040] 63.50 [2.500] 31.55 [1.242] 10.41 [.410]*3 12.27 [.483] 3.30 [.130] 6 D50000AN*1E0*2 D50000AN*1E60*2 D50000AN*1E70*2 Std-D: 50 High-D: 78 Combo-D: 24W7, 36W4, 43W2, 47W1 Combo-D High-D: n/a 5 56.13 [2.210] 18.47 [.727] 59.44 [2.340] 51.82 [2.040] 74.83 [2.946] 61.11 [2.406] 31.55 [1.242] 10.41 [.410]*3 15.09 [.594] 3.30 [.130] 6 Combo-D: 46W4 Combo-D High-D: n/a 6 58.52 [2.304] 20.07 [.790] 59.44 [2.340] 51.82 [2.040] 77.22 [3.040] 63.50 [2.500] 31.55 [1.242] 10.41 [.410]*3 16.69 [.657] 3.30 [.130] 6 D104000AN*1E0*2 Std-D: n/a D104000AN*1E60*2 High-D: 104 D104000AN*1E70*2 *1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2. *2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G) *3 Smaller cable openings may be achieved by inverting one or both cable clamps. connectpositronic.com 4 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS For use with code T2, VL or V3 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. A Backshell, aluminum, top opening*1 G Nominal cable opening 3.81 [.150] H A backshell shown with T2* option Cable opening *also available with polarized fixed jackposts, contact Technical Sales for more information. J Cable clamp A B K C Number of internal grounding screws D A backshell shown with V3* option E *see page 20 for code 'V3' information. A backshell shown with VL* option *see page 20 for code 'VL' information PART NUMBER Connector / Contact Arrangement Compatibility Shell Size A B C D E G H (Min) (Max) J K D9000AN*1T20*2 D9000AN*1V30 D9000AN*1VL0 Std-D: 9 High-D: 15 Combo-D: 5W1, 2WK2 Combo-D High-D: 8W2 1 30.96 [1.219] 14.88 [.586] 50.08 [2.000] 43.18 [1.700] 24.99 [.984] 9.19 [.362] 6.10 [.240]*3 11.51 [.453] 1.14 [.045] 4 D15000AN*1T20*2 D15000AN*1V30 D15000AN*1VL0 Std-D: 15 High-D: 26 Combo-D: 3W3, 3WK3, 7W2, 11W1 Combo-D High-D: 19W1 2 39.29 [1.547] 14.88 [.586] 50.08 [2.000] 43.18 [1.700] 33.32 [1.312] 17.53 [.690] 8.89 [.350]*3 11.51 [0.453] 2.54 [.100] 4 D25000AN*1T20*2 D25000AN*1V30 D25000AN*1VL0 Std-D: 25 High-D: 44 Combo-D: 5W5, 9W4, 13W3, 17W2, 21W1 Combo-D High-D: 15W4 3 53.19 [2.094] 14.88 [.586] 50.08 [2.000] 43.18 [1.700] 47.04 [1.852] 17.53 [.690] 8.89 [.350]*3 11.51 [0.453] 2.54 [.100] 4 D37000AN*1T20*2 D37000AN*1V30 D37000AN*1VL0 Std-D: 37 High-D: 62 Combo-D: 8W8, 13W6, 17W5, 21WA4, 25W3, 27W2 Combo-D High-D: 45W2 4 69.49 [2.736] 14.88 [.586] 57.15 [2.250] 49.53 [1.950] 63.50 [2.500] 31.55 [1.242] 10.41 [.410]*3 11.51 [0.453] 3.30 [.130] 6 D50000AN*1T20*2 D50000AN*1V30 D50000AN*1VL0 Std-D: 50 High-D: 78 Combo-D: 24W7, 36W4, 43W2, 47W1 Combo-D High-D: n/a 5 67.11 [2.642] 17.70 [.697] 57.15 [2.250] 49.53 [1.950] 61.11 [2.406] 31.55 [1.242] 10.41 [.410]*3 14.33 [.564] 3.30 [.130] 6 D104000AN*1T20*2 Std-D: n/a High-D: 104 Combo-D: 46W4 Combo-D High-D: n/a 6 69.49 [2.736] 19.30 [.760] 57.15 [2.250] 49.53 [1.950] 63.50 [2.500] 31.55 [1.242] 10.41 [.410]*3 15.93 [.627] 3.30 [.130] 6 *1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2. *2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G) *3 Smaller cable openings may be achieved by inverting one or both cable clamps. THE SCIENCE OF CERTAINTY 5 connectpositronic.com Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS For use with code E, E6 or E7 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. AS Backshell, aluminum, side opening*1 3.81 [.150] J Cable clamp A AS backshell shown with E option H Cable opening C D K Number of internal grounding screws E6 shown for reference E6 shown for reference F E E6 shown for reference B AS backshell shown with E6 option AS backshell shown with E7 option Connector / Contact Arrangement Compatibility PART NUMBER Shell Size A B C D E F G H (Min) (Max) J K D9000ASN*1E0*2 D9000ASN*1E60*2 D9000ASN*1E70*2 Std-D: 9 High-D: 15 Combo-D: 5W1, 2WK2 Combo-D High-D: 8W2 1 20.01 [.788] 15.65 [.616] 55.84 [2.198] 50.30 [1.980] 38.72 [1.524] 24.99 [.984] 8.64 [.340] 6.10 [.240]*3 12.27 [.483] 1.14 [.045] 1 D15000ASN*1E0*2 D15000ASN*1E60*2 D15000ASN*1E70*2 Std-D: 15 High-D: 26 Combo-D: 3W3, 3WK3, 7W2, 11W1 Combo-D High-D: 19W1 2 28.24 [1.112] 15.65 [.616] 62.91 [2.477] 56.90 [2.240] 47.07 [1.852] 33.32 [1.312] 10.21 [.402] 8.89 [.350]*3 12.27 [.483] 2.54 [.100] 2 D25000ASN*1E0*2 D25000ASN*1E60*2 D25000ASN*1E70*2 Std-D: 25 High-D: 44 Combo-D: 5W5, 9W4, 13W3, 17W2, 21W1 Combo-D High-D: 15W4 3 42.06 [1.656] 15.65 [.616] 62.85 [2.474] 58.17 [2.290] 60.76 [2.392] 47.04 [1.852] 10.21 [.402] 8.89 [.350]*3 12.27 [.483] 2.54 [.100] 3 D37000ASN*1E0*2 D37000ASN*1E60*2 D37000ASN*1E70*2 Std-D: 37 High-D: 62 Combo-D: 8W8, 13W6, 17W5, 21WA4, 25W3, 27W2 Combo-D High-D: 45W2 4 58.52 [2.304] 15.65 [.616] 74.07 [2.916] 68.08 [2.680] 77.22 [3.040] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 12.27 [.483] 3.30 [.130] 4 D50000ASN*1E0*2 D50000ASN*1E60*2 D50000ASN*1E70*2 Std-D: 50 High-D: 78 Combo-D: 24W7, 36W4, 43W2, 47W1 Combo-D High-D: n/a 5 56.13 [2.210] 18.47 [.727] 74.07 [2.916] 68.08 [2.680] 74.83 [2.946] 61.11 [2.406] 31.52 [1.241] 10.41 [.410]*3 15.09 [.594] 3.30 [.130] 4 D104000ASN*1E0*2 D104000ASN*1E60*2 D104000ASN*1E70*2 Std-D: n/a High-D: 104 Combo-D: 46W4 Combo-D High-D: n/a 6 58.52 [2.304] 20.07 [.790] 74.07 [2.916] 68.08 [2.680] 77.22 [3.040] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 16.69 [.657] 3.30 [.130] 4 *1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2. *2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G) *3 Smaller cable openings may be achieved by inverting one or both cable clamps. connectpositronic.com 6 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS For use with code T2, VL or V3 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. AS Backshell, aluminum, side opening*1 3.81 [.150] G Nominal cable opening AS backshell shown with T2 option J H Cable clamp Cable opening K Number of internal grounding screws C D AS backshell hown with V3* option E *see page 20 for code 'V3' information B A AS backshell shown with VL* option *see page 20 for code 'VL' information PART NUMBER Connector / Contact Arrangement Compatibility Shell Size A B C ±0.64 [.025] D E G H (Min) (Max) J K D9000ASN*1T20*2 D9000ASN*1V30 D9000ASN*1VL0 Std-D: 9 High-D: 15 Combo-D: 5W1, 2WK2 Combo-D High-D: 8W2 1 30.96 [1.219] 14.88 [.586] 50.92 [2.005] 48.26 [1.900] 24.99 [.984] 8.64 [.340] 6.10 [.240]*3 11.51 [0.453] 1.14 [.045] 2 D15000ASN*1T20*2 D15000ASN*1V30 D15000ASN*1VL0 Std-D: 15 High-D: 26 Combo-D: 3W3, 3WK3, 7W2, 11W1 Combo-D High-D: 19W1 2 39.29 [1.547] 14.88 [.586] 59.96 [2.361] 55.88 [2.200] 33.32 [1.312] 10.21 [.402] 8.89 [.350]*3 11.51 [0.453] 2.54 [.100] 3 D25000ASN*1T20*2 D25000ASN*1V30 D25000ASN*1VL0 Std-D: 25 High-D: 44 Combo-D: 5W5, 9W4, 13W3, 17W2, 21W1 Combo-D High-D: 15W4 3 53.19 [2.094] 14.88 [.586] 59.96 [2.361] 55.88 [2.200] 47.04 [1.852] 10.21 [.402] 8.89 [.350]*3 11.51 [0.453] 2.54 [.100] 3 D37000ASN*1T20*2 D37000ASN*1V30 D37000ASN*1VL0 Std-D: 37 High-D: 62 Combo-D: 8W8, 13W6, 17W5, 21WA4, 25W3, 27W2 Combo-D High-D: 45W2 4 69.49 [2.736] 14.88 [.586] 73.17 [2.881] 69.85 [2.750] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 11.51 [0.453] 3.30 [.130] 4 D50000ASN*1T20*2 D50000ASN*1V30 D50000ASN*1VL0 Std-D: 50 High-D: 78 Combo-D: 24W7, 36W4, 43W2, 47W1 Combo-D High-D: n/a 5 67.11 [2.642] 17.70 [.697] 73.17 [2.881] 69.85 [2.750] 61.11 [2.406] 31.52 [1.241] 10.41 [.410]*3 14.33 [.564] 3.30 [.130] 4 D104000ASN*1T20*2 Std-D: n/a High-D: 104 Combo-D: 46W4 Combo-D High-D: n/a 6 69.49 [2.736] 19.30 [.760] 73.17 [2.881] 69.85 [2.750] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 15.93 [.627] 3.30 [.130] 4 *1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2. *2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G) *3 Smaller cable openings may be achieved by inverting one or both cable clamps. THE SCIENCE OF CERTAINTY 7 connectpositronic.com Positronic D-Sub Accessories Backshells LIGHTWEIGHT ALUMINUM BACKSHELLS For use with code E, E6 or E7 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. AL Backshell, aluminum, top opening*1, low profile G Nominal cable opening 3.81 [.150] H Cable opening AL backshell shown with E option J Cable clamp A C B K Number of internal grounding screws D E6 shown for reference F E6 shown for reference E E6 shown for reference AL backshell shown with E6 option AL backshell shown with E7 option PART NUMBER Connector / Contact Arrangement Compatibility Shell Size A B C D E F G H (Min) (Max) J K D9000ALN*1E0*2 D9000ALN*1E60*2 D9000ALN*1E70*2 Std-D: 9 High-D: 15 1 20.32 [.800] 15.65 [.616] 35.05 [1.380] 27.69 [1.090] 32.33 [1.273] 24.99 [.984] 8.64 [.340] 5.81 [.229]*3 11.98 [0.471] 1.140 [.045] 1 D15000ALN*1E0*2 D15000ALN*1E60*2 D15000ALN*1E70*2 Std-D: 15 High-D: 26 2 28.45 [1.120] 15.65 [.616] 37.85 [1.490] 30.23 [1.190] 40.64 [1.600] 33.32 [1.312] 10.21 [.402] 6.10 [.240]*3 12.27 [.483] 1.140 [.045] 2 D25000ALN*1E0*2 D25000ALN*1E60*2 D25000ALN*1E70*2 Std-D: 25 High-D: 44 3 42.06 [1.656] 15.65 [.616] 37.85 [1.490] 30.23 [1.190] 54.61 [2.150] 47.04 [1.852] 18.42 [.725] 8.89 [.350]*3 12.27 [.483] 2.54 [.100] 2 D37000ALN*1E0*2 D37000ALN*1E60*2 D37000ALN*1E70*2 Std-D: 37 High-D: 62 4 58.52 [2.304] 15.65 [.616] 37.85 [1.490] 30.23 [1.190] 71.12 [2.800] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 12.27 [.483] 3.30 [.130] 2 D50000ALN*1E0*2 D50000ALN*1E60*2 D50000ALN*1E70*2 Std-D: 50 High-D: 78 5 56.13 [2.210] 18.47 [.727] 37.85 [1.490] 30.23 [1.190] 68.60 [2.701] 61.11 [2.406] 31.44 [1.238] 10.41 [.410]*3 15.09 [.594] 3.30 [.130] 2 D104000ALN*1E0*2 D104000ALN*1E60*2 D104000ALN*1E70*2 Std-D: n/a High-D: 104 6 58.52 [2.304] 20.07 [.790] 37.85 [1.490] 30.23 [1.190] 71.12 [2.800] 63.50 [2.500] 31.52 [1.241] 10.41 [.410]*3 16.69 [.657] 3.30 [.130] 2 *1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2. *2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G) *3 Smaller cable openings may be achieved by inverting one or both cable clamps. connectpositronic.com 8 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells DIECAST / METAL BACKSHELL, QUICK REFERENCE H G GA HARDWARE QUICK REFERENCE OPTIONS Backshell Rotating No Hardware Jackscrews Fixed Jackscrews Quick Disconnect Locking System Low Profile Extended Height Adapter Cable Opening EMI / RFI Page ✓ ✓ Modular EMI/RFI 10-13 G ✓ ✓ ✓ ✓ ✓ H ✓ ✓ ✓ ✓ ✓ THE SCIENCE OF CERTAINTY 9 Top 14 connectpositronic.com Positronic D-Sub Accessories Backshells ZINC, DIECAST BACKSHELLS*1 For use with code VL For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. G (Low Profile) G (Extended) Backshell, modular opening, zinc, die cast, EMI/RFI, low profile Backshell, extended height, modular opening, zinc, die cast, EMI/RFI A B A B 12.95 [.510] 12.95 [.510] 40.00 [1.575] 55.00 [2.165] G backshell 'low profile' shown VL shown for reference VL shown for reference VL shown for reference VL shown for reference FEATURES • Automatic rapid locking system keeps connection secure and is easy to unlock using the slide latch when needed. • Gripping shoulders enable trouble-free extraction of the connector assembly, even with tightly packed aligned cable adapters. • Cable adapters are designed with multiple entries and can permit the looping through of cables. Cable entries not used are sealed to maintain EMI/RFI shielding. • Two height options are available, low-profile or an increased height option. PART NUMBER D9000G00 D9000GVL0 D9000G00-1023.2 D9000GVL0-1023.0 D15000G00 D15000GVL0 D15000G00-1023.2 D15000GVL0-1023.0 D25000G00 D25000GVL0 D25000G00-1023.2 D25000GVL0-1023.0 D37000G00 D37000GVL0 D37000G00-1023.2 D37000GVL0-1023.0 D50000G00 D50000GVL0 D50000G00-1023.2 D50000GVL0-1023.0 Shell Size Backshell Height Low Profile Extended A B Cable Exit Option 32.00 [1.260] 14.60 [.575] 2 Side*2 G backshell 'low profile' shown with VL* option *see page 20 for code 'VL' information Cable Opening (Min) (Max) 3.00 [.118] 11.99 [.472] Low Profile 1 Extended G backshell shown with -1023.2 extended option Low Profile 2 39.30 [1.547] 14.60 [.575] 1 Top, 2 Side*3 3.00 [.118] 11.99 [.472] 53.20 [2.094] 14.60 [.575] 1 Top, 2 Side*3 3.00 [.118] 11.99 [.472] 69.50 [2.736] 14.60 [.575] 1 Top, 2 Side*3 3.00 [.118] 11.99 [.472] Extended Low Profile 3 Extended Low Profile 4 Extended G backshell shown with -1023.0 extended and VL* options Low Profile 67.00 [2.638] 5 17.90 [.705] 1 Top, 2 Side*3 5.00 [.197] 14.00 [.551] *see page 20 for code 'VL' information Extended *1 To prevent stripping of the backshell assembly screws, we recommend using pozidriv screwdriver bits available from stock using part number 9535-2-2-0, contact Technical Sales. For the mounting screws, we recommend using a standard phillips head screwdriver bit. *2 These backshells are supplied with one (1) cable clamp set and one (1) opening plug. See page 13 for optional crimp Ferrule system. *3 These backshells are supplied with one (1) cable clamp set and two (2) opening plugs. See page 13 for optional crimp Ferrule system. connectpositronic.com 10 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells ZINC, DIE CAST BACKSHELLS*1 For use with code E For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. G (Low Profile) G (Extended) Backshell, modular opening, zinc, die cast, EMI/RFI, low profile Backshell, extended height, modular opening, zinc, die cast, EMI/RFI D D 12.95 [.510] 12.95 [.510] A A C B 2X 4-40 UNC thread rotating male jackscrews 2X 4-40 UNC thread rotating male jackscrews C B FEATURES G backshell 'low profile' shown with E option • Gripping shoulders enable trouble-free extraction of the connector assembly even with tightly packed aligned backshells. • • Rotating jackscrews offer the most secure mechanical locking of the connector system. • For use with connector shell sizes 3 - 5 are designed with three (3) cable entries and can permit the looping through of cables. Cable entries not used are sealed with supplied metal plugs to maintain EMI/ RFI shielding qualities. Standard height backshells for use with connector shell sizes 1 and 2 are available with a top or side cable exit option. Contact Technical Sales for details. G backshell shown with -1023.5 extended and internal hex jackpost options • Two (2) height options are available, one being a low profile option. An extended height option is offered for use with power conductors and coaxial cable, such as might be used with the Positronic CBD/CBM series connectors. • Grounding to the backshells may be accomplished by fastening wires inside backshell with an M2.5 ­threaded Posidriv head screw. PART NUMBER Shell Size D9000GE0 D9000GE0-1023.50 D9000GE0-1023.5 D9000GE0-1023.49 D15000GE0 D15000GE0-1579.0 Backshell Height Low Profile Extended 35.50 [1.398] Low Profile 1 2 Extended* 2 Extended*2 D25000GE0 2 Extended* D37000GE0 4 Extended*2 D50000GE0 D104000GE0 Extended*2 6 Low Profile 55.00 [2.165] 42.00 [1.654] Low Profile 5 D50000GE0-1023.5 55.00 [2.165] 40.00 [1.575] Low Profile D37000GE0-1023.5 55.00 [2.165] 40.00 [1.575] Low Profile 3 D25000GE0-1023.5 50.50 [1.988] 40.00 [1.575] Low Profile D15000GE0-1023.5 A 57.00 [2.244] 39.62 [1.560] B C D Cable Exit Option Cable Opening (Min) (Max) 3.00 [.118] 11.99 [.472] 3.00 [.118] 11.99 [.472] 1 Top 31.00 [1.220] 25.00 [.984] 14.80 [.582] 1 Side 1 Side 1 Top 1 Top, 1 Side*3 1 Side*3 39.40 [1.551] 33.30 [1.311] 14.80 [.582] 53.20 [2.094] 47.00 [1.850] 14.80 [.582] 1 Top, 2 Side*4 3.00 [.118] 11.99 [.472] 69.50 [2.736] 63.50 [2.500] 14.80 [.582] 1 Top, 2 Side*4 3.00 [.118] 11.99 [.472] 67.00 [2.638] 61.10 [2.406] 17.60 [.692] 1 Top, 2 Side*4 5.00 [.197] 14.00 [.551] 72.01 [2.835] 63.50 [2.500] 19.40 [.764] 1 Top, 2 side*4 5.00 [.197] 14.00 [.551] 1 Top, 1 Side*3 *1 To prevent stripping of the backshell assembly screws, we recommend using Pozidriv screwdriver bits available from stock using part number 9535-2-2-0, contact Technical Sales. Standard height GE backshell use the Pozidriv style jackscrews. *2 The extended height backshells use an internal hex jackscrew. Internal hex jackscrews are available for the standard height, but require an MOS. *3 These backshells are supplied with one (1) cable clamp set and one (1) opening plug. See page 13 for optional crimp Ferrule system. *4 These backshells are supplied with one (1) cable clamp set and two (2) opening plugs. See page 13 for optional crimp Ferrule system. THE SCIENCE OF CERTAINTY 11 connectpositronic.com Positronic D-Sub Accessories Backshells ZINC, DIE CAST ADAPTERS For use with code G backshell For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. GA (Adapter) Backshell adapter, side opening, zinc, die cast, EMI/RFI 17.60 [.693] 30.00 [1.181] GA adapter shown 2X 4-40 UNC thread rotating male jackscrews B A FEATURES • • • • Can be used as a gender changer which provides EMI/RFI protection. • If no connector is inserted into the rear side of the adapter backshell, the opening can be closed with a optional cover plate which can be adapted for use with LED’s, mini-switches, and coaxial connectors. (Optional cover plate to be ordered separately) • • Jackscrew locking system is supplied as a standard for secure mechanical coupling. Allows for internal placement of a printed circuit board between the connectors. Can be used to adapt connectors of one interface standard to another. Used in applications where tapping into the electrical line path between connectors is necessary. A cable exit is provided for this application. Grounding to the backshell may be accomplished by fastening wires inside backshell with an M2.5 t­hreaded Pozidrive head screw. Shell Size A B D9000GA0 1 44.00 [1.733] D15000GA0 2 D25000GA0 D37000GA0 PART NUMBER Cable Opening Optional Cover Plate Optional Cable Opening Plug*2 11.99 [.472] A4589-9-0-0*3 A4596-1-0-0*3 3.00 [.118] 11.99 [.472] A4589-15-0-0*3 A4596-1-0-0*3 47.00 [1.850] 3.00 [.118] 11.99 [.472] A4589-25-0-0*3 A4596-1-0-0*3 63.50 [2.500] 3.00 [.118] 11.99 [.472] A4589-37-0-0*3 A4596-1-0-0*3 (Min) (Max) 25.00 [0.984] 3.00 [.118] 52.30 [2.059] 33.30 [1.311] 3 66.00 [2.598] 4 82.50 [3.248] *1 To prevent stripping of the backshell assembly screws, we recommend using Pozidriv screwdriver bits available from stock using part number 9535-2-2-0, contact Technical Sales. *2 See page 13 for optional Crimp Ferrule System. *3 Must be purchased separately. connectpositronic.com 12 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells CRIMP FERRULE SYSTEMS For use with code G backshell The crimp ferrule system can be used with all Positronic code “G” backshells and is recommended when maximizing EMI/RFI protection is desired. The crimp ferrule system optimizes the transition of the cable shield into the cable adapter in three ways. • It provides a low impedance connection of the cable shield to the cable adapter which remains constant over time. • The system provides an EMI/RFI tight cable exit point. • The system provides for high mechanical retention of the cable in the cable adapter. Crimp ferrule (top left) and crimp flange (bottom right) APPLICATION INSTRUCTIONS Application of the crimp ferrule system is quite simple. #1 o  nce the cable insulation and shield are cut to the correct dimensions #2 the crimp ferrule is placed over the cable and the crimp flange is inserted between the shield and the conductors #3 the crimp ferrule is now slid over the cable insulation into position over the crimp flange and the crimp is made using Positronic-supplied hand press and die sets #5 #1 #2 #3 #4 this assembly is then terminated to the connector and placed into the cable adapter #5 finally, the cover is placed on the cable adapter and secured using four (4) screws #4 To order the Positronic supplied hand press, request part number 9520-0-0-0 or for hand crimp tool, request part number 9521-3-0-0. To order Positronic-supplied die sets, contact Technical Sales for ordering information, since die sets are customized based on the specific crimp flanges, crimp ferrules and cables used. CRIMP FERRULE / FLANGE CREAT A PART • A4592 *** *** 0 Crimp ferrule A4593 *** *** 0 Crimp flange Basic Series A4592 A4593 Plating 0 Crimp ferrule Crimp flange • Standard plating Diameters*1 • *1 C  ontact Technical Sales for part number completion which is determined by customerrequired cable diameters and type. THE SCIENCE OF CERTAINTY 13 connectpositronic.com Positronic D-Sub Accessories Backshells METAL BACKSHELLS For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. H Backshell, metal, top opening Ø 3.45 [.136] E D F B C H H backshell shown G A Shell Size A B C D (Max) E F G H (Max) D15000H00 2 38.89 [1.531] 12.47 [0.491] 33.32 [1.312] 14.68 [.578] 18.11 [.713] 7.92 [.312] 19.05 [.750] 30.96 [1.219] D25000H00 3 52.78 [2.078] 12.47 [0.491] 47.04 [1.852] 14.68 [.578] 25.40 [1.000] 7.92 [.312] 25.40 [1.000] 38.91 [1.532] D37000H00 4 69.03 [2.718] 12.47 [0.491] 63.50 [2.500] 14.68 [.578] 34.93 [1.375] 7.92 [.312] 25.40 [1.000] 38.91 [1.532] D50000H00 5 66.68 [2.625] 15.27 [.601] 61.11 [2.406] 17.45 [.687] 35.69 [1.405] 10.31 [.406] 28.58 [1.125] 42.09 [1.657] PART NUMBER connectpositronic.com 14 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells PLASTIC / COMPOSITE BACKSHELL, QUICK REFERENCE L J Y Z HARDWARE QUICK REFERENCE OPTIONS Backshell Rotating No Hardware Jackscrews Fixed Jackscrews Quick Disconnect Locking System Low Profile Extended Height Adapter Cable Opening EMI / RFI Page J ✓ ✓ ✓ Top 16 L ✓ ✓ ✓ Side 16 Y ✓ Z ✓ THE SCIENCE OF CERTAINTY ✓ 15 Top EMI/RFI 18 Modular EMI/RFI 17 connectpositronic.com Positronic D-Sub Accessories Backshells PLASTIC BACKSHELLS For use with code VL, V3 and V5 For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. J L Backshell, plastic, top opening Backshell, plastic, side opening Cable Opening Cable Opening B A C A F D B J backshell shown E F J backshell shown with V3* option *see page 20 for code 'V3' information J backshell shown with V5 option *see page 20 for code 'V5' information Shell Size A B C D E F D9000J0*10 D9000L0*10 1 32.05 [1.262] 15.06 [.593] 29.11 [1.146] 38.61 [1.520] 26.16 [1.030] D15000J0*10 D15000L0*10 2 39.40 [1.551] 15.77 [.621] 34.44 [1.356] 48.26 [1.900] D25000J0*10 D25000L0*10 3 54.08 [2.129] 15.77 [.621] 39.70 [1.563] D37000J0*10 D37000L0*10 4 70.66 [2.782] 15.77 [.621] D50000J0*10 D50000L0*10 5 68.28 [2.688] 18.62 [.733] PART NUMBER Cable Opening (Min) (Max) 21.95 [.864] Ø3.43 [.145] Ø7.11 [.280] 31.50 [1.240] 25.96 [1.022] Ø4.06 [.160] Ø6.99 [.275] 63.30 [2.492] 35.05 [1.380] 30.12 [1.186] Ø2.79 [.110] Ø6.99 [.275] 49.94 [1.848] 79.20 [3.188] 42.93 [1.690] 38.25 [1.506] 5.84 X 16.00 [.230] X [.630] 8.89 X 16.00 [.350] X [.630] 49.94 [1.848] 76.58 [3.015] 42.93 [1.690] 38.25 [1.506] 5.84 X 16.00 [.230] X [.630] 10.92 X 16.00 [.430] X [.630] J backshell shown with VL option *see page 20 for code 'VL' information *1 Replace ‘0’ with desired code ‘V3, V5 or VL’ to obtain desired hardware for backshell (e.g. D9000JV30) L backshell shown connectpositronic.com 16 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Backshells COMPOSITE BACKSHELLS For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. Z*1 Z4*1 Backshell, composite, modular opening, rotating male jackscrews Backshell, composite, modular opening, fixed female jackposts Z6 *1 Z7*1 Backshell, composite, modular opening, rotating polarized jackscrews Backshell, composite, modular opening, rotating female jackposts Notes Top cable opening *1 Illustration is shown for Z backshell. The only difference for Z4, Z6 and Z7 backshells will be jackscrew system. *2 Side opening is not available on shell size 5. Z backshell shown with rotating male jackscrews A C Side cable opening*2 B Jackscrew shown for reference Jackscrews shown for reference TYPICAL INSERTS Z4 backshell shown with fixed female jackposts INSERT TREE ASSEMBLY Various inserts are provided to accommodate different cable sizes. (for shell size 1 through 4) Shell Size A B C D9000Z00 D9000Z400 D9000Z600 D9000Z700 1 35.23 [1.387] 49.15 [1.935] D15000Z00 D15000Z400 D15000Z600 D15000Z700 2 43.56 [1.715] D25000Z00 D25000Z400 D25000Z600 D25000Z700 3 D37000Z00 D37000Z400 D37000Z600 D37000Z700 4 D50000Z00 D50000Z400 D50000Z600 D50000Z700 5 PART NUMBER Cable Opening (Min) (Max) 18.80 [.740] 2.54 [.100] 10.16 X 14.48 [.400] X [.570] 49.15 [1.935] 18.74 [.738] 2.54 [.100] 10.16 X 14.48 [.400] X [.570] 57.25 [2.254] 55.88 [2.200] 18.74 [.738] 2.54 [.100] 13.97 X 14.48 [.550] X [.570] 73.74 [2.903] 55.88 [2.200] 18.62 [.733] 2.54 [.100] 13.97 X 14.48 [.550] X [.570] Z6 backshell shown with male and female rotating jackscrews Z7 backshell shown with female rotating jackscrews 71.35 [2.809] THE SCIENCE OF CERTAINTY 68.58 [2.700] 22.74 [.895] 2.54 [.100] Ø16.00 [.630] 17 connectpositronic.com Positronic D-Sub Accessories Backshells COMPOSITE BACKSHELLS For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings. Y (size 50)*1 Y (size 104)*1 Backshell, composite, size 50, top opening, rotating male jackscrews Backshell, composite, size 104, top/side opening, rotating male jackscrews Y6 (size 50)*1 Y6 (size 104)*1 Backshell, composite, size 50, top opening, rotating polarized jackscrews Backshell, composite, size 104, top/side opening, rotating polarized jackscrews Cable clamp opening 5.84 [.230] x 16.00 [.630] min. 16.51 [.650 ] x 16.00 [.630] max. Cable opening positions Ø 3.18 [.125] min. Ø 13.97 [.550] max. Y for size 50 D D C C A A B B Y for size 104 Jackscrews shown for reference Note Jackscrews shown for reference *1 Illustrations shown for Y backshell. The only difference for Y6 backshell will be jackscrew system and ‘B’ dimension. Cable opening insert tree for size 104 backshell Y6 for size 50 Contact Technical Sales for availability of other size backshells PART NUMBER Shell Size A D50000Y00 5 51.94 [2.045] B 38.02 [1.497] D50000Y600 30.08 [1.200] max. D104000Y00 26.04 [1.025] 6 D104000Y600 connectpositronic.com 51.08 [2.011] 25.04 [.986] C D 67.44 [2.655] 19.66 [.774] Y6 for size 104 71.88 [2.830] 21.29 [.838] 18 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Locking Systems JACKSCREW SYSTEM T, T2, T3 or T7 B A E or E3 A B E2 A CODE Description A B T *3 Fixed female jackposts, 4-40 UNC threads*1 11.10 [.437] 6.35 [.250] T2*3 Fixed female jackposts, 4-40 UNC threads*1, washer set 12.70 [.500] 5.03 [.198] T3*3 Fixed female jackposts, 4-40 UNC threads*1, washer set 20.65 [.813] 5.03 [.198] T7*2 *3 Fixed female jackposts, 4-40 UNC threads 10.92 [.430] 4.57 [.180] CODE Description A B E*3 Rotating male jackscrews, 4-40 UNC threads, slotted thumbscrews 16.43 [.647] 11.10 [.437] E3*3 Rotating male jackscrews, 4-40 UNC threads, internal hex, low profile 16.43 [.647] 11.10 [.437] CODE Description A E2*3 Rotating male jackscrews, 4-40 UNC threads, slotted, low profile 6.10 [.240] *1 Internal thread length of T, T2 or T3 jackscrews is 3.05 [.120] nominal. Jackscrew supplied on connectors in combination with other accessories may differ dimensionally, contact Technical Sales for more information. *2 T7 jackscrews supplied on connectors in combination with other accessories may differ dimensionally, contact Technical Sales for more information. *3 T, T2, T3, T7, E, E2 or E3 passivated stainless steel jackscrews available. Contact Technical Sales for ordering information. JACKSCREW SYSTEM - CODING DEVICE (KEYING) E6 *2 T6 *2 Rotating male jackscrews, rotating female jackpost, 4-40 UNC threads*1 Fixed female jackpost, fixed male jackscrew, 4-40 UNC threads Top view of connector Top view of connector A C B C Position 1 for male connector D B D Position 1 for female connector A Position 1 for male connector Position 1 for female connector A B C D A B C D 11.30 [.445] 5.59 [.220] 4.93 [.194] 11.07 [.436] 16.94 [.667] 3.84 [.151] 4.50 [.177] 17.60 [.693] *1 For customer installations of knobs onto jackscrews, recommend set screw torque value of 16 in-oz. Recommend application of thread lock to set screw. *2 T6 or E6 passivated stainless steel options available. Contact Technical Sales for ordering information. THE SCIENCE OF CERTAINTY 19 connectpositronic.com Positronic D-Sub Accessories Locking Systems JACKSCREW SYSTEM - CODING DEVICE (KEYING) OPTIONS UP TO EIGHT CODING DEVICE OPTIONS! Jackscrews can be supplied in configurations to allow for up to four coding device options, as shown in the table. an additional four coding device options can be achieved by reversing the connector genders. Option Male Connector Code (MOS) Female Connector Code (MOS) 1 2 male rotating E *2 2 female fixed T *2 2 2 female rotating E6 *2 (-833.7*3) 2 male fixed T6 *2 (-866.1*3) 3 1 female rotating*1 1 male rotating*1 E6 *2 1 male fixed*1 1 female fixed*1 T6 *2 4*4 1 male rotating*1 1 female rotating*1 E6 *2 (-1827.1*3) 1 female fixed*1 1 male fixed*1 T6 *2 (-1827.0*3) *1 Additional options are achieved by switching male and female genders. *2 For dimensional information see page 19. *3 To achieve keying option required, add MOS suffix ‘-833.7’, ‘-866.1’, ‘-1827.1’ or ‘-1827.0’ to end of final part number. *4 Reverse polarized connector. QUICK DISCONNECT LOCKING SYSTEMS V3 Lock tabs, use with free cable or front panel mount connectors Lock tabs A B C V5 PART NUMBER Shell Size A B C D9/370000V30 1 6.86 [.270] 11.68 [.460] 6.91 [.272] D9/370000V30 2 6.86 [.270] 11.68 [.460] 6.91 [.272] D9/370000V30 3 6.86 [.270] 11.68 [.460] 6.91 [.272] D9/370000V30 4 6.86 [.270] 11.68 [.460] 6.91 [.272] D500000V30 5 6.86 [.270] 14.73 [.580] 6.91 [.272] PART NUMBER Shell Size A B (Max) C D9/370000V50 1 4.32 [.170] 1.57 [.062] 11.81 [.465] D9/370000V50 2 4.32 [.170] 1.57 [.062] 11.81 [.465] D9/370000V50 3 4.32 [.170] 1.57 [.062] 11.81 [.465] D9/370000V50 4 4.32 [.170] 1.57 [.062] 11.81 [.465] D500000V50 5 4.32 [.170] 1.57 [.062] 14.86 [.585] Rear View of Panel Lock tabs, use with rear panel mount connectors C Lock tabs Panel A 1.19 [.047] 7.87 [.310] B Mounting screw removed for clarity VL *1 May be used with front or back mounted locking tabs, see V3 and V5. Actuation lock lever *1 VL Actuation lock lever A B connectpositronic.com C D 20 PART NUMBER Shell Size A B C D (Max) D90000VL0 1 14.73 [.580] 37.08 [1.460] 6.53 [.257] 15.04 [.592] D150000VL0 2 14.73 [.580] 44.96 [1.770] 6.53 [.257] 15.04 [.592] D250000VL0 3 14.73 [.580] 59.94 [2.360] 6.53 [.257] 15.04 [.592] D370000VL0 4 14.73 [.580] 76.58 [3.015] 6.53 [.257] 15.04 [.592] D500000VL0 5 16.13 [.635] 73.66 [2.900] 6.78 [.267] 17.91 [.705] THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Mounting Options CLEARANCE HOLE / FLOAT MOUNTS 0 02 Clearance hole, Ø3.05±0.13 [.120±.005] For non-stainless steel connector housing (shells) Clearance hole, Ø3.91 [.154] Clearance holes, two places Clearance holes, two places 0 F Clearance hole, Ø3.05±0.13 [.120±.005] For stainless steel connector housing (shells) Float mounts Ø3.05±0.25 [.120±.010] 0.81 [.032] Total diametral float Clearance holes, two places Ø 2.18 +0.13/-0.00 [.086 +.005/-.000] clearance holes, two places SWAGED SPACERS C5 C7 P Standoffs, swaged, boardlock, cul-de-sac style, 4-40 threaded hole, 8.89 [.350] Inside wall mount, angle brackets, boardlocks, alignment bar Standoffs, removable, brass 9.91 [.390] 8.89 [.350] Cul-de-sac style swaged spacer A 4-40 UNC threads 4-40 UNC threads S Standoffs, swaged, 4-40 Ø4.75 [.187] A SERIES Termination Code MD, MDX, HDC all ODD 21, 3, 32, 4, 5 SND 2, 3, 32, 36, 42, 5 CBD, CBM, CBDD 2, 21, 3, 35, 36, 37, 4, 5, 55, 57, 7, 75,77, 65, 85 SCBM 0, 2, 3, 35, 36, 37, 5, 55, 57, 65, 7, 75, 77, 85 SCBDD 21, 3, 35, 36, 37, 4, 45, 47, 65, 84 CBD, CBM, CBDD 93 Printed board Internal View of Standoff PCD, PCDD 0.38 [.015] Cul-de-sac style swaged spacer 4-40 UNC threads*1 *1 Non-removable threaded hardware is built and inspected to 0.56 Nm [5in/lbs] or 80 in/oz torque. THE SCIENCE OF CERTAINTY 98 RD, ORD, DD, CBC, CBCD all ODD 0, 1, 2 SND 0, 1, 12 SDD all SCBC, SCBCD all SD all 21 A 5.72 [.225] 6.35 [.250] 6.73 [.265] SERIES Termination Code MD, MDX, ED, HDC all ODD 21, 3, 32, 4, 5 CBD, CBDD, CBM all RD, ORD, DD, CBC, CBCD all ODD 0, 1, 2 SD all A 5.72 [.225] 6.35 [.250] 9.53 [.375] 11.10 [.437] 9.53 [.375] 11.10 [.437] connectpositronic.com Positronic D-Sub Accessories Mounting Options SWAGED SPACER WITH BOARDLOCK S7*1 S6 *1 Standoffs, swaged, 4-40, boardlocks, for use with F ferrite inductor Standoffs, swaged, 4-40, boardlocks Internal View of Standoff Internal View of Standoff Ø4.75 [.187] Ø4.75 [.187] A A 0.38 [.015] 4-40 UNC Threads*2 SERIES Termination Code MD, MDX, HDC 3, 32, 33, 36 ODD 3, 32 SND 3, 32, 36 CBD, CBM, CBDD 3, 35, 36, 37, 65 SCBM 3, 35, 36, 37, 65 SCBDD 3, 35, 36, 37, 65 DD 3, 32 SDD 3, 32 SD 3, 32 0.38 [.015] 4-40 UNC threads*2 A 5.72 [.225] Connector Series Termination Code MD, MDX, HDC, ODD 32, 33 ED, HDC 36 DD 32, 33 A 9.53 [.375] 6.35 [.250] 13.08 [.515] 9.53 [.375] 11.10 [.437] *1 Printed board mounting hole to be Ø3.12±0.08 [.123±.003] for use with boardlocks. *2 Non-removable threaded hardware is built and inspected to 5in/lbs or 80 in/oz torque. SWAGED PLASTIC MOUNTING BRACKETS WITH ALIGNMENT BAR SWAGED LOCKNUT S5 Locknut, swaged, 4-40 1.40 [.055] Non-conductive mounting brackets are necessary in many applications. Internal View of Locknut Locknut insert Ø4.57 [.180] Panel 2.92 [.115] 0.38 [.015] 4-40 UNC threads 2.5 threads in metal, nominal.*1 Contact Technical Sales for more information *1 Non-removable threaded hardware is built and inspected to 5in/lbs or 80 in/oz torque. connectpositronic.com 22 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Mounting Options ANGLE BRACKET*1 R R2*1 R3 R6 *1 Angle brackets, swaged, metal with fixed female jackposts Angle brackets, swaged, metal, alignment bar with fixed female jackposts Angle brackets, swaged, metal, clearance hole, Ø3.05 [.120] Angle brackets, swaged, metal, clearance hole, Ø3.05 [.120], alignment bar 5.72 [.225] 5.72 [.225] Ø 4.75 [.187] Ø 4.75 [.187] 4-40 UNC threads 4-40 UNC threads R4 R7*1 Angle brackets, swaged, metal, 4-40 threaded hole Angle brackets, swaged, metal, 4-40 threaded hole, alignment bar Ø3.05 [.120] clearance hole Ø3.05 [.120] clearance hole 0.38 [.015] Connector housing (shells) Mounting bracket 4-40 UNC Threads R3/R6 has Ø 3.05 [.120] clearance hole. 4-40 UNC threads 4-40 UNC threads R5 R8*1 Angle brackets, swaged, metal, 4-40 locknut Angle brackets, swaged, metal, 4-40 locknut, alignment bar 0.38 [.015] Connector housing (shells) Mounting bracket 4-40 UNC Threads 2.5 threads in metal, nominal. 4-40 UNC threads with locknut Polyester locknut insert 4-40 UNC threads with locknut *1 Contact alignment bar is supplied with R2, R6, R7 and R8 options only. THE SCIENCE OF CERTAINTY 23 connectpositronic.com Positronic D-Sub Accessories Boardlocks FERRITE INDUCTOR BAR / BEADS F Ferrite inductor*1 Q 3.43±0.13 [.135±.005] Ferrite inductor bar*2 Notes *1 This bar option is available for connector layout options 9, 15, 25, and 37. Ferrite beads are used for the other sizes. Contact Technical Sales for ferrite inductor ordering information on those connectors. Ferrite inductor*1, for use with boardlocks and right angle mounting brackets *2 Specify Code F or Q when ordering. F is for ferrite inductor and Q is for ferrite inductor with boardlocks and right angle brackets. FERRITE INDUCTOR AVAILABILITY A 0.25 [0.010] Nominal Ferrite inductor bar*2 L Series A L MD, MDX, HDC 9.53 [.375] 6.10 [.240] ODD 9.53 [.375] 4.19 [.165] DD 13.08 [.515] 4.19 [.165] 33 MD, MDX, HDC 9.53 [.375] 9.27 [.365] 36 ED, HDC 9.53 [.375] 2.57 [.101] 4 MD, MDX - - 5 ODD - - 59 MD - - 6 MD, HDC 9.53 [.375] 9.14 [.360] 32 IMPEDANCE [OHMS] FILTERING CHARACTERISTICS ATTENUATION [dB] Termination Code FREQUENCY BOARDLOCKS For use with code R,R2,R3,R4,R5,R6,R7,and R8 N Boardlocks, for use with angle brackets Typical Performance Evaluation Data Internal View of Boardlock Printed Board Hole Ø 2.79 [.110] Ø Hole Printed board mounting hole to be Ø3.120±0.08 [.123±.003] for use with boardlock. connectpositronic.com Printed board 3.33 [.131] 24 Retention force Newton Lbs. Newton Lbs. 3.05 [.120] 32.25 7-1/4 25.58 5-3/4 3.12 [.123] 25.58 5-3/4 24.47 5-1/2 3.18 [.125] 12.23 2-3/4 11.12 2-1/2 3.25 [.128] 7.78 1-3/4 10.01 2-1/4 3.20 [.126] Plated 7.78 1-3/4 10.01 2-1/4 Mounting bracket Printed board Insertion force THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Other Options BLIND MATE SYSTEM Blind mating guide pins Float mounting plate (MOS -759.0) (MOS -759.1) To obtain blind mating guide pins, add the suffix ‘-759.0’ to the end of the part number. To obtain float mounting plate, add the suffix ‘-759.1’ to the end of the part number. 18.92 [.745] A C B Ø2.84±0.08 [.112±.003] Ø3.05 [.120] hole 0.84 [.033] total diametral float, 0.25 [.010] total axial float Contact Technical Sales for additional ordering information Shell Size A (nominal) B C 1 49.02 [1.93] 17.20 [0.677] 40.28 [1.586] 2 57.35 [2.258] 17.20 [0.677] 48.62 [1.914] 3 71.25 [2.805] 17.20 [0.677] 62.51 [2.461] 4 87.53 [3.446] 17.20 [0.677] 78.79 [3.102] 5 85.14 [3.352] 20.04 [0.789] 76.40 [3.008] 6 87.53 [3.446] 21.59 [.850] 78.79 [3.102] The use of blind mating hardware on D-Sub connectors can create functional challenges within the application and therefore requires additional mechanical design rigor. Be aware that system tolerances must be exact and mating force allowances may need to be higher than expected. Customers should qualify the use of this option in their particular application. FLARED CONNECTOR HOUSING (SHELL) Flared MOS-1503.33 Standard Flared connector housing Flared connector housings provide a more generous misalignment characteristics than standard D-subminiature connector housings. Connector housing for reference Contact Technical Sales for part numbers and detail information. IN-LINE CRIMP SPLICE B L A Contact Technical Sales for crimp tool part number THE SCIENCE OF CERTAINTY PART NUMBER WIRE SIZE AWG / [mm2] L A B PSK43636-*1 20-26 [0.5/0.12] 12.70 [.500] 1.14 [.045] 1.93 [.076] PSK43637-*1 16-20 [1.5/0.5] 14.61 [.575] 1.68 [.066] 2.57 [.101] PSK43638-*1 12-18 [4.0-1.0] 14.66 [.577] 2.46 [.097] 3.81 [.150] *1 To order crimp splice with insulating sleeve, add ‘-W’ suffix to part number. To order without sleeve, add ‘-N’ suffix. 25 connectpositronic.com Positronic D-Sub Accessories Other Options CUL-DE-SAC STYLE INSIDE WALL MOUNT For use with code WD and WDD C7*1 C5 *1 C8*1 Inside wall mount, angle brackets, boardlocks, alignment bar Inside wall mount 3.81 [.150] Inside wall mount, boardlocks 3.81 [.150] 3.81 [.150] 3.30 [.130] 3.30 [.130] 3.30 [.130] Water-tight Sealing Water-tight Sealing Water-tight Sealing 4-40 UNC threads 4-40 UNC threads 4-40 UNC threads ENCLOSURE WALL MOUNT SEALING PLATE For use with code WD and WDD A*1 Inside wall mount sealing plate Enclosure O-ring Enclosure O-ring UNIBODY DESIGN LEGACY DESIGN *1 Sealing plate is mounted to enclosure wall with jackscrews torqued to a value of .20 Nm [1.75 in-lb] minimum, .25 Nm [.2.25 in-lb] maximum. Enclosure mount sealing plate Enclosure mount sealing plate 3.81 [.150] 3.81 [.150] 2.03 [.080] max. 2.03 [.080] max. OUTSIDE WALL ENCLOSURE MOUNT For use sealed D-sub connectors requiring to be mounted to outside of the enclosure C9 Enclosure Outside wall mount, sealing plate*1 O-ring NOTE: Outside wall mount not available in unibody design Fix female jackpost 4-40 UNC threads Enclosure mount sealing plate *1 Sealing plate is mounted to enclosure wall with 3.81 [.150] jackscrews torqued to a value of .20 Nm [1.75 in-lb] minimum, .25 Nm [.2.25 in-lb] maximum. 5.08 [.200] max. practical limit Contact Technical Sales for additional ordering information connectpositronic.com 26 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Other Options INTERFACIAL SEAL Available for male connectors only. Furnished with all male WD and WDD series connectors A Size 25 interfacial seal shown for reference only B Contact Technical Sales for additional ordering information Shell Size Gender A B 1 Male 17.17 [.676] 8.59 [.338] 2 Male 25.40 [1.000] 8.59 [.338] 3 Male 39.37 [1.550] 8.59 [.338] 4 Male 55.57 [2.188] 8.59 [.338] 5 Male 52.78 [2.078] 11.18 [.440] 6 Male 56.17 [2.212] 12.85 [.506] INTERFACIAL SEAL / REAR GROMMENTS For use with EVD series INTERFACIAL SEAL & REAR GROMMET Interfacial seal Rear grommet Layout 9 INTERFACIAL SEAL 0.94 [.037] A 15 B 25 10.41 [.410] A 2.29 [.090] 37 REAR GROMMET B 50 Seal Type A B Interfacial 16.51 [.650] 8.08 [.318] Grommet 18.421 [.725] 9.53 [.375] Interfacial 24.84 [.978] 8.08 [.318] Grommet 26.70 [1.051] 9.53 [.375] Interfacial 38.43 [1.513] 8.08 [.318] 9.53 [.375] Grommet 40.51 [1.595] Interfacial 54.76 [2.156] 8.08 [.318] Grommet 57.07 [2.247] 9.53 [.375] Interfacial 52.27 [2.058] 10.80 [.425] Grommet 54.53 [2.147] 12.45 [.490] SEALING PLUGS For use with EVD series, Order separately, part number A4737-37-0-0 3.48 [.137] 14.16 [.557] ø2.36 [ø.093] ø1.40 [ø.055] THE SCIENCE OF CERTAINTY 27 connectpositronic.com Positronic D-Sub Accessories Other Options PROTECTIVE COVER Cover Without Ears REPLACEMENT PART NUMBERS Shell Size For connectors without fixed female jackscrews Gender Conductive Without Ears Static Dissipative Without Ears With Ears Male A4931-9-0-0 A4931-9-1-0 A4931-9-100-0 Female A4932-9-0-0 A4932-9-1-0 A4932-9-100-0 Male A4931-15-0-0 A4931-15-1-0 A4931-15-100-0 Female A4932-15-0-0 A4932-15-1-0 A4932-15-100-0 Male A4931-25-0-0 A4931-25-1-0 A4931-25-100-0 Female A4932-25-0-0 A4932-25-1-0 A4932-25-100-0 Male A4931-37-0-0 A4931-37-1-0 A4931-37-100-0 Female A4932-37-0-0 A4932-37-1-0 A4932-37-100-0 Male A4931-50-0-0 A4931-50-1-0 A4931-50-100-0 Female A4932-50-0-0 A4932-50-1-0 A4932-50-100-0 Male --- --- A4931-16-100-0 Female --- --- A4932-16-100-0 1 2 3 Cover With Ears For connectors with fixed female jackscrews 4 5 6 EMI/RFI PROTECTIVE COVER For use with code SAD, SADD, SACBM, SND, SDD, SCBM, SCBC, SCBDD and SCBCD EMI/RFI Cover Shell Size A PART NUMBER Mates To Gender PSK633-9MG*1 Female 1 B PSK633-9FG*1 Male PSK633-15MG*1 Female C PSK633-15FG*1 Male PSK633-25MG*1 Female 30.81 [1.213] 12.55 [.494] PSK633-25FG*1 Male PSK633-37MG*1 Female 10.90 [.429] 10.72 [.422] PSK633-37FG*1 Male PSK633-50MG*1 Female 10.82 [.426] PSK633-50FG*1 Male PSK633-104MG*1 Female 10.82 [.426] PSK633-104FG*1 Male 12.55 [.494] 10.90 [.429] 10.82 [.426] 15.37 [.605] 10.90 [.429] 10.82 [.426] 69.32 [2.729] 6 12.55 [.494] 10.90 [.429] 66.93 [2.635] 5 12.55 [.494] 10.90 [.429] 69.32 [2.729] 4 C ±0.25 [.010] 10.72 [.422] 53.04 [2.088] 3 connectpositronic.com B ±0.38 [.015] 39.14 [1.541] 2 *1 A ±0.38 [.015] 16.97 [.668] 10.90 [.429] To order protective cover with code ‘E2’ rotating male screw locks, insert “N” into the last digit of part number. Omit this digit if thread locks are not required. 28 THE SCIENCE OF CERTAINTY Positronic D-Sub Accessories Other Options MACHINED ALUMINUM MOUNTING PLATE With conductive o-ring Fixed female jackscrews Enclosure shown for reference only Panel mount sealing plate Silicone sealant Rear shell Front shell Epoxy sealant O-ring O-ring seal 2.03 [.080] max. panel thickness 3.81 [.150] 4.50 [.177] OTHER SEALED D-SUBMINIATURE CONNECTOR OPTIONS MD Style Connector COMBO-D Style Connector Panel mount sealing plate Silicone sealant Contacts have special water-tight interference fit seal into insulator Female contact Rear shell Contacts are sealed to insulator with epoxy sealant Front shell ODD Style Connector Silicone sealant Female contact Rear shell Front shell Epoxy sealant O-ring seal COMBO-D Style Connector Silicone sealant Silicone sealant Interfacial seal, contact technical sales for availability of all sizes Silicone sealant Interfacial seal Male contact Male contact Rear shell Front shell Contacts are sealed to insulator with epoxy sealant Rear shell Front shell SEALED STANDARD OR HIGH DENSITY D-SUBMINATURE • Available in both standard density and high density connector variants. • Standard MD or ODD series connectors can be sealed between the connector shell and the connector insert. • Contact technical sales for more information. SEALED COMBINATION D-SUBMINATURE • Could be supplied with mounting plate or without. • Contact technical sales for more information or additional contact configurations. THE SCIENCE OF CERTAINTY 29 connectpositronic.com Positronic Accessories Online See connectpositronic.com/Dsub for all other Dsub-related information including: ✔ ✔ ✔ ✔ ✔ Footprints Tooling Product updates Detailed dimensions 2D/3D drawings All dimensional tolerances are ± 0.38 [0.015], unless otherwise specified. Dimensions are in millimeter [inches]. All dimensions are subject to change. Product pictures may not be identical in appearance to actual production parts. Information in this catalog is proprietary to Positronic and its subsidiaries. Positronic believes the data contained herein to be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in whole or in part. Products described within this catalog may be protected by one or more of the following US patents: #4,900,261* #6,835,079 * #5,255,580 #7,115,002 Patented in Canada, 1992 The following trademarks are owned by Positronic Industries, Inc.: Positronic Industries, Inc.®, Positronic®, Connector Excellence®, P+ logo®, PosiBand®, PosiShop®, Optik-D™, and The Science of Certainty®. The color blue as it appears on various connectors is a trademark of Positronic Industries, Inc., Registered in U.S. Patent and Trademark Office. #5,329,697 #8,944,697 #6,260,268 #9,304,263 Other patents pending Federal Supply Code for Manufacturers Positronic Industries: 28198 Positronic Industries SAS: FA7Y0 Positronic Asia PTE LTD: QB952 Positronic | Americas Positronic | Europe Positronic | Asia Sales Offices 423 N Campbell Ave 46 route d’Engachies 3014A Ubi Rd 1 #07-01 Positronic has local sales Springfield MO 65806 USA F-32020 Auch Cedex 9 France +65 6842 1419 representation all over the world. +1 800 641 4054 +33 5 6263 4491 Singapore 408703 For the nearest sales office visit info@connectpositronic.com contact@connectpositronic.com singapore@connectpositronic.com www.connectpositronic.com/sales connectpositronic.com THE SCIENCE OF CERTAINTY
D50000J00/AA 价格&库存
很抱歉,暂时无法提供与“D50000J00/AA”相匹配的价格&库存,您可以联系我们找货
