GF3F1MASCRCE
GF3F1MASCRCE
    POSITRONIC(宝西)
    REC SLIM POWER 3F1M SOD CABLE
GF3F1MASCRCE 数据手册
Utility Connectors GF / GFPL SERIES PROFESSIONAL QUALITY UTILITY CONNECTORS FIXED CONTACT / LOW PROFILE Positronic connectpositronic.com High Reliability Size 20 fixed contacts, 7.5 amperes Low Profile, countersink side mounting holes. Connectors can be “stacked” side by side. Male and female contacts can be configured within individual connectors to provide polarization and coding (keying) options. UL Recognized: Terminations include solder cup, straight and right angle (90°) printed board mount. • UL File # E49351 TECHNICAL CHARACTERISTICS MATERIALS AND FINISHES: Insulator: Glass-filled DAP per ASTMD-5948 Type SDG-F. Gray color is standard. Precision machined copper alloy, gold flash over nickel. Other finishes are available upon request. Fixed Contacts: Locking Systems: Polarization: Mechanical Operations: Open Entry Contacts: Closed Entry Contacts: Straight and right angle (90º) printed board mount - 0.64 mm [0.025 inch] termination diameter. Friction. Gender positioning of contacts. 500 operations per IEC 60512-5. 1,000 operations per IEC 60512-5. MECHANICAL CHARACTERISTICS: ELECTRICAL CHARACTERISTICS: Contacts: Size 20 Fixed: Male contact, 1.02 mm [0.040 inch] mating diameter. Female contact, open entry is standard. “Closed Entry” available on solder cup termination for high reliability applications. Contact Current Rating: Initial Contact Resistance: Flash over Voltage: Test Voltage: Insulation Resistance: Clearance and Creepage: Working Voltage: 44.5 N [10 Ibs.], minimum. CLIMATIC CHARACTERISTICS: Solder cup - 1.17 mm [0.046 inch] hole diameter for 0.5mm2 [20 AWG] wire maximum. Temperature Range: Damp Heat, Steady State: Contact Retention in Connector Insert: Contact Termination : 7.5 amperes, maximum. 0.010 ohms, maximum. 2000 VAC (rms). 1200 VAC (rms). 5 G ohms, minimum. 0.97 mm [0.038 inch], minimum. 300 VAC (rms). -55°C to +125°C. 21 days Visit our web site for the latest catalog updates and supplements at http://www.connectpositronic.com/catalogs DIMENSIONS ARE IN MILLIMETERS [INCHES]. ALL DIMENSIONS ARE SUBJECT TO CHANGE. Catalog C-022 Rev. A1 GF / GFPL SERIES Utility Connectors PROFESSIONAL QUALITY UTILITY CONNECTORS Positronic connectpositronic.com FIXED CONTACT / LOW PROFILE INSULATOR DIMENSIONS MALE OR FEMALE CONTACTS MAY BE POPULATED IN ANY POSITION GF 2-POLE RIGHT PANEL MOUNTED *1 LEFT PANEL MOUNTED *1 3.18 [0.125] 3.18 [0.125] 8.69 [0.342] 4.37 [0.172] 1.57 [0.062] 1.57 [0.062] 4.37 [0.172] 7.14 [0.281] 7.14 [0.281] A 5.54 [0.218] Ø2.36 [Ø0.093] 11.13 [0.438] 5.54 [0.218] A 11.13 [0.438] B B 8.69 [0.342] Panel shown for reference only Panel shown for reference only Ø2.36 [Ø0.093] GF 4-POLE 1 LEFT PANEL MOUNTED *1 RIGHT PANEL MOUNTED * 6.35 [0.250] 6.35 [0.250] 1.57 [0.062] 4.37 [0.172] 7.14 [0.281] 7.14 [0.281] Ø2.36 [Ø0.093] Panel shown for reference only 11.13 [0.438] 5.54 [0.218] B A B 5.54 [0.218] A 11.13 [0.438] D 8.69 [0.342] 1.57 [0.062] C 3.18 [0.125] 4.37 [0.172] D 3.18 [0.125] C 8.69 [0.342] Panel shown for reference only Ø2.36 [Ø0.093] NOTE: *1 When viewing the connector from the rear with the “A” contact position down, the panel on the left dictates “L” Code while the panel on the right dictates “R” code. See ordering information page “Step 5”. SOLDER CUP TERMINATION CODE SC 19.05 [0.750] Typical part number: GF1M1FASCL Ø1.17 [0.046] I.D. 13.43 [0.529] Typical part number: GF1M1FBSCR Ø1.02±0.03 [0.040±0.001] STRAIGHT SOLDER PRINTED BOARD MOUNT TERMINATION CODE DS3, DS4, DS5 AND DS6 O.A.L. L 5.62 [0.221] Typical part number: GF1M1FADS3L Ø0.64 [0.025] Ø1.02±0.03 [0.040±0.001] Typical part number: GF1M1FBDS3R 2 DIMENSIONS ARE IN MILLIMETERS [INCHES]. ALL DIMENSIONS ARE SUBJECT TO CHANGE. CONTACT CODE L O.A.L. DS3 2.36 [0.093] 17.37 [0.684] DS4 3.18 [0.125] 18.19 [0.716] DS5 3.96 [0.156] 18.97 [0.747] DS6 4.75 [0.187] 19.79 [0.779] GF / GFPL SERIES Utility Connectors PROFESSIONAL QUALITY UTILITY CONNECTORS FIXED CONTACT / LOW PROFILE Positronic connectpositronic.com RIGHT ANGLE (90°) PRINTED BOARD MOUNT TERMINATION AVAILABLE IN VERTICAL OR HORIZONTAL MOUNTS GFPL 2-POLE 1 VERTICAL PANEL MOUNTED * Ø1.02±0.03 [0.040±0.001] HORIZONTAL PANEL MOUNTED B Ø1.02±0.03 [0.040±0.001] A 2.54 (0.100) Minimum Panel shown for reference only A Panel shown for reference only Ø0.64 [0.025] 3.18 [0.125] 2.54 (0.100) Minimum B Ø0.64 [0.025] 3.18 [0.125] 6.99 [0.275] Typical part number: GFPL2M000RV Typical part number: GFPL2M000H GFPL 4-POLE VERTICAL PANEL MOUNTED *1 HORIZONTAL PANEL MOUNTED Panel shown for reference only Ø1.02±0.03 [0.040±0.001] C A B D Ø1.02±0.03 [0.040±0.001] 2.54 (0.100) Minimum B D A C Panel shown for reference only Ø0.64 [0.025] 3.18 [0.125] 2.54 (0.100) Minimum Ø0.64 [0.025] 3.18 [0.125] 6.99 [0.275] 6.99 [0.275] Typical part number: GFPL2M2FAC0RV Typical part number: GFPL2M2FCD0H NOTE: *1 When viewing the connector from the rear with the “A” contact position down, the panel on the left dictates “L” code while the panel on the right dictates “R” code. See ordering information page “Step 5”. U N I Q U E F E A T U R E S GF and GFPL connectors can be “STACKED” in building block fashion to create custom configurations. NOTE: Positronic recommends the use of a #2 82° countersunk screw. DIMENSIONS ARE IN MILLIMETERS [INCHES]. ALL DIMENSIONS ARE SUBJECT TO CHANGE. 3 GF / GFPL SERIES PROFESSIONAL QUALITY UTILITY CONNECTORS Positronic connectpositronic.com Utility Connectors FIXED CONTACT / LOW PROFILE ORDERING INFORMATION - CODE NUMBERING SYSTEM Specify Complete Connector By Selecting An Option From Step 1 through 5. GF SERIES STEP EXAMPLE 1 GF 2 3M1F 3 A 4 DS5 5 L - 6 -14 STEP 1 - BASIC SERIES STEP 6 - SPECIAL OPTIONS GF - Solder cup or straight printed board mount termination CE - Closed entry contacts on female solder cup terminations -14 - 0.000030 [0.76] gold over nickel. STEP 2 - QUANTITY AND GENDER OF CONTACTS 2 POLE INSULATOR 2M0 - 2 Male, No Female. 2F0 - 2 Female, No Male. 1M1F - 1 Male,1 Female. Contact Technical Sales for special options. 4 POLE INSULATOR 4M0 - 4 Male, No Female. 4F0 - 4 Female, No Male. 3M1F - 3 Male, 1 Female. 3F1M - 3 Female, 1 Male. 2M2F - 2 Male, 2 Female. STEP 5 - MOUNTING OPTIONS L - Left panel mount. R - Right panel mount. STEP 4 - CONTACT TERMINATION TYPE STEP 3 - POSITION OF POLARIZING CONTACT 0 A, B, C, D EXAMPLES: GF4M00DS3R GF1M1FASCL GF2M2FCDSCL All contacts same gender Specify polarizing position(s) of contact(s) for the second gender specified in Step 2 above. No specification needed. Specifies “A” position of the female contact. Specifies “C” and “D” positions of the female contact. SC - Solder cup. For closed entry design, add ‘CE” in Step 6. DS3 - Solder, Straight printed board mount with 2.36 [0.093] tail length. DS4 - Solder, Straight printed board mount with 3.18 [0.125] tail length. DS5 - Solder, Straight printed board mount with 3.96 [0.156] tail length. DS6 - Solder, Straight printed board mount with 4.75 [0.187] tail length. O R D E R I N G I N F O R M AT I O N - C O D E N U M B E R I N G S Y S T E M GFPL SERIES Specify Complete Connector By Selecting An Option From Step 1 through 5. STEP EXAMPLE 1 GFPL 2 2M2F 3 AB 4 0 5 H GFPL - Right angle (90°) printed board mount termination -14 - 0.000030 [0.76] gold over nickel. Contact Technical Sales for special options. STEP 2 - QUANTITY AND GENDER OF CONTACTS 4 POLE INSULATOR 4M0 - 4 Male, No Female. 4F0 - 4 Female, No Male. 3M1F - 3 Male, 1 Female. 3F1M - 3 Female, 1 Male. 2M2F - 2 Male, 2 Female. STEP 3 - POSITION OF POLARIZING CONTACT 0 A, B, C, D 6 -14 STEP 6 - SPECIAL OPTIONS STEP 1 - BASIC SERIES 2 POLE INSULATOR 2M0 - 2 Male, No Female. 2F0 - 2 Female, No Male. 1M1F - 1 Male, 1 Female. - All contacts same gender Specify polarizing position(s) of contact(s) for the second gender specified in Step 2 above. STEP 5 - MOUNTING OPTIONS LV - Left panel vertical mount. RV - Right panel vertical mount. H - Horizontal mount. STEP 4 - CONTACT TERMINATION TYPE 0 - Right angle (90°) printed board mount. EXAMPLES: GFPL4M000RV GFPL3M1FA0H GFPL2M2FCD0LV No specification needed. Specifies “A” position of the female contact. Specifies “C” and “D” positions of the female contact. Positronic | Americas Positronic | Europe Positronic | Asia Sales Offices 1325 N Eldon Ave 46 route d’Engachies 3014A Ubi Rd 1 #07-01 Positronic has local sales Springfield MO 65803 USA F-32020 Auch Cedex 9 France Singapore 408703 representation all over the world. +1 800 641 4054 +33 5 6263 4491 +65 6842 1419 For the nearest sales office visit info@connectpositronic.com contact@connectpositronic.com singapore@connectpositronic.com www.connectpositronic.com/sales
GF3F1MASCRCE 价格&库存
很抱歉,暂时无法提供与“GF3F1MASCRCE”相匹配的价格&库存,您可以联系我们找货
