ACCESSORIES
FOR USE WITH D-SUB CONNECTORS
THE SCIENCE OF CERTAINTY®
M016 20/04
TABLE OF CONTENTS
Backshells
Backshells quick reference guide
1
ALUMINUM BACKSHELLS
Positronic builds premium power and signal
connectors for a variety of industries. But every
product delivers a single outcome: Certainty.
Driven by the mission-critical needs of our
customers, we’ve gone to school on the
subject for over 50 years. We approach it with
Material & finish quick reference options
A series
DIECAST / METAL BACKSHELLS
Hardware quick reference options
G series
H series
2
3-8
9
10-13
14
PLASTIC / COMPOSIT BACKSHELLS
J series
L series
15
16
16
Z series
17
Y series
18
Locking Systems
scientific discipline – honing the fusion of raw
Jackscrew systems
material, engineering ingenuity, and precision
Jackscrew systems coding device
Quick disconnect locking system
19
19-20
manufacturing to push the next limits of reliability.
Mounting Options
And with every new project, our curiosity is
reignited. How will certainty be achieved in
your system, with its own unique demands?
The answers have graced the most formidable
missions of our time, from the fires of super-sonic
flight to the merciless scapes of Mars.
WHAT CAN YOU BE CERTAIN ABOUT?
• Rock-solid reliability
Clearance hole / float mounts
21
Swaged spacers
21
Swaged spacer with boardlock
22
Swaged locknut
22
Swaged plastic mounting brackets
22
Right angle brackets
23
Boardlocks and Inductors
Ferrite inductor bar / beads
24
Boardlocks
24
Other Options
Blind mate system
25
• Maximum design flexibility
flexibility
Flared connector housing (shell)
25
• High efficiency,
efficiency, low heat performance
In-line crimp splice
25
Cul-de-sac style inside wall mount
26
Enclosure wall mount sealing plate
26
Outside wall enclousure mount
26
Interfacial seal / rear grommets
27
Sealing plugs
27
Protective cover
28
EMI/RFI protective cover
28
Machined aluminum mounting plate
29
Other sealed D-Sub connector options
29
• Responsive, knowledgeable support
THE SCIENCE
OF CERTAINTY ®
Positronic
D-Sub Accessories Backshells
BACKSHELLS QUICK REFERENCE
A
AL
AS
G
H
J
L
Y
Z
TECHNICAL CHARACTERISTICS
Backshell
Code
Material
Finish
Cable Clamp
(Material, finish)
Hardware
(Material, finish)
Unique Attributes
Page
AN*
aluminum
nickel
aluminum, nickel
steel with nickel plate
top opening, light weight,
EMI
4-5
ALN*
aluminum
nickel
aluminum, nickel
EMI, low profile
8
ASN*
aluminum
nickel
aluminum, nickel
side opening, light weight,
EMI
6-7
zinc, die cast
modular opening, EMI/RFI
metal
10-13
steel, zinc plate with
chromate seal
similar to SAE AS85049/48
14
G
zinc, die cast
H
steel
J
glass-filled polyester, UL94 V-0
steel, nickel plate
top opening, for vibration
applications
16
L
steel, nickel plate
side opening, for vibration
applications
16
Y
composite polyester, UL94 V-0
steel, nickel plate for size 50
backshell only.
steel with zinc plate and
chromate seal or tin plate;
stainless steel, passivated.
EMI/RFI composite.
Attenuation: 40+ decibels.
Sizes 50 & 104 only
18
Z
composite. Attenuation: 40+
decibels.
17
zinc plate with
chromate seal
See ‘Material & Finish Options’ chart on page 2 for additional options
1
connectpositronic.com
Positronic
LIGHTWEIGHT ALUMINUM BACKSHELL, QUICK REFERENCE
A*
AL*
AS*
See chart below for ‘Material & Finish Options’
MATERIAL & FINISH OPTIONS
Code
N
Backshell & Cable
Clamp Finish
Nickel
Hardware Type
Hardware Material
& Finish
T2
E
E6
E7
VL
V3
Steel with nickel plate
OPTIONAL MATERIAL & FINISHES
A
Anodize
B
Anodize
C
No finish
D
No finish
I
Yellow chromate
conversion
J
Yellow Chromate
conversion
Brass with zinc plate and
chromate seal
chromate seal
chromate seal
Custom Machined Aluminum Backshells Available!
Contact Technical Sales for details.
2
Positronic
LIGHTWEIGHT ALUMINUM BACKSHELLS
This product has been designed for use in applications as a lightweight, EMI backshell for
D-subminiature connectors. The features of the product are outlined below. Please contact
technical sales for pricing and additional options.
GROUND SCREWS
APERTURE / STRAIN RELIEF
• Sized and spaced for use with 6.35mm [.250 inch]
diameter ring terminals
• Appropriate for high density wire bundles using
twisted, shielded pairs
• Ground shelf height and ground screw length allow for
stacking of ring terminals
• Cable clamps can be “spooned” to provide strain relief
for small wire bundle
• Holes are pre-tapped for ease of installation
• Wide form factor allows the user to easily meet bend
radius requirements
• Ground screws are located outside the exiting wire
path to facilitate wire routing
• Ground holes are tapped through to the outside which
provide for optional external grounding
SPACIOUS INTERIOR
• Shape maximizes internal area which facilitates
harness assembly
THUMB GRIP
• Grip facilitates installation and removal in tight spaces
LOCKING SYSTEM
• Available with jackscrews or quick disconnect locking
device
• No obstructions behind any portion of the connector
body allows backshell to be used with Combo-D
connectors
TECH SPECS
ENVIRONIMENTAL
MATERIAL AND FINISHES
Backshell
& Cable Clamps
Aluminum; aluminum with electroless nickel plate;
aluminum with yellow anodize; aluminum with yellow
chromate conversion. Zinc content is 1% maximum.
Jackscrews &
Screws
Steel with nickel plate; brass with zinc plate and
chromate seal; brass, with 1.27μm min Au over Cu.
Stainless steel options available, contact Technical
Sales.
Actuation Lock
System
Operating
Temperature
WEIGHT CHART *1
Backshell Size
D*2000ANVL
Ounces [grams]
D*2000ANE
Ounces [grams]
9
1.43 [40.50]
1.08 [30.54]
15
1.60 [45.24]
1.32 [37.44]
25
1.95 [55.22]
1.62 [45.92]
37
2.53 [71.60]
2.19 [62.06]
50
2.61 [74.00]
2.26 [63.94]
104
n/a
2.41 [68.44]
ELECTRICAL
Range of Operation,
Calculated Method
2 GHz minimum.
MECHANICAL
Ground Screws
Can accept up to 6.35mm [.250 inch] diameter ring
terminal.
Locking System
Jackscrews or quick disconnect locking device
-55 to 125ºC
*1 Contact Technical Sales for weights on T2, E6, E7 and V3 hardware options.
*2 Designates backshell size in part number. All hardware in a backshell assembly including
cable clamps, screws, etc.
3
Positronic
For use with code E, E6 or E7
For the sake of brevity, only basic dimensions are shown here. Full dimensional detail is available in the respective product drawings.
A
Backshell, aluminum, top opening*1
G
Nominal
cable opening
3.81 [.150]
H
Cable opening
J
Cable clamp
A backshell shown with E option
2X 2.41 [.095]
hex socket
B
A
K
C
Number
of internal
grounding
screws
D
E6 shown
for reference
F
E
A backshell shown with E6 option
E6 shown
for reference
E6 shown
for reference
A backshell shown with E7 option
PART NUMBER
Connector /
Contact Arrangement Compatibility
Shell
Size
A
B
C
D
E
F
G
H
(Min)
(Max)
J
K
D9000AN*1E0*2
D9000AN*1E60*2
D9000AN*1E70*2
Std-D: 9
High-D: 15
Combo-D: 5W1, 2WK2
Combo-D High-D: 8W2
1
23.06
[.908]
15.65
[.616]
53.09
[2.090]
45.47
[1.790]
38.71
[1.524]
24.99
[.984]
9.19
[.362]
6.10
[.240]*3
12.27
[.483]
1.27
[.050]
4
D15000AN*1E0*2
D15000AN*1E60*2
D15000AN*1E70*2
Std-D: 15
High-D: 26
Combo-D: 3W3, 3WK3,
7W2, 11W1
Combo-D High-D: 19W1
2
31.39
[1.236]
15.65
[.616]
53.09
[2.090]
45.47
[1.790]
47.04
[1.852]
33.32
[1.312]
17.53
[.690]
8.89
[.350]*3
12.27
[.483]
2.54
[.100]
4
D25000AN*1E0*2
D25000AN*1E60*2
D25000AN*1E70*2
Std-D: 25
High-D: 44
Combo-D: 5W5, 9W4, 13W3,
17W2, 21W1
Combo-D High-D: 15W4
3
42.06
[1.656]
15.65
[.616]
53.09
[2.090]
45.47
[1.790]
60.76
[2.392]
47.04
[1.852]
17.53
[.690]
8.89
[.350]*3
12.27
[.483]
2.54
[.100]
4
D37000AN*1E0*2
D37000AN*1E60*2
D37000AN*1E70*2
Std-D: 37
High-D: 62
Combo-D: 8W8, 13W6, 17W5,
21WA4, 25W3, 27W2
Combo-D High-D: 45W2
4
58.52
[2.304]
15.65
[.616]
59.44
[2.340]
51.82
[2.040]
77.22
[3.040]
63.50
[2.500]
31.55
[1.242]
10.41
[.410]*3
12.27
[.483]
3.30
[.130]
6
D50000AN*1E0*2
D50000AN*1E60*2
D50000AN*1E70*2
Std-D: 50
High-D: 78
Combo-D: 24W7, 36W4,
43W2, 47W1
Combo-D High-D: n/a
5
56.13
[2.210]
18.47
[.727]
59.44
[2.340]
51.82
[2.040]
74.83
[2.946]
61.11
[2.406]
31.55
[1.242]
10.41
[.410]*3
15.09
[.594]
3.30
[.130]
6
Combo-D: 46W4
Combo-D High-D: n/a
6
58.52
[2.304]
20.07
[.790]
59.44
[2.340]
51.82
[2.040]
77.22
[3.040]
63.50
[2.500]
31.55
[1.242]
10.41
[.410]*3
16.69
[.657]
3.30
[.130]
6
D104000AN*1E0*2
Std-D: n/a
D104000AN*1E60*2 High-D: 104
D104000AN*1E70*2
*1 For additional ‘Material & Finish Options’, replace ‘N’ with desired ‘Code’ from chart on page 2.
*2 For 1.27μm min Au over Cu, replace the last ‘0’ with ‘G’ in part number and *1 note must remain as ‘N’ (e.g. D90000ANT2G)
*3 Smaller cable openings may be achieved by inverting one or both cable clamps.
4
Positronic
For use with code T2, VL or V3
A
G
Nominal
cable opening
3.81 [.150]
H
A backshell shown with T2* option
Cable opening
*also available with polarized fixed jackposts,
contact Technical Sales for more information.
J
Cable clamp
A
B
K
C
Number
of internal
grounding
screws
D
A backshell shown with V3* option
E
*see page 20 for code 'V3' information.
A backshell shown with VL* option
*see page 20 for code 'VL' information
PART NUMBER
Connector /
Shell
Size
A
B
C
D
E
G
H
(Min)
(Max)
J
K
D9000AN*1T20*2
D9000AN*1V30
D9000AN*1VL0
Std-D: 9
High-D: 15
Combo-D: 5W1, 2WK2
Combo-D High-D: 8W2
1
30.96
[1.219]
14.88
[.586]
50.08
[2.000]
43.18
[1.700]
24.99
[.984]
9.19
[.362]
6.10
[.240]*3
11.51
[.453]
1.14
[.045]
4
D15000AN*1T20*2
D15000AN*1V30
D15000AN*1VL0
Std-D: 15
High-D: 26
Combo-D: 3W3, 3WK3,
7W2, 11W1
2
39.29
[1.547]
14.88
[.586]
50.08
[2.000]
43.18
[1.700]
33.32
[1.312]
17.53
[.690]
8.89
[.350]*3
11.51
[0.453]
2.54
[.100]
4
D25000AN*1T20*2
D25000AN*1V30
D25000AN*1VL0
Std-D: 25
High-D: 44
17W2, 21W1
3
53.19
[2.094]
14.88
[.586]
50.08
[2.000]
43.18
[1.700]
47.04
[1.852]
17.53
[.690]
8.89
[.350]*3
11.51
[0.453]
2.54
[.100]
4
D37000AN*1T20*2
D37000AN*1V30
D37000AN*1VL0
Std-D: 37
High-D: 62
21WA4, 25W3, 27W2
4
69.49
[2.736]
14.88
[.586]
57.15
[2.250]
49.53
[1.950]
63.50
[2.500]
31.55
[1.242]
10.41
[.410]*3
11.51
[0.453]
3.30
[.130]
6
D50000AN*1T20*2
D50000AN*1V30
D50000AN*1VL0
Std-D: 50
High-D: 78
43W2, 47W1
Combo-D High-D: n/a
5
67.11
[2.642]
17.70
[.697]
57.15
[2.250]
49.53
[1.950]
61.11
[2.406]
31.55
[1.242]
10.41
[.410]*3
14.33
[.564]
3.30
[.130]
6
D104000AN*1T20*2
Std-D: n/a
High-D:
104
Combo-D: 46W4
Combo-D High-D: n/a
6
69.49
[2.736]
19.30
[.760]
57.15
[2.250]
49.53
[1.950]
63.50
[2.500]
31.55
[1.242]
10.41
[.410]*3
15.93
[.627]
3.30
[.130]
6
5
Positronic
AS
Backshell, aluminum, side opening*1
3.81 [.150]
J
Cable clamp
A
AS backshell shown with E option
H
Cable opening
C D
K
Number
of internal
grounding
screws
E6 shown
for reference
E6 shown
for reference
F
E
E6 shown
for reference
B
AS backshell shown with E6 option
AS backshell shown with E7 option
Connector /
PART NUMBER
Shell
Size
A
B
C
D
E
F
G
H
(Min)
(Max)
J
K
D9000ASN*1E0*2
D9000ASN*1E60*2
D9000ASN*1E70*2
Std-D: 9
High-D: 15
Combo-D: 5W1, 2WK2
Combo-D High-D: 8W2
1
20.01
[.788]
15.65
[.616]
55.84
[2.198]
50.30
[1.980]
38.72
[1.524]
24.99
[.984]
8.64
[.340]
6.10
[.240]*3
12.27
[.483]
1.14
[.045]
1
D15000ASN*1E0*2
D15000ASN*1E60*2
D15000ASN*1E70*2
Std-D: 15
High-D: 26
Combo-D: 3W3, 3WK3,
7W2, 11W1
2
28.24
[1.112]
15.65
[.616]
62.91
[2.477]
56.90
[2.240]
47.07
[1.852]
33.32
[1.312]
10.21
[.402]
8.89
[.350]*3
12.27
[.483]
2.54
[.100]
2
D25000ASN*1E0*2
D25000ASN*1E60*2
D25000ASN*1E70*2
Std-D: 25
High-D: 44
17W2, 21W1
3
42.06
[1.656]
15.65
[.616]
62.85
[2.474]
58.17
[2.290]
60.76
[2.392]
47.04
[1.852]
10.21
[.402]
8.89
[.350]*3
12.27
[.483]
2.54
[.100]
3
D37000ASN*1E0*2
D37000ASN*1E60*2
D37000ASN*1E70*2
Std-D: 37
High-D: 62
21WA4, 25W3, 27W2
4
58.52
[2.304]
15.65
[.616]
74.07
[2.916]
68.08
[2.680]
77.22
[3.040]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
12.27
[.483]
3.30
[.130]
4
D50000ASN*1E0*2
D50000ASN*1E60*2
D50000ASN*1E70*2
Std-D: 50
High-D: 78
43W2, 47W1
Combo-D High-D: n/a
5
56.13
[2.210]
18.47
[.727]
74.07
[2.916]
68.08
[2.680]
74.83
[2.946]
61.11
[2.406]
31.52
[1.241]
10.41
[.410]*3
15.09
[.594]
3.30
[.130]
4
D104000ASN*1E0*2
D104000ASN*1E60*2
D104000ASN*1E70*2
Std-D: n/a
High-D: 104
Combo-D: 46W4
Combo-D High-D: n/a
6
58.52
[2.304]
20.07
[.790]
74.07
[2.916]
68.08
[2.680]
77.22
[3.040]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
16.69
[.657]
3.30
[.130]
4
6
Positronic
AS
3.81 [.150]
G
Nominal
cable opening
AS backshell shown with T2 option
J
H
Cable clamp
Cable opening
K
Number of internal
grounding screws
C D
AS backshell hown with V3* option
E
B
A
AS backshell shown with VL* option
PART NUMBER
Connector /
Shell
Size
A
B
C
±0.64
[.025]
D
E
G
H
(Min)
(Max)
J
K
D9000ASN*1T20*2
D9000ASN*1V30
D9000ASN*1VL0
Std-D: 9
High-D: 15
Combo-D: 5W1, 2WK2
Combo-D High-D: 8W2
1
30.96
[1.219]
14.88
[.586]
50.92
[2.005]
48.26
[1.900]
24.99
[.984]
8.64
[.340]
6.10
[.240]*3
11.51
[0.453]
1.14
[.045]
2
D15000ASN*1T20*2
D15000ASN*1V30
D15000ASN*1VL0
Std-D: 15
High-D: 26
Combo-D: 3W3, 3WK3,
7W2, 11W1
2
39.29
[1.547]
14.88
[.586]
59.96
[2.361]
55.88
[2.200]
33.32
[1.312]
10.21
[.402]
8.89
[.350]*3
11.51
[0.453]
2.54
[.100]
3
D25000ASN*1T20*2
D25000ASN*1V30
D25000ASN*1VL0
Std-D: 25
High-D: 44
17W2, 21W1
3
53.19
[2.094]
14.88
[.586]
59.96
[2.361]
55.88
[2.200]
47.04
[1.852]
10.21
[.402]
8.89
[.350]*3
11.51
[0.453]
2.54
[.100]
3
D37000ASN*1T20*2
D37000ASN*1V30
D37000ASN*1VL0
Std-D: 37
High-D: 62
21WA4, 25W3, 27W2
4
69.49
[2.736]
14.88
[.586]
73.17
[2.881]
69.85
[2.750]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
11.51
[0.453]
3.30
[.130]
4
D50000ASN*1T20*2
D50000ASN*1V30
D50000ASN*1VL0
Std-D: 50
High-D: 78
43W2, 47W1
Combo-D High-D: n/a
5
67.11
[2.642]
17.70
[.697]
73.17
[2.881]
69.85
[2.750]
61.11
[2.406]
31.52
[1.241]
10.41
[.410]*3
14.33
[.564]
3.30
[.130]
4
D104000ASN*1T20*2
Std-D: n/a
High-D: 104
Combo-D: 46W4
Combo-D High-D: n/a
6
69.49
[2.736]
19.30
[.760]
73.17
[2.881]
69.85
[2.750]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
15.93
[.627]
3.30
[.130]
4
7
Positronic
AL
Backshell, aluminum, top opening*1, low profile
G
Nominal
cable opening
3.81 [.150]
H
Cable opening
AL backshell shown with E option
J
Cable clamp
A
C
B
K
Number
of internal
grounding
screws
D
E6 shown
for reference
F
E6 shown
for reference
E
E6 shown
for reference
AL backshell shown with E6 option
AL backshell shown with E7 option
PART NUMBER
Connector /
Contact Arrangement
Compatibility
Shell
Size
A
B
C
D
E
F
G
H
(Min)
(Max)
J
K
D9000ALN*1E0*2
D9000ALN*1E60*2
D9000ALN*1E70*2
Std-D: 9
High-D: 15
1
20.32
[.800]
15.65
[.616]
35.05
[1.380]
27.69
[1.090]
32.33
[1.273]
24.99
[.984]
8.64
[.340]
5.81
[.229]*3
11.98
[0.471]
1.140
[.045]
1
D15000ALN*1E0*2
D15000ALN*1E60*2
D15000ALN*1E70*2
Std-D: 15
High-D: 26
2
28.45
[1.120]
15.65
[.616]
37.85
[1.490]
30.23
[1.190]
40.64
[1.600]
33.32
[1.312]
10.21
[.402]
6.10
[.240]*3
12.27
[.483]
1.140
[.045]
2
D25000ALN*1E0*2
D25000ALN*1E60*2
D25000ALN*1E70*2
Std-D: 25
High-D: 44
3
42.06
[1.656]
15.65
[.616]
37.85
[1.490]
30.23
[1.190]
54.61
[2.150]
47.04
[1.852]
18.42
[.725]
8.89
[.350]*3
12.27
[.483]
2.54
[.100]
2
D37000ALN*1E0*2
D37000ALN*1E60*2
D37000ALN*1E70*2
Std-D: 37
High-D: 62
4
58.52
[2.304]
15.65
[.616]
37.85
[1.490]
30.23
[1.190]
71.12
[2.800]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
12.27
[.483]
3.30
[.130]
2
D50000ALN*1E0*2
D50000ALN*1E60*2
D50000ALN*1E70*2
Std-D: 50
High-D: 78
5
56.13
[2.210]
18.47
[.727]
37.85
[1.490]
30.23
[1.190]
68.60
[2.701]
61.11
[2.406]
31.44
[1.238]
10.41
[.410]*3
15.09
[.594]
3.30
[.130]
2
D104000ALN*1E0*2
D104000ALN*1E60*2
D104000ALN*1E70*2
Std-D: n/a
High-D: 104
6
58.52
[2.304]
20.07
[.790]
37.85
[1.490]
30.23
[1.190]
71.12
[2.800]
63.50
[2.500]
31.52
[1.241]
10.41
[.410]*3
16.69
[.657]
3.30
[.130]
2
8
Positronic
DIECAST / METAL BACKSHELL, QUICK REFERENCE
H
G
GA
HARDWARE QUICK REFERENCE OPTIONS
Backshell
Rotating
No Hardware
Jackscrews
Fixed
Jackscrews
Quick
Disconnect
Locking
System
Low Profile
Extended
Height
Adapter
Cable
Opening
EMI / RFI
Page
Modular
EMI/RFI
10-13
G
H
9
Top
14
Positronic
ZINC, DIECAST BACKSHELLS*1
For use with code VL
G (Low Profile)
G (Extended)
Backshell, modular opening, zinc, die cast, EMI/RFI,
low profile
Backshell, extended height, modular opening,
A
B
A
B
12.95
[.510]
12.95
[.510]
40.00
[1.575]
55.00
[2.165]
G backshell 'low profile' shown
VL shown
for reference
VL shown
for reference
VL shown
for reference
VL shown
for reference
FEATURES
Automatic rapid locking system keeps connection secure and is easy to unlock using the
slide latch when needed.
Gripping shoulders enable trouble-free extraction of the connector assembly, even with
tightly packed aligned cable adapters.
Cable adapters are designed with multiple entries and can permit the looping through of
cables. Cable entries not used are sealed to maintain EMI/RFI shielding.
Two height options are available, low-profile or an increased height option.
PART NUMBER
D9000G00
D9000GVL0
D9000G00-1023.2
D9000GVL0-1023.0
D15000G00
D15000GVL0
D15000G00-1023.2
D15000GVL0-1023.0
D25000G00
D25000GVL0
D25000G00-1023.2
D25000GVL0-1023.0
D37000G00
D37000GVL0
D37000G00-1023.2
D37000GVL0-1023.0
D50000G00
D50000GVL0
D50000G00-1023.2
D50000GVL0-1023.0
Shell
Size
Backshell Height
Low Profile Extended
A
B
Cable Exit
Option
32.00
[1.260]
14.60
[.575]
2 Side*2
G backshell 'low profile' shown with VL* option
Cable Opening
(Min)
(Max)
3.00
[.118]
11.99
[.472]
Low Profile
1
Extended
G backshell shown with -1023.2
extended option
Low Profile
2
39.30
[1.547]
14.60
[.575]
1 Top, 2 Side*3
3.00
[.118]
11.99
[.472]
53.20
[2.094]
14.60
[.575]
1 Top, 2 Side*3
3.00
[.118]
11.99
[.472]
69.50
[2.736]
14.60
[.575]
1 Top, 2 Side*3
3.00
[.118]
11.99
[.472]
Extended
Low Profile
3
Extended
Low Profile
4
Extended
G backshell shown with -1023.0
extended and VL* options
Low Profile
67.00
[2.638]
5
17.90
[.705]
1 Top, 2 Side*3
5.00
[.197]
14.00
[.551]
Extended
*1 To prevent stripping of the backshell assembly screws, we recommend using pozidriv screwdriver bits available from stock using part number
9535-2-2-0, contact Technical Sales. For the mounting screws, we recommend using a standard phillips head screwdriver bit.
*2 These backshells are supplied with one (1) cable clamp set and one (1) opening plug. See page 13 for optional crimp Ferrule system.
*3 These backshells are supplied with one (1) cable clamp set and two (2) opening plugs. See page 13 for optional crimp Ferrule system.
10
Positronic
ZINC, DIE CAST BACKSHELLS*1
For use with code E
G (Low Profile)
G (Extended)
low profile
D
D
12.95 [.510]
12.95 [.510]
A
A
C
B
2X
4-40 UNC thread
rotating male jackscrews
2X
4-40 UNC thread
C
B
FEATURES
G backshell 'low profile' shown with E option
Gripping shoulders enable trouble-free extraction of the connector assembly even with tightly packed
aligned backshells.
Rotating jackscrews offer the most secure mechanical locking of the connector system.
For use with connector shell sizes 3 - 5 are designed with three (3) cable entries and can permit the
looping through of cables. Cable entries not used are sealed with supplied metal plugs to maintain EMI/
RFI shielding qualities.
Standard height backshells for use with connector shell sizes 1 and 2 are available with a top or side
cable exit option. Contact Technical Sales for details.
G backshell shown with -1023.5 extended and
internal hex jackpost options
Two (2) height options are available, one being a low profile option. An extended height option is offered
for use with power conductors and coaxial cable, such as might be used with the Positronic CBD/CBM
series connectors.
Grounding to the backshells may be accomplished by fastening wires inside backshell with an M2.5
threaded Posidriv head screw.
PART NUMBER
Shell
Size
D9000GE0
D9000GE0-1023.50
D9000GE0-1023.5
D9000GE0-1023.49
D15000GE0
D15000GE0-1579.0
Backshell Height
Low Profile
Extended
35.50
[1.398]
Low Profile
1
2
Extended*
2
Extended*2
D25000GE0
2
Extended*
D37000GE0
4
Extended*2
D50000GE0
D104000GE0
Extended*2
6
Low Profile
55.00
[2.165]
42.00
[1.654]
Low Profile
5
D50000GE0-1023.5
55.00
[2.165]
40.00
[1.575]
Low Profile
D37000GE0-1023.5
55.00
[2.165]
40.00
[1.575]
Low Profile
3
D25000GE0-1023.5
50.50
[1.988]
40.00
[1.575]
Low Profile
D15000GE0-1023.5
A
57.00
[2.244]
39.62
[1.560]
B
C
D
Cable Exit
Option
Cable Opening
(Min)
(Max)
3.00
[.118]
11.99
[.472]
3.00
[.118]
11.99
[.472]
1 Top
31.00
[1.220]
25.00
[.984]
14.80
[.582]
1 Side
1 Side
1 Top
1 Top, 1 Side*3
1 Side*3
39.40
[1.551]
33.30
[1.311]
14.80
[.582]
53.20
[2.094]
47.00
[1.850]
14.80
[.582]
1 Top, 2 Side*4
3.00
[.118]
11.99
[.472]
69.50
[2.736]
63.50
[2.500]
14.80
[.582]
1 Top, 2 Side*4
3.00
[.118]
11.99
[.472]
67.00
[2.638]
61.10
[2.406]
17.60
[.692]
1 Top, 2 Side*4
5.00
[.197]
14.00
[.551]
72.01
[2.835]
63.50
[2.500]
19.40
[.764]
1 Top, 2 side*4
5.00
[.197]
14.00
[.551]
1 Top, 1 Side*3
*1 To prevent stripping of the backshell assembly screws, we recommend using Pozidriv screwdriver bits available from stock using part number 9535-2-2-0, contact Technical Sales.
Standard height GE backshell use the Pozidriv style jackscrews.
*2 The extended height backshells use an internal hex jackscrew. Internal hex jackscrews are available for the standard height, but require an MOS.
*3 These backshells are supplied with one (1) cable clamp set and one (1) opening plug. See page 13 for optional crimp Ferrule system.
*4 These backshells are supplied with one (1) cable clamp set and two (2) opening plugs. See page 13 for optional crimp Ferrule system.
11
Positronic
ZINC, DIE CAST ADAPTERS
For use with code G backshell
GA (Adapter)
Backshell adapter, side opening, zinc, die cast, EMI/RFI
17.60
[.693]
30.00
[1.181]
GA adapter shown
2X
4-40 UNC thread
B
A
FEATURES
Can be used as a gender changer which provides EMI/RFI protection.
If no connector is inserted into the rear side of the adapter backshell, the opening can be closed with a
optional cover plate which can be adapted for use with LED’s, mini-switches, and coaxial connectors.
(Optional cover plate to be ordered separately)
Jackscrew locking system is supplied as a standard for secure mechanical coupling.
Allows for internal placement of a printed circuit board between the connectors.
Can be used to adapt connectors of one interface standard to another.
Used in applications where tapping into the electrical line path between connectors is necessary. A cable
exit is provided for this application.
Grounding to the backshell may be accomplished by fastening wires inside backshell with an M2.5 threaded
Pozidrive head screw.
Shell
Size
A
B
D9000GA0
1
44.00
[1.733]
D15000GA0
2
D25000GA0
D37000GA0
PART NUMBER
Cable Opening
Optional Cover
Plate
Optional Cable
Opening Plug*2
11.99
[.472]
A4589-9-0-0*3
A4596-1-0-0*3
3.00
[.118]
11.99
[.472]
A4589-15-0-0*3
A4596-1-0-0*3
47.00
[1.850]
3.00
[.118]
11.99
[.472]
A4589-25-0-0*3
A4596-1-0-0*3
63.50
[2.500]
3.00
[.118]
11.99
[.472]
A4589-37-0-0*3
A4596-1-0-0*3
(Min)
(Max)
25.00
[0.984]
3.00
[.118]
52.30
[2.059]
33.30
[1.311]
3
66.00
[2.598]
4
82.50
[3.248]
*2 See page 13 for optional Crimp Ferrule System.
*3 Must be purchased separately.
12
Positronic
CRIMP FERRULE SYSTEMS
The crimp ferrule system can be used with all Positronic code “G” backshells and is
recommended when maximizing EMI/RFI protection is desired.
The crimp ferrule system optimizes the transition of the cable shield into the cable adapter
in three ways.
• It provides a low impedance connection of the cable shield to the cable adapter
which remains constant over time.
• The system provides an EMI/RFI tight cable exit point.
• The system provides for high mechanical retention of the cable in the cable adapter.
Crimp ferrule (top left) and
crimp flange (bottom right)
APPLICATION INSTRUCTIONS
Application of the crimp ferrule system is quite simple.
#1 o
nce the cable insulation and shield are cut to the
correct dimensions
#2 the crimp ferrule is placed over the cable and the
crimp flange is inserted between the shield and the
conductors
#3 the crimp ferrule is now slid over the cable insulation
into position over the crimp flange and the crimp is
made using Positronic-supplied hand press and die
sets
#5
#1
#2
#3
#4 this assembly is then terminated to the connector and
placed into the cable adapter
#5 finally, the cover is placed on the cable adapter and
secured using four (4) screws
#4
To order the Positronic supplied hand press, request part number 9520-0-0-0 or for hand crimp tool, request part number 9521-3-0-0.
To order Positronic-supplied die sets, contact Technical Sales for ordering information, since die sets are customized based on the specific
crimp flanges, crimp ferrules and cables used.
CRIMP FERRULE / FLANGE CREAT A PART
A4592
Crimp ferrule
A4593
Crimp flange
Basic Series
A4592
A4593
Plating
Crimp ferrule
Crimp flange
Standard plating
Diameters*1
*1 C
ontact Technical Sales for part number
completion which is determined by customerrequired cable diameters and type.
13
Positronic
METAL BACKSHELLS
H
Backshell, metal, top opening
Ø 3.45
[.136]
E
D
F
B
C
H
H backshell shown
G
A
Shell Size
A
B
C
D
(Max)
E
F
G
H
(Max)
D15000H00
2
38.89
[1.531]
12.47
[0.491]
33.32
[1.312]
14.68
[.578]
18.11
[.713]
7.92
[.312]
19.05
[.750]
30.96
[1.219]
D25000H00
3
52.78
[2.078]
12.47
[0.491]
47.04
[1.852]
14.68
[.578]
25.40
[1.000]
7.92
[.312]
25.40
[1.000]
38.91
[1.532]
D37000H00
4
69.03
[2.718]
12.47
[0.491]
63.50
[2.500]
14.68
[.578]
34.93
[1.375]
7.92
[.312]
25.40
[1.000]
38.91
[1.532]
D50000H00
5
66.68
[2.625]
15.27
[.601]
61.11
[2.406]
17.45
[.687]
35.69
[1.405]
10.31
[.406]
28.58
[1.125]
42.09
[1.657]
PART NUMBER
14
Positronic
PLASTIC / COMPOSITE BACKSHELL, QUICK REFERENCE
L
J
Y
Z
Backshell
Rotating
No Hardware
Jackscrews
Fixed
Jackscrews
Quick
Disconnect
Locking
System
Low Profile
Extended
Height
Adapter
Cable
Opening
EMI / RFI
Page
J
Top
16
L
Side
16
Y
Z
15
Top
EMI/RFI
18
Modular
EMI/RFI
17
Positronic
PLASTIC BACKSHELLS
For use with code VL, V3 and V5
J
L
Backshell, plastic, top opening
Backshell, plastic, side opening
Cable Opening
Cable Opening
B
A
C
A
F
D
B
J backshell shown
E
F
J backshell shown with V3* option
J backshell shown with V5 option
*see page 20 for code 'V5' information
Shell
Size
A
B
C
D
E
F
D9000J0*10
D9000L0*10
1
32.05
[1.262]
15.06
[.593]
29.11
[1.146]
38.61
[1.520]
26.16
[1.030]
D15000J0*10
D15000L0*10
2
39.40
[1.551]
15.77
[.621]
34.44
[1.356]
48.26
[1.900]
D25000J0*10
D25000L0*10
3
54.08
[2.129]
15.77
[.621]
39.70
[1.563]
D37000J0*10
D37000L0*10
4
70.66
[2.782]
15.77
[.621]
D50000J0*10
D50000L0*10
5
68.28
[2.688]
18.62
[.733]
PART NUMBER
Cable Opening
(Min)
(Max)
21.95
[.864]
Ø3.43
[.145]
Ø7.11
[.280]
31.50
[1.240]
25.96
[1.022]
Ø4.06
[.160]
Ø6.99
[.275]
63.30
[2.492]
35.05
[1.380]
30.12
[1.186]
Ø2.79
[.110]
Ø6.99
[.275]
49.94
[1.848]
79.20
[3.188]
42.93
[1.690]
38.25
[1.506]
5.84 X 16.00
[.230] X [.630]
8.89 X 16.00
[.350] X [.630]
49.94
[1.848]
76.58
[3.015]
42.93
[1.690]
38.25
[1.506]
5.84 X 16.00
[.230] X [.630]
10.92 X 16.00
[.430] X [.630]
J backshell shown with VL option
*1 Replace ‘0’ with desired code ‘V3, V5 or VL’ to obtain desired hardware for backshell (e.g. D9000JV30)
L backshell shown
16
Positronic
COMPOSITE BACKSHELLS
Z*1
Z4*1
Backshell, composite, modular opening,
fixed female jackposts
Z6 *1
Z7*1
rotating polarized jackscrews
rotating female jackposts
Notes
Top cable opening
*1 Illustration is shown for Z backshell. The only difference
for Z4, Z6 and Z7 backshells will be jackscrew system.
*2 Side opening is not available on shell size 5.
Z backshell shown with
A
C
Side cable opening*2
B
Jackscrew shown
for reference
Jackscrews shown for reference
TYPICAL INSERTS
Z4 backshell shown with
INSERT TREE ASSEMBLY
Various inserts are provided to
accommodate different cable sizes.
(for shell size 1 through 4)
Shell
Size
A
B
C
D9000Z00
D9000Z400
D9000Z600
D9000Z700
1
35.23
[1.387]
49.15
[1.935]
D15000Z00
D15000Z400
D15000Z600
D15000Z700
2
43.56
[1.715]
D25000Z00
D25000Z400
D25000Z600
D25000Z700
3
D37000Z00
D37000Z400
D37000Z600
D37000Z700
4
D50000Z00
D50000Z400
D50000Z600
D50000Z700
5
PART NUMBER
Cable Opening
(Min)
(Max)
18.80
[.740]
2.54
[.100]
10.16 X 14.48
[.400] X [.570]
49.15
[1.935]
18.74
[.738]
2.54
[.100]
10.16 X 14.48
[.400] X [.570]
57.25
[2.254]
55.88
[2.200]
18.74
[.738]
2.54
[.100]
13.97 X 14.48
[.550] X [.570]
73.74
[2.903]
55.88
[2.200]
18.62
[.733]
2.54
[.100]
13.97 X 14.48
[.550] X [.570]
Z6 backshell shown with
male and female rotating jackscrews
Z7 backshell shown with
71.35
[2.809]
68.58
[2.700]
22.74
[.895]
2.54
[.100]
Ø16.00 [.630]
17
Positronic
Y (size 50)*1
Y (size 104)*1
Backshell, composite, size 50, top
opening, rotating male jackscrews
Backshell, composite, size 104, top/side
Y6 (size 50)*1
Y6 (size 104)*1
Backshell, composite, size 50, top opening,
opening, rotating polarized jackscrews
Cable clamp opening
5.84 [.230] x 16.00 [.630] min.
16.51 [.650 ] x 16.00 [.630] max.
Cable opening positions
Ø 3.18 [.125] min.
Ø 13.97 [.550] max.
Y for size 50
D
D
C
C
A
A
B
B
Y for size 104
Note
*1 Illustrations shown for Y backshell. The only difference for Y6
backshell will be jackscrew system and ‘B’ dimension.
Cable opening insert tree
for size 104 backshell
Y6 for size 50
Contact Technical Sales for availability of other size backshells
PART NUMBER
Shell
Size
A
D50000Y00
5
51.94
[2.045]
B
38.02
[1.497]
D50000Y600
30.08
[1.200]
max.
D104000Y00
26.04
[1.025]
6
D104000Y600
51.08
[2.011]
25.04
[.986]
C
D
67.44
[2.655]
19.66
[.774]
Y6 for size 104
71.88
[2.830]
21.29
[.838]
18
Positronic
D-Sub Accessories Locking Systems
JACKSCREW SYSTEM
T, T2, T3 or T7
B
A
E or E3
A
B
E2
A
CODE
Description
A
B
T *3
Fixed female jackposts, 4-40 UNC threads*1
11.10
[.437]
6.35
[.250]
T2*3
Fixed female jackposts, 4-40 UNC threads*1,
washer set
12.70
[.500]
5.03
[.198]
T3*3
washer set
20.65
[.813]
5.03
[.198]
T7*2 *3
10.92
[.430]
4.57
[.180]
CODE
Description
A
B
E*3
Rotating male jackscrews, 4-40 UNC threads,
slotted thumbscrews
16.43
[.647]
11.10
[.437]
E3*3
internal hex, low profile
16.43
[.647]
11.10
[.437]
CODE
Description
A
E2*3
slotted, low profile
6.10
[.240]
*1 Internal thread length of T, T2 or T3 jackscrews is 3.05 [.120] nominal. Jackscrew supplied on connectors in combination with other accessories may differ dimensionally, contact Technical Sales
*2 T7 jackscrews supplied on connectors in combination with other accessories may differ dimensionally, contact Technical Sales for more information.
*3 T, T2, T3, T7, E, E2 or E3 passivated stainless steel jackscrews available. Contact Technical Sales for ordering information.
JACKSCREW SYSTEM - CODING DEVICE (KEYING)
E6 *2
T6 *2
Rotating male jackscrews, rotating female jackpost, 4-40 UNC threads*1
Fixed female jackpost, fixed male jackscrew, 4-40 UNC threads
Top view of connector
A
C
B
C
Position 1 for
male connector
D
B
D
Position 1 for
female connector
A
Position 1 for
male connector
Position 1 for
female connector
A
B
C
D
A
B
C
D
11.30
[.445]
5.59
[.220]
4.93
[.194]
11.07
[.436]
16.94
[.667]
3.84
[.151]
4.50
[.177]
17.60
[.693]
*1 For customer installations of knobs onto jackscrews, recommend set screw torque value of 16 in-oz. Recommend application of thread lock to set screw.
*2 T6 or E6 passivated stainless steel options available. Contact Technical Sales for ordering information.
19
Positronic
JACKSCREW SYSTEM - CODING DEVICE (KEYING) OPTIONS
UP TO EIGHT CODING DEVICE OPTIONS!
Jackscrews can be supplied in configurations to allow for up to four coding device
options, as shown in the table. an additional four coding device options can be achieved
by reversing the connector genders.
Option
Male Connector
Code
(MOS)
Female
Connector
Code
(MOS)
1
2 male rotating
E *2
2 female fixed
T *2
2
2 female rotating
E6 *2
(-833.7*3)
2 male fixed
T6 *2
(-866.1*3)
3
1 female rotating*1
1 male rotating*1
E6 *2
1 male fixed*1
1 female fixed*1
T6 *2
4*4
1 male rotating*1
1 female rotating*1
E6 *2
(-1827.1*3)
1 female fixed*1
1 male fixed*1
T6 *2
(-1827.0*3)
*1 Additional options are achieved by switching male and female genders.
*2 For dimensional information see page 19.
*3 To achieve keying option required, add MOS suffix ‘-833.7’, ‘-866.1’,
‘-1827.1’ or ‘-1827.0’ to end of final part number.
*4 Reverse polarized connector.
QUICK DISCONNECT LOCKING SYSTEMS
V3
Lock tabs, use with free cable or front panel mount connectors
Lock tabs
A
B
C
V5
PART NUMBER
Shell
Size
A
B
C
D9/370000V30
1
6.86 [.270]
11.68 [.460]
6.91 [.272]
D9/370000V30
2
6.86 [.270]
11.68 [.460]
6.91 [.272]
D9/370000V30
3
6.86 [.270]
11.68 [.460]
6.91 [.272]
D9/370000V30
4
6.86 [.270]
11.68 [.460]
6.91 [.272]
D500000V30
5
6.86 [.270]
14.73 [.580]
6.91 [.272]
PART NUMBER
Shell
Size
A
B
(Max)
C
D9/370000V50
1
4.32
[.170]
1.57
[.062]
11.81
[.465]
D9/370000V50
2
4.32
[.170]
1.57
[.062]
11.81
[.465]
D9/370000V50
3
4.32
[.170]
1.57
[.062]
11.81
[.465]
D9/370000V50
4
4.32
[.170]
1.57
[.062]
11.81
[.465]
D500000V50
5
4.32
[.170]
1.57
[.062]
14.86
[.585]
Rear View of Panel
Lock tabs, use with rear panel mount connectors
C
Lock tabs
Panel
A
1.19
[.047]
7.87 [.310]
B
Mounting screw
removed for clarity
VL
*1 May be used with front or back mounted locking tabs, see V3 and V5.
Actuation lock lever
*1
VL
Actuation
lock lever
A
B
C
D
PART NUMBER
Shell
Size
A
B
C
D
(Max)
D90000VL0
1
14.73
[.580]
37.08
[1.460]
6.53
[.257]
15.04
[.592]
D150000VL0
2
14.73
[.580]
44.96
[1.770]
6.53
[.257]
15.04
[.592]
D250000VL0
3
14.73
[.580]
59.94
[2.360]
6.53
[.257]
15.04
[.592]
D370000VL0
4
14.73
[.580]
76.58
[3.015]
6.53
[.257]
15.04
[.592]
D500000VL0
5
16.13
[.635]
73.66
[2.900]
6.78
[.267]
17.91
[.705]
Positronic
D-Sub Accessories Mounting Options
CLEARANCE HOLE / FLOAT MOUNTS
Clearance hole, Ø3.05±0.13 [.120±.005]
For non-stainless steel connector housing (shells)
Clearance hole, Ø3.91 [.154]
Clearance holes, two places
F
For stainless steel connector housing (shells)
Float mounts
Ø3.05±0.25
[.120±.010]
0.81 [.032]
Total diametral float
Ø 2.18 +0.13/-0.00 [.086 +.005/-.000]
clearance holes, two places
SWAGED SPACERS
C5
C7
P
Standoffs, swaged, boardlock, cul-de-sac
style, 4-40 threaded hole, 8.89 [.350]
Inside wall mount, angle brackets,
boardlocks, alignment bar
Standoffs, removable, brass
9.91
[.390]
8.89
[.350]
Cul-de-sac style
swaged spacer
A
4-40 UNC
threads
4-40 UNC
threads
S
Standoffs, swaged, 4-40
Ø4.75
[.187]
A
SERIES
Termination Code
MD, MDX, HDC
all
ODD
21, 3, 32, 4, 5
SND
2, 3, 32, 36, 42, 5
CBD, CBM, CBDD
2, 21, 3, 35, 36, 37, 4, 5, 55,
57, 7, 75,77, 65, 85
SCBM
0, 2, 3, 35, 36, 37, 5, 55,
57, 65, 7, 75, 77, 85
SCBDD
21, 3, 35, 36, 37,
4, 45, 47, 65, 84
CBD, CBM, CBDD
93
Printed board
Internal View of Standoff
PCD, PCDD
0.38
[.015]
Cul-de-sac
style swaged
spacer
4-40 UNC threads*1
*1 Non-removable threaded hardware
is built and inspected to 0.56 Nm
[5in/lbs] or 80 in/oz torque.
98
RD, ORD, DD, CBC, CBCD
all
ODD
0, 1, 2
SND
0, 1, 12
SDD
all
SCBC, SCBCD
all
SD
all
21
A
5.72
[.225]
6.35
[.250]
6.73
[.265]
SERIES
Termination
Code
MD, MDX, ED,
HDC
all
ODD
21, 3, 32, 4, 5
CBD, CBDD,
CBM
all
RD, ORD, DD,
CBC, CBCD
all
ODD
0, 1, 2
SD
all
A
5.72 [.225]
6.35 [.250]
9.53 [.375]
11.10 [.437]
9.53
[.375]
11.10
[.437]
Positronic
SWAGED SPACER WITH BOARDLOCK
S7*1
S6 *1
Standoffs, swaged, 4-40, boardlocks,
for use with F ferrite inductor
Ø4.75
[.187]
Ø4.75
[.187]
A
A
0.38
[.015]
4-40 UNC Threads*2
SERIES
Termination Code
MD, MDX, HDC
3, 32, 33, 36
ODD
3, 32
SND
3, 32, 36
CBD, CBM, CBDD
3, 35, 36, 37, 65
SCBM
3, 35, 36, 37, 65
SCBDD
3, 35, 36, 37, 65
DD
3, 32
SDD
3, 32
SD
3, 32
0.38
[.015]
4-40 UNC threads*2
A
5.72 [.225]
Connector Series
Termination Code
MD, MDX, HDC, ODD
32, 33
ED, HDC
36
DD
32, 33
A
9.53
[.375]
6.35 [.250]
13.08
[.515]
9.53 [.375]
11.10 [.437]
*1 Printed board mounting hole to be Ø3.12±0.08 [.123±.003] for use with
boardlocks.
*2 Non-removable threaded hardware is built and inspected to 5in/lbs or
80 in/oz torque.
SWAGED PLASTIC
MOUNTING BRACKETS
WITH ALIGNMENT BAR
SWAGED LOCKNUT
S5
Locknut, swaged, 4-40
1.40
[.055]
Non-conductive mounting brackets are
necessary in many applications.
Internal View of Locknut
Locknut
insert
Ø4.57
[.180]
Panel
2.92
[.115]
0.38
[.015]
4-40 UNC threads
2.5 threads in metal, nominal.*1
*1 Non-removable threaded hardware is built and inspected to 5in/lbs or 80 in/oz torque.
22
Positronic
ANGLE BRACKET*1
R
R2*1
R3
R6 *1
Angle brackets, swaged, metal with
metal, alignment bar with
Angle brackets, swaged, metal,
clearance hole, Ø3.05 [.120]
clearance hole, Ø3.05 [.120],
alignment bar
5.72
[.225]
5.72
[.225]
Ø 4.75
[.187]
Ø 4.75
[.187]
4-40 UNC threads
4-40 UNC threads
R4
R7*1
4-40 threaded hole
4-40 threaded hole, alignment bar
Ø3.05 [.120]
clearance hole
Ø3.05 [.120]
clearance hole
0.38
[.015]
Connector housing
(shells)
Mounting bracket
4-40 UNC Threads
R3/R6 has Ø 3.05
[.120] clearance hole.
4-40 UNC threads
4-40 UNC threads
R5
R8*1
Angle brackets, swaged, metal, 4-40 locknut
4-40 locknut, alignment bar
0.38
[.015]
Connector housing
(shells)
Mounting bracket
4-40 UNC Threads
nominal.
4-40 UNC threads
with locknut
Polyester locknut
insert
4-40 UNC threads
with locknut
*1 Contact alignment bar is supplied with R2, R6, R7 and R8 options only.
23
Positronic
D-Sub Accessories Boardlocks
FERRITE INDUCTOR BAR / BEADS
F
Ferrite inductor*1
Q
3.43±0.13
[.135±.005]
Ferrite inductor bar*2
Notes
*1 This bar option is available for connector layout options 9, 15, 25, and
37. Ferrite beads are used for the other sizes. Contact Technical Sales
for ferrite inductor ordering information on those connectors.
Ferrite inductor*1,
for use with boardlocks and
right angle mounting brackets
*2 Specify Code F or Q when ordering. F is for ferrite inductor and Q is for
ferrite inductor with boardlocks and right angle brackets.
FERRITE INDUCTOR AVAILABILITY
A
0.25 [0.010]
Nominal
L
Series
A
L
MD, MDX,
HDC
9.53 [.375]
6.10 [.240]
ODD
9.53 [.375]
4.19 [.165]
DD
13.08 [.515]
4.19 [.165]
33
MD, MDX,
HDC
9.53 [.375]
9.27 [.365]
36
ED, HDC
9.53 [.375]
2.57 [.101]
4
MD, MDX
5
ODD
59
MD
6
MD, HDC
9.53 [.375]
9.14 [.360]
32
IMPEDANCE [OHMS]
FILTERING CHARACTERISTICS
ATTENUATION [dB]
Termination
Code
FREQUENCY
BOARDLOCKS
For use with code R,R2,R3,R4,R5,R6,R7,and R8
N
Boardlocks, for use with angle brackets
Typical Performance Evaluation Data
Internal View of Boardlock
Printed Board
Hole Ø
2.79 [.110]
Ø Hole
Ø3.120±0.08 [.123±.003] for use
with boardlock.
Printed
board
3.33
[.131]
24
Retention force
Newton
Lbs.
Newton
Lbs.
3.05 [.120]
32.25
7-1/4
25.58
5-3/4
3.12 [.123]
25.58
5-3/4
24.47
5-1/2
3.18 [.125]
12.23
2-3/4
11.12
2-1/2
3.25 [.128]
7.78
1-3/4
10.01
2-1/4
3.20 [.126]
Plated
7.78
1-3/4
10.01
2-1/4
Mounting
bracket
Printed board
Insertion force
Positronic
D-Sub Accessories Other Options
BLIND MATE SYSTEM
Blind mating guide pins Float mounting plate
(MOS -759.0)
(MOS -759.1)
To obtain blind mating guide pins, add the suffix
‘-759.0’ to the end of the part number.
To obtain float mounting plate, add the suffix
‘-759.1’ to the end of the part number.
18.92
[.745]
A
C
B
Ø2.84±0.08
[.112±.003]
Ø3.05 [.120] hole
0.84 [.033] total diametral float,
0.25 [.010] total axial float
Contact Technical Sales for additional ordering information
Shell
Size
A
(nominal)
B
C
1
49.02 [1.93]
17.20 [0.677]
40.28 [1.586]
2
57.35 [2.258]
17.20 [0.677]
48.62 [1.914]
3
71.25 [2.805]
17.20 [0.677]
62.51 [2.461]
4
87.53 [3.446]
17.20 [0.677]
78.79 [3.102]
5
85.14 [3.352]
20.04 [0.789]
76.40 [3.008]
6
87.53 [3.446]
21.59 [.850]
78.79 [3.102]
The use of blind mating hardware on D-Sub connectors can create
functional challenges within the application and therefore requires
additional mechanical design rigor. Be aware that system tolerances
must be exact and mating force allowances may need to be higher
than expected. Customers should qualify the use of this option in
their particular application.
FLARED CONNECTOR HOUSING (SHELL)
Flared MOS-1503.33
Standard
Flared connector housings provide a more generous
misalignment characteristics than standard
D-subminiature connector housings.
Connector housing for reference
for part numbers
and detail information.
IN-LINE CRIMP SPLICE
B
L
A
Contact Technical Sales for crimp tool part number
PART NUMBER
WIRE SIZE
AWG / [mm2]
L
A
B
PSK43636-*1
20-26 [0.5/0.12]
12.70
[.500]
1.14
[.045]
1.93
[.076]
PSK43637-*1
16-20 [1.5/0.5]
14.61
[.575]
1.68
[.066]
2.57
[.101]
PSK43638-*1
12-18 [4.0-1.0]
14.66
[.577]
2.46
[.097]
3.81
[.150]
*1 To order crimp splice with insulating sleeve, add ‘-W’ suffix to part number.
To order without sleeve, add ‘-N’ suffix.
25
Positronic
CUL-DE-SAC STYLE INSIDE WALL MOUNT
For use with code WD and WDD
C7*1
C5 *1
C8*1
Inside wall mount
3.81 [.150]
Inside wall mount, boardlocks
3.81 [.150]
3.81 [.150]
3.30 [.130]
3.30 [.130]
3.30 [.130]
Water-tight
Sealing
Water-tight
Sealing
Water-tight
Sealing
4-40 UNC
threads
4-40 UNC
threads
4-40 UNC
threads
ENCLOSURE WALL MOUNT SEALING PLATE
A*1
Inside wall mount sealing plate
Enclosure
O-ring
Enclosure
O-ring
UNIBODY DESIGN
LEGACY DESIGN
*1 Sealing plate is mounted to enclosure wall with
jackscrews torqued to a value of .20 Nm [1.75 in-lb]
minimum, .25 Nm [.2.25 in-lb] maximum.
Enclosure mount
sealing plate
Enclosure mount
sealing plate
3.81 [.150]
3.81 [.150]
2.03 [.080] max.
2.03 [.080] max.
OUTSIDE WALL ENCLOSURE MOUNT
For use sealed D-sub connectors requiring to be mounted to outside of the enclosure
C9
Enclosure
Outside wall mount, sealing plate*1
O-ring
NOTE: Outside wall mount not
available in unibody design
Fix female
jackpost
4-40 UNC threads
Enclosure mount
sealing plate
3.81 [.150]
5.08 [.200] max.
practical limit
26
Positronic
INTERFACIAL SEAL
Available for male connectors only. Furnished with all male WD and WDD series connectors
A
Size 25 interfacial seal shown
for reference only
B
Shell
Size
Gender
A
B
1
Male
17.17 [.676]
8.59 [.338]
2
Male
25.40 [1.000]
8.59 [.338]
3
Male
39.37 [1.550]
8.59 [.338]
4
Male
55.57 [2.188]
8.59 [.338]
5
Male
52.78 [2.078]
11.18 [.440]
6
Male
56.17 [2.212]
12.85 [.506]
INTERFACIAL SEAL / REAR GROMMENTS
For use with EVD series
INTERFACIAL SEAL & REAR GROMMET
Interfacial
seal
Rear grommet
Layout
9
INTERFACIAL SEAL
0.94
[.037]
A
15
B
25
10.41
[.410]
A
2.29
[.090]
37
REAR GROMMET
B
50
Seal Type
A
B
Interfacial
16.51 [.650]
8.08 [.318]
Grommet
18.421 [.725]
9.53 [.375]
Interfacial
24.84 [.978]
8.08 [.318]
Grommet
26.70 [1.051]
9.53 [.375]
Interfacial
38.43 [1.513]
8.08 [.318]
9.53 [.375]
Grommet
40.51 [1.595]
Interfacial
54.76 [2.156]
8.08 [.318]
Grommet
57.07 [2.247]
9.53 [.375]
Interfacial
52.27 [2.058]
10.80 [.425]
Grommet
54.53 [2.147]
12.45 [.490]
SEALING PLUGS
For use with EVD series, Order separately, part number A4737-37-0-0
3.48
[.137]
14.16
[.557]
ø2.36
[ø.093]
ø1.40
[ø.055]
27
Positronic
PROTECTIVE COVER
Cover Without Ears
REPLACEMENT PART NUMBERS
Shell Size
For connectors without fixed female jackscrews
Gender
Conductive
Without Ears
Static Dissipative
Without Ears
With Ears
Male
A4931-9-0-0
A4931-9-1-0
A4931-9-100-0
Female
A4932-9-0-0
A4932-9-1-0
A4932-9-100-0
Male
A4931-15-0-0
A4931-15-1-0
A4931-15-100-0
Female
A4932-15-0-0
A4932-15-1-0
A4932-15-100-0
Male
A4931-25-0-0
A4931-25-1-0
A4931-25-100-0
Female
A4932-25-0-0
A4932-25-1-0
A4932-25-100-0
Male
A4931-37-0-0
A4931-37-1-0
A4931-37-100-0
Female
A4932-37-0-0
A4932-37-1-0
A4932-37-100-0
Male
A4931-50-0-0
A4931-50-1-0
A4931-50-100-0
Female
A4932-50-0-0
A4932-50-1-0
A4932-50-100-0
Male
A4931-16-100-0
Female
A4932-16-100-0
1
2
3
Cover With Ears
For connectors with fixed female jackscrews
4
5
6
EMI/RFI PROTECTIVE COVER
For use with code SAD, SADD, SACBM, SND, SDD, SCBM, SCBC, SCBDD and SCBCD
EMI/RFI Cover
Shell
Size
A
PART NUMBER
Mates To
Gender
PSK633-9MG*1
Female
1
B
PSK633-9FG*1
Male
PSK633-15MG*1
Female
C
PSK633-15FG*1
Male
PSK633-25MG*1
Female
30.81 [1.213]
12.55 [.494]
PSK633-25FG*1
Male
PSK633-37MG*1
Female
10.90 [.429]
10.72 [.422]
PSK633-37FG*1
Male
PSK633-50MG*1
Female
10.82 [.426]
PSK633-50FG*1
Male
PSK633-104MG*1
Female
10.82 [.426]
PSK633-104FG*1
Male
12.55 [.494]
10.90 [.429]
10.82 [.426]
15.37 [.605]
10.90 [.429]
10.82 [.426]
69.32 [2.729]
6
12.55 [.494]
10.90 [.429]
66.93 [2.635]
5
12.55 [.494]
10.90 [.429]
69.32 [2.729]
4
C
±0.25
[.010]
10.72 [.422]
53.04 [2.088]
3
B
±0.38
[.015]
39.14 [1.541]
2
*1
A
±0.38
[.015]
16.97 [.668]
10.90 [.429]
To order protective cover with code ‘E2’ rotating male screw locks, insert “N” into the last digit of
part number. Omit this digit if thread locks are not required.
28
Positronic
MACHINED ALUMINUM MOUNTING PLATE
With conductive o-ring
Fixed female jackscrews
Enclosure shown
for reference only
Panel mount
sealing plate
Silicone
sealant
Rear shell
Front shell
Epoxy sealant
O-ring
O-ring seal
2.03 [.080] max.
panel thickness
3.81 [.150]
4.50 [.177]
OTHER SEALED D-SUBMINIATURE CONNECTOR OPTIONS
MD Style Connector
COMBO-D Style Connector
Panel mount
sealing plate
Silicone sealant
Contacts have
special water-tight
interference fit seal
into insulator
Female contact
Rear shell
Contacts are
sealed to insulator
with epoxy sealant
Front shell
ODD Style Connector
Silicone sealant
Female contact
Rear shell
Front shell
Epoxy sealant
O-ring seal
Silicone sealant
Silicone sealant
Interfacial seal, contact
technical sales for
availability of all sizes
Silicone sealant
Interfacial seal
Male contact
Male contact
Rear shell
Front shell
Contacts are sealed
to insulator with
epoxy sealant
Rear shell
Front shell
SEALED STANDARD OR HIGH DENSITY D-SUBMINATURE
• Available in both standard density and high density connector variants.
• Standard MD or ODD series connectors can be sealed between the connector shell and the connector insert.
• Contact technical sales for more information.
SEALED COMBINATION D-SUBMINATURE
• Could be supplied with mounting plate or without.
• Contact technical sales for more information or additional contact configurations.
29
Positronic
Accessories Online
See connectpositronic.com/Dsub
for all other Dsub-related
information including:
Footprints
Tooling
Product updates
Detailed dimensions
2D/3D drawings
All dimensional tolerances are ± 0.38 [0.015], unless otherwise specified. Dimensions are in millimeter [inches]. All
dimensions are subject to change. Product pictures may not be identical in appearance to actual production parts.
Information in this catalog is proprietary to Positronic and its subsidiaries. Positronic believes the data contained herein to
be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion
and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in
whole or in part.
Products described within this catalog may be protected
by one or more of the following US patents:
#4,900,261*
#6,835,079
#5,255,580
#7,115,002
Patented in Canada, 1992
The following trademarks are owned by Positronic Industries, Inc.: Positronic Industries, Inc.®, Positronic®, Connector
Excellence®, P+ logo®, PosiBand®, PosiShop®, Optik-D™, and The Science of Certainty®. The color blue as it appears
on various connectors is a trademark of Positronic Industries, Inc., Registered in U.S. Patent and Trademark Office.
#5,329,697
#8,944,697
#6,260,268
#9,304,263
Other patents pending
Federal Supply Code for Manufacturers
Positronic Industries: 28198
Positronic Industries SAS: FA7Y0
Positronic Asia PTE LTD: QB952
Positronic | Americas
Positronic | Europe
Positronic | Asia
Sales Offices
423 N Campbell Ave
46 route d’Engachies
3014A Ubi Rd 1 #07-01
Positronic has local sales
Springfield MO 65806 USA
F-32020 Auch Cedex 9 France
+65 6842 1419
representation all over the world.
+1 800 641 4054
+33 5 6263 4491
Singapore 408703
For the nearest sales office visit
info@connectpositronic.com
contact@connectpositronic.com
singapore@connectpositronic.com
www.connectpositronic.com/sales
