FEEDER-CHOLDER
FEEDER-CHOLDER
    FORTEX
    FORTEX - FEEDER-CHOLDER - Reel Holder, MPP1 Manual Pick & Place Manipulator
FEEDER-CHOLDER 数据手册
MPP1 VISION PICK & PLACE MANIPULATOR The MPP1 Manual Pick & Place Manipulator is a compact system intended for manual assembling of PCB prototypes or small series PCBs. The assembly head performs a smooth movement in both X and Y axis and therefore it allows the user to comfortably pick the components from the feeders and put them gently and accurately onto a PCB. Precise movement of the header in Z axis direction, allows very gentle placing of larger components (Integrated circuits, processors) into the Solder paste, using the integrated vacuum switch. Rotation of components can be regulated by a button on the manipulator head. Effective lighting is also integrated in the assembling head. Features:-               Perfect ergonomics Very efficient working area of 380x295mm Placement made easier by a colour Full HD camera connected to a 15″ TFT LCD monitor Standard HDMI output so larger monitor can be connected if required 0201, QFN Package Placement accuracy Vacuum pump with selection of syringes Arm support assures a comfortable position for operator Sensitive head with 360° rotation of pipette Efficient lighting built into the arm Optional Feeders ensure machine is suitable for taped or reeled components Vacuum pump delivered as standard 3 Board supports
FEEDER-CHOLDER 价格&库存
很抱歉,暂时无法提供与“FEEDER-CHOLDER”相匹配的价格&库存,您可以联系我们找货
