CBS2004828
CBS2004828
    COSEL
CBS2004828 数据手册
DC-DC Converters Bus Converter . Power Module Type Low Profile Isolated Safety Approvals OCP OVP Remote ON/OFF CBS-series Feature Optional parts Compact DC-DC Converter, ”HALF BRICK” which has been standard size for Telecommunication Market High efficiency High density High reliability : not built-in aluminum and tantalum electrolytic capacitor Built-in overcurrent, overvoltage and thermal protection circuits Built-in remote ON/OFF Mounting hole (M3 tapped) Optional parts Heat sink Model CBS50, CBS100, CBS200 CE marking Low Voltage Directive RoHS Directive UKCA marking Electrical Equipment Safety Regulations RoHS Regulations Safety agency approvals UL60950-1, C-UL recognized, TuV approved 5-year warranty www.cosel.co.jp/en/ December 27, 2022 CBS-1 DC-DC Converters Bus Converter . Power Module Type CBS50 Ordering information CB S 50 48 12 -O 1 2 3 4 5 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 24 :DC18 - 36V 48 :DC36 - 76V 5 Output voltage 6 Optional R : with Remote ON/OFF Positive logic control T : with Mounting hole f3.4 thru FO:w i t h A d d i t i o n o f a Heat sink R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS50241R8 21.06 1.8V 11.7A CBS50242R5 29.25 2.5V 11.7A CBS502403 38.6 3.3V 11.7A CBS502405 50.0 5V 10A CBS502412 50.4 12V 4.2A CBS502415 51.0 15V 3.4A CBS502424 50.4 24V 2.1A CBS502428 50.4 28V 1.8A CBS50241R8 CBS50242R5 CBS502403 CBS502405 CBS502412 DC18 - 36 1.24typ 1.58typ 2.04typ 2.48typ 2.39typ 79typ 84typ 88typ 71typ 77typ 1.8 2.5 3.3 5 12 11.7 11.7 11.7 10 4.2 10max 10max 24max 10max 10max 10max 10max 24max 10max 10max 80max 80max 80max 80max 120max 120max 120max 150max 120max 120max 120max 120max 120max 120max 150max 200max 200max 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 24V, Io=100%) Fixed (TRM pin open), adjustable by external resistor 1.70 - 1.98 1.98 - 2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 1.77 - 1.88 2.46 - 2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 Works over 105% of rating and recovers automatically 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 Provided Provided (Negative logic L : ON, H : OFF) CBS502415 CBS502424 CBS502428 2.44typ 87typ 15 3.4 30max 30max 120max 150max 150max 200max 150max 300max 60max 2.41typ 87typ 24 2.1 48max 48max 120max 150max 150max 250max 240max 480max 90max 2.41typ 87typ 28 1.8 56max 56max 120max 150max 150max 250max 280max 560max 90max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 CBS504812 50.4 12V 4.2A CBS504815 51.0 15V 3.4A CBS504824 50.4 24V 2.1A CBS504828 50.4 28V 1.8A CBS50481R8 CBS50482R5 CBS504803 CBS504805 CBS504812 DC36 - 76 0.62typ 0.79typ 1.01typ 1.23typ 1.18typ 80typ 85typ 89typ 71typ 77typ 1.8 2.5 3.3 5 12 11.7 11.7 11.7 10 4.2 10max 10max 10max 10max 24max 10max 10max 10max 10max 24max 80max 80max 80max 80max 120max 120max 120max 120max 120max 150max 120max 120max 120max 120max 150max 200max 200max 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 48V, Io=100%) Fixed (TRM pin open), adjustable by external resistor 1.70 - 1.98 1.98 -2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 1.77 - 1.88 2.46 -2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 Works over 105% of rating and recovers automatically 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 Provided Provided (Negative logic L : ON, H : OFF) CBS504815 CBS504824 CBS504828 1.21typ 88typ 15 3.4 30max 30max 120max 150max 150max 200max 150max 300max 60max 1.19typ 88typ 24 2.1 48max 48max 120max 150max 150max 250max 240max 480max 90max 1.19typ 88typ 28 1.8 56max 56max 120max 150max 150max 250max 280max 560max 90max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS50481R8 21.06 1.8V 11.7A CBS50482R5 29.25 2.5V 11.7A CBS504803 38.6 3.3V 11.7A CBS504805 50.0 5V 10A SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF CBS-2 December 27, 2022 www.cosel.co.jp/en/ CBS50 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE PIN, BASE PLATE OUTPUT-CASE PIN, BASE PLATE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20t15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 57.9X12.7X61.0mm [2.28X0.5X2.4 inches](WXHXD) / 83g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC24V,DC48V) and rated load. *2 Ripple and ripple noise is measured by using measuring board with recommended capacitor Co & the film capacitor 0.1mF. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN:RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 When the input voltage is in the range of DC18 - 20V, DC36 - 40V, output voltage adjustment range is 60 - 105% (except for 1R8/2R5). External view ¶Recomending size for processing PCB 48.3 [0.19] ±0.5 2-º2 ±0.2 [1.9] [0.08] Name Plate [0.4] [0.3] [0.3] [0.4] 10.16 7.62 7.62 10.16 4-º3.5 [0.14] 48.3 [1.9] ¶Dimensions in mm, [ ¶Div. : 0.5inch ]= inches ¶Weight : 83g max ¶Tolerance : ±0.3 [±0.012] ¶Case : PBT ¶Base Plate: Aluminum ¶Dimensions in mm, [ ]= inches ¶Mounting hole screwing torque : 0.49N•m(5.0kgf•cm)max [0.2] +VOUT +VIN (5.1) [0.4] TRM +S RC [2.4] -S 61max CASE [2] -VOUT 50.8 ±0.5 -VIN [0.6] [0.4] [0.04] 10.16 15.24 10.16 50.8 [2.0] 2-º2.5 [0.1] 7.62 [0.3] 7.62 10.16 15.24 10.16 [0.3] [0.4] [0.6] [0.4] [2.28] (4.8) 7-º1.5 [0.06] 4-M3 Mounting Hole 57.9max 7-º1±0.1 [0.5] Case(PBT) 12.7 ±0.5 Lot No. [0.2] Base Plate(Aluminum) 5.08 ±0.5 (TOP VIEW) Performance data ¡INPUT CURRENT CHARACTERISTICS (CBS502428) ¡INPUT CURRENT CHARACTERISTICS (CBS504828) 4 4 INPUT CURRENT INPUT CURRENT A 5 A 5 3 Io=100% 2 Io=50% 1 3 2 Io=100% 1 Io=50% 0 0 www.cosel.co.jp/en/ 10 20 INPUT VOLTAGE V 30 40 0 December 27, 2022 0 20 40 INPUT VOLTAGE V 60 80 CBS-3 DC-DC Converters Bus Converter . Power Module Type CBS100 Ordering information CB 1 S 100 48 2 3 4 12 -O 5 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 24:DC18 - 36V 48:DC36 - 76V 5 Output voltage 6 Optional R : with Remote ON/OFF Positive logic control T : with Mounting hole f3.4 thru FO:w i t h A d d i t i o n o f a Heat sink R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS100241R8 42.12 1.8V 23.4A CBS100242R5 58.50 2.5V 23.4A CBS1002403 77.2 3.3V 23.4A CBS1002405 100.0 5V 20A CBS1002412 100.8 12V 8.4A CBS1002415 100.5 15V 6.7A CBS1002424 100.8 24V 4.2A CBS1002428 100.8 28V 3.6A CBS100241R8 CBS100242R5 CBS1002403 CBS1002405 CBS1002412 DC18 - 36 2.47typ 3.17typ 4.07typ 5.02typ 4.77typ 71typ 77typ 79typ 83typ 88typ 1.8 2.5 3.3 5 12 23.4 23.4 23.4 20 8.4 10max 10max 24max 10max 10max 10max 10max 10max 10max 24max 80max 80max 80max 80max 120max 120max 120max 120max 120max 150max 120max 120max 120max 120max 150max 200max 200max 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 24V, Io=100%) Fixed (TRM pin open), adjustable by external resistor 1.70 - 1.98 1.98 - 2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 1.77 - 1.88 2.46 - 2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 Works over 105% of rating and recovers automatically 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 Provided Provided (Negative logic L : ON, H : OFF) CBS1002415 CBS1002424 CBS1002428 4.81typ 87typ 15 6.7 30max 30max 120max 150max 150max 200max 150max 300max 60max 4.83typ 87typ 24 4.2 48max 48max 120max 150max 150max 250max 240max 480max 90max 4.83typ 87typ 28 3.6 56max 56max 120max 150max 150max 250max 280max 560max 90max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 CBS1004812 100.8 12V 8.4A CBS1004815 100.5 15V 6.7A CBS1004824 100.8 24V 4.2A CBS1004828 100.8 28V 3.6A CBS100481R8 CBS100482R5 CBS1004803 CBS1004805 CBS1004812 DC36 - 76 1.24typ 1.58typ 2.01typ 2.48typ 2.36typ 71typ 77typ 80typ 84typ 89typ 1.8 2.5 3.3 5 12 23.4 23.4 23.4 20 8.4 10max 10max 10max 10max 24max 10max 10max 10max 10max 24max 80max 80max 80max 80max 120max 120max 120max 120max 120max 150max 120max 120max 120max 120max 150max 200max 200max 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 48V, Io=100%) Fixed (TRM pin open), adjustable by external resistor 1.70 - 1.98 1.98 -2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 1.77 - 1.88 2.46 -2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 Works over 105% of rating and recovers automatically 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 Provided Provided (Negative logic L : ON, H : OFF) CBS1004815 CBS1004824 CBS1004828 2.38typ 88typ 15 6.7 30max 30max 120max 150max 150max 200max 150max 300max 60max 2.39typ 88typ 24 4.2 48max 48max 120max 150max 150max 250max 240max 480max 90max 2.39typ 88typ 28 3.6 56max 56max 120max 150max 150max 250max 280max 560max 90max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS100481R8 42.12 1.8V 23.4A CBS100482R5 58.50 2.5V 23.4A CBS1004803 77.2 3.3V 23.4A CBS1004805 100.0 5V 20A SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF CBS-4 December 27, 2022 www.cosel.co.jp/en/ CBS100 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE PIN, BASE PLATE OUTPUT-CASE PIN, BASE PLATE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20t15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 57.9X12.7X61.0mm [2.28X0.5X2.4 inches] (WXHXD) / 83g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC24V,DC48V) and rated load. *2 Ripple and ripple noise is measured by using measuring board with recommended capacitor Co & the film capacitor 0.1mF. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN:RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 When the input voltage is in the range of DC18 - 20V, DC36 - 40V output voltage adjustment range is 60 - 105% (except for 1R8/2R5). External view ¶Recomending size for processing PCB 48.3 ±0.5 2-º2 ±0.2 [1.9] [0.19] [0.08] Name Plate 4-º3.5 [0.14] [0.4] [0.3] [0.3] [0.4] 48.3 [1.9] ¶Dimensions in mm, [ ¶Div. : 0.5inch ]= inches ¶Weight : 83g max ¶Tolerance : ±0.3 [±0.012] ¶Case : PBT ¶Base Plate: Aluminum ¶Dimensions in mm, [ ]= inches ¶Mounting hole screwing torque : 0.49N•m(5.0kgf•cm)max [0.2] +VOUT +VIN (5.1) [0.4] [2] TRM +S RC 10.16 7.62 7.62 10.16 -S [2.4] CASE 61max -VOUT 50.8 ±0.5 -VIN [0.6] [0.4] [0.04] 10.16 15.24 10.16 50.8 [2.0] 2-º2.5 [0.1] 7.62 [0.3] 7.62 10.16 15.24 10.16 [0.3] [0.4] [0.6] [0.4] (4.8) 7-º1±0.1 7-º1.5 [0.06] 4-M3 Mounting Hole 57.9max [2.28] [0.5] Case(PBT) 12.7 ±0.5 Lot No. [0.2] Base Plate(Aluminum) 5.08 ±0.5 (TOP VIEW) Performance data ¡INPUT CURRENT CHARACTERISTICS (CBS1002428) 8 8 INPUT CURRENT A 10 A INPUT CURRENT ¡INPUT CURRENT CHARACTERISTICS (CBS1004828) 10 6 Io=100% 4 Io=50% 2 6 4 Io=100% 2 Io=50% 0 0 www.cosel.co.jp/en/ 10 20 INPUT VOLTAGE V 30 40 0 December 27, 2022 0 20 40 INPUT VOLTAGE 60 80 V CBS-5 DC-DC Converters Bus Converter . Power Module Type CBS200 Ordering information CB 1 S 200 48 2 3 12 -O 4 5 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 24:DC18 - 36V 48:DC36 - 76V 5 Output voltage 6 Optional R : with Remote ON/OFF Positive logic control T : with Mounting hole f3.4 thru FO:w i t h A d d i t i o n o f a Heat sink R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS200241R8 63.00 1.8V 35A CBS200242R5 87.50 2.5V 35A CBS2002403 115.5 3.3V 35A CBS2002405 150.0 5V 30A CBS2002412 CBS2002415 CBS2002424 200.4 201.0 201.6 12V 16.7A 15V 13.4A 24V 8.4A CBS2002428 201.6 28V 7.2A SPECIFICATIONS MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] CBS200241R8 CBS200242R5 CBS2002403 CBS2002405 CBS2002412 DC18 - 36 INPUT 3.75typ 4.80typ 6.09typ 7.62typ 9.60typ 70typ 76typ 79typ 82typ 87typ 1.8 2.5 3.3 5 12 35 35 30 16.7 35 10max 10max 24max 10max 10max 10max 10max 10max 10max 24max 80max 80max 80max 80max 120max 120max 120max 120max 120max 150max 120max 120max 120max 120max 150max 200max 200max OUTPUT 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 24V, Io=100%) Fixed (TRM pin open), adjustable by external resistor OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 1.70 - 1.98 1.98 - 2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 OUTPUT VOLTAGE SETTING[V] 1.77 - 1.88 2.46 - 2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 CIRCUIT AND REMOTE SENSING Provided OTHERS REMOTE ON/OFF Provided (Negative logic L : ON, H : OFF) MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS200481R8 63.00 1.8V 35A CBS200482R5 87.50 2.5V 35A CBS2004803 115.5 3.3V 35A CBS2004805 150.0 5V 30A CBS2002415 CBS2002424 CBS2002428 9.63typ 87typ 15 13.4 30max 30max 120max 150max 150max 200max 150max 300max 60max 9.66typ 87typ 24 8.4 48max 48max 120max 150max 150max 250max 240max 480max 90max 9.66typ 87typ 28 7.2 56max 56max 120max 150max 150max 250max 280max 560max 90max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 CBS2004812 CBS2004815 200.4 201.0 12V 16.7A 15V 13.4A CBS2004824 201.6 24V 8.4A CBS2004828 201.6 28V 7.2A CBS2004848 201.6 48V 4.2A CBS2004815 CBS2004824 CBS2004828 CBS2004848 4.76typ 88typ 15 13.4 30max 30max 120max 150max 150max 200max 150max 300max 60max 4.77typ 88typ 24 8.4 48max 48max 120max 150max 150max 250max 240max 480max 90max 4.77typ 88typ 28 7.2 56max 56max 120max 150max 150max 250max 280max 560max 90max 4.77typ 88typ 48 4.2 96max 96max 200max 250max 250max 400max 480max 960max 180max 9.0 - 16.5 14.55 - 15.45 14.4 - 26.4 23.28 - 24.72 16.8 - 30.8 27.16 - 28.84 43.2 - 52.8 46.56 - 49.44 17.25 - 21.00 27.60 - 33.60 32.20 - 39.20 55.20 - 67.20 SPECIFICATIONS MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 RIPPLE[mVp-p] -40 to -20C *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] CBS200481R8 CBS200482R5 CBS2004803 CBS2004805 CBS2004812 DC36 - 76 1.88typ 2.40typ INPUT 3.01typ 3.77typ 4.74typ 70typ 76typ 80typ 83typ 88typ 1.8 2.5 3.3 5 12 35 35 35 30 16.7 10max 10max 10max 10max 24max 10max 10max 10max 10max 24max 80max 80max 80max 80max 120max 120max 120max 120max 120max 150max 120max 120max 120max 120max 150max 200max 200max OUTPUT 200max 200max 200max 35max 35max 35max 50max 120max 66max 66max 66max 100max 240max 16max 16max 16max 20max 40max 200max (DCIN 48V, Io=100%) Fixed (TRM pin open), adjustable by external resistor OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 1.70 - 1.98 1.98 -2.75 1.98 - 3.63 3.0 - 5.5 7.2 - 13.2 OUTPUT VOLTAGE SETTING[V] 1.77 - 1.88 2.46 -2.61 3.25 - 3.45 4.90 - 5.20 11.74 - 12.46 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 2.16 - 2.88 3.00 - 4.00 4.00 - 5.50 5.75 - 7.00 13.80 - 16.80 CIRCUIT AND REMOTE SENSING Provided OTHERS REMOTE ON/OFF Provided (Negative logic L : ON, H : OFF) CBS-6 December 27, 2022 www.cosel.co.jp/en/ CBS200 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE PIN, BASE PLATE OUTPUT-CASE PIN, BASE PLATE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20t15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 57.9X12.7X61.0mm [2.28X0.5X2.4 inches] (WXHXD) / 83g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC24V,DC48V) and rated load. *2 Ripple and ripple noise is measured by using measuring board with recommended capacitor Co & the film capacitor 0.1mF. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN:RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 When the input voltage is in the range of DC18 - 20V, DC36 - 40V, output voltage adjustment range is 60 - 105% (except for 1R8/2R5/48). External view ¶Recomending size for processing PCB 48.3 ±0.5 2-º2 ±0.2 [1.9] 7-º1±0.1 [0.08] Name Plate [0.4] [0.3] [0.3] [0.4] 10.16 7.62 7.62 10.16 4-º3.5 [0.14] 48.3 [1.9] ¶Dimensions in mm, [ ¶Div. : 0.5inch ]= inches ¶Weight : 83g max ¶Tolerance : ±0.3 [±0.012] ¶Case : PBT ¶Base Plate: Aluminum ¶Dimensions in mm, [ ]= inches ¶Mounting hole screwing torque : 0.49N•m(5.0kgf•cm)max [0.2] +VOUT +VIN (5.1) [0.4] TRM +S RC [2.4] -S 61max CASE [2] -VOUT 50.8 ±0.5 -VIN [0.6] [0.4] [0.04] 10.16 15.24 10.16 50.8 [2.0] 2-º2.5 [0.1] 7.62 [0.3] 7.62 10.16 15.24 10.16 [0.3] [0.4] [0.6] [0.4] [2.28] [0.19] 7-º1.5 [0.06] 4-M3 Mounting Hole 57.9max (4.8) [0.5] Case(PBT) 12.7 ±0.5 Lot No. [0.2] Base Plate(Aluminum) 5.08 ±0.5 (TOP VIEW) Performance data ¡INPUT CURRENT CHARACTERISTICS (CBS2004828) 20 15 15 A 20 10 Io=100% 5 Io=50% INPUT CURRENT INPUT CURRENT A ¡INPUT CURRENT CHARACTERISTICS (CBS2002428) 10 Io=100% 5 Io=50% 0 0 www.cosel.co.jp/en/ 10 20 INPUT VOLTAGE V 30 40 0 December 27, 2022 0 20 40 INPUT VOLTAGE V 60 80 CBS-7 DC-DC Converters Bus Converter . Power Module Type CBS350 Ordering information CB 1 S 350 48 2 3 4 12 -O 5 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional R : with Remote ON/OFF Positive logic control T : with Mounting hole f3.4 thru R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS3502412 CBS3502424 CBS3502428 CBS3502432 CBS3502448 CBS3504812 CBS3504824 CBS3504828 CBS3504832 CBS3504848 300 348 350 352 302 348 348 350 352 350 12V 25A 24V 14.5A 28V 12.5A 32V 11A 48V 6.3A 12V 29A 24V 14.5A 28V 12.5A 32V 11A 48V 7.3A SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 -40 to -20C *2 RIPPLE[mVp-p] 0 to 15%Load *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to 15%Load *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS OUTPUT VOLTAGE SETTING[V] *1 OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-BASE PLATE OUTPUT-BASE PLATE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD CBS3502412 CBS3502424 CBS3502428 CBS3502432 CBS3502448 CBS3504812 CBS3504824 DC20 - 36 DC36 - 76 14.5typ 16.7typ 16.4typ 16.5typ 14.0typ 8.33typ 8.15typ 86typ 87typ 89typ 89typ 87typ 89typ 90typ 12 24 28 32 12 24 48 25 14.5 12.5 11 29 14.5 6.3 24max 48max 56max 64max 24max 48max 96max 24max 48max 56max 64max 24max 48max 96max 120max 150max 180max 180max 300max 120max 150max 150max 180max 220max 220max 360max 150max 180max 240max 300max 360max 360max 600max 240max 300max 150max 180max 220max 220max 360max 150max 180max 200max 250max 280max 280max 500max 200max 250max 300max 360max 440max 440max 720max 300max 360max 120max 240max 280max 320max 480max 120max 240max 240max 480max 560max 640max 960max 240max 480max 40max 90max 90max 120max 180max 40max 90max 200max (DCIN 24V, Io=100%) 200max (DCIN 48V, Fixed (TRM pin open), adjustable by external resistor CBS3504828 CBS3504832 CBS3504848 DC36 - 60 8.10typ 8.15typ 8.15typ 90typ 90typ 91typ 28 32 48 12.5 11 7.3 56max 64max 96max 56max 64max 96max 180max 180max 300max 220max 220max 360max 360max 360max 600max 220max 220max 360max 280max 280max 500max 440max 440max 720max 280max 320max 480max 560max 640max 960max 90max 120max 180max Io=100%) 7.2 - 13.2 14.4 - 26.4 16.8 - 30.8 25.6 - 35.2 38.4 - 52.8 7.2 - 13.2 14.4 - 26.4 16.8 - 30.8 25.6 - 35.2 38.4 - 55.2 11.88 - 12.12 23.76 - 24.24 27.72 - 28.28 31.68 - 32.32 47.52 - 48.48 11.88 - 12.12 23.76 - 24.24 27.72 - 28.28 31.68 - 32.32 47.52 - 48.48 Works over 105% of rating and recovers automatically 13.80 - 16.80 27.60 - 33.60 32.20 - 39.20 36.80 - 44.80 57.50 - 63.00 13.80 - 16.80 27.60 - 33.60 32.20 - 39.20 36.80 - 44.80 57.50 - 63.00 Provided Provided (Negative logic L : ON, H : OFF) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20t15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 57.9X12.7X61.0mm [2.28X0.5X2.4 inches] (WXHXD) / 83g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC24V,DC48V), rated load, and aluminum base plate temperature 25C. *2 Ripple and ripple noise is measured by using measuring board with recommended capacitor Co & the film capacitor 0.1mF. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 When the input voltage is in the range of DC20 - 22V, DC36 - 40V, output voltage is limited. Refer to the manual. CBS-8 December 27, 2022 www.cosel.co.jp/en/ CBS350 External view ¶Recomending size for processing PCB (TOP VIEW) 7-º1.5 [0.06] [0.2] 5.08 t0.5 Case(PBT) [2.28] 4-M3 Mounting Hole [1.9] 2-º2 t0.2 57.9max (4.8) [0.19] 7-º1t0.1 48.3 t0.5 [0.08] Name Plate www.cosel.co.jp/en/ [0.4] [0.3] [0.3] [0.4] 10.16 7.62 7.62 10.16 [2.4] +VOUT [0.2] +VIN 61max TRM +S [2] RC 50.8 t0.5 -S (5.1) [0.4] -VOUT NC [0.6] [0.4] 10.16 15.24 10.16 [0.04] -VIN 2-º2.5 [0.1] 7.62 [0.3] 7.62 10.16 15.24 10.16 [0.3] [0.4] [0.6] [0.4] [0.5] 12.7t0.5 Lot No. 50.8 [2.0] Base Plate(Aluminum) December 27, 2022 48.3 [1.9] 4-º3.5 [0.14] ¶Dimensions in mm, [ ¶Div. : 0.5inch ]= inches ¶Weight : 83g max ¶Tolerance : t0.3 [t0.012] ¶Case : PBT ¶Base Plate: Aluminum ¶Dimensions in mm, [ ]= inches ¶Mounting hole screwing torque : 0.49N•m(5.0kgf•cm)max CBS-9 DC-DC Converters Bus Converter . Power Module Type CBS450 Ordering information CB 1 S 450 48 2 3 4 28 -O 5 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional R : with Remote ON/OFF Positive logic control T : with Mounting hole f3.4 thru R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT CBS4504824 456 24V 19A CBS4504828 448 28V 16A CBS4504832 400 32V 12.5A SPECIFICATIONS INPUT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +100C *2 -40 to -20C *2 RIPPLE[mVp-p] 0 to 15%Load *2 -20 to +100C *2 RIPPLE NOISE[mVp-p] -40 to -20C *2 0 to 15%Load *2 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS OUTPUT VOLTAGE SETTING[V] *1 OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-BASE PLATE OUTPUT-BASE PLATE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD CBS4504824 CBS4504828 CBS4504832 DC38 - 60 DC36 - 76 DC36 - 76 10.6typ 10.5typ 9.3typ 90typ 91typ 91typ 24 28 32 19 16 12.5 48max 56max 64max 48max 56max 64max 180max 210max 210max 220max 260max 260max 360max 430max 430max 220max 260max 260max 280max 330max 330max 440max 520max 520max 240max 280max 280max 480max 560max 560max 90max 90max 120max 200max (DCIN 48V, Io=100%) Fixed (TRM pin open), adjustable by external resistor 19.2 - 26.0 16.8 - 32.2 25.6 - 35.2 23.52 - 24.48 27.44 - 28.56 31.36 - 32.64 Works over 105% of rating and recovers automatically 27.60 - 33.60 32.20 - 39.20 36.80 - 44.80 Provided Provided (Negative logic L : ON, H : OFF) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) DC1,500V or AC1,000V 1minute, Cutoff current = 10mA, DC500V 50MW min(20t15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20t15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 57.9X12.7X61.0mm [2.28X0.5X2.4 inches] (WXHXD) / 83g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC48V), rated load, and aluminum base plate temperature 25C. *2 Ripple and ripple noise is measured by using measuring board with recommended capacitor Co & the film capacitor 0.1mF. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for the input range. CBS-10 December 27, 2022 www.cosel.co.jp/en/ CBS450 External view ¶Recomending size for processing PCB (TOP VIEW) 7-º1.5 [0.06] [0.2] 5.08 t0.5 Case(PBT) [2.28] 4-M3 Mounting Hole [1.9] 2-º2 t0.2 57.9max (4.8) [0.19] 7-º1t0.1 48.3 t0.5 [0.08] Name Plate www.cosel.co.jp/en/ [0.4] [0.3] [0.3] [0.4] 10.16 7.62 7.62 10.16 [2.4] +VOUT [0.2] +VIN 61max TRM +S [2] RC 50.8 t0.5 -S (5.1) [0.4] -VOUT NC [0.6] [0.4] 10.16 15.24 10.16 [0.04] -VIN 2-º2.5 [0.1] 7.62 [0.3] 7.62 10.16 15.24 10.16 [0.3] [0.4] [0.6] [0.4] [0.5] 12.7t0.5 Lot No. 50.8 [2.0] Base Plate(Aluminum) December 27, 2022 48.3 [1.9] 4-º3.5 [0.14] ¶Dimensions in mm, [ ¶Div. : 0.5inch ]= inches ¶Weight : 83g max ¶Tolerance : t0.3 [t0.012] ¶Case : PBT ¶Base Plate: Aluminum ¶Dimensions in mm, [ ]= inches ¶Mounting hole screwing torque : 0.49N•m(5.0kgf•cm)max CBS-11 CBS-series Pin Configuration 4-Mounting hole No. 1 2 3 9 -VOUT -VIN 4 (CBS50/100/200) CASE 3 (CBS350/450)NC 8 -S 7 TRM RC 2 6 +S +VIN 1 5 +VOUT 4 5 6 7 8 9 Pin Name +VIN RC NC CASE -VIN +VOUT +S TRM -S -VOUT Mounting hole Function +DC input Remote ON/OFF No connection (CBS350/450) Wiring base plate (CBS50/100/200) -DC input +DC output +Remote sensing Adjustment of output voltage -Remote sensing -DC output Mounting hole *bottom view Implementation・Mounting Method Mounting method ¡When multiple power modules are used side by side, position them with sufficient spaces to allow adequate air ventilation so that the aluminum base plate temperature of each power module will remain within the temperature range shown in the ‟derating”. ¡Do not pass the DC input pattern underneath the power module as this will increase conducted noise. Place the DC input pattern away from the power module. Do not pass the DC output pattern underneath the power module as this will increase output noise. Place the DC output pattern away from the power module. ¡High frequency noise is radiated from the power module. When mounting the power module on a PCB, leave a copper pattern on the PCB to let it act as a shield and connect this pattern to the CASE pin (CBS50/100/200) or the mounting hole. ¡When a heat sink cannot be fixed on the base plate side, order the power module with ”-T”option. A heat sink can be mounted by affix- Standard Optional : -T ing a M3 tap on the heat sink. In case of CBS350/450, make sure a mounting hole will be connected to a grounding capacitor CY. Mounting hole M3 tapped f3.4 thru Stress onto the pins ¡Applying excessive stress to the input or output pins of the power module may damage internal connections. Avoid applying stress in ¡Input and output pins are soldered onto the internal PCB. Do not bend or pull the leads with excessive force. ¡As unexpected stress may be applied to the pins from vibration or shock, fix the power module by using the mounting holes with screws to reduce stress. +S +VOUT +VIN ¡As unexpected stress may be applied to the pins, set the diameter of the PCB mounting hole at 3.5mm. ¡Fix the power module to the PCB with the screws before soldering the input and output pins to prevent the PCB pattern being damaged. -VOUT -S TRM -VIN CASE NC RC excess of that shown in right figure. +VOUT, -VOUT Less than 39.2N(4kgf) Less than 39.2N(4kgf) Less than 39.2N(4kgf) Others Less than 19.6N(2kgf) Less than 19.6N(2kgf) Less than 19.6N(2kgf) Soldering temperature ¡Flow soldering ¡Soldering iron (26W) CBS-12 : 260ª for up to 15 seconds. : 450ª for up to 5 seconds. December 27, 2022 www.cosel.co.jp/en/ CBS-series Derating ¡Use the power modules with conduction cooling (e.g. heat dissipation from the aluminum base plate to the attached heat sink).Below shows the derating curves with respect to the aluminum base plate temperature. Note that operation within the hatched areas will cause a significant level of ripple and ripple noise. Contact us for more information on cooling methods. ¡It is necessary to note thermal fatigue life by power cycle. Please reduce the temperature fluctuation range as much as possible when the up and down of temperature are frequently generated.Contact for more information on cooling methods. ¿CBS50, CBS100, CBS200 2 1 Load factor[%] 100 Tc:Measuring point 1CBS200O12,15,24,28,48 2Others (Excluding CBS350/450) 50 Aluminum base plate 0 -40 -20 0 20 40 60 (85) 80 100 110 Aluminum base plate temperature Tc [C] ¿CBS350 Load factor[%] 100 (85.7) (83.3) 2 1CBS3502412,CBS3502448,CBS3504848 2Others (CBS350) 50 (15) 0 -40 -20 0 20 40 60 (85) 80 1 100 110 Aluminum base plate temperature Tc [C] ¿CBS400 Load factor[%] 100 (75) CBS450 50 (15) 0 -40 -20 0 20 40 60 (85) 80 100 110 Aluminum base plate temperature Tc [C] Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://www.cosel.co.jp/redirect/catalog/en/CBS/ Before using our product https://en.cosel.co.jp/technical/caution/index.html www.cosel.co.jp/en/ December 27, 2022 CBS NOTICE CBS-13 CBS-series Basic Characteristics Data Basic Characteristics Data Model Circuit method Switching frequency [kHz] CBS50 Forward converter 310 CBS100 Forward converter 370 CBS200 Forward converter 370 CBS350 Forward converter 370 CBS450 Forward converter 370 Input current [A] Material Single sided Series/Redundancy operation availability Double Series Redundancy sided operation operation - Aluminum Yes Yes - - Aluminum Yes Yes *1 - - Aluminum Yes Yes *1 Rated input fuse Inrush current protection Refer to table No.1 PCB/Pattern *1 - - Aluminum Yes Yes *1 - - Aluminum Yes Yes *1 *1 Refer to Instruction Manual. Table1. The value of input current (at rated input voltage and rated load) Model [A] Output Voltage 1.8V 2.5V 3.3V 5V 12V 15V 24V 28V 32V 48V CBS5024 1.2 1.6 2.0 2.5 2.4 2.4 2.4 2.4 - - CBS5048 0.6 0.8 1.0 1.3 1.2 1.2 1.2 1.2 - - CBS10024 2.5 3.2 4.1 5.0 4.8 4.8 4.8 4.8 - - CBS10048 1.2 1.6 2.0 2.5 2.4 2.4 2.4 2.4 - - CBS20024 3.8 4.8 6.1 7.6 9.6 9.6 9.7 9.7 - - CBS20048 1.9 2.4 3.0 3.8 4.8 4.8 4.8 4.8 - 4.8 CBS35024 - - - - 15 - 17 17 17 14 CBS35048 - - - - 8.4 - 8.2 8.1 8.2 8.2 CBS45048 - - - - - - 10.6 10.5 9.3 - CBS-14 December 27, 2022 www.cosel.co.jp/en/
CBS2004828
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4mm x 4mm。
CBS2004828 价格&库存
很抱歉,暂时无法提供与“CBS2004828”相匹配的价格&库存,您可以联系我们找货
CBS2004828
  • 1+1303.502071+169.45105
