H-SN-24
H-SN-24
    COSEL
H-SN-24 数据手册
Optional Parts Harness Mating harness Model LHA10F LHA15F LHA30F LHA50F LHA75F LHA100F LHA150F,LHP150F LHA300F,LHP300F LHA300F, LHP300F LHP300F LCA10S LCA15S LCA30S LCA50S, LGA50A LCA75S, LGA75A LCA100S, LGA100A LCA150S, LGA150A LGA240A, LFA300F, LFP300F TECS Harness model # Output Input H-OU-34 H-OU-34 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-18 H-IN-10 H-OU-18 H-OU-46 H-OU-10 H-OU-54 H-OU-7 H-IN-4 H-OU-8 H-IN-4 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-10 H-IN-10 H-OU-11 H-OU-12 H-OU-11 H-IN-14 H-OU-12 H-OU-9 H-IN-29 Model number H-IN-4 Model SNA-01,-03 SNA-06 SNR-10 LDA10F LDA15F LDA30F, LFA30F LDA50F, LEA50F, LFA50F LDA75F, LEA75F, LFA75F LDA100W, LEA100F, LFP100F, LFA100F LMA100F, LEP100F, 150F, 240F LDA150W, LEA150F, LFP150F, LFA150F, LFA240F, LFP240F, LMA150F, LMA240F LFA10F LFA15F LDA300W H-IN-5 Type Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-7 Type Housing : 1-178128-5 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 35g max Model number H-IN-10 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-14 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-IN-29 Housing : VHR-3N(J.S.T) Pin : SVH-21T-P1.1 or BVH-21T-P1.1 (J.S.T) Weight : 25g max Option-20 H-IN-7 H-OU-11 H-OU-12 H-OU-34 H-OU-34 H-OU-22 Optional : connector type ”-J” (LDA300W) Optional : connector type ”-J1” (LGA50A,75A,100A,150A,240A) Optional : connector type ”-J1” (LFA10F,15F,30F,50F,75F,100F,150F,240F,300F) Optional : connector type ”-J1” (LFP100F,150F,240F,300F) Optional : connector type ”-J1” (LMA100F,150F,240F) Optional : connector type ”-J5 ” (LHA300F) Optional : connector type ”-J5 ” (LHP300F) Housing : XHP-7 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 10g max Model number Harness model # Input Output H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-OU-18 H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-IN-5 or H-OU-10 H-IN-10 1 2 3 4 5 6 7 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 6 7 8 LCA Series LDA Series LGA Series LEA Series LEP Series LFA Series LFP Series LHA Series LHP Series LMA Series SNA Series SNR Series TECS Series Wire +50 -0 Pin # Wire AWG 1 2, 3 4 5, 6 7 UL1007 22 black Length (mm) 500 UL1007 22 white 500 UL1007 22 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 white Length (mm) 500 UL1015 18 black 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 ,2 3 4 ,5 6 7 ,8 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 UL1015 UL1015 AWG18 AWG18 white black Color Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire Type 1 2 3 +50 -0 October 26, 2023 Length (mm) 500 500 www.cosel.co.jp/en/ Optional Parts Model number H-OU-7 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Model number H-OU-8 Type Type Housing : XHP-4 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 15g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 40g max Model number H-OU-10 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Model number H-OU-11 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-12 Type Housing : VHR-7N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 70g max Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-22 Type Housing : 1-178288-8 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 100g max Model number H-OU-34 Type 1 2 1 2 3 4 1 2 3 4 1 2 3 4 5 6 7 8 1 2 3 4 5 6 1 2 3 4 5 6 7 1 2 3 4 5 6 1 2 3 4 5 6 7 8 9 10 1 2 Wire +50 -0 H-OU-46 Type Housing : VHR-10N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 100g max Model number H-OU-54 Housing : VHR-8N (J.S.T.) Pin : SVH-41T-P1.1 (J.S.T.) Weight : 100g max www.cosel.co.jp/en/ Type 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 Wire AWG Color 1 2 UL1007 UL1007 22 22 black red Pin # Wire AWG Color 1 2 3 4 UL1007 UL1007 UL1007 UL1007 22 22 22 22 black black red red Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Wire AWG Color UL1015 18 red Pin # Wire AWG Color 1-7 UL1015 18 black Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-4 5-8 UL1430 UL1430 16 16 black red Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Pin # 1-6 Length (mm) 500 +50 -0 Wire Length (mm) 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire +50 -0 Housing : VHR-2N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number Pin # Wire Length (mm) 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 October 26, 2023 Option-21 Optional Parts LGA Series LFA Series LFP Series LHA Series LHP Series LMA Series Mating harness Harness model # Input Output H-OU-33 H-OU-33 H-OU-28 H-OU-28 Model LFA10F LFA15F LFA30F, *LHA30F LFA50F, LGA50A, *LHA50F LFA75F, LGA75A, *LHA75F, *LHA100F,*LHA150F,*LHP150F LFP100F, LFA100F, LGA100A LMA100F H-IN-12 H-OU-31 H-OU-32 *LHA300F,*LHP300F H-IN-13 Model number H-IN-12 Type Housing : 1-1123722-5 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 30g max Model number H-IN-13 Type Housing : 1-1123722-8 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 55g max Model number H-OU-28 Type Housing : 1-1123722-4 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 40g max Model number H-OU-29 Type Housing : 1-1123722-6 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 60g max Model number H-OU-30 Type Housing : 1-1123722-8 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 75g max Model number H-OU-31 Housing : 1-1123722-6 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 60g max Option-22 *Optional:connector type "-J4" (LHA30F,50F,75F,100F,150F,300F) *Optional:connector type "-J4" (LHP150F,300F) H-OU-30 LFP150F, LFA150F, LGA150A, LFA240F, LFP240F, LMA150F LMA240F LGA240A, LFA300F LFP300F H-OU-29 Type H-OU-47 H-OU-31 H-OU-32 1 2 3 4 5 1 2 3 4 5 6 7 8 1 2 3 4 1 2 3 4 5 6 1 2 3 4 5 6 7 8 1 2 3 4 5 6 Wire +50 -0 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 ,2 3 4 ,5 6 7 ,8 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-6 UL1015 18 red Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire +50 -0 October 26, 2021 Length (mm) 500 Optional Parts Model number H-OU-32 Type 1 2 3 4 5 6 7 Housing : 1-1123722-7 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 70g max Model number H-OU-33 Type 1 2 Wire H-OU-47 Type Housing : 1-1123722-0 (TycoElectronics) Pin : 1123721-1 or 1318912-1 (TycoElectronics) Weight : 100g max 1 2 3 4 5 6 7 8 9 10 Wire AWG Color 1-7 UL1015 18 black Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Length (mm) 500 +50 -0 Wire +50 -0 Housing : 1-1123722-2 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 20g max Model number Pin # Wire Length (mm) 500 500 Length (mm) 500 500 +50 -0 LFP Series Harness for connecting the external capacitor unit is prepared for LFP240/300F(U1 type). Model number H-IN-23 Type 1 2 3 4 Housing : VHR-4N(J.S.T.) Pin : SVH-21T-P1.1(J.S.T.) Weight : 5g max +50 -0 Wire 1 2 3 4 Pin # 1 2 3 4 Wire AWG Color Length (mm) UL1015 20 black 100 UL1015 20 red 100 LHA Series LHP Series Harness for connecting the external capacitor unit is prepared for LHA150F/300F and LHP150F/300F (U1 type). Model number H-IN-25 CN A: Housing : VHR-3N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Type CN A 1 2 3 +50 -0 1 2 3 4 CN B Wire Pin # CN A CN B CN B: Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 1 2 3 4 Color black Length (mm) 100 20 red 100 UL1015 20 black 100 UL1015 20 red 100 Wire AWG UL1015 20 UL1015 Weight : 5g max October 26, 2021 Option-23 Optional Parts Mating harness Model LEB100F LEB150F LEB225F Input H-IN-5 or H-IN-10 Model number H-IN-5 Harness model # Option: -Z Output H-OU-23 H-OU-25 H-OU-23 H-OU-24 H-IN-10 H-OU-13 +50 -0 Type LEB Series LDC Series Pin # Wire AWG Color Length (mm) 1 2 3 4 5 UL1015 18 black 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color Length (mm) 1 2 3 4 5 UL1015 18 black 500 UL1015 18 white 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color Length (mm) 1, 2 3, 4 5 6, 7 8 UL1007 UL1007 UL1007 UL1007 UL1007 22 22 22 22 22 red black orange gray purple 500 500 500 500 500 Pin # Wire AWG Color Length (mm) 1 2, 3 4 5 6 UL1015 UL1015 UL1015 UL1015 UL1015 18 18 18 18 18 purple gray orange black red 500 500 500 500 500 Pin # Wire AWG Color Length (mm) 1 2, 3 4 5, 6 7, 8 UL1015 UL1015 UL1015 UL1015 UL1015 18 18 18 18 18 purple gray orange black red 500 500 500 500 500 Wire 1 2 3 4 5 +50 -0 Type Wire 1 2 3 4 5 6 7 8 Housing : XHP-8 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 25g max Harness model # Input Output H-OU-13 H-IN-5 or H-OU-14 H-IN-10 H-OU-19 Wire 1 2 3 4 5 Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number LDC15F LDC30F LDC60F Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number Model +50 -0 Model number H-OU-14 Type Wire 1 2 3 4 5 6 Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max +50 -0 Model number H-OU-19 Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Type Wire 1 2 3 4 5 6 7 8 +50 -0 Option-24 October 26, 2021 Optional Parts Model number H-OU-23 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Model number H-OU-24 Wire 1 2 3 4 5 6 7 8 Wire AWG 1, 2 3, 4 5, 6 7, 8 UL1015 UL1015 UL1015 UL1015 18 18 18 18 Pin # Wire AWG 1, 2, 3 4, 5, 6 7, 8 9, 10 UL1015 UL1015 UL1015 UL1015 18 18 18 18 Pin # Wire AWG 1 2 3 UL1007 UL1007 UL1007 22 22 22 Color gray orange black red Length (mm) 500 500 500 500 Color gray orange black red Length (mm) 500 500 500 500 Color orange gray purple Length (mm) 500 500 500 +50 -0 Type Wire 1 2 3 4 5 6 7 8 9 10 Housing : VHR-10N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 100g max Pin # +50 -0 Model number H-OU-25 Housing : XHP-3 (J.S.T.) Pin : SXH-001-P0.6 (J.S.T.) Weight : 10g max Type Wire 1 2 3 +50 -0 October 26, 2021 Option-25 Optional Parts Harness for remote ON/OFF(R type) is prepared in LDA, LEA, LEB, LEP, LFA, LFP & LMA series. Mating harness Model LDA50F, LDA75F, LDA100W, LDA150W, LDA300W LEA50F, LEA75F, LEA100F, LEA150F, LEP100F, LEP150F, LEP240F LEB100F, LEB150F, LEB225F LFA100F, LFA150F, LFA240F, LFA300F, LFP100F, LFP150F, LFP240F, LFP300F LHA100F,LHA150F,LHA300F,LHP150F,LHP300F LMA100F, LMA150F, LMA240F Model number H-RC-1 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Option-26 Harness model # H-RC-1 LDA LEA LEB LEP LFA LFP LHA LHP LMA Series Series Series Series Series Series Series Series Series Wire Type 1 2 +50 -0 October 26, 2021 Pin # Wire AWG 1 2 UL1007 UL1007 22 22 Color orange blue Length (mm) 500 500 Optional Parts MAX Series Harness to use the function of the output module is prepared in MAX series. Mating harness Model Harness model # MAX1600F H-SN-3 Harness for using no function of the output module. It is appended to standard model. MAX1600T H-SN-4 Harness for using all functions of output module. MAX3200T H-SN-6 Harness for using all functions except remote sensing of the output module. Model number H-SN-3 Contents Type Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 1g max Model number H-SN-4 max Type H-SN-6 Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 - 28 28 28 28 - red black red black - Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 28 28 red black brown black orange black yellow green blue purple Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 28 28 28 28 red black red black brown black orange black yellow green blue purple Length (mm) 30 30 30 30 - Wire 11 9 7 5 3 1 Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 10g max Model number Wire 11 9 7 5 3 1 +50 -0 Type Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire 11 9 7 5 3 1 +50 -0 Length (mm) 30 30 30 30 500 500 500 500 500 500 500 500 The even number pin side of the connector is the same wiring as the odd number pin side. October 26, 2021 Option-27 Optional Parts ACE Series Harness to use the function of the output module is prepared in ACE series. Mating harness Model ACE series Harness model # Contents H-SN-14 Harness for using AUX and PR alarm of CN1. H-SN-16 Harness for using all function of output modules. (CN2) H-SN-17 Harness for using all functions except remote sensing of the output modules. (CN2) H-SN-18 Harness for using remote ON/OFF of output module S, T, U.(CN2) Model number H-SN-14 Type Wire 3 2 1 H-SN-16 Wire AWG Color 1 2 3 UL1007 UL1007 UL1007 22 22 22 black yellow red Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 yellow orange blue black red red black black Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 yellow orange blue black red red black black Pin # Wire AWG Color 1 2 UL1007 UL1007 26 26 yellow orange +50 -0 Housing : XHP-3 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 10g max Model number Pin # Type Wire 9 7 5 3 1 Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max Length (mm) 500 500 500 +50 -0 Length (mm) 500 500 500 500 500 500 500 500 The even number pin side of the connector is the same wiring as the odd number pin side. Model number H-SN-17 Type Wire max 9 7 5 3 1 Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 5g max +50 -0 Pin #7 and #8 are shorted with harness and also pin #9 and #10. Length (mm) 500 500 500 500 30 30 30 30 The even number pin side of the connector is the same wiring as the odd number pin side. Model number H-SN-18 Housing : PHR-2 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 4g max Option-28 Type Wire 2 1 +50 -0 October 26, 2021 Length (mm) 500 500 Optional Parts ADA Series Harness to use the function of ADA Series is prepared. Please see the our company home page or consult us about detailed information. Mating harness Model Harness model # ADA Series H-SN-23 H-IN-11 H-OU-26 H-PA-5 H-RC-2 Contents :Harness for using option:-W and/or -R when I/O interface is terminal block type (standard). :Input harness when I/O interface is connector type (option:-J). :Output harness when I/O interface is connector type (option:-J). :Harness for parallel operation when I/O interface is connector type (option:-J). :Harness for using option:-R when I/O interface is connector type (option:-J). Model number H-SN-23 Type Wire 13 11 9 7 5 3 1 Housing : PHDR-14VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 6g max Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 11 12 13 14 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 red black orange blue yellow black Wire AWG Color UL1051 UL1051 UL1051 UL1051 18 18 18 18 white white black black Wire AWG Color UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 16 16 16 16 16 16 16 16 16 16 red red red red red black black black black black Pin # Wire AWG Color 1 2 UL1007 UL1007 22 22 white black Pin # Wire AWG Color 1 2 3 UL1007 UL1007 22 22 white red +50 -0 Even number pin side of the connector is the same wiring as odd number pin side. Model number H-IN-11 Type A 3 2 1 Model number H-OU-26 H-PA-5 Type A 5 4 3 2 1 H-RC-2 Housing : 171822-3(AMP) Pin : 170204-2 equivalent goods(AMP) Weight : 7g max B A B A B A 1 1 2 2 3 3 Length (mm) 500 500 500 500 Wire B 5 4 3 2 1 Pin # B A B A B A B A B A +50 -0 Type 1 1 2 2 3 3 4 4 5 5 Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire 2 1 2 1 +50 -0 Housing : 171822-2(AMP) Pin : 170204-2 equivalent goods(AMP) Weight : 4g max Model number Pin # +50 -0 Housing : 178289-5(AMP) Pin : 1-353717-5 equivalent goods(AMP) Weight : 105g max Model number Wire B 3 2 1 Housing : 1-178129-6(AMP) Pin : 1-175218-5 equivalent goods(AMP) Weight : 45g max Length (mm) 500 500 500 500 500 500 Type Length (mm) 200 200 Wire 3 2 1 +50 -0 October 26, 2021 Length (mm) 500 500 Option-29 Optional Parts PB Series Harness to use the function is prepared in PB series. Mating harness Harness model # Model PBA10F, PBA15F, PBW15F, PBA30F, PBW30F, H-IN-3 or H-IN-27 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F 1 H-OU-9 PBA10F, PBA15F, PBA30F, PBA50F H-OU-18 PBA75F, PBA100F, PBA150F 1 PBW15F, PBW30F, PBW50F H-OU-48 H-RC-1 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F H-SN-1 PBA100F, PBA150F 2 PBA10F, PBA15F, PBW15F, PBA30F, PBW30F H-SN-18 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F H-PA-3 PBA300F H-SN-20 PBA600F H-SN-21 PBA1000F H-SN-22 PBA1500F H-SN-24 PBA1500T 1 Available for 12V, 15V, 24V, 36V and 48V output model in PBA100F / 150F. 2 Available for 3.3V and 5V output model in PBA100F / 150F. Model number H-IN-3 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-IN-27 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Pin : : 40g max Weight Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 4 5 1 2 3 4 5 1 2 3 4 1 2 3 4 5 6 Weight : 60g max Model number H-OU-48 Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Pin : : 40g max Weight Option-30 Type 1 2 3 4 Contents Input harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Harness for using option : -R Harness for using option : -K Harness for using option : -V Harness for parallel operation Harness for using all functions of CN1 and CN2 Harness for using all functions except remote sensing of CN2 Harness for using all functions of CN3 Harness for using example remote ON/OFF circuit (C) Wire +50 -0 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green/yellow 500 Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Length (mm) 500 500 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 Color purple black black red Length (mm) 500 500 500 500 Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 500 500 +50 -0 Wire +50 -0 October 26, 2021 Optional Parts Model number H-RC-1 Type Wire 1 2 +50 -0 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Model number H-SN-1 Type Model number H-SN-18 H-PA-3 +50 -0 Type H-SN-20 Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 8g max AWG Color Length (mm) UL1061 UL1061 28 28 black red 500 500 Pin # Wire AWG Color 1 2 UL1007 UL1007 26 26 yellow orange Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 red black yellow green blue orange purple Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 red black yellow green blue black orange purple 1 2 UL1007 UL1007 Pin # 1 2 3 4 Length (mm) 500 500 Wire 1 3 5 7 9 +50 -0 Type Wire AWG Wire 2 1 Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 5g max Model number +50 -0 Type Housing : PHR-2 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 4g max Model number Length (mm) 500 500 Wire Wire 1 2 3 4 Housing : XHP-4 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 3g max 22 22 Color orange blue Pin # Length (mm) 270 270 270 270 270 270 270 Wire 2 4 6 8 10 9 7 5 3 1 +50 -0 October 26, 2021 Length (mm) 500 500 500 500 500 500 500 500 Option-31 Optional Parts Model number H-SN-21 Type Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 6g max Wire 2 4 6 8 10 9 7 5 3 1 +50 -0 Model number H-SN-22 Type +50 -0 Model number H-SN-24 CN A : Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Type CN A CN B max 2 4 6 8 10 8 6 4 2 max CN B : Housing : PHDR-08VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 2g max Pin #1 and #2, Pin #3 and #4 in CN A are connected by harness. Pin #9 in CN A and Pin #4 in CN B are connected by harness. Pin #10 in CN A and Pin #5 in CN B are connected by harness. Option-32 Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 yellow green blue black orange purple Pin # Wire AWG Color 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 pink brown white yellow gray Pin # Wire AWG Color 1 2 3 4 5 CN A 6 7 8 9 10 1 2 3 4 CN B 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 - 28 28 28 28 28 28 28 28 - red red black black black black black black - Length (mm) 500 500 500 500 500 500 Wire 2 4 6 8 7 5 3 1 Housing : PHDR-8VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 5g max Pin # October 26, 2021 Length (mm) 500 500 500 500 500 Wire Length (mm) 30 30 30 30 70 70 70 70 - Optional Parts SC Series Mating harness Model Harness model # SC Series H-SN-27 H-SN-28 H-SN-29 H-SN-30 H-OU-35 H-PA-7 H-PA-8 Connector SCHA SCDA CN1,CN2 CN1 CN4 CN3,CN4 CN5,CN6 CN5,CN6 CN7,CN8 CN7,CN8 CN9,CN10 Output connector 1 20 Output connector 1 14 CN3,CN4 CN5,CN6 CN3,CN4 CN5,CN6 Contents Harness for using remote signal ON/OFF function Harness for using MAS,SLV,CTB,PCONT,COM terminal Harness for using system ON/OFF function Harness for using alarm / output voltage monitor terminal Output harness Harness for using parallel connection (SLAVE unit-SLAVE unit) Harness for using parallel connection (MASTER unit-SLAVE unit) Model number H-SN-27 Type A 1 2 3 4 H-SN-28 Type Housing : 1-1318118-6 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 65g max Model number H-SN-29 A 1 2 3 4 5 6 A 1 2 3 H-SN-30 A 1 2 3 Model number H-OU-35 Housing : 1-179958-2 (Tyco Electronics AMP) Pin : 179956-2 or 316041-2 (Tyco Electronics AMP) Weight : 6g max UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 22 22 22 22 22 22 22 22 brown green red blue orange purple yellow gray Wire AWG Color UL1007 UL1007 UL1007 UL1007 UL1007 - 22 22 22 22 22 - brown red orange yellow green - Wire AWG Color UL1007 UL1007 - 22 22 - brown orange - Wire AWG Color UL1007 - 22 - brown - Length (mm) 2000 - UL1007 UL1007 UL1007 - 22 22 22 - red green orange - 2000 2000 2000 - Pin # Wire AWG Color 1 2 UL1015 UL1015 10 10 red black A B A B A B A B 1 1 2 2 3 3 4 4 1 1 2 2 3 3 4 4 5 5 6 6 A B A B A B A B A B A B Pin # Length (mm) 2000 2000 2000 2000 2000 - A B A B A B 1 1 2 2 3 3 Length (mm) 2000 2000 - Wire B 1 2 3 Pin # +50 -0 Housing : 2-1318119-3 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 50g max Color Wire B 1 2 3 +50 -0 Type AWG Pin # +50 -0 Type Length (mm) 2000 2000 2000 2000 2000 2000 2000 2000 Wire Wire B 1 2 3 4 5 6 Housing : 1-1318119-3 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 25g max Model number Pin # +50 -0 Housing : 1-1318119-4 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 100g max Model number Wire B 1 2 3 4 Type A B A B A B 1 1 2 2 3 3 Wire 1 2 +50 -0 October 26, 2021 Length (mm) 2000 2000 Option-33 Optional Parts Model number H-PA-7 Type Housing : 1-1318118-6 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 20g max CN1 A B 1 1 2 2 3 3 4 4 5 5 6 6 CN2 A B 1 1 2 2 3 3 4 4 5 5 6 6 Wire Pin # A B A B A B A B A B A B A B A B A B A B A B A B 20 CN1 Connection Model number H-PA-8 Housing : 1-1318118-6 (Tyco Electronics AMP) Pin : 1318105-1 or 1318107-1 (Tyco Electronics AMP) Weight : 20g max Type CN1 CN2 A2 A2 A3 A3 A4 A4 A5 A5 CN1 A B 1 1 2 2 3 3 4 4 5 5 6 6 CN2 A B 1 1 2 2 3 3 4 4 5 5 6 6 CN2 Pin # CN1 Connection Option-34 CN2 A1 A2 A3 A3 A4 A4 A5 A5 October 26, 2021 AWG UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 - 22 22 22 22 22 22 22 22 - Color red orange yellow green red orange yellow green - Wire AWG Color UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 - 22 22 22 22 22 22 22 22 - brown orange yellow green brown orange yellow green - Length (mm) 400 400 400 400 400 400 400 400 - Wire 20 CN1 1 1 2 2 3 3 4 4 5 5 6 6 1 1 2 2 3 3 4 4 5 5 6 6 Wire CN2 A B A B A B A B A B A B A B A B A B A B A B A B 1 1 2 2 3 3 4 4 5 5 6 6 1 1 2 2 3 3 4 4 5 5 6 6 Length (mm) 400 400 400 400 400 400 400 400 - Optional Parts PMA Series Mating harness Model Harness model # PMA15F, PMA30F, PMA60F, PMA100F H-IN -15 H-OU-28 PMA15F, PMA30F H-OU-29 PMA60F H-OU-30 PMA100F PMA15F, PMA30F, PMA60F, PMA100F H-IN - 3 PMA15F, PMA30F H-OU- 9 PMA60F H-OU-18 PMA100F H-OU-10 PMA60F, PMA100F H-RC- 1 Model number H-IN-3 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-IN-15 Type Housing : 1-1123722-5 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 20g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Pin : : 40g max Weight Model number H-OU-10 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Contents Input harness when I/O interface is connector (Mfr:Tyco Electronics AMP) type Output harness when I/O interface is connector (Mfr:Tyco Electronics AMP) type Output harness when I/O interface is connector (Mfr:Tyco Electronics AMP) type Output harness when I/O interface is connector (Mfr:Tyco Electronics AMP) type Input harness when I/O interface is connector (Mfr:J.S.T ) type (option:-J) Output harness when I/O interface is connector (Mfr:J.S.T ) type (option:-J) Output harness when I/O interface is connector (Mfr:J.S.T ) type (option:-J) Output harness when I/O interface is connector (Mfr:J.S.T ) type (option:-J) Harness for using option : -R 1 2 3 4 5 1 2 3 4 5 1 2 3 4 1 2 3 4 5 6 7 8 1 2 3 4 5 6 Weight : 60g max Model number H-OU-28 Type Housing : 1-1123722-4 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 40g max Model number H-OU-29 Housing : 1-1123722-6 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 60g max Type 1 2 3 4 1 2 3 4 5 6 Wire +50 -0 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green 500 Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Wire +50 -0 Wire +50 -0 Wire Wire Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire +50 -0 Wire Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 October 26, 2021 Option-35 Optional Parts Model number H-OU-30 Type Housing : 1-1123722-8 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 75g max Model number H-RC-1 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Option-36 1 2 3 4 5 6 7 8 Wire Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1 2 UL1007 UL1007 22 22 orange blue +50 -0 Type Wire 1 2 Length (mm) 500 500 +50 -0 October 26, 2021 Length (mm) 500 500 Optional Parts P L A Series P J A Series Harness to use the function is prepared in PLA series, PJA series. The latest information is in our websit Mating harness Model Harness model # Contents PLA15F, PLA30F, PLA50F, PJA100F, PJA150F H-IN-22 H-OU-37 H-OU-38 H-IN-26 H-OU-44 H-RC-1 H-RC-6 H-PA-9 H-SN-32 H-SN-33 H-RC-5 H-SN-18 Input harness when I/O interface is connector type (option : -J) Output harness when I/O interface is connector type (option : -J) Output harness when I/O interface is connector type (option : -J) Input harness when I/O interface is connector type (option : -J1) Output harness when I/O interface is connector type (option : -J1) Harness for using option : -R Harness for using option : -R Harness for parallel operation (option: -W) Harness for using all functions of option -W and -R Harness for using all functions except remote sensing of option -W and -R Harness for using a function of option -R Harness for using option : -V PJA100F, PJA150F PLA15F, PLA30F, PLA50F PJA100F, PJA150F PJA100F, PJA150F PJA100F, PJA150F PJA300F PJA600F, PJA1000F, PJA1500F PJA300F, PJA600F, PJA1000F, PJA1500F * These harnesses are used for product which includes option. ●Model number H-IN-22 ●Type Housing : 1-1123722-5 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 30g max ●Model number H-OU-37 +50 -0 ●Type Housing : 1-1123722-6 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 60g max ●Model number H-OU-38 ●Type ●Type Housing : VHR-5N (J.S.T.) +50 -0 1 2 3 4 5 Housing:VHR-6N(J.S.T.) Pin:SVH-21T-P1.1(J.S.T.) Weight :60g max Color 1 2 3 4 5 UL1015 18 green Length (mm) 500 UL1015 18 white 500 UL1015 18 black 500 Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 red black Pin # Wire AWG Color 1, 2 3, 4 UL1015 UL1015 18 18 red black Length (mm) 500 500 Pin # Wire AWG 1 2 3 4 5 UL1015 18 Color green Length (mm) 500 UL1015 18 white 500 UL1015 18 black 500 Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 red black ●Wire +50 -0 Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max H-OU-44 AWG ●Wire 1 2 3 4 : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 40g max ●Model number Wire ●Wire 1 2 3 4 5 6 Pin H-IN-26 Pin # Length (mm) 500 500 +50 -0 Housing : 1-1123722-4 (Tyco Electronics AMP) ●Model number ●Wire 1 2 3 4 5 ●Type 1 2 3 4 5 6 ●Wire Length (mm) 500 500 +50 -0 October 26, 2021 Option-37 Optional Parts ●Model number H-RC-1 ●Type ●Wire 1 2 +50 -0 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max ●Model number H-RC-6 ●Type +50 -0 Housing : XAP-02V-1 (J.S.T.) Pin Wire AWG 1 2 UL1007 UL1007 22 22 Pin # Wire AWG 1 2 UL1007 UL1007 22 22 Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 Color red orange purple green black Length (mm) 270 270 270 270 270 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 28 Color red orange purple yellow blue green black Length (mm) 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 Color orange purple yellow blue green black Length (mm) 500 500 500 500 500 500 Wire UL1061 UL1061 - AWG 28 28 - Color orange purple - Length (mm) 500 500 - ●Wire 1 2 : SXA-001T-P0.6(J.S.T.) Length (mm) 500 orange blue 500 Pin # Color Length (mm) orange 500 blue 500 Color Weight : 7g max Model number H-PA-9 1 3 5 7 9 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 4g max Model number H-SN-32 Wire Type +50 -0 Wire Type 2 4 6 8 10 9 7 5 3 1 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 7g max +50 -0 Model number H-SN-33 2 4 6 8 10 9 7 5 3 1 +50 -0 Model number H-RC-5 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 3g max Pin # 1 2 3 4 5 6 7 8 9 10 Wire Type 2 4 6 8 10 9 7 5 3 1 +50 -0 Option-38 Pin # 1 2 3 4 5 6 7 8 9 10 Wire Type Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 6g max Pin # 1 2 3 4 5 6 7 8 9 10 October 26, 2021 Pin # 1 2 3 4 5 6 7 8 9 10 Optional Parts ●Model number H-SN-18 Housing : PHR-2(J.S.T.) Pin : SPH-002T-P0.5S(J.S.T.) Weight : 4g max ●Type ●Wire 2 1 +50 -0 October 26, 2021 Pin # Wire AWG 1 2 UL1007 UL1007 26 26 Length (mm) yellow 500 orange 500 Color Option-39 Optional Parts Harness to use the function is prepared in GHA & GMA series. Mating harness GHASeries GMASeries Standard type (GHA300F, GHA500F : Molex connector, GMA series : Tyco connector) Model Contents Harness model # H-IN-17 H-SN-34 H-SN-35 H-SN-56 H-SN-57 H-IN-24 H-SN-18 H-SN-38 H-SN-79 GHA300F, GHA500F GMA300F Input harness Harness for using all functions. Harness for using AUX (5V) remote control and PG terminal. Harness for using all functions. (J2) Harness for using AUX (5V) remote control and PG terminal. (J2) Input harness Harness for using AUX (12V). Harness for using all functions. Harness for using all functions. (AWG24 for 1A) -J1 and -J3 type (J.S.T. connector) Model Contents Harness model # GHA300F, GHA500F GHA700F GMA300F H-IN-18 H-SN-38 H-SN-39 H-SN-79 H-IN-26 H-SN-38 H-SN-39 H-SN-79 H-IN-18 H-SN-18 H-SN-38 H-SN-79 Input harness Harness for using all functions. Harness for using AUX (5V) remote control and PG terminal. Harness for using all functions. (AWG24 for 1A) Input harness Harness for using all functions. Harness for using AUX (5V) remote control and PG terminal. Harness for using all functions. (AWG24 for 1A) Input harness Harness for using AUX (12V). Harness for using all functions. Harness for using all functions. (AWG24 for 1A) ●Model number H-IN-17 ●Type Housing : 09-50-8031 (Molex) Pin (1-3) : 08-50-0105 (Molex) : 08-65-0114 (Molex) (4) : 170603-2 (Tyco Electronics) Weight : 25g max ●Model number H-IN-18 ●Wire 4 Pin # Wire AWG Color 1 2 3 1 2 3 4 UL3239 18 black Length (mm) 500 UL3239 UL3239 18 18 white green 500 500 +50 -0 *The color becomes the light hue. ●Type Housing : VHR-3N (J.S.T.) Pin (1-3) : SVH-21T-P1.1 (J.S.T.) ●Wire 4 Pin # Wire AWG Color 1 2 3 1 2 3 4 UL1015 18 black Length (mm) 500 UL1015 UL1015 18 18 white green 500 500 +50 -0 (4) : 170603-2 (Tyco Electronics) Weight : 35g max ●Model number H-IN-24 Housing : 1-1123722-3 (Tyco Electronics) Pin (1-3) : 1123721-1 (Tyco Electronics) (4) : 170603-2 (Tyco Electronics) Weight : 35g max www.cosel.co.jp/en/ ●Type ●Wire 4 Pin # Wire AWG Color 1 2 3 1 2 3 4 UL1015 18 black Length (mm) 500 UL1015 UL1015 18 18 white green 500 500 +50 -0 April 18, 2024 Option-41 Optional Parts ●Model number H-IN-26 ●Type 1 2 3 4 5 Housing : VHR-5N (J.S.T.) ●Wire +50 -0 Pin : SVH-21T-P1.1(J.S.T.) Weight : 30g max ●Model number H-SN-34 ●Type Housing : 51110-0851 (Molex) 2 4 6 8 ●Model number +50 -0 H-SN-56 ●Type Housing : 51110-0860 (Molex) 2 4 6 8 ●Model number +50 -0 H-SN-35 ●Type Housing : 51110-0851 (Molex) Pin 2 4 6 8 +50 -0 Weight : 6g max ●Model number H-SN-57 ●Type Housing : 51110-0860 (Molex) Pin 2 4 6 8 +50 -0 Weight : 6g max ●Model number H-SN-38 Housing : PHDR-08VS (J.S.T.) : SPHD-002T-P0.5 (J.S.T.) Pin Weight : 8g max Option-42 500 UL1015 18 black 500 Pin # Wire AWG 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 Pin # Wire AWG 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 Pin # Wire AWG Color 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 blue brown yellow gray orange purple 500 500 500 500 500 500 Pin # Wire AWG Color Length (mm) 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 blue brown yellow gray Pin # Wire AWG 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 UL1015 UL1015 ●Type Length (mm) 500 red black 500 blue 500 brown 500 yellow 500 gray 500 orange 500 purple 500 Color orange purple ●Wire 2 4 6 8 Length (mm) 500 red black 500 blue 500 brown 500 yellow 500 gray 500 orange 500 purple 500 Color ●Wire 1 3 5 7 : 50394-8051 (Molex) white 1 2 3 4 5 ●Wire 1 3 5 7 : 50394-8051 (Molex) 18 AWG ●Wire 1 3 5 7 Pin : 50394-8051 (Molex) Weight : 8g max Length (mm) 500 Wire ●Wire 1 3 5 7 Pin : 50394-8051 (Molex) Weight : 8g max 18 Color green Pin # 1 3 5 7 +50 -0 April 18, 2024 Length (mm) 500 500 500 500 500 500 Length (mm) 500 red black 500 blue 500 brown 500 yellow 500 gray 500 orange 500 purple 500 Color www.cosel.co.jp/en/ Optional Parts ●Model number H-SN-39 ●Type Housing : PHDR-08VS (J.S.T.) : SPHD-002T-P0.5 (J.S.T.) Pin Weight : 6g max ●Model number H-SN-18 ●Wire 2 4 6 8 1 3 5 7 +50 -0 ●Type +50 -0 : SPH-002T-P0.5S(J.S.T.) Pin Weight : 4g max H-SN-79 ●Type : SPHD-002T-P0.5(J.S.T.) Pin Weight : 20g max AWG Color 1 2 3 4 5 6 7 8 Length (mm) UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 blue brown yellow gray orange purple 500 500 500 500 500 500 Pin # Wire AWG 1 2 UL1007 UL1007 26 26 Pin # Wire AWG 1 2 3 4 5 6 7 8 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 24 24 24 24 24 24 24 24 ●Wire 2 4 6 8 Housing : PHDR-08VS(J.S.T.) Wire ●Wire 2 1 Housing : PHR-2(J.S.T.) ●Model number Pin # 1 3 5 7 +50 -0 Length (mm) yellow 500 orange 500 Color Length (mm) red 500 black 500 blue 500 brown 500 yellow 500 gray 500 orange 500 purple 500 Color Harness for connecting the external capacitor unit is prepared for GHA700F (U1 type). Model number H-IN-25 CN A: Housing : VHR-3N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Type CN A 1 2 3 +50 -0 1 2 3 4 CN B Wire Pin # CN A CN B CN B: Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 1 2 3 4 Color black Length (mm) 100 20 red 100 20 black 100 20 red 100 Wire AWG UL1015 20 UL1015 UL1015 UL1015 Weight : 5g max www.cosel.co.jp/en/ April 18, 2024 Option-43 Optional Parts F E TA Series Mating harness Model Harness model # FETA2500BA FETA3000BA FETA7000T FETA7000ST H-SN-47 H-SN-55 H-PA-12 H-PA-13 H-SN-77 H-SN-78 H-PA-19 FETA3000BC Contents Harness for using all of CN1 and CN2 (Single side housing) Harness for using all of CN1 and CN2 (Both side housing) Harness for parallel operation Harness for parallel operation and using all other functions of CN1 and CN2 Harness for using all of CN1 and CN2 (Single side housing) Harness for using all of CN3 (Single side housing) Harness for parallel operation Model number H-SN-47 Wire Type 2 4 6 8 10 12 Housing : PUDP-12V-S(J.S.T.) Pin : SPUD-002T-P0.5(J.S.T.) Weight : 13g max Pin # 1 2 3 4 5 6 7 8 9 10 11 12 11 9 7 5 3 1 +50 -0 Model number H-SN-55 Type 1 3 5 7 9 11 Housing : PUDP-12V-S(J.S.T) Pin : SPUD-002T-P0.5(J.S.T) Tube : E-651U-1(NIKKAN INDUSTRIES) Weight : 12g max Model number H-SN-77 Tube +50 -0 AWG 28 28 28 28 28 28 28 28 28 28 28 28 Color white pink brown yellow gray orange purple red black blue yellow green Length (mm) 500 500 500 500 500 500 500 500 500 500 500 500 Wire UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 UL10368 AWG 28 28 28 28 28 28 28 28 28 28 28 28 Color red white white white white white white white white white white white Length (mm) 200 200 200 200 200 200 200 200 200 200 200 200 Wire UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 Color gray orange purple red Length (mm) 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 Color white pink brown yellow gray orange Length (mm) 500 500 500 500 500 500 Wire Pin # 1 2 3 4 5 6 7 8 9 10 11 12 Wire Type 2 4 6 8 Housing : PUDP-8V-S(J.S.T) Pin : SPUD-002T-P0.5(J.S.T) Tube : EXLON-J f3.0(IWASE) Weight : 3g max Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 7 5 3 1 +50 -0 H-SN-77 H-SN-77 Pin # 1 2 3 4 5 6 7 8 +50 -0 Model number H-SN-78 Housing : DF11-6DS-2C(HIROSE ELECTRIC) Pin : DF11-2428SCF(HIROSE ELECTRIC) Tube : EXLON-J f3.0(IWASE) Weight : 4g max Wire Type 2 4 6 5 3 1 +50 -0 H-SN-78 H-SN-78 Pin # 1 2 3 4 5 6 +50 -0 www.cosel.co.jp/en/ July 25, 2023 Option-43 Optional Parts Model number H-PA-12 1 3 5 7 9 11 Housing : PUDP-12V-S(J.S.T.) Pin : SPUD-002T-P0.5(J.S.T.) Weight : 5g max Model number H-PA-13 Wire Type Pin # 1 2 3 4 5 6 7 8 9 10 11 12 +50 -0 Type CN1 CN2 +50 -0 +50 -0 1 3 5 7 9 11 Housing : PUDP-12V-S(J.S.T.) Pin : SPUD-002T-P0.5(J.S.T.) Weight : 16g max +50 -0 Terminals of Pin #1 - #6 in CN1 and CN2 are opened. Pin #7 - #12 in CN1 are connected to same pins in CN2 by harness. Model number H-PA-19 Housing : PUDP-8V-S(J.S.T.) Pin : SPUD-002T-P0.5(J.S.T.) Tube : EXLON-J f3.0(IWASE) Weight : 5g max Option-44 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 Color purple red black blue yellow green Length (mm) 210 210 210 210 210 210 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 28 28 28 28 28 28 Color white pink brown yellow gray orange purple red black blue yellow green Length (mm) 500 500 500 500 500 500 210 210 210 210 210 210 Wire UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 Color gray orange purple red Length (mm) 210 210 210 210 Wire Pin # 1 2 3 4 5 6 7 8 9 10 11 12 Wire Type CN1 1 3 5 7 CN2 H-PA-19 +50 -0 July 25, 2023 Pin # 1 2 3 4 5 6 7 8 www.cosel.co.jp/en/ Optional Parts PCA Series Harness to use the function is prepared in PCA series. Mating harness Model Harness model # H-PA-14 H-PA-15 H-PA-16 H-SN-48 PCA300F PCA600F PCA1000F PCA1500F H-SN-49 H-SN-50 H-SN-51 H-SN-52 H-SN-53 H-SN-54 H-SN-66 Model Harness model # Contents Harness for abnormal protection of series - H-PA-14 operation Harness for parallel operation and N+1 H-SN-48 parallel redundancy operation Harness for master-salve operation of H-SN-49 parallel operation (-P3 option) Harness for using all functions of CN1 and H-SN-50 PCA600F-O-P2 CN2 H-SN-51 Harness for using all functions except H-SN-52 remote sensing of CN1 and CN2 Harness for using all functions of CN3 H-SN-53 Harness for using all functions of CN4 Harness for using example remote ON/OFF H-SN-54 circuit (C) Harness for use in slave setting of masterslave operation (-P3 option) Harness for use in effective setting of external output voltage adjustment Harness for using PMBus communication (-I option) Model number H-PA-14 External view Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max H-PA-14 +50 -0 Wiring diagram 1 2 3 4 5 6 7 8 9 10 11 12 Model number H-PA-15 Contents Harness for series operation and parallel operation (master-slave operation) Harness for using all functions of CN1 and CN2 Harness for using all functions except remote sensing of CN1 and CN2 Harness for using all functions of CN3 Harness for using all functions of CN4 Harness for using example remote ON/OFF circuit (C) Harness for use in slave setting of masterslave operation Harness for use in effective setting of external output voltage adjustment Wire Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 Color pink yellow gray orange purple Length (mm) 180 180 180 180 180 Pin # Wire AWG 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 Color blue black pink green gray orange purple Length (mm) 180 180 180 180 180 180 180 Pin # 1 2 3 4 5 6 7 8 9 10 11 12 1 2 3 4 5 6 7 8 9 10 11 12 External view Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max H-PA-15 +50 -0 Wiring diagram 1 2 3 4 5 6 7 8 9 10 11 12 Wire 1 2 3 4 5 6 7 8 9 10 11 12 October 26, 2021 Option-43 Optional Parts Model number H-PA-16 External view Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max H-PA-16 +50 -0 Wiring diagram 1 2 3 4 5 6 7 8 9 10 11 12 Model number H-SN-48 Wire 1 2 3 4 5 6 7 8 9 10 11 12 Length (mm) 500 500 500 500 500 500 500 500 500 500 AWG 28 28 28 28 28 28 28 28 Color blue black pink green yellow brown orange purple Length (mm) 500 500 500 500 500 500 500 500 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 Pin # Wire AWG 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 +50 -0 Wire 1 2 3 4 5 6 7 8 9 10 11 12 External view Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 10g max H-SN-49 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 11 12 Option-44 28 28 28 28 28 28 28 28 28 28 Color red black blue black pink green yellow brown orange purple AWG H-SN-48 Wiring diagram H-SN-49 Length (mm) 180 180 180 180 180 180 180 180 Wire External view Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 10g max Model number Color blue black pink green yellow gray orange purple Pin # 1 2 3 4 5 6 7 8 9 10 11 12 October 26, 2021 Optional Parts Model number H-SN-50 External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max H-SN-50 +50 -0 Wiring diagram Wire 1 2 3 4 5 6 7 8 9 10 Model number H-SN-51 Color brown blue orange pink brown Length (mm) 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 - AWG 28 28 28 28 - Color black black black black - Length (mm) 70 70 70 70 - UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 Wire Pin # 1 2 3 4 5 6 7 8 External view CN A : Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max AWG 28 28 28 28 28 1 2 3 4 5 6 7 8 9 10 +50 -0 1 2 3 4 5 6 7 8 CN B : Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG H-SN-51 Wiring diagram H-SN-52 Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire External view Housing : PHDR-08VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 6g max Model number 24 24 28 24 28 28 28 28 28 28 Color orange white blue white yellow gray orange black purple green Pin # H-SN-52 max Wiring diagram CN A 1 2 3 4 5 6 7 8 9 10 11 12 CN B 1 2 3 4 5 6 7 8 9 10 October 26, 2021 Wire Pin # 1 2 3 4 5 6 CN A 7 8 9 10 11 12 1 2 3 4 5 CN B 6 7 8 9 10 Option-45 Optional Parts Model number H-SN-53 External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max H-SN-53 max Wiring diagram 1 2 3 4 5 6 7 8 9 10 Model number H-SN-54 Wire Length (mm) 30 30 Wire UL1061 UL1061 - AWG 28 28 - Color purple purple - Length (mm) 30 30 - Pin # Wire AWG 1 2 3 4 5 6 7 8 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 28 28 28 28 28 28 28 28 Color brown red orange yellow green blue purple gray Length (mm) 500 500 500 500 500 500 500 500 H-SN-54 max Wire Pin # Pin #8 and #9 are connected by harness. 1 2 3 4 5 6 7 8 9 10 External view H-SN-66 Housing : PHDR-08VS (J.S.T) Pin : SPHD-002T-P0.5 (J.S.T) Weight : 8g max 50max Wiring diagram +50 -0 Wire 1 2 3 4 5 6 7 8 Option-46 Color green green 1 2 3 4 5 6 7 8 9 10 Wiring diagram 1 2 3 4 5 6 7 8 9 10 H-SN-66 AWG 28 28 External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 3g max Model number Wire UL1061 UL1061 Pin # October 26, 2021 Optional Parts AME Series Mating harness Model Harness model # AME H-SN-58 H-SN-59 H-SN-60 H-SN-68 H-SN-51 H-SN-66 H-SN-61 H-SN-62 H-SN-63 H-SN-69 H-SN-65 H-SN-67 H-OU-42 H-OU-43 H-OU-52 Model number H-SN-58 Contents Harness for functions (AUX, GI, PR, INFO (for -I3 option)) in CN1 Harness for functions in CN3 (for Output module A-D,J-M) Harness for functions in CN3 (for Output module E4-H4,E-H) Harness for functions in CN3 (for Output module R) Harness for functions in CN2 (for -I3 option) Harness for functions in CN2 (for -I option) Molex housing version of H-SN-58 (for -J3 option) Molex housing version of H-SN-59 (for -J3 option of output module A-D,J-M) Molex housing version of H-SN-60 (for -J3 option of output module E4-H4,E-H) Molex housing version of H-SN-68 (for -J3 option of output module R) Molex housing version of H-SN-51 (for -I3J3 option) Molex housing version of H-SN-66 (for -IJ3 option) Output harness (for -J2 option of output module A-D,K-M) Output harness (for -J2 option of output module E4-H4,E-H,J) Output harness (for -J2 option of output module R) External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max H-SN-58 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 Model number H-SN-59 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG AWG24 AWG24 AWG28 AWG24 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 Color orange white blue white green purple pink brown yellow gray Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 - AWG Color AWG28 yellow AWG28 orange AWG28 blue AWG28 gray - Length (mm) 500 500 500 500 - External view H-SN-59 Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 4g max +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 October 26, 2021 Option-47 Optional Parts Model number H-SN-60 External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max H-SN-60 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 Model number H-SN-68 Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 Color yellow orange blue gray brown green purple white Length (mm) 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG Color AWG28 brown AWG28 blue AWG28 orange AWG28 pink AWG28 brown Length (mm) 500 500 500 500 500 +50 -0 Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 External view Housing : PHDR-08VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 6g max H-SN-51 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 Option-48 Color yellow orange blue gray red black brown green purple white H-SN-68 Wiring diagram H-SN-51 AWG AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 External view Housing : PHDR-10VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 8g max Model number Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 1 2 3 4 5 6 7 8 October 26, 2021 Optional Parts Model number H-SN-66 External view H-SN-66 Housing : PHDR-08VS (J.S.T) Pin : SPHD-002T-P0.5 (J.S.T) Weight : 8g max 50max +50 -0 Wiring diagram Wire 1 2 3 4 5 6 7 8 Model number H-SN-61 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG AWG24 AWG24 AWG28 AWG24 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 Color orange white blue white green purple pink brown yellow gray Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 - AWG Color AWG28 yellow AWG28 orange AWG28 blue AWG28 gray - Length (mm) 500 500 500 500 - AWG 1 2 3 4 5 6 7 8 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 H-SN-61 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 H-SN-62 Length (mm) 500 500 500 500 500 500 500 500 Wire External view Housing : 51110-1056 (Molex) Pin : 50394-8051 (Molex) Weight : 8g max Model number 28 28 28 28 28 28 28 28 Color brown red orange yellow green blue purple gray Pin # External view H-SN-62 Housing : 51110-1056 (Molex) Pin : 50394-8051 (Molex) Weight : 4g max +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 October 26, 2021 Option-49 Optional Parts Model number H-SN-63 External view Housing : 51110-1056 (Molex) Pin : 50394-8051 (Molex) Weight : 8g max H-SN-63 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 Model number H-SN-69 Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 Color yellow orange blue gray brown green purple white Length (mm) 500 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG Color AWG28 brown AWG28 blue AWG28 orange AWG28 pink AWG28 brown Length (mm) 500 500 500 500 500 +50 -0 Wire Pin # 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 External view Housing : 51110-0856 (Molex) Pin : 50394-8051 (Molex) Weight : 6g max H-SN-65 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 Option-50 Color yellow orange blue gray red black brown green purple white H-SN-69 Wiring diagram H-SN-65 AWG AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 AWG28 External view Housing : 51110-1056 (Molex) Pin : 50394-8051 (Molex) Weight : 8g max Model number Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 1 2 3 4 5 6 7 8 October 26, 2021 Optional Parts Model number H-SN-67 External view H-SN-67 Housing : 51110-0856 (Molex) Pin : 50394-8051 (Molex) Weight : 8g max 50max +50 -0 Wiring diagram Wire 1 2 3 4 5 6 7 8 Model number H-OU-42 28 28 28 28 28 28 28 28 Color brown red orange yellow green blue purple gray Length (mm) 500 500 500 500 500 500 500 500 Wire UL1430 UL1430 UL1430 UL1430 AWG AWG16 AWG16 AWG16 AWG16 Color black black red red Length (mm) 500 500 500 500 Wire UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 AWG AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 Color black black red red black black red red Length (mm) 500 500 500 500 500 500 500 500 Pin # Wire AWG Color 1 2 3 4 5 6 7 8 UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 AWG16 black red black red black red black red Pin # Wire AWG 1 2 3 4 5 6 7 8 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 UL2651 External view Housing : 39014041 (Molex) Pin : 45750-3111 (Molex) Weight : 40g max H-OU-42 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 1 2 3 4 Model number H-OU-43 External view Housing : 39012085 (Molex) Pin : 45750-31111 (Molex) Weight : 80g max H-OU-43 +50 -0 Wiring diagram Wire Pin # 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 Model number H-OU-52 External view Housing : 39012085 (Molex) Pin : 45750-3111 (Molex) Weight : 80g max H-OU-52 +50 -0 Wiring diagram Wire 1 2 3 4 5 6 7 8 October 26, 2021 Length (mm) 500 500 500 500 500 500 500 500 Option-51 Optional Parts R B Series Mating harness Model Harness model # Contents H-IN- 5 H-IN-10 H-IN-25 H-OU-41 H-OU-39 H-OU-40 Input harness (ground wire : green) Input harness (ground wire : green/yellow) Harness for connecting the external capacitor unit (CR-HUT). Output harness (for V3) Output harness (for V1-V2) Output harness (for V1-�V2) Harness for using Remote control / Alarm / Communication · For Remote control Use only pin # 1 and 3 · For Alarm and Communication Use only pin # 2 and 3 Output harness (for V2) Output harness (for �V2) Output harness (for V1) Harness for using Remote control / Alarm / Communication · For Remote control Use only pin # 1 and 3 · For Alarm and Communication Use only pin # 2 and 3 RBC200F RBC300F RBC200F H-SN-64 H-OU-49 H-OU-50 H-OU-51 RBC300F H-SN-70 Model number H-IN-5 Type 1 2 3 4 5 Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-10 Type 1 2 3 4 5 Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-25 Type +50 -0 Pin # Wire AWG 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green/yellow 500 Color black Length (mm) 100 Color Wire +50 -0 CN A 1 2 3 CN A: Housing : VHR-3N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Wire +50 -0 1 2 3 4 CN B Wire Pin # Wire AWG UL1015 20 UL1015 20 red 100 UL1015 20 black 100 UL1015 20 red 100 Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 red black Pin # Wire AWG Color 1, 2 3, 4 5 6 7 UL1015 UL1015 UL1015 UL1015 18 18 18 18 red black orange gray Pin # Wire AWG Color 1, 2 3, 4 5 6 7 UL1015 UL1015 UL1015 UL1015 UL1015 18 18 18 18 18 red black orange gray purple CN A CN B CN B: Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 1 2 3 4 Weight : 5g max Model number H-OU-41 Type 1 2 Wire +50 -0 Housing : VHR-2N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-OU-39 Type Housing : VHR-7N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 70g max Model number H-OU-40 Housing : VHR-7N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 70g max Option-52 Type 1 2 3 4 5 6 7 1 2 3 4 5 6 7 Wire +50 -0 Wire +50 -0 October 26, 2021 Length (mm) 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 500 500 500 Optional Parts Model number Type H-SN-64 1 2 3 Housing : PHR-3 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 4g max Model number Type H-OU-49 1 2 3 4 Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number Type H-OU-50 1 2 3 4 Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number Type H-OU-51 Housing : VHR-6N (J.S.T.) Pin : SVH-41T-P1.1 (J.S.T.) Weight : 65g max Model number H-SN-70 Housing : PHR-4 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 8g max Type 1 2 3 4 5 6 1 2 3 4 Wire +50 -0 Color orange yellow blue Length (mm) 500 500 500 Color orange gray Length (mm) 500 500 18 18 18 Color orange gray purple Length (mm) 500 500 500 Wire AWG Color UL1430 UL1430 UL1430 UL1430 UL1430 UL1430 16 16 16 16 16 16 red red red black black black Length (mm) 500 500 500 500 500 500 Pin # Wire AWG 1 2 3 4 UL1017 UL1017 UL1017 UL1017 26 26 26 26 Color orange yellow blue gray Length (mm) 500 500 500 500 Pin # Wire AWG 1 2 3 UL1017 UL1017 UL1017 26 26 26 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 18 18 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 UL1015 Pin # 1 2 3 4 5 6 Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire +50 -0 October 26, 2021 Option-53 Optional Parts A E A Series Harness to use the function of AEA Series is prepared. Please see the our company home page or consult us about detailed information. Mating harness Model Harness model # Contents AEA Series H-PA-17 H-IN-11 H-OU-53 H-SN-39 H-SN-71 Harness for parallel operation (CN1,CN2) Input harness when I/O interface is connector type (option:-J) Output harness when I/O interface is connector type (option:-J) Harness for using functions of CN4 (option:-I4) Harness for using functions of CN3 (option:-R3 and -I4) Model number H-PA-17 Type Wire 2 1 H-PA-17 H-IN-11 Type A 3 2 1 H-OU-53 H-SN-39 Housing : PHDR-08VS (J.S.T.) : SPHD-002T-P0.5 (J.S.T.) Pin Weight : 6g max www.cosel.co.jp/en/ AWG Color 1 2 UL1007 UL1007 26 26 yellow orange Wire AWG Color UL1015 UL1015 UL1015 UL1015 18 18 18 18 white white black black Wire AWG Color 1 1 2 2 3 3 4 4 5 5 6 6 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 UL1007 16 16 16 16 16 16 16 16 16 16 16 16 red red red red red red black black black black black black Length (mm) 500 500 500 500 500 500 500 500 500 500 500 500 Pin # Wire AWG Color 1 2 3 4 5 6 7 8 Length (mm) UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 blue brown yellow gray orange purple 500 500 500 500 500 500 Pin # +50 -0 Type Housing : 178289-6(TE connectivity) Pin : 1-353717-5 equivalent goods (TE connectivity) Weight : 120g max ●Model number Wire Wire B 3 2 1 Housing : 1-178129-6(TE Connectivity) Pin : 1-175218-5 equivalent goods (TE Connectivity) Weight : 45g max Model number A 6 5 4 3 2 1 B 6 5 4 3 2 1 B A B A B A 1 1 2 2 3 3 Length (mm) 500 500 500 500 Wire H-OU-53 Pin # +50 -0 ●Type B A B A B A B A B A B A ●Wire 2 4 6 8 Length (mm) 200 200 Pin # +50 -0 Housing : PHR-2 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 4g max Model number 2 1 1 3 5 7 +50 -0 March 07, 2024 Option-57 Optional Parts Model number H-SN-71 External view H-SN-71 Housing : PHDR-12VS (J.S.T.) Pin : SPHD-002T-P0.5 (J.S.T.) Weight : 22g max +50 -0 Wiring diagram Wire 1 2 3 4 5 6 7 8 9 10 11 12 Option-58 March 07, 2024 Pin # Wire AWG 1 2 3 4 5 6 7 8 9 10 11 12 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 24 24 24 24 24 24 28 28 28 28 28 28 Color orange white red blue red blue brown green purple black yellow grey Length (mm) 500 500 500 500 500 500 500 500 500 500 500 500 www.cosel.co.jp/en/ Optional Parts HCA Series Mating harness Model Harness model # HCA3500TF H-SN-74 H-SN-75 H-SN-76 H-PA-18 Model number H-SN-74 Contents Harness for using functions of CN1 and CN2. (Single side housing) Harness for using functions of CN3 without digital communication. (Single side housing) Harness for using functions of CN3. (Single side housing) (For -I4 option) Harness for parallel operation. (Both side housing) External view H-SN-74 Housing : PDHR-08VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 10g max +50 -0 Wire Pin # 1 2 3 4 5 6 7 8 Model number H-SN-75 Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 Color red black green yellow gray Length (mm) 500 500 500 500 500 External view Housing : PDHR-14VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 20g max H-SN-75 +50 -0 Wire Pin # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 www.cosel.co.jp/en/ Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 24 28 24 28 28 28 28 28 28 28 April 03, 2024 Color white gray orange purple red black pink gray orange blue Length (mm) 500 500 500 500 500 500 500 500 500 500 Option-59 Optional Parts Model number H-SN-76 External view Housing : PDHR-14VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 25g max H-SN-76 +50 -0 Wire Pin # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Model number H-PA-18 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 24 28 24 28 28 28 28 28 28 28 28 28 28 28 Color white gray orange blue yellow brown purple green red black pink gray orange blue Length (mm) 500 500 500 500 500 500 500 500 500 500 500 500 500 500 External view H-PA-18 Housing : PDHR-08VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 7g max +50 -0 Wiring diagram 1 2 3 4 5 6 7 8 Option-60 Wire 1 2 3 4 5 6 7 8 April 03, 2024 Pin # 1 2 3 4 5 6 7 8 Wire UL1061 UL1061 UL1061 AWG 28 28 28 Color green yellow gray Length (mm) 180 180 180 www.cosel.co.jp/en/
H-SN-24 价格&库存
很抱歉,暂时无法提供与“H-SN-24”相匹配的价格&库存,您可以联系我们找货
H-SN-24
  • 1+63.545631+8.26073
H-SN-24
