DHS200A12
DHS200A12
    COSEL
    插件,61x58.4mm
    DHS200A12
DHS200A12 数据手册
DC-DC Converters Bus Converter . Power Module Type Low Profile Isolated Safety Approvals OCP OVP Remote ON/OFF DHS-series Feature Optional parts Ideal for distributed power systems Thin and small size Built-in overcurrent, overvoltage and thermal protection circuits Built-in remote ON/OFF Mounting hole (M3 tapped) Heat sink CE marking Low Voltage Directive RoHS Directive UKCA marking Electrical Equipment Safety Regulations RoHS Regulations Safety agency approvals UL60950-1, C-UL, EN62368-1 5-year warranty www.cosel.co.jp/en/ December 27, 2022 DHS-1 DC-DC Converters Bus Converter . Power Module Type DHS50A Ordering information DH 1 S 50 2 3 A *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 A : DC60-160V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS50A05 DHS50A12 DHS50A15 DHS50A24 MAX OUTPUT WATTAGE[W] 50.0 50.4 51.0 50.4 DC OUTPUT 5V 10A 12V 4.2A 15V 3.4A 24V 2.1A MODEL DHS50A05 DHS50A12 DHS50A15 DHS50A24 VOLTAGE[V] DC60 - 160 SPECIFICATIONS INPUT CURRENT[A] *1 0.55A 0.55A 0.55A 0.55A EFFICIENCY[%] *1 84.0typ 86.0typ 86.0typ 86.0typ VOLTAGE[V] 5 12 15 24 CURRENT[A] 10 4.2 3.4 2.1 LINE REGULATION[mV] 10max 24max 30max 48max LOAD REGULATION[mV] 10max 24max 30max 48max 0 to +100C *2 80max 120max 120max 120max -40 to 0C *2 120max 150max 150max 150max 0 to 15% Load *2 160max 240max 240max 240max 0 to +100C *2 120max 150max 150max 150max -40 to 0C *2 200max 200max 200max 250max 0 to 15% Load *2 240max 300max 300max 300max 0 to +65C 50max 120max 150max 240max -40 to +100C 100max 240max 300max 480max 40max 60max 90max RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 20max 200max (DCIN 110V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 4.50 - 6.00 10.80 - 13.20 13.50 - 16.50 21.60 - 26.40 4.97 - 5.13 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 17.25 - 21.75 27.60 - 34.80 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 6.30 - 7.60 13.90 - 17.55 CIRCUIT AND REMOTE SENSING nothing OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis Complies with IEC61373 Category 1 Class B IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis Complies with IEC61373 Category 1 Class B AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X37.3mm [2.3X0.5X1.47 inches] (WXHXD) / 60g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC110V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-2 December 27, 2022 www.cosel.co.jp/en/ DHS50A External view Recomending size for processing PCB (TOP VIEW) Base Plate(Aluminum) Lot No. 2-f3.5 [0.14] 12.7 ±0.5 [0.5] 4-f1.5 [0.06] 7.62 7.62 [1.47] RC [1.1] -VIN 27.94 ±0.5 TRM +VOUT 37.3 max -VOUT 7.62 7.62 5.08 7.62 [0.3] [0.3] [0.2] [0.3] [0.3] 2-f2 ±0.2 [0.08] 2-f2.5 [0.1] 48.3 [1.9] Name Plate [0.19] +VIN (4.7) 7.62 5.08 1.27 [0.3] [0.2] [0.05] 4-f1±0.1 [0.04] 58.4 max [2.3] 48.3 ±0.5 [1.9] [0.3] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 2-M3 Mounting Hole ¶ Dimensions in mm, [ ]=inches ¶ Div. : 0.2inch ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 60g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max www.cosel.co.jp/en/ December 27, 2022 DHS-3 DC-DC Converters Bus Converter . Power Module Type DHS100A Ordering information DH 1 S 100 2 3 A *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 A : DC60-160V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS100A05 DHS100A12 DHS100A15 DHS100A24 MAX OUTPUT WATTAGE[W] 100.0 100.8 100.5 100.8 DC OUTPUT 5V 20A 12V 8.4A 15V 6.7A 24V 4.2A MODEL DHS100A05 DHS100A12 DHS100A15 DHS100A24 VOLTAGE[V] DC60 - 160 SPECIFICATIONS INPUT CURRENT[A] *1 1.1A 1.1A 1.1A 1.1A EFFICIENCY[%] *1 85.0typ 88.0typ 88.0typ 88.0typ VOLTAGE[V] 5 12 15 24 CURRENT[A] 20 8.4 6.7 4.2 LINE REGULATION[mV] 10max 24max 30max 48max LOAD REGULATION[mV] 10max 24max 30max 48max 0 to +100C *2 80max 120max 120max 120max -40 to 0C *2 120max 150max 150max 150max 0 to 15% Load *2 160max 240max 240max 240max 0 to +100C *2 120max 150max 150max 150max -40 to 0C *2 200max 200max 200max 250max 0 to 15% Load *2 240max 300max 300max 300max 0 to +65C 50max 120max 150max 240max -40 to +100C 100max 240max 300max 480max 40max 60max 90max RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 20max 200max (DCIN 110V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 4.50 - 6.00 10.80 - 13.20 13.50 - 16.50 21.60 - 26.40 4.97 - 5.13 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 17.25 - 21.75 27.60 - 34.80 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 6.30 - 7.60 13.90 - 17.55 CIRCUIT AND REMOTE SENSING nothing OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis Complies with IEC61373 Category 1 Class B IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis Complies with IEC61373 Category 1 Class B AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X37.3mm [2.3X0.5X1.47 inches] (WXHXD) / 60g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC110V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-4 December 27, 2022 www.cosel.co.jp/en/ DHS100A External view Recomending size for processing PCB (TOP VIEW) Base Plate(Aluminum) Lot No. 2-f3.5 [0.14] 12.7 ±0.5 [0.5] 4-f1.5 [0.06] 7.62 7.62 [1.47] RC [1.1] -VIN 27.94 ±0.5 TRM +VOUT 37.3 max -VOUT 7.62 7.62 5.08 7.62 [0.3] [0.3] [0.2] [0.3] [0.3] 2-f2 ±0.2 [0.08] 2-f2.5 [0.1] 48.3 [1.9] Name Plate [0.19] +VIN (4.7) 7.62 5.08 1.27 [0.3] [0.2] [0.05] 4-f1±0.1 [0.04] 58.4 max [2.3] 48.3 ±0.5 [1.9] [0.3] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 2-M3 Mounting Hole ¶ Dimensions in mm, [ ]=inches ¶ Div. : 0.2inch ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 60g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max www.cosel.co.jp/en/ December 27, 2022 DHS-5 DC-DC Converters Bus Converter . Power Module Type DHS200A Ordering information DH 1 S 200 2 3 A *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 A : DC60-160V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS200A05 DHS200A12 DHS200A15 DHS200A24 MAX OUTPUT WATTAGE[W] 200.0 200.4 201.0 201.6 DC OUTPUT 5V 40A 12V 16.7A 15V 13.4A 24V 8.4A MODEL DHS200A05 DHS200A12 DHS200A15 DHS200A24 VOLTAGE[V] DC60 - 160 SPECIFICATIONS INPUT CURRENT[A] *1 2.1A 2.1A 2.1A 2.1A EFFICIENCY[%] *1 87.0typ 88.0typ 88.0typ 88.0typ VOLTAGE[V] 5 12 15 24 CURRENT[A] 40 16.7 13.4 8.4 LINE REGULATION[mV] 10max 24max 30max 48max LOAD REGULATION[mV] 10max 24max 30max 48max 0 to +100C *2 80max 120max 120max 120max -40 to 0C *2 120max 150max 150max 150max 0 to 15% Load *2 160max 240max 240max 240max 0 to +100C *2 120max 150max 150max 150max -40 to 0C *2 200max 200max 200max 250max 0 to 15% Load *2 240max 300max 300max 300max 0 to +65C 50max 120max 150max 240max -40 to +100C 100max 240max 300max 480max 40max 60max 90max RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 20max 200max (DCIN 110V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 3.00 - 6.00 7.20 - 13.20 9.00 - 16.50 14.40 - 26.40 4.97 - 5.13 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 17.25 - 20.25 27.60 - 32.40 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 6.30 - 7.30 13.90 - 16.35 CIRCUIT AND REMOTE SENSING Provided OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis Complies with IEC61373 Category 1 Class B IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis Complies with IEC61373 Category 1 Class B AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X61mm [2.3X0.5X2.4 inches] (WXHXD) / 100g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC110V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-6 December 27, 2022 www.cosel.co.jp/en/ DHS200A External view Recomending size for processing PCB (TOP VIEW) 12.7 ±0.5 [0.5] Lot No. 6-f1.5 [0.06] 2-f2.5 [0.1] 58.4 max [2.3] 48.3 ±0.5 [1.9] 2-f2 ±0.2 [0.08] 7.62 5.08 5.08 7.62 7.62 5.08 5.08 [0.3] [0.2] [0.2] [0.3] [0.3] [0.2] [0.2] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 6-f1 ±0.1 [0.04] 12.7 [0.5] -S 12.7 [0.5] RC TRM +S +VIN 50.8 ±0.5 [2] 61 max [2.4] 10.16 7.62 7.62 10.16 [0.4] [0.3] [0.3] [0.4] -VOUT -VIN Name Plate www.cosel.co.jp/en/ 4-f3.5 [0.14] 48.3 [1.9] (5.1) [0.2] +VOUT 50.8 [2.0] Base Plate(Aluminum) ¶ Dimensions in mm, [ ]=inches 4-M3 Mounting Hole ¶ Div. : 0.2inch December 27, 2022 ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 100g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max DHS-7 DC-DC Converters Bus Converter . Power Module Type DHS50B Ordering information DH 1 S 50 2 3 B *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 B : DC200-400V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS50B03 DHS50B05 DHS50B12 DHS50B15 DHS50B24 DHS50B28 MAX OUTPUT WATTAGE[W] 33.0 50.0 50.4 51.0 50.4 50.4 DC OUTPUT 3.3V 10A 5V 10A 12V 4.2A 15V 3.4A 24V 2.1A 28V 1.8A MODEL DHS50B03 DHS50B05 DHS50B12 DHS50B15 DHS50B24 DHS50B28 VOLTAGE[V] DC200 - 400 SPECIFICATIONS INPUT CURRENT[A] *1 0.15A 0.22A 0.22A 0.22A 0.22A 0.22A EFFICIENCY[%] *1 77.0typ 80.0typ 83.0typ 83.0typ 83.0typ 82.0typ VOLTAGE[V] 3.3 5 12 15 24 28 CURRENT[A] 10 10 4.2 3.4 2.1 1.8 LINE REGULATION[mV] 10max 10max 24max 30max 48max 56max LOAD REGULATION[mV] 10max 10max 24max 30max 48max 56max 0 to +100C *2 80max 80max 120max 120max 120max 120max -40 to 0C *2 120max 120max 150max 150max 150max 150max 0 to 15% Load *2 160max 160max 240max 240max 240max 240max 0 to +100C *2 120max 120max 150max 150max 150max 150max -40 to 0C *2 200max 200max 200max 200max 250max 250max 0 to 15% Load *2 240max 240max 300max 300max 300max 300max 0 to +65C 35max 50max 120max 150max 240max 280max 100max 240max 300max 480max 560max 20max 40max 60max 90max 90max RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] -40 to +100C 66max DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 16max 200max (DCIN 280V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 2.97 - 3.96 4.50 - 6.00 10.80 - 13.20 13.50 - 16.50 21.60 - 26.40 25.20 - 30.80 3.30 - 3.40 4.97 - 5.13 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 27.56 - 28.44 17.25 - 21.75 27.60 - 34.80 32.20 - 40.60 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 4.20 - 5.70 6.30 - 7.60 13.90 - 17.55 CIRCUIT AND REMOTE SENSING None OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL, EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X37.3mm [2.3X0.5X1.47 inches] (WXHXD) / 60g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC280V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-8 December 27, 2022 www.cosel.co.jp/en/ DHS50B External view Recomending size for processing PCB (TOP VIEW) Base Plate(Aluminum) Lot No. 2-f3.5 [0.14] 12.7 ±0.5 [0.5] 4-f1.5 [0.06] 7.62 7.62 [1.47] RC [1.1] -VIN 27.94 ±0.5 TRM +VOUT 37.3 max -VOUT 7.62 7.62 5.08 7.62 [0.3] [0.3] [0.2] [0.3] [0.3] 2-f2 ±0.2 [0.08] 2-f2.5 [0.1] 48.3 [1.9] Name Plate [0.19] +VIN (4.7) 7.62 5.08 1.27 [0.3] [0.2] [0.05] 4-f1±0.1 [0.04] 58.4 max [2.3] 48.3 ±0.5 [1.9] [0.3] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 2-M3 Mounting Hole ¶ Dimensions in mm, [ ]=inches ¶ Div. : 0.2inch ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 60g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max www.cosel.co.jp/en/ December 27, 2022 DHS-9 DC-DC Converters Bus Converter . Power Module Type DHS100B Ordering information DH 1 S 100 2 3 B *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 B : DC200-400V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS100B03 DHS100B05 DHS100B12 DHS100B15 DHS100B24 DHS100B28 MAX OUTPUT WATTAGE[W] 66.0 100.0 100.8 100.5 100.8 100.8 DC OUTPUT 3.3V 20A 5V 20A 12V 8.4A 15V 6.7A 24V 4.2A 28V 3.6A MODEL DHS100B03 DHS100B05 DHS100B12 DHS100B15 DHS100B24 DHS100B28 VOLTAGE[V] DC200 - 400 SPECIFICATIONS INPUT CURRENT[A] *1 0.30A 0.44A 0.42A 0.42A 0.42A 0.42A EFFICIENCY[%] *1 79.0typ 82.0typ 85.0typ 86.0typ 86.0typ 86.0typ VOLTAGE[V] 3.3 5 12 15 24 28 CURRENT[A] 20 20 8.4 6.7 4.2 3.6 LINE REGULATION[mV] 10max 10max 24max 30max 48max 56max LOAD REGULATION[mV] 10max 10max 24max 30max 48max 56max 0 to +100C *2 80max 80max 120max 120max 120max 120max -40 to 0C *2 120max 120max 150max 150max 150max 150max 0 to 15% Load *2 160max 160max 240max 240max 240max 240max 0 to +100C *2 120max 120max 150max 150max 150max 150max -40 to 0C *2 200max 200max 200max 200max 250max 250max 0 to 15% Load *2 240max 240max 300max 300max 300max 300max 0 to +65C 35max 50max 120max 150max 240max 280max 100max 240max 300max 480max 560max 20max 40max 60max 90max 90max RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] -40 to +100C 66max DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 16max 200max (DCIN 280V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 2.97 - 3.96 4.50 - 6.00 10.80 - 13.20 13.50 - 16.50 21.60 - 26.40 25.20 - 30.80 3.30 - 3.40 4.97 - 5.13 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 27.56 - 28.44 17.25 - 21.75 27.60 - 34.80 32.20 - 40.60 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 4.20 - 5.70 6.30 - 7.60 13.90 - 17.55 CIRCUIT AND REMOTE SENSING None OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL, EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X37.3mm [2.3X0.5X1.47 inches] (WXHXD) / 60g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC280V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-10 December 27, 2022 www.cosel.co.jp/en/ DHS100B External view Recomending size for processing PCB (TOP VIEW) Base Plate(Aluminum) Lot No. 2-f3.5 [0.14] 12.7 ±0.5 [0.5] 4-f1.5 [0.06] 7.62 7.62 [1.47] RC [1.1] -VIN 27.94 ±0.5 TRM +VOUT 37.3 max -VOUT 7.62 7.62 5.08 7.62 [0.3] [0.3] [0.2] [0.3] [0.3] 2-f2 ±0.2 [0.08] 2-f2.5 [0.1] 48.3 [1.9] Name Plate [0.19] +VIN (4.7) 7.62 5.08 1.27 [0.3] [0.2] [0.05] 4-f1±0.1 [0.04] 58.4 max [2.3] 48.3 ±0.5 [1.9] [0.3] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 2-M3 Mounting Hole ¶ Dimensions in mm, [ ]=inches ¶ Div. : 0.2inch ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 60g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max www.cosel.co.jp/en/ December 27, 2022 DHS-11 DC-DC Converters Bus Converter . Power Module Type DHS250B Ordering information DH 1 S 250 2 3 B *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 B : DC200-400V 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) MODEL DHS250B03 DHS250B05 DHS250B07 DHS250B12 DHS250B15 DHS250B24 DHS250B28 DHS250B48 MAX OUTPUT WATTAGE[W] 165.0 250.0 247.5 252.0 247.5 252.0 252.0 249.6 DC OUTPUT 3.3V 50A 5V 50A 7.5V 33A 12V 21A 15V 16.5A 24V 10.5A 28V 9.0A 48V 5.2A SPECIFICATIONS MODEL DHS250B03 DHS250B05 DHS250B07 DHS250B12 DHS250B15 DHS250B24 DHS250B28 DHS250B48 VOLTAGE[V] INPUT *1 0.67A 1.0A 1.0A 1.0A 1.0A 1.0A 1.0A 1.0A EFFICIENCY[%] *1 88.0typ 90.0typ 88.0typ 88.0typ 88.0typ 88.0typ 88.0typ 89.0typ VOLTAGE[V] 3.3 5 7.5 12 15 24 28 48 CURRENT[A] 50 50 33 21 16.5 10.5 9.0 5.2 LINE REGULATION[mV] 10max 10max 20max 24max 30max 48max 56max 96max LOAD REGULATION[mV] RIPPLE[mVp-p] OUTPUT DC200 - 400 CURRENT[A] RIPPLE NOISE[mVp-p] TEMPERATURE REGULATION[mV] 10max 10max 20max 24max 30max 48max 56max 96max 0 to +100C *2 80max 80max 100max 120max 120max 120max 120max 200max -40 to 0C *2 120max 120max 130max 150max 150max 150max 150max 250max 0 to 15% Load *2 160max 160max 200max 240max 240max 240max 240max 400max 0 to +100C *2 120max 120max 130max 150max 150max 150max 150max 250max -40 to 0C *2 200max 200max 200max 200max 200max 250max 250max 400max 0 to 15% Load *2 240max 240max 260max 300max 300max 300max 300max 500max 0 to +65C 35max 50max 70max 120max 150max 240max 280max 480max 100max 140max 240max 300max 480max 560max 960max 20max 30max 40max 60max 90max 90max 180max -40 to +100C 66max DRIFT[mV] *3 START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] *4 OUTPUT VOLTAGE SETTING[V] 16max 200max (DCIN 280V, Io=100%) Fixed (TRM pin open), adjustable by external VR or external voltage 1.98 - 3.96 3.00 - 6.00 4.50 - 8.25 7.20 - 13.20 9.00 - 16.50 14.40 - 26.40 16.80 - 30.80 28.80 - 52.80 3.30 - 3.40 4.97 - 5.13 7.43 - 7.67 11.91 - 12.29 14.76 - 15.24 23.62 - 24.38 27.56 - 28.44 47.24 - 48.76 17.25 - 20.25 27.60 - 32.40 32.20 - 37.80 55.20 - 64.80 OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically PROTECTION OVERVOLTAGE PROTECTION[V] 4.20 - 4.85 6.30 - 7.30 8.70 - 10.20 13.90 - 16.35 CIRCUIT AND REMOTE SENSING Provided OTHERS REMOTE ON/OFF Provided (Negative Logic L : ON, H :OFF) ISOLATION INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max ENVIRONMENT SAFETY OTHERS STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL, EN62368-1 CASE SIZE/WEIGHT 58.4X12.7X61mm [2.3X0.5X2.4 inches](WXHXD) / 100g max COOLING METHOD Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 At rated input(DC280V) and rated load. *2 Ripple and ripple noise is measured by using measuring board. Refer to the manual. *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *4 Refer to the manual for input range. DHS-12 December 27, 2022 www.cosel.co.jp/en/ DHS250B External view Recomending size for processing PCB (TOP VIEW) 12.7 ±0.5 [0.5] Lot No. 6-f1.5 [0.06] 2-f2.5 [0.1] 58.4 max [2.3] 48.3 ±0.5 [1.9] 2-f2 ±0.2 [0.08] 7.62 5.08 5.08 7.62 7.62 5.08 5.08 [0.3] [0.2] [0.2] [0.3] [0.3] [0.2] [0.2] (5.0) [0.2] 5.0 ±0.5 [0.2] Case(PBT) 6-f1 ±0.1 [0.04] 12.7 [0.5] -S 12.7 [0.5] RC TRM +S +VIN 50.8 ±0.5 [2] 61 max [2.4] 10.16 7.62 7.62 10.16 [0.4] [0.3] [0.3] [0.4] -VOUT -VIN Name Plate www.cosel.co.jp/en/ 4-f3.5 [0.14] 48.3 [1.9] (5.1) [0.2] +VOUT 50.8 [2.0] Base Plate(Aluminum) ¶ Dimensions in mm, [ ]=inches 4-M3 Mounting Hole ¶ Div. : 0.2inch December 27, 2022 ¶ Tolerance : ±0.3 [±0.012] ¶ Weight : 100g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max DHS-13 DHS-series Pin Configuration ¿ DHS50/100 6 -VOUT 5 TRM -VIN 3 RC 2 4 +VOUT +VIN 1 *bottom view No. DHS50/100 DHS200/250 1 1 2 2 3 3 4 4 5 6 5 7 8 6 Pin Connection 2-FG +VIN RC -VIN +VOUT +S TRM -S -VOUT Mounting hole Function +DC input Remote ON/OFF -DC input +DC output +Remote sensing Adjustment of output voltage -Remote sensing -DC output Mounting hole ¿ DHS200/250 8 -VOUT -VIN 3 7 -S 6 TRM RC 2 5 +S +VIN 1 4 +VOUT *bottom view 4-FG Implementation・Mounting Method Mounting method ¡The unit can be mounted in any direction. When two or more power supplies are used side by side, position them with proper intervals to allow enough air ventilation. Aluminum base plate temperature around each power supply should not exceed the temperature range shown in “Derating”. ¡Avoid placing the DC input line pattern lay out underneath the unit, it will increase the line conducted noise. Make sure to leave an ample distance between the line pattern lay out and the unit. Also avoid placing the DC output line pattern underneath the unit because it may increase the output noise. Lay out the pattern away from the unit. ¡High-frequency noise radiates directly from the unit to the atmosphere. Therefore, design the shield pattern on the printed circuit board and connect its one to FG. Shield pattern The shield pattern prevents noise radiation. Shield pattern -VIN -VOUT +VIN +VOUT -VOUT +VOUT -VIN +VIN DHS50, DHS100 DHS-14 *bottom view December 27, 2022 DHS200, DHS250 *bottom view www.cosel.co.jp/en/ DHS-series Implementation・Mounting Method Stress onto the pins -VOUT ¡Applying excessive stress to the input or output pins of the power module may damage internal connections. Avoid applying stress in TRM excess of that shown in right figure. ¡Input and output pins are soldered onto the internal PCB. Do not bend or pull the leads with excessive force. +VOUT -VIN RC +VIN ¡As unexpected stress may be applied to the pins, set the diameter of the PCB mounting hole at 3.5mm. DHS50, DHS100 *bottom view ¡As unexpected stress may be applied to the pins from vibration or shock, fix the power module by using the mounting holes with screws to reduce stress. ¡Fix the power module to the PCB with the screws before soldering the input and output pins to prevent the PCB pattern being damaged. -VOUT -VIN -S TRM RC +S +VIN +VOUT DHS200, DHS250 *bottom view +VOUT, -VOUT Less than 39.2N(4kgf) Less than 39.2N(4kgf) Others Less than 19.6N(2kgf) Less than 39.2N(4kgf) Less than 19.6N(2kgf) Less than 19.6N(2kgf) Soldering temperature : 260C for up to 15 seconds. ¡Flow soldering ¡Soldering iron (26W) : 450Cfor up to 5 seconds. Derating ¡Use the power modules with conduction cooling (e.g. heat dissipation from the aluminum base plate to the attached heat sink).Below shows the derating curves with respect to the aluminum base plate temperature. Note that operation within the hatchedareas will cause a significant level of ripple and ripple noise. ¡Please measure the temperature on the aluminum base plate edge side when you cannot measure the temperature of the center part of the aluminum base plate.In this case, please take 5deg temperature margin from the derating characteristic of below. ¡It is necessary to note the thermal fatigue life by power cycle. Please reduce the temperature fluctuation range as much as possible when the up and down of the temperature are frequently generated. Contact us for more information on cooling methods. ¿ DHS50, DHS100 Load factor [%] 1 1DHS100B24,28 2Others 50 15 0 -40 Tc Measuring point 2 100 -20 0 20 40 60 (85) 80 Aluminum base plate temperature Tc [C] www.cosel.co.jp/en/ 100 110 DHS50, DHS100 December 27, 2022 DHS200, DHS250 DHS-15 DHS-series Derating ¿DHS200 ¿DHS250 1DHS200A05 2Others 50 15 0 -40 100 1 -20 0 20 40 Load factor [%] Load factor [%] 100 2 60 (75) (85) 80 100 110 2 1DHS250B12,48 2Others 50 15 0 -40 Aluminum base plate temperature Tc [C] -20 0 20 40 1 60 (75) (85) 80 100 110 Aluminum base plate temperature Tc [C] Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://www.cosel.co.jp/redirect/catalog/en/DHS/ Before using our product https://en.cosel.co.jp/technical/caution/index.html DHS NOTICE Basic Characteristics Data Model Circuit method Switching frequency [kHz] Input current [A] Rated input fuse DHS50A DHS50B Forward converter 470 *1 DHS100A DHS100B Forward converter 470 DHS200A DHS250B Forward converter 360 Series/Parallel operation availability PCB/Pattern Material Single sided Double sided Series operation Parallel operation - Aluminum Yes Yes *2 *1 - Aluminum Yes Yes *2 *1 - Aluminum Yes Yes *2 *1 R  efer to Specification.  efer to Instruction Manual. *2 R DHS-16 December 27, 2022 www.cosel.co.jp/en/
DHS200A12 价格&库存
很抱歉,暂时无法提供与“DHS200A12”相匹配的价格&库存,您可以联系我们找货
