H-OU-21
H-OU-21
    COSEL
    WIRE HARNESS FOR PAA/PB
H-OU-21 数据手册
Optional Parts PB PMA PDA Series Attachment Plate model Applicable models PBA10F PBA15F, PBW15F, PDA15F PBA30F, PBW30F, PMA15F, PDA30F PBA50F, PBW50F, PMA30F, PDA50F PBA75F, PMA60F PBA100F PBA150F, PMA100F F-PBA10-1 F-PBA15-1 F-PBA30-1 F-PBA50-1 F-PBA75-1 F-PBA100-1 F-PBA150-1 Example TOP VIEW F-PBA10-1 Size 21 Size 2 - 3.5 5 15 5 18.5 36.5 5 78 88 (Unit : mm) (Tolerance : 1) F-PBA15-1 5 95 105 Material : SECC Thickness : 2.0 Weight : 60g max 2 - 3.5 18.5 36.5 BASE Attachment Material : SECC Thickness : 2.0 Weight : 70g max M3 Flat screw is requested when mounting. Please check catalog for the size of screw. Mounting hole size 13.5 2-M3 FRONT 78 95 18.5 Size 5 113 123 21 32 18.5 36.5 2 - 3.5 3 - 3.5 5 5 Material : SECC Thickness : 2.0 Weight : 85g max 6 F-PBA50-1 F-PBA30-1 Size 25 37 FRONT 2-M3 13.5 Mounting hole size 130 140 Material : SECC Thickness : 2.0 Weight : 95g max M3 Flat screw is requested when mounting. Please check catalog for the size of screw. 13.5 2-M3 FRONT Mounting hole size FRONT 130 113 Option-2 3-M3 25 26 Mounting hole size March 01, 2024 www.cosel.co.jp/en/ Optional Parts TOP VIEW F-PBA100-1 5 3 - 3.5 145 155 5 25 37 32 25 37 32 3 - 3.5 25 Size 6 19 Size 6 F-PBA75-1 (Unit : mm) (Tolerance : 1) 157 167 Material : SECC Thickness : 2.0 Weight : 110g max Material : SECC Thickness : 2.0 Weight : 110g max M3 Flat screw is requested when mounting. Please check catalog for the size of screw. Mounting hole size 25 26 3-M3 FRONT 3-M3 25 26 Mounting hole size FRONT 145 157 Size 3 - 3.5 5 25 37 32 19 6 F-PBA150-1 178 188 Material : SECC Thickness : 2.0 Weight : 130g max M3 Flat screw is requested when mounting. Please check catalog for the size of screw. Mounting hole size 3-M3 25 26 FRONT 178 www.cosel.co.jp/en/ March 01, 2024 Option-3 Optional Parts Example FRONT REVERSE Attachment Plate model Applicable models PBA10F PBA15F, PBW15F, PDA15F PBA30F, PBW30F, PMA15F, PDA30F PBA50F, PBW50F, PMA30F, PDA50F PBA75F, PMA60F PBA100F PBA150F, PMA100F F-PBA10-2 F-PBA15-2 F-PBA30-2 F-PBA50-2 F-PBA75-2 F-PBA100-2 F-PBA150-2 Using hole-A Using hole-B TOP VIEW F-PBA15-2 F-PBA10-2 (Unit : mm) (Tolerance : 1) Size hole-A 3 - 3.5 21.5 11.5 15 15 35 hole-B 10 hole-A hole-B hole-A 3 - 3.5 17.5 17.5 35 15 hole-A 85.5 20.5 5.5 15 15 35 10 hole-B 68.5 35 hole-B 15 Size Material : SECC Thickness : 1.6 Weight : 70g max Material : SECC Thickness : 1.6 Weight : 60g max F-PBA30-2 M3 screw is requested when mounting. Please check catalog for the size of screw. F-PBA50-2 Size hole-B hole-B hole-A 3 - 3.5 15 103.5 hole-A 123 hole-A 3 - 3.5 20 9 15 15 35 hole-B 10 hole-B 17.5 17.5 35 35 21 hole-A Material : SECC Thickness : 1.6 Weight : 80g max 14 21 15 25 45 7 Size Material : SECC Thickness : 2.0 Weight : 120g max M3 screw is requested when mounting. Please check catalog for the size of screw. Option-4 March 01, 2024 www.cosel.co.jp/en/ Optional Parts TOP VIEW (Unit : mm) (Tolerance : 1) F-PBA100-2 F-PBA75-2 Size hole-B hole-A 3 - 3.5 hole-B 12 15 25 45 21 hole-A hole-B 7 20.5 3 - 3.5 35 17.5 35 hole-B hole-A 150 21 138 17.5 hole-A Material : SECC Thickness : 2.0 Weight : 130g max hole-B hole-A 18 19.5 15 25 45 7 Size Material : SECC Thickness : 2.0 Weight : 140g max M3 screw is requested when mounting. Please check catalog for the size of screw. F-PBA150-2 Size hole-A hole-B 3 - 3.5 hole-B hole-A 19.5 12 15 25 45 8 19 38 22 171 Material : SECC Thickness : 2.0 Weight : 170g max M3 screw is requested when mounting. Please check catalog for the size of screw. www.cosel.co.jp/en/ March 01, 2024 Option-5 Optional Parts DIN rail Attachment Plate(PB Series) APPLICABLE TO MODEL Plate model FD-PBA10 FD-PBA15 FD-PBA30 FD-PBA50 FD-PBA100 FD-PBA300 DIN rail width : 35mm screws for installation Type Qty Model PBA10F PBA15F, PBW15F PBA30F, PBW30F PBA50F, PBW50F, PBA75F PBA100F PBA150F PBA300F M3 2pcs M3 M3 M4 3pcs 2pcs 2pcs 78 FD-PBA10, FD-PBA15, FD-PBA30 EXTERNAL VIEW 23.5 2 11 35.5 Plate model Model FD-PBA10 PBA10F FD-PBA15 PBA15F, PBW15F FD-PBA30 PBA30F, PBW30F Option-14 16.5 2 L1 75.0 2 92.0 2 110.0 2 L1 7.1max Material : SECC Thickness : 1.0 Tolerance : 1 1 Screws for installation (attached to Plate) Weight : FD-PBA10 45g max FD-PBA15 55g max FD-PBA30 60g max March 01, 2024 www.cosel.co.jp/en/ Optional Parts L4 FD-PBA50, FD-PBA100 EXTERNAL VIEW 6.6 1 Plate model Model PBA50F FD-PBA50 PBA75F PBA100F FD-PBA100 PBA150F 1 L2 L3 L1 135 150 162 183 L1 L2 L3 L4 16.5 2 41 102.5 13.5 2 42.5 112 Material : SECC Thickness : 1.6 Tolerance : 1 1 Screws for installation (attached to Plate) Weight : FD-PBA50 220g max Weight : FD-PBA100 260g max L4 FD-PBA300 EXTERNAL VIEW 1 6 1 L3 Plate model Model FD-PBA300 PBA300F www.cosel.co.jp/en/ L1 195.5 L2 L2 25max L1 L3 44 L4 112 March 01, 2024 Material : SPHC Thickness : 2.0 Tolerance : 1 1 Screws for installation (attached to Plate) Weight : 500g max Option-15 Optional Parts PB Series Harness to use the function is prepared in PB series. Mating harness Harness model # Model PBA10F, PBA15F, PBW15F, PBA30F, PBW30F, H-IN-3 or H-IN-27 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F 1 H-OU-9 PBA10F, PBA15F, PBA30F, PBA50F H-OU-18 PBA75F, PBA100F, PBA150F 1 PBW15F, PBW30F, PBW50F H-OU-48 H-RC-1 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F H-SN-1 PBA100F, PBA150F 2 PBA10F, PBA15F, PBW15F, PBA30F, PBW30F H-SN-18 PBA50F, PBW50F, PBA75F, PBA100F, PBA150F H-PA-3 PBA300F H-SN-20 PBA600F H-SN-21 PBA1000F H-SN-22 PBA1500F H-SN-24 PBA1500T 1 Available for 12V, 15V, 24V, 36V and 48V output model in PBA100F / 150F. 2 Available for 3.3V and 5V output model in PBA100F / 150F. Model number H-IN-3 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-IN-27 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Pin : : 40g max Weight Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 4 5 1 2 3 4 5 1 2 3 4 1 2 3 4 5 6 Weight : 60g max Model number H-OU-48 Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Pin : : 40g max Weight www.cosel.co.jp/en/ Type 1 2 3 4 Contents Input harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Output harness when I/O interface is connector (Mfr: J.S.T.) type (option : -J1) Harness for using option : -R Harness for using option : -K Harness for using option : -V Harness for parallel operation Harness for using all functions of CN1 and CN2 Harness for using all functions except remote sensing of CN2 Harness for using all functions of CN3 Harness for using example remote ON/OFF circuit (C) Wire +50 -0 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 20 white Length (mm) 500 UL1015 20 black 500 UL1015 20 green/yellow 500 Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Length (mm) 500 500 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 Color purple black black red Length (mm) 500 500 500 500 Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 500 500 +50 -0 Wire +50 -0 March 01, 2024 Option-31 Optional Parts Model number H-RC-1 Type Wire 1 2 +50 -0 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Model number H-SN-1 Type Model number H-SN-18 H-PA-3 +50 -0 Type H-SN-20 Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 8g max Color Length (mm) UL1061 UL1061 28 28 black red 500 500 Pin # Wire AWG Color 1 2 UL1007 UL1007 26 26 yellow orange Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 red black yellow green blue orange purple Pin # Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 28 28 red black yellow green blue black orange purple UL1007 UL1007 Pin # 1 2 3 4 Length (mm) 500 500 Length (mm) 270 270 270 270 270 270 270 Wire 2 4 6 8 10 9 7 5 3 1 +50 -0 Option-32 AWG 1 2 Wire 1 3 5 7 9 +50 -0 Type Wire AWG Wire 2 1 Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 5g max Model number +50 -0 Type Housing : PHR-2 (J.S.T.) Pin : SPH-002T-P0.5S (J.S.T.) Weight : 4g max Model number Length (mm) 500 500 Wire Wire 1 2 3 4 Housing : XHP-4 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 3g max 22 22 Color orange blue Pin # March 01, 2024 Length (mm) 500 500 500 500 500 500 500 500 www.cosel.co.jp/en/ Optional Parts Model number H-SN-21 Type Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 6g max Wire 2 4 6 8 10 9 7 5 3 1 +50 -0 Model number H-SN-22 Type +50 -0 Model number H-SN-24 CN A : Housing : PHDR-10VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Type CN A CN B max 2 4 6 8 10 8 6 4 2 max CN B : Housing : PHDR-08VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 2g max Pin #1 and #2, Pin #3 and #4 in CN A are connected by harness. Pin #9 in CN A and Pin #4 in CN B are connected by harness. Pin #10 in CN A and Pin #5 in CN B are connected by harness. www.cosel.co.jp/en/ Wire AWG Color 1 2 3 4 5 6 7 8 9 10 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 28 yellow green blue black orange purple Pin # Wire AWG Color 1 2 3 4 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 28 28 28 28 28 pink brown white yellow gray Pin # Wire AWG Color 1 2 3 4 5 CN A 6 7 8 9 10 1 2 3 4 CN B 5 6 7 8 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 - 28 28 28 28 28 28 28 28 - red red black black black black black black - Length (mm) 500 500 500 500 500 500 Wire 2 4 6 8 7 5 3 1 Housing : PHDR-8VS(J.S.T) Pin : SPHD-002T-P0.5(J.S.T) Weight : 5g max Pin # March 01, 2024 Length (mm) 500 500 500 500 500 Wire Length (mm) 30 30 30 30 70 70 70 70 - Option-33 Optional Parts Terminal Attachment Terminal attachment to facilitate two or more terminal connections to power supply output is prepared in PBA, MAX, ACE and AME series. Type Mating Model B-MX-1 PBA600F MAX1600F MAX1600T MAX3200T Contents Terminal attachment to facilitate terminal connections to power supply output B-MX-9 MAX1600F MAX1600T MAX3200T Terminal attachment for series operation as output modules B-MX-9 B-MX-1 Size Size 36 R2 6 2-M5 2-M4 6 6 14 6 8.2 7.5 10.5 10 6 6.5 4- 6 17 13 14 14 6 18.5 3 14 2-R2 2-R2 6 2- 6 6.5 6.5 6-R1 42 3 Material : Copper Thickness : 2.0 Dimension in mm Weight : 30g max 6.5 6.5 6-R2 Material : Copper Thickness : 1.5 Dimension in mm Weight : 15g max It is necessary to install B-MX-1 on opposite direction to avoid short-circuit between + and - terminal block. Please note the direction of the installation to prevent the short-circuit between the outputs when using B-MX-1 and B-MX-9 at the same time. The cover of terminal block does not be attached to B-MX-1 with installation screw and solderless terminal occasionally. Option-60 March 01, 2024 www.cosel.co.jp/en/ Optional Parts PB Series Fan unit Fan unit is prepared by the option. Fan unit type Matching model External Pin connection Air flow FAN-PB3 (Standard) PBA300F Weight : 90g max FAN-PB3-F3 PBA300F (Air flow reverse : -F3) Pin No. Air flow Weight : 90g max Air flow Content 1 GND 2 FAN ALARM 3 POWER LENGTH OF HARNESS = 40 5mm FAN-PB3-F4 PBA300F (Low speed : -F4) CONNECTOR = PHR-3 (Mfr : J. S. T) TERMINAL = SPH-002T-P0.5S (Mfr : J. S. T) Weight : 90g max Air flow FAN-PB6 (Standard) PBA600F Weight : 120g max Air flow CONNECTOR = XAP-03V-1 (Mfr : J. S. T) TERMINAL = SXA-001T-P0.6 (Mfr : J. S. T) FAN-PB6-F1 PBA600F (Long life : -F1) Weight : 150g max FAN-PB6-F3 PBA600F (Air flow reverse : -F3) Air flow Pin No. Content 1 GND 2 FAN ALARM 3 POWER LENGTH OF HARNESS = 55 7mm Weight : 120g max Air flow FAN-PB6-F4 PBA600F (Low speed : -F4) Weight : 120g max 1 Handle with care and don’t add the impact such as falls or throwing to the unit. 2 Exchange the unit after intercepting the input power. 3 When the unit is exchanged, make sure there are not loosening of the connector and shutting the harness. Option-66 March 01, 2024 www.cosel.co.jp/en/ Optional Parts PB Series Fan unit Fan unit is prepared by the option. Fan unit type Matching model External Pin connection Air flow FAN-PB10 (Standard) PBA1000F Weight : 210g max Air flow FAN-PB10-F1 PBA1000F (Long life : -F1) Weight : 260g max FAN-PB10-F3 PBA1000F (Air flow reverse : -F3) Air flow Weight : 210g max Air flow CONNECTOR = XAP-03V-1 (Mfr : J. S. T) TERMINAL = SXA-001T-P0.6 (Mfr : J. S. T) FAN-PB10-F4 PBA1000F (Low speed : -F4) Weight : 200g max FAN-PB15 (Standard) Air flow PBA1500F PBA1500T Pin No. Content 1 GND 2 FAN ALARM 3 POWER LENGTH OF HARNESS = 55 7mm Weight : 210g max FAN-PB15-F1 (Long life : -F1) Air flow PBA1500F PBA1500T Weight : 260g max FAN-PB15-F3 (Air flow reverse : -F3) PBA1500F PBA1500T Air flow Weight : 210g max Air flow FAN-PB15-F4 PBA1500F PBA1500T (Low speed : -F4) Weight : 200g max 1 Handle with care and don’t add the impact such as falls or throwing to the unit. 2 Exchange the unit after intercepting the input power. 3 When the unit is exchanged, make sure there are not loosening of the connector and shutting the harness. www.cosel.co.jp/en/ March 01, 2024 Option-67 Optional Parts Insulated tube for PBA1000F, PBA1500F, PBA1500T, PJA1000F & PJA1500F This is a tube used to insulate an output terminal. Plate model T-PBA1500-1 T-PBA1500-2 Applicable to model PBA1000F, PBA1500F, PBA1500T, PJA1000F, PJA1500F PBA1000F, PBA1500F, PBA1500T, PJA1000F, PJA1500F AC (L) AC (N) NC FG V.A D J CN 1 CN 2 CN 3 Example(PBA1500F) (Unit : mm) (Tolerance : 1) T-PBA1500-1 T-PBA1500-2 This is used when insulating the root portion of an output terminal. 10.8 16.8 (20.2) This is used when insulating the tip portion of an output terminal. (13) (32.4) 29 (58) Material : Silicone rubber Black Weight : 2g max Material : Silicone rubber Black Weight : 15g max If this product is attached, a wiring portion can't visible. Be careful not to forget to attach the screw or the bolt for electric wire connection. Option-72 March 01, 2024 www.cosel.co.jp/en/
H-OU-21 价格&库存
很抱歉,暂时无法提供与“H-OU-21”相匹配的价格&库存,您可以联系我们找货
H-OU-21
  • 1+127.438211+15.93960
  • 4+125.574564+15.70650
  • 10+124.4208710+15.56220
  • 25+123.1784425+15.40680
  • 40+121.4035340+15.18480
H-OU-21
