H-IN-5
H-IN-5
    COSEL
H-IN-5 数据手册
Optional Parts Harness Mating harness Model LHA10F LHA15F LHA30F LHA50F LHA75F LHA100F LHA150F,LHP150F LHA300F,LHP300F LHA300F, LHP300F LHP300F LCA10S LCA15S LCA30S LCA50S, LGA50A LCA75S, LGA75A LCA100S, LGA100A LCA150S, LGA150A LGA240A, LFA300F, LFP300F TECS Harness model # Output Input H-OU-34 H-OU-34 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-18 H-IN-10 H-OU-18 H-OU-46 H-OU-10 H-OU-54 H-OU-7 H-IN-4 H-OU-8 H-IN-4 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-10 H-IN-10 H-OU-11 H-OU-12 H-OU-11 H-IN-14 H-OU-12 H-OU-9 H-IN-29 Model number H-IN-4 Model SNA-01,-03 SNA-06 SNR-10 LDA10F LDA15F LDA30F, LFA30F LDA50F, LEA50F, LFA50F LDA75F, LEA75F, LFA75F LDA100W, LEA100F, LFP100F, LFA100F LMA100F, LEP100F, 150F, 240F LDA150W, LEA150F, LFP150F, LFA150F, LFA240F, LFP240F, LMA150F, LMA240F LFA10F LFA15F LDA300W H-IN-5 Type Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-7 Type Housing : 1-178128-5 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 35g max Model number H-IN-10 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-14 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-IN-29 Housing : VHR-3N(J.S.T) Pin : SVH-21T-P1.1 or BVH-21T-P1.1 (J.S.T) Weight : 25g max Option-20 H-IN-7 H-OU-11 H-OU-12 H-OU-34 H-OU-34 H-OU-22 Optional : connector type ”-J” (LDA300W) Optional : connector type ”-J1” (LGA50A,75A,100A,150A,240A) Optional : connector type ”-J1” (LFA10F,15F,30F,50F,75F,100F,150F,240F,300F) Optional : connector type ”-J1” (LFP100F,150F,240F,300F) Optional : connector type ”-J1” (LMA100F,150F,240F) Optional : connector type ”-J5 ” (LHA300F) Optional : connector type ”-J5 ” (LHP300F) Housing : XHP-7 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 10g max Model number Harness model # Input Output H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-OU-18 H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-IN-5 or H-OU-10 H-IN-10 1 2 3 4 5 6 7 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 6 7 8 LCA Series LDA Series LGA Series LEA Series LEP Series LFA Series LFP Series LHA Series LHP Series LMA Series SNA Series SNR Series TECS Series Wire +50 -0 Pin # Wire AWG 1 2, 3 4 5, 6 7 UL1007 22 black Length (mm) 500 UL1007 22 white 500 UL1007 22 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 white Length (mm) 500 UL1015 18 black 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 ,2 3 4 ,5 6 7 ,8 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 UL1015 UL1015 AWG18 AWG18 white black Color Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire Type 1 2 3 +50 -0 October 26, 2023 Length (mm) 500 500 www.cosel.co.jp/en/ Optional Parts Model number H-OU-7 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Model number H-OU-8 Type Type Housing : XHP-4 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 15g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 40g max Model number H-OU-10 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Model number H-OU-11 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-12 Type Housing : VHR-7N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 70g max Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-22 Type Housing : 1-178288-8 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 100g max Model number H-OU-34 Type 1 2 1 2 3 4 1 2 3 4 1 2 3 4 5 6 7 8 1 2 3 4 5 6 1 2 3 4 5 6 7 1 2 3 4 5 6 1 2 3 4 5 6 7 8 9 10 1 2 Wire +50 -0 H-OU-46 Type Housing : VHR-10N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 100g max Model number H-OU-54 Housing : VHR-8N (J.S.T.) Pin : SVH-41T-P1.1 (J.S.T.) Weight : 100g max www.cosel.co.jp/en/ Type 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 Wire AWG Color 1 2 UL1007 UL1007 22 22 black red Pin # Wire AWG Color 1 2 3 4 UL1007 UL1007 UL1007 UL1007 22 22 22 22 black black red red Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Wire AWG Color UL1015 18 red Pin # Wire AWG Color 1-7 UL1015 18 black Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-4 5-8 UL1430 UL1430 16 16 black red Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Pin # 1-6 Length (mm) 500 +50 -0 Wire Length (mm) 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire +50 -0 Housing : VHR-2N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number Pin # Wire Length (mm) 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 October 26, 2023 Option-21 Optional Parts Harness for remote ON/OFF(R type) is prepared in LDA, LEA, LEB, LEP, LFA, LFP, LHA, LHP & LMA series. Mating harness Model LDA50F, LDA75F, LDA100W, LDA150W, LDA300W LEA50F, LEA75F, LEA100F, LEA150F, LEP100F, LEP150F, LEP240F LEB100F, LEB150F, LEB225F LFA100F, LFA150F, LFA240F, LFA300F, LFP100F, LFP150F, LFP240F, LFP300F LHA100F,LHA150F,LHA300F,LHP150F,LHP300F LMA100F, LMA150F, LMA240F Model number H-RC-1 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Option-26 Harness model # H-RC-1 LDA LEA LEB LEP LFA LFP LHA LHP LMA Series Series Series Series Series Series Series Series Series Wire Type 1 2 +50 -0 October 26, 2023 Pin # Wire AWG 1 2 UL1007 UL1007 22 22 Color orange blue Length (mm) 500 500 www.cosel.co.jp/en/
H-IN-5 价格&库存
很抱歉,暂时无法提供与“H-IN-5”相匹配的价格&库存,您可以联系我们找货
H-IN-5
    H-IN-5
    • 10+29.5446110+3.81363
    H-IN-5
      • 1+65.16980
      库存:91
