H-RC-1
H-RC-1
    COSEL
H-RC-1 数据手册
Optional Parts PLA-PJA Series Attachment BASE Attachment Plate model Applicable models F-PLA15-1 F-PLA30-1 F-PLA50-1 PLA15F PLA30F PLA50F PLA100F, PLA150F, F-PLA100-1 PJA100F, PJA150F F-PLA300-1 PLA300F, PJA300F F-PLA600-1 PLA600F, PJA600F Example (PLA300F) TOP VIEW F-PLA15-1 (Unit : mm) (Tolerance : 1) F-PLA30-1 Size Size 6 21 6 100 19.5 6 19.5 6 21 85 39 2- 3.5 39 2- 3.5 112 97 Material : SECC Thickness : 2.0 Weight : 75g max Material : SECC Thickness : 2.0 Weight : 65g max M3 Flat screw is requested when mounting. Please check the instruction manual for the size of screw. Mounting hole size 2-M3 FRONT 2-M3 13.5 85 100 F-PLA50-1 F-PLA100-1 Size Size 111 123 30 42 141 153 Material : SECC Thickness : 2.0 Weight : 85g max 23 41 6 Material : SEHC Thickness : 2.3 hole-A : PLA/PJA100F hole-B : PLA/PJA150F Weight : 130g max 13.5 FRONT 3-M3 30 2-M3 111 Option-6 6 M3 Flat screw is requested when mounting. Please check the instruction manual for the size of screw. Mounting hole size Mounting hole size FRONT hole-A hole-B 19.5 6 21 hole-A hole-B 3- 3.5 39 2- 3.5 hole-A hole-B 6 FRONT 13.5 Mounting hole size 141 March 14, 2019 Optional Parts F-PLA300-1 F-PLA600-1 Size Size 4- 4.5 210 222 6 235 247 Material : SEHC Thickness : 3.2 Weight : 300g max 46 6 36.5 6 33 45 53 65 4- 4.5 6 Material : SEHC Thickness : 3.2 Weight : 460g max M4 Flat screw is requested when mounting. Please check the instruction manual for the size of screw. Mounting hole size Mounting hole size 4-M4 FRONT FRONT 53 33 4-M4 210 235 March 14, 2019 Option-7 Optional Parts Example Example (PLA15F-50F) hole-B FRONT REVERSE Attachment Plate model F-PLA15-2 F-PLA30-2 F-PLA50-2 (PLA15F-50F) hole-A Applicable models PLA15F PLA30F PLA50F PLA100F, PLA150F, F-PLA100-2 PJA100F, PJA150F F-PLA300-2 PLA300F, PJA300F F-PLA600-2 PLA600F, PJA600F Example (PLA300F) Example (PLA100F) F-PLA15-2 (Unit : mm) (Tolerance : 1) F-PLA30-2 Size 19 89 hole-B 15 25 hole-A 3- 3.5 39 24 10 15 25 Material : SECC Thickness : 1.6 Weight : 70g max F-PLA50-2 7 10 hole-A 19 7 hole-A hole-B hole-B 24 38 3- 3.5 19 hole-A 38 74 hole-B 45 45 Size Material : SECC Thickness : 1.6 Weight : 80g max M3 screw is requested when mounting. Please check the instruction manual for the size of screw. F-PLA100-2 Size 45 45 Size 12 17.5 Material : SECC Thickness : 1.6 Weight : 85g max M3 screw is requested when mounting. Please check the instruction manual for the size of screw. Option-8 March 14, 2019 7 6- 3.5 20.5 hole-B hole-A 24 15 25 19 39 10 3- 3.5 27 3- 3.5 hole-A 41 hole-B 112 hole-A hole-B hole-B hole-A 7 hole-A 38 hole-B 100 15 25 Material : SECC Thickness : 2.0 hole-A : PLA/PJA100F hole-B : PLA/PJA150F Weight : 120g max Optional Parts F-PLA300-2 (Unit : mm) (Tolerance : 1) F-PLA600-2 Size 10 127±0.5 35 Material : SEHC Thickness : 2.0 Weight : 600g max 10 40 71 26 57 19.5 4- 4.5 250 15.5 4- 4.5 225 15.5 140 122 25 25 Size 145 ±0.5 Material : SEHC Thickness : 2.0 Weight : 800g max M4 screw is requested when mounting. Please check the instruction manual for the size of screw. March 14, 2019 Option-9 Optional Parts BASE Attachment Plate model Applicable models F-PLA300-3 PLA300F, PJA300F F-PLA600-3 PLA600F, PJA600F Example (PLA300F) TOP VIEW F-PLA300-3 (Unit : mm) (Tolerance : 1) F-PLA600-3 Size Size 4- 4.5 186 198 6 35 6 208 220 Material : SEHC Thickness : 3.2 Weight : 750g max 6 Material : SEHC Thickness : 3.2 Weight : 950g max 114 FRONT 132 4-M4 4-M4 FRONT 186 Option-10 35 M4 Flat screw is requested when mounting. Please check the instruction manual for the size of screw. Mounting hole size Mounting hole size 144 6 114 126 132 4- 4.5 208 March 14, 2019 Optional Parts Din rail Attachment Plate(PLA-PJA Series) APPLICABLE TO MODEL Plate model FD-PLA15-2 FD-PLA30-2 FD-PLA50-2 FD-PJA100-2 FD-PJA150-2 Din rail width : 35mm screws for installation Type Qty Model PLA15F PLA30F PLA50F PJA100F, PLA100F PJA150F, PLA150F M3 2pcs L3 L4 1 L5 FD-PLA15-2, FD-PLA30-2, FD-PLA50-2 FD-PJA100-2, FD-PJA150-2 EXTERNAL VIEW V.ADJ L2 Plate model FD-PLA15-2 FD-PLA30-2 FD-PLA50-2 FD-PJA100-2 FD-PJA150-2 Model PLA15F PLA30F PLA50F PJA100F PJA150F L1 80 2 95 2 106 2 113.5 2 133.5 2 12.5max L2 39 39 39 42.6 42.6 L1 L3 46.5 46.5 46.5 57 57 L4 80 80 80 97 97 L5 85.5 85.5 85.5 102 102 March 14, 2019 8max Material : SPCC (surface finishing : nickel plating) Thickness FD-PLA15-2 : 1.0 FD-PLA30-2 : 1.0 FD-PLA50-2 : 1.0 FD-PJA100-2 : 1.6 FD-PJA150-2 : 1.6 Tolerance : 1 1 Screws for installation (attached to Plate) Weight : FD-PLA15-2 95g max FD-PLA30-2 105g max FD-PLA50-2 110g max FD-PJA100-2 170g max FD-PJA150-2 180g max Option-19 Optional Parts P L A Series P J A Series Harness to use the function is prepared in PLA series, PJA series. The latest information is in our websit Mating harness Model Contents Harness model # PLA15F, PLA30F, PLA50F, PLA100F, PLA150F, PJA100F, PJA150F PLA100F, PLA150F, PJA100F, PJA150F PLA15F, PLA30F, PLA50F PJA100F, PJA150F PJA100F, PJA150F PLA100F, PLA150F, PJA100F, PJA150F PLA300F, PJA300F PLA600F, PJA600F, PJA1000F, PJA1500F PLA300F, PLA600F, PJA300F, PJA600F, PJA1000F, PJA1500F H-IN-22 Input harness when I/O interface is connector type (option : -J) H-OU-37 H-OU-38 H-IN-26 H-OU-44 H-RC-1 H-RC-6 H-PA-9 H-SN-32 H-SN-33 H-RC-5 Output harness when I/O interface is connector type (option : -J) Output harness when I/O interface is connector type (option : -J) Input harness when I/O interface is connector type (option : -J1) Output harness when I/O interface is connector type (option : -J1) Harness for using option : -R Harness for using option : -R Harness for parallel operation (option: -W) Harness for using all functions of option -W and -R Harness for using all functions except remote sensing of option -W and -R Harness for using a function of option -R H-SN-18 Harness for using option : -V * These harnesses are used for product which includes option. ●Model number H-IN-22 ●Type Housing : 1-1123722-5 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 30g max ●Model number H-OU-37 +50 -0 ●Type Housing : 1-1123722-6 (Tyco Electronics AMP) Pin : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 60g max ●Model number H-OU-38 ●Type ●Type Housing : VHR-5N (J.S.T.) +50 -0 1 2 3 4 5 Housing:VHR-6N(J.S.T.) Pin:SVH-21T-P1.1(J.S.T.) Weight :60g max Color 1 2 3 4 5 UL1015 18 green Length (mm) 500 UL1015 18 white 500 UL1015 18 black 500 Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 red black Pin # Wire AWG Color 1, 2 3, 4 UL1015 UL1015 18 18 red black Length (mm) 500 500 Pin # Wire AWG 1 2 3 4 5 UL1015 18 Color green Length (mm) 500 UL1015 18 white 500 UL1015 18 black 500 Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 red black ●Wire +50 -0 Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max H-OU-44 AWG ●Wire 1 2 3 4 : 1123721-1 or 1318912-1 (Tyco Electronics AMP) Weight : 40g max ●Model number Wire ●Wire 1 2 3 4 5 6 Pin H-IN-26 Pin # Length (mm) 500 500 +50 -0 Housing : 1-1123722-4 (Tyco Electronics AMP) ●Model number ●Wire 1 2 3 4 5 ●Type 1 2 3 4 5 6 ●Wire Length (mm) 500 500 +50 -0 March 14, 2019 Option-43 Optional Parts ●Model number H-RC-1 ●Type ●Wire 1 2 +50 -0 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max ●Model number H-RC-6 ●Type +50 -0 Housing : XAP-02V-1 (J.S.T.) Pin Wire AWG 1 2 UL1007 UL1007 22 22 Pin # Wire AWG 1 2 UL1007 UL1007 22 22 Wire UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 Color red orange purple green black Length (mm) 270 270 270 270 270 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 28 Color red orange purple yellow blue green black Length (mm) 500 500 500 500 500 500 500 Wire UL1061 UL1061 UL1061 UL1061 UL1061 UL1061 AWG 28 28 28 28 28 28 Color orange purple yellow blue green black Length (mm) 500 500 500 500 500 500 Wire UL1061 UL1061 - AWG 28 28 - Color orange purple - Length (mm) 500 500 - ●Wire 1 2 : SXA-001T-P0.6(J.S.T.) Length (mm) 500 orange blue 500 Pin # Color Length (mm) orange 500 blue 500 Color Weight : 7g max Model number H-PA-9 1 3 5 7 9 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 4g max Model number H-SN-32 Wire Type +50 -0 Wire Type 2 4 6 8 10 9 7 5 3 1 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 7g max +50 -0 Model number H-SN-33 2 4 6 8 10 9 7 5 3 1 +50 -0 Model number H-RC-5 Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 3g max Powered by TCPDF (www.tcpdf.org) Pin # 1 2 3 4 5 6 7 8 9 10 Wire Type 2 4 6 8 10 9 7 5 3 1 +50 -0 Option-44 Pin # 1 2 3 4 5 6 7 8 9 10 Wire Type Housing : PHDR-10VS(J.S.T.) Pin : SPHD-002T-P0.5(J.S.T.) Weight : 6g max Pin # 1 2 3 4 5 6 7 8 9 10 March 14, 2019 Pin # 1 2 3 4 5 6 7 8 9 10
H-RC-1 价格&库存
很抱歉,暂时无法提供与“H-RC-1”相匹配的价格&库存,您可以联系我们找货
H-RC-1
