H-IN-10
H-IN-10
    COSEL
H-IN-10 数据手册
Optional Parts Harness Mating harness Model LHA10F LHA15F LHA30F LHA50F LHA75F LHA100F LHA150F,LHP150F LHA300F,LHP300F LHA300F, LHP300F LHP300F LCA10S LCA15S LCA30S LCA50S, LGA50A LCA75S, LGA75A LCA100S, LGA100A LCA150S, LGA150A LGA240A, LFA300F, LFP300F TECS Harness model # Output Input H-OU-34 H-OU-34 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-18 H-IN-10 H-OU-18 H-OU-46 H-OU-10 H-OU-54 H-OU-7 H-IN-4 H-OU-8 H-IN-4 H-OU-9 H-OU-9 H-IN-5 or H-OU-18 H-OU-10 H-IN-10 H-OU-11 H-OU-12 H-OU-11 H-IN-14 H-OU-12 H-OU-9 H-IN-29 Model number H-IN-4 Model SNA-01,-03 SNA-06 SNR-10 LDA10F LDA15F LDA30F, LFA30F LDA50F, LEA50F, LFA50F LDA75F, LEA75F, LFA75F LDA100W, LEA100F, LFP100F, LFA100F LMA100F, LEP100F, 150F, 240F LDA150W, LEA150F, LFP150F, LFA150F, LFA240F, LFP240F, LMA150F, LMA240F LFA10F LFA15F LDA300W H-IN-5 Type Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-7 Type Housing : 1-178128-5 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 35g max Model number H-IN-10 Type Housing : VHR-5N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 30g max Model number H-IN-14 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-IN-29 Housing : VHR-3N(J.S.T) Pin : SVH-21T-P1.1 or BVH-21T-P1.1 (J.S.T) Weight : 25g max Option-20 H-IN-7 H-OU-11 H-OU-12 H-OU-34 H-OU-34 H-OU-22 Optional : connector type ”-J” (LDA300W) Optional : connector type ”-J1” (LGA50A,75A,100A,150A,240A) Optional : connector type ”-J1” (LFA10F,15F,30F,50F,75F,100F,150F,240F,300F) Optional : connector type ”-J1” (LFP100F,150F,240F,300F) Optional : connector type ”-J1” (LMA100F,150F,240F) Optional : connector type ”-J5 ” (LHA300F) Optional : connector type ”-J5 ” (LHP300F) Housing : XHP-7 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 10g max Model number Harness model # Input Output H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-OU-18 H-OU-8 H-OU-8 H-OU-9 H-OU-9 H-OU-18 H-IN-5 or H-OU-10 H-IN-10 1 2 3 4 5 6 7 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 6 7 8 LCA Series LDA Series LGA Series LEA Series LEP Series LFA Series LFP Series LHA Series LHP Series LMA Series SNA Series SNR Series TECS Series Wire +50 -0 Pin # Wire AWG 1 2, 3 4 5, 6 7 UL1007 22 black Length (mm) 500 UL1007 22 white 500 UL1007 22 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 white Length (mm) 500 UL1015 18 black 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green/yellow 500 Pin # Wire AWG Color 1 ,2 3 4 ,5 6 7 ,8 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 UL1015 UL1015 AWG18 AWG18 white black Color Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire +50 -0 Wire Type 1 2 3 +50 -0 October 26, 2023 Length (mm) 500 500 www.cosel.co.jp/en/ Optional Parts Model number H-OU-7 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Model number H-OU-8 Type Type Housing : XHP-4 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 15g max Model number H-OU-9 Type Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 40g max Model number H-OU-10 Type Housing : VHR-8N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 80g max Model number H-OU-11 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-12 Type Housing : VHR-7N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 70g max Model number H-OU-18 Type Housing : VHR-6N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 60g max Model number H-OU-22 Type Housing : 1-178288-8 (Tyco Electronics) Pin : 1-175218-2 or Pin : 1-175218-3 (Tyco Electronics) Weight : 100g max Model number H-OU-34 Type 1 2 1 2 3 4 1 2 3 4 1 2 3 4 5 6 7 8 1 2 3 4 5 6 1 2 3 4 5 6 7 1 2 3 4 5 6 1 2 3 4 5 6 7 8 9 10 1 2 Wire +50 -0 H-OU-46 Type Housing : VHR-10N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 100g max Model number H-OU-54 Housing : VHR-8N (J.S.T.) Pin : SVH-41T-P1.1 (J.S.T.) Weight : 100g max www.cosel.co.jp/en/ Type 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 Wire AWG Color 1 2 UL1007 UL1007 22 22 black red Pin # Wire AWG Color 1 2 3 4 UL1007 UL1007 UL1007 UL1007 22 22 22 22 black black red red Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Wire AWG Color UL1015 18 red Pin # Wire AWG Color 1-7 UL1015 18 black Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-4 5-8 UL1430 UL1430 16 16 black red Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Pin # 1-6 Length (mm) 500 +50 -0 Wire Length (mm) 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire +50 -0 Housing : VHR-2N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Weight : 20g max Model number Pin # Wire Length (mm) 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 October 26, 2023 Option-21 Optional Parts LGA Series LFA Series LFP Series LHA Series LHP Series LMA Series Mating harness Harness model # Input Output H-OU-33 H-OU-33 H-OU-28 H-OU-28 Model LFA10F, *LHA10F LFA15F, *LHA15F LFA30F, *LHA30F LFA50F, LGA50A, *LHA50F LFA75F, LGA75A, *LHA75F, *LHA100F,*LHA150F,*LHP150F LFP100F, LFA100F, LGA100A LMA100F H-IN-12 H-OU-31 H-OU-32 *LHA300F,*LHP300F H-IN-13 Model number H-IN-12 Type Housing : 1-1123722-5 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 30g max Model number H-IN-13 Type Housing : 1-1123722-8 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 55g max Model number H-OU-28 Type Housing : 1-1123722-4 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 40g max Model number H-OU-29 Type Housing : 1-1123722-6 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 60g max Model number H-OU-30 Type Housing : 1-1123722-8 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 75g max Model number H-OU-31 Housing : 1-1123722-6 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 60g max Option-22 *Optional:connector type "-J4" (LHA10F,15F,30F,50F,75F,100F,150F,300F) *Optional:connector type "-J4" (LHP150F,300F) H-OU-30 LFP150F, LFA150F, LGA150A, LFA240F, LFP240F, LMA150F LMA240F LGA240A, LFA300F LFP300F H-OU-29 Type H-OU-47 H-OU-31 H-OU-32 1 2 3 4 5 1 2 3 4 5 6 7 8 1 2 3 4 1 2 3 4 5 6 1 2 3 4 5 6 7 8 1 2 3 4 5 6 Wire +50 -0 Pin # Wire AWG Color 1 2 3 4 5 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 ,2 3 4 ,5 6 7 ,8 UL1015 18 black Length (mm) 500 UL1015 18 white 500 UL1015 18 green 500 Pin # Wire AWG Color 1 2 3 4 UL1015 UL1015 UL1015 UL1015 18 18 18 18 black black red red Pin # Wire AWG Color 1-3 4-6 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-4 5-8 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-6 UL1015 18 red Wire +50 -0 Wire +50 -0 Wire Length (mm) 500 500 500 500 Length (mm) 500 500 +50 -0 Wire Length (mm) 500 500 +50 -0 Wire Length (mm) 500 +50 -0 October 26, 2023 www.cosel.co.jp/en/ Optional Parts Model number H-OU-32 Type 1 2 3 4 5 6 7 Housing : 1-1123722-7 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 70g max Model number H-OU-33 Type 1 2 Wire H-OU-47 Type Housing : 1-1123722-0 (TycoElectronics) Pin : 1123721-1 or 1318912-1 (TycoElectronics) Weight : 100g max 1 2 3 4 5 6 7 8 9 10 Wire AWG Color 1-7 UL1015 18 black Pin # Wire AWG Color 1 2 UL1015 UL1015 18 18 black red Pin # Wire AWG Color 1-5 6 - 10 UL1015 UL1015 18 18 black red Length (mm) 500 +50 -0 Wire +50 -0 Housing : 1-1123722-2 (Tyco Electronics) Pin : 1123721-1 or 1318912-1 (Tyco Electronics) Weight : 20g max Model number Pin # Wire Length (mm) 500 500 Length (mm) 500 500 +50 -0 LFP Series Harness for connecting the external capacitor unit is prepared for LFP240/300F(U1 type). Model number H-IN-23 Type 1 2 3 4 Housing : VHR-4N(J.S.T.) Pin : SVH-21T-P1.1(J.S.T.) Weight : 5g max +50 -0 Wire 1 2 3 4 Pin # 1 2 3 4 Wire AWG Color Length (mm) UL1015 20 black 100 UL1015 20 red 100 LHA Series LHP Series Harness for connecting the external capacitor unit is prepared for LHA150F/300F and LHP150F/300F (U1 type). Model number H-IN-25 CN A: Housing : VHR-3N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) Type CN A 1 2 3 +50 -0 1 2 3 4 CN B Wire Pin # CN A CN B CN B: Housing : VHR-4N (J.S.T.) Pin : SVH-21T-P1.1 (J.S.T.) 1 2 3 1 2 3 4 Color black Length (mm) 100 20 red 100 UL1015 20 black 100 UL1015 20 red 100 Wire AWG UL1015 20 UL1015 Weight : 5g max www.cosel.co.jp/en/ October 26, 2023 Option-23 Optional Parts Harness for remote ON/OFF(R type) is prepared in LDA, LEA, LEB, LEP, LFA, LFP, LHA, LHP & LMA series. Mating harness Model LDA50F, LDA75F, LDA100W, LDA150W, LDA300W LEA50F, LEA75F, LEA100F, LEA150F, LEP100F, LEP150F, LEP240F LEB100F, LEB150F, LEB225F LFA100F, LFA150F, LFA240F, LFA300F, LFP100F, LFP150F, LFP240F, LFP300F LHA100F,LHA150F,LHA300F,LHP150F,LHP300F LMA100F, LMA150F, LMA240F Model number H-RC-1 Housing : XHP-2 (J.S.T.) Pin : SXH-001T-P0.6 (J.S.T.) Weight : 7g max Option-26 Harness model # H-RC-1 LDA LEA LEB LEP LFA LFP LHA LHP LMA Series Series Series Series Series Series Series Series Series Wire Type 1 2 +50 -0 October 26, 2023 Pin # Wire AWG 1 2 UL1007 UL1007 22 22 Color orange blue Length (mm) 500 500 www.cosel.co.jp/en/ Optional Parts External capacitor unit LFP Series,LHA Series LHP Series,RB Series By connecting an external capacitor unit to the power supply, it is possible to extend the hold-up time. External capacitor unit model Approved power supply Hold-up time * Appearance 100 ms (Power supply output 180W) CR-HUT241-1 (Rated capacitance:240μF) 55 ms (Power supply output 360W) LFP240F LFP300F LHA150F LHA300F LHP150F LHP300F RBC200F RBC300F CR-HUT721-1 (Rated capacitance:720μF) CR-HUT282-2 (Rated capacitance:2,800μF) 220 ms (Power supply output 180W) 110 ms (Power supply output 360W) 650 ms (Power supply output 180W) 300 ms (Power supply output 360W) 1,100 ms (Power supply output 180W) CR-HUT502-2 (Rated capacitance:5,040μF) 500 ms (Power supply output 360W) * It is reference data in the case of connecting LFP300F-O-TU1Y. Hold-up time will vary depending on the environment (power supply, output power, etc). Please refer to the Instruction Manual of approved power supply for more information. 1 Specification ITEM INPUT VOLTAGE[V] RATED CAPACITANCE [μF] ELECTRICAL SPECIFICATIONS CHARGE COMPLETION TIME [s] *1 LED LIGHTING VOLTAGE [V] *2 DISCHARGING TIME [s] OPERATING TEMP.,HUMID. *3 STORAGE TEMP.,HUMID. ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SIZE OTHERS WEIGHT COOLING METHOD CR-HUT241-1 CR-HUT721-1 CR-HUT282-2 CR-HUT502-2 DC420max 240typ 720typ 2,800typ 5,040typ 2yp 5typ 30typ 60typ 45typ 30typ 55typ 165typ 285yp -20 to +70C, 20 - 90%RH (Non condensing) -20 to +75C, 20 - 90%RH (Non condensing) 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis Be certified by connecting to the correct power 45X48X110mm [1.77X1.89X4.33 inches] (WXHXD) 85X58X206mm [3.35X2.28X8.11 inches] (WXHXD) 105g max 195g max 525g max 860g max Convection *1 Time to be charged to over 98% of the applied voltage. *2 Capacitor voltage which LED turns on. *3 LED turn off time after input voltage shut off from full charged condition. www.cosel.co.jp/en/ October 26, 2023 Option-71 Optional Parts 2 External View 1.CR-HUTO-1 Point A Name Plate 3- 3.5 Mounting Hole [0.2] 5 1 2 VC(-) 4 VC(+) 3.5 [0.14] [1.38] 35 ± 0.5 CN1 CR-HUT 45 [1.77] LED [0.16] 100 ± 0.5 [3.94] 110 [0.2] ¶Tolerance ¶Weight in mm, [ ]=inches : ±1 [±0.04] : 105g max (CR-HUT241-1) 195g max (CR-HUT721-1) Mounting Hole 4 5 ¶Dimensions ¶PCB material : CEM3 ¶Thick line represents the capacitor mounted on CR-HUT241-1. [4.33] All capacitors are mounted on CR-HUT721-1. [1.77] CN1 45 Connector B3P4-VH Mating Connector VHR-4N Chain : SVH-21T-P1.1 [0.12] (Lead) 3max Terminal PCB t=1.6 ¶4 Mounting holes are existing. Loose : BVH-21T-P1.1 Manufacturer J.S.T. Pin No. 1 2 Function VC(-) VC(-) 3 4 VC(+) ¶Pin 3 is removed ¶The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶Do not use press-fitting bush. ¶Point A is thermometry points. Please refer to Instruction Manual 3. 2.CR-HUTO-2 Point A 3- 3.5 Mounting Hole CN1 VC(-) VC(+) 4 85 [3.35] 75 ± 0.5 1 2 3.2 Mounting Hole ¶Dimensions 3.5 [0.14] [2.95] ¶Tolerance 5 [0.2] CR-HUT 5 [0.2] 98 ± 0.5 [3.86] 142 ± 0.5 [5.59] Name Plate 4 3.2 Mounting Hole LED [0.16] 196 ± 0.5 [7.72] 206 [8.11] Mounting Hole ¶Weight in mm, [ ]=inches : ±1 [±0.04] : 525g max (CR-HUT282-2) 860g max (CR-HUT502-2) ¶PCB material : CEM3 ¶Thick line represents the capacitor mounted on CR-HUT282-2. All capacitors are mounted on CR-HUT502-2. CN1 Connector B3P4-VH 55 [2.17] Mating Connector VHR-4N Chain : SVH-21T-P1.1 (Lead) [0.12] 3max Terminal ¶4 Mounting holes are existing. back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶Do not use press-fitting bush. ¶Point A is thermometry points. Please refer to Instruction Manual 3. ¶The Option-72 Loose : BVH-21T-P1.1 Manufacturer PCB t=1.6 October 26, 2023 J.S.T. Pin No. 1 2 Function VC(-) VC(-) 3 4 VC(+) ¶Pin 3 is removed www.cosel.co.jp/en/ Optional Parts ¿Caution (1) Distance between the external capacitor unit and power supply 3 Assembling and Installation Method unit must be secured more than 5mm. When connected to RB series, distance must be secured more than 6mm. (2) It must be 30mm or less, since the noise is generated from the wire which is connecting the external capacitor unit and power 3.1 Installation method supply. And, it is necessary to twist the wire as short as possible. ¡This external capacitor unit is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. ¡In case of metal chassis, keep the distance between d1 & d2 for to insulate between lead of component and metal chassis. If it is less (3) It is necessary to use wires which rated voltage is 600V or more. ¡Mounting method ¿ CR-HUTO-1 (A) than d1 & d2, insert the insulation sheet between external capacitor (B) CN1 unit and metal chassis. CN1 d2 CN1 CN1 Standard Position (D) CN1 (E) (F) d1 d2 CN1 CN1 d2 d2 d2 (C) When connected to LFP series d1 = 8mm min d2 = 4mm min When connected to RB series d1 = 10mm min d2 = 6mm min CN1 Fig.3.4 CR-HUTO-1 Mounting method ¿ CR-HUTO-2 CN1 (A) Fig.3.1 Installation method Standard Position (D) ¡There is a possibility that it is not possible to cool enough when the external capacitor unit is used by the sealing up space as (B) CN1 (C) CN1 (E) showing in Figure 3.2. CN1 (F) Please use it after confirming the temperature of point A of Instruction Manual 3.2. CN1 CN1 Case Fig.3.5 CR-HUTO-2 Mounting method external capacitor unit Fig.3.2 Installation example 3.2 Environment to use the Unit and Installation environment ¡When using the unit,it is necessary to dissipate heat of the external capacitor unit. Table 3.1 shows the relation between the maximum ¡Connection method Power supply Power supply VC(+) VC(-) +Vbc temperature Point A and Installation environment. -Vbc Please consider the ventilation to keep sufficient convection for whole external capacitor unit. And temperature of Point A must be d=5 - 30mm Harness H-IN-23 (sell separately) Harness H-IN-25 (sell separately) d=6 - 30mm CN1 CN1 VC(+) VC(-) External capacitor unit (CR-HUT) When connected to LFP series +VC External capacitor unit (CR-HUT) When connected to RB series Fig.3.3 Connection method www.cosel.co.jp/en/ -VC kept under maximum temperature shown table 3.1. The expectancy life at maximum temperature of Point A is three years or more. Please refer to External View for the position of Point A. Please contact us for details. Remarks: *Please be careful of electric shock or earth leakage in case of temperature measurement, because Point A is live potential. *Please refer to 3.4 if you want to extend the longevity of the expectancy life. October 26, 2023 Option-73 Optional Parts Table 3.1 Temperatures of Point A Mounting Method A,B,C,D,E F A,B,C,D,E,F Cooling Method Convection Convection Forced air Max temperature[C] 86 81 75 3.3 Mounting screw ¡The mounting screw should be M3. The hatched area shows the allowance of metal parts for mounting. ¿ CR-HUTO-1 8 8 Do not short-circuit the CN1 terminals. 8 ¡This external capacitor unit is manufactured by SMD technology. The stress to PCB like twisting or bending causes the defect of 8 Unit[mm] the unit, so handle the unit with care. Fig.3.6 CR-HUTO-1 Allowance of metal for mounting -Tighten all the screws in the screw hole. CR-HUTO-1 (4 places) ¿ CR-HUTO-2 CN1 8 8 8 8 8 CR-HUTO-2 (6 places) 8 CR-HUT-2 may be a mounting method of the following. (Refer 8 S  crew should be used to hole A (4 places). 8 8 8 ¡High voltage remains inside the external capacitor unit after voltage shut off. ¡There is possibility that electric charge is remained inside the capacitor. CN1 8 ¡Do not touch absolutely during operation. There is a risk of electric shock. off. 8 8 ¡This external capacitor unit is the rugged PCB type. Do not drop conductive objects in the external capacitor unit. There is a risk of electric shock, do not touch until the LED turns 8 8 4 Others Fig.4.1) 8 Unit[mm] S  crew or resin spacer should be used to hole B (2 places). R  ecommendation resin spacer: MPS series ( KITAGAWA INDUSTRIES CO.,LTD.) Hole A : 3.5 Fig.3.7 CR-HUTO-2 Allowance of metal for mounting Hole A : 3.5 CN1 3.4 Expectancy life and warranty ¡Expectancy Life. Mounting Method Cooling Method A,B,C,D,E,F Convection ¡Warranty Warranty 5 years. Average ambient temperature (year) Ta = 60C or less Ta = 70C Expectancy Life Hole B : 3.2 10years 6years Fig.4.1 CR-HUTO-2 Resin spacer mounting method - Install the PCB of the external capacitor unit horizontally to the surface of mounting. -Avoid the impact such as drops. Option-74 October 26, 2023 www.cosel.co.jp/en/
H-IN-10 价格&库存
很抱歉,暂时无法提供与“H-IN-10”相匹配的价格&库存,您可以联系我们找货
H-IN-10
    H-IN-10
    库存:78
    H-IN-10
      • 1+99.370071+12.87020
      • 5+69.150435+8.95621
      • 10+64.2353910+8.31963
      • 30+60.9614530+7.89560
      • 50+60.3066750+7.81079
      • 60+60.1409060+7.78932
      • 100+59.81765100+7.74745
      库存:15
