CD1H561KC0BER1D100
CD1H561KC0BER1D100
    DERSONIC(德尔创)
    插件,P=5.08mm
    560PF ±10% 50V
CD1H561KC0BER1D100 数据手册
DOC NO.: DEC-SA-WI006 REV.: B/0 DATE: 2021/02/02 独石电容器规格承认书 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 客户 CUSTOMER 立创商城 客户料号 CUSTOMER P/N C2761754 客户规格描述 CUST. SPEC 规格描述 DESCRIPTION 50V/561/K/F5.08/斜尖/L10/环氧(蓝)/X7R(Ⅱ)/0603/ZNR 产品编码 PART NUMBER CD1H561KC0BER1D100 日期 DATE 2021/5/10 文件编号 DOC. NO. 德尔创承认栏 APPROVED BY DERSONIC DEC-SA-WI006 客户承认栏 APPROVED BY CUSTOMER 批 准 APPROVED BY 审核 CHECK BY 制订 FORMULATE BY 彭少雄 吴成爱 陈冬花 批 准 APPROVED BY 审核 CHECK BY 东莞市德尔创电子有限公司 DONGGUAN DERSONIC ELECTRONIC CO., LTD. ZNR ® ZNRC ® 广东省东莞市长安镇锦厦河南工业区锦平路5号 No. 5, Jinping Rd., Jinxia Henan Industrial Zone, Changan Town, Dongguan City TEL: +86-769-8155 5686 FAX: +86-769-8155 5989 E-mail: sales@dersonic.com / quality@dersonic.com Website: http://www.dersonic.com 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 1 / 9 1. 规格表 DATA SHEET 产品编码 Part number CD1H561KC0BER1D100 规格描述 Description 50V/561/K/F5.08/斜尖/L10/环氧(蓝)/X7R(Ⅱ)/0603/ZNR 客户料号 Customer P/N C2761754 介质类别 Dielectric class Class 2 额定电压 Rated voltage 电容量 Capacitance 损耗角正切 Tangent of loss angle 耐电压 Testing voltage 绝缘电阻 Insulation resistance 温度特性 Temperature characteristics 尺寸 DIMENSIONS 50Vdc 560pF ±10% @ 1kHz 1.0V 25ºC 0.105 max @ 1kHz 1.0V 25ºC 125Vdc (Charge/discharge 2mA max) 3s PASS 10000MΩ min @ 50V 60s, RH≤70% X7R(Ⅱ) ΔC/C: ±15% @ -55ºC~125ºC W (Weight) 5mm max H (Height) 3.8mm max T (Thickness) 3.2mm max F (Lead spacing) 5.08mm±0.8mm L (Lead length) 10mm±2.0mm ød (Lead diameter) 0.55mm max 标志 Marking ZNR 561 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 2 / 9 2. 总则 GENERAL 1) 本规格书适用于电子设备用独石电容器。 This specification applies to the leaded type MLCC for the electronic equipment. 2) 独石电容器 Monolithic capacitor 独石电容器是一种用积层陶瓷电容器焊接导线、并用环氧树脂包封后的电容器。 Monolithic capacitor is a capacitor with a multilayer ceramic capacitor soldering lead wire and coating epoxy resin. 其具有以下特点: It has the following characteristics: ■ 体积小,容量大,适合自动安装的编带包装。 Miniature size, large capacitance, tape and reel packaging suitable for autoplacement. ■ 环氧树脂封装,从而具有优良的防潮性能、机械强度及耐热性。 Epoxy resin coating creates excellent performance in humidity resistance, mechanical strength and heat resistance. ■ 工业生产标准尺寸及多种脚型产品。 Standard size, various lead configurations. 3) 符合RoHS 2.0 Complies with RoHS 2.0 3. 适用标准 APPLICABLE STANDARD 本产品符合下列标准,且本规格书的相关内容引用以下标准,当双方对此存在争议时,可依以下标准 进行仲裁。 This product complies with the following standards, and the relevant content of this specification refers to the following standards, when the two sides in dispute, the following criteria for arbitration. GB/T 2693-2001 电子设备用固定电容器 第1部分 总规范(IDT IEC 60384-1) Fixed capacitors for use in electronic equipmen — Part 1: Generic specification (IDT IEC 60384-1) GB/T 5966-2011 电子设备用固定电容器 第8部分 分规范 1类瓷介固定电容器(IDT IEC 60384-8) Fixed capacitors for use in electronic equipmen — Part 8: Sectional specification: Fixed capacitors of ceramic dielectric, Class 1 (IDT IEC 60384-8) GB/T 5968-2011 电子设备用固定电容器 第9部分 分规范 2类瓷介固定电容器(IDT IEC 60384-9) Fixed capacitors for use in electronic equipmen — Part 9: Sectional specification: Fixed capacitors of ceramic dielectric, Class 2 (IDT IEC 60384-9) 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 3 / 9 4. 产品编码 PART NUMBER 本公司产品编码方式,举例说明如下: The product part number representation of the company, examples are as follows: CD 1H 类别 Type 额定电压 Rated voltage 561 K C0 B 标称容量 容量偏差 引线 编带包装 Nominal Capacitance 成型方式 或散装脚长 capacitance tolerance Lead format Taping packing or Lead length (bulk) E R1 D 100 包封 Coating 温度特性 Temperature characteristics 芯片 Chip spec 生产识别码 Production identification code ■ 类别 Type CD: 独石电容器 Leads type MLCC ■ 额定电压 Rated voltage 1H: 50V 2A: 100V 2H: 500V ■ 标称容量 Nominal capacitance 用3位数表示,单位pF。如下所示: In 3 digits, unit is pF, as shown in below: 3A: 1kV 3D: 2kV 3F: 3kV 1E: 25V 2E: 250V 1J: 63V 2J: 630V 561: 560pF (1uF = 1,000nF = 1,000,000pF) ■ 容量偏差 Capacitance tolerance ■ 引线成型方式 Lead format C: ±0.25pF D: ±0.50pF 代码 Code A B C D E J: ±5% K: ±10% M: ±20% 脚距 Lead spacing 2.54mm 3.5mm 5.08mm 7.50mm 10.0mm S: +50%/-20% Z: +80%/-20% P: +100%/-0% 代码 Code 1 0 9 脚型样式 Lead style drawing ■ 编带包装或散装脚长 Taping packing or Lead length (bulk) ● Taping T: Reel packing P: Ammo packing ● 4: 6: 8: 9: Bulk (Leads length) 3.5mm A: 8.0mm 4.0mm B: 10.0mm 5.0mm I: 24.0mm 6.0mm ■ 包封 Coating E: 环氧(蓝) Epoxy (Blue) H: 环氧(黄) Epoxy (Yellow) ■ 温度特性 Temperature characteristics CH: NP0 R1: X7R F4: Y5V R2: X5R ■ 芯片规格 Chip spec D: 0603 E: 0805 F: 1206 G: 1210 H: 1808 I: 1812 ■ 生产识别码 Production identification code 内部控制码,本规格书不作说明。 Inteer control code will not be described in this an approval specifications. V: Q: C: 2: 7.0mm 9.0mm 12.0mm 3.0mm J: 1825 K: 2220 L: 2225 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 4 / 9 5. 测量和试验 MEASUREMENT AND TEST 序 No. 项目 Item 标准 Specifications 1 工作温度范围 Operating temp. range -55ºC~125ºC 2 3 4 5 6 7 额定电压 Rated voltage (UR) 50V 外观形状没有明显的缺点,尺寸在标准范 外观与尺寸 围内。 Appearance (APP) No marked defect on appearance form and Dimension and dimensions are within specified range. 标志 Marking 清晰易于识别。 To be easily legible. 容量 (CR) 560pF±10% Capacitance (CR) 损耗角正切(tanδ) Tangent of loss 0.105 max angle (tanδ) 绝缘电阻 Insulation Resistance (IR) 10000MΩ min 试验方法 Testing Method 额定电压是指在工作温度范围内,可连续施加在电容器上的最 大直流电压或最大交流电压有效值或脉冲电压的峰值。 当交流电压附加于直流电压时,Vp-p或Vo-p(以较大者为准) 应维持在额定电压范围内。 The rated voltage is defined as the maximum voltage which may be applied continuously to the capacitor within the operating temperature range. When AC voltage is superimposed on DC voltage, Vp-p or Vo-p, whichever is larger, should be maintained within the rated voltage range. 电容必须用目视检查其明显的缺点。 The capacitor should be visually inspected for evidence of defect. 尺寸用游标卡尺测量。 Dimensions should be measured with slide calipers. 目视检查。 The capacitor should be visually inspected. 容量与tanδ在25±1℃下,使用下列条件进行测量。 The capacitance, tanδ should be measured at 25°C±1° C with the following conditions. 1kHz 1.0Vrms 在两导线间施加下列电压进行测量,时间不超过1分钟。 The insulation resistance should be measured with a DC voltage not exceeding the following voltage at normal temperature and humidity and less than 1 minute of charging. 50VDC 8 耐电压 Testing Voltage (TV) 没有不合格 No failure. 在电容器两导线间施加下列测试电压1到5s后不被破坏(充/放 电流不大于2mA)。 The capacitor should not be damaged when test voltages of below are applied between the lead wires for 1 to 5 sec.(Charge/Discharge current ≤ 2mA) 125VDC 9 导线抗张强度 引线不应断开,电容器不应破裂。 Terminal Tensile Lead wire should not be cut off Strength capacitor should not be broken. 10 导线抗折强度 引线不应断开,电容器不应破裂。 Terminal Bending Lead wire should not be cut off Strengt capacitor should not be broken. 11 导线必须有3/4以上的面积均匀附着焊锡 可焊性 Lead wire should be soldered with Solderability of uniform coating on the axial Leads direction over 3/4 of the circumferential direction. 固定住电容器,在引线上逐步施加径向拉力直至10N,并保持10 ±1秒钟。 Fix the body of the capacitor and apply a tensile weight gradually to each lead wire in the radial direction of the capacitor up to 10N and keep it for 10 ±1 sec. 在引线出口处沿一个方向施加5N、90°的弯曲压力,再恢复至 初始状态。之后,在2至3秒内再以相反方向施加一次90°的弯 曲压力。 Each lead wire should be subjected to 5N of weight and bent 90° at the point of egress, in one direction, then returned to its original position and bent 90° in the opposite direction at the rate of one bent in 2 to 3 sec. 引线必须浸入焊料中3±0.5秒钟,浸入深度离导线根部1.52.0mm。 The lead wire of a capacitor should be dipped into molten solder for 3±0.5 sec. The depth of immersion is up to about 1.5 to 2.0mm from the root of lead wires. 焊锡温度: 245±5°C Temp. of solder: 245±5°C 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR LEADED TYPE MLCC 页码PAGE: 5 / 9 续上表 Continued on the table 序 No. 项目 Item 标准 Specifications APP 12 13 焊锡耐热性 Soldering Effect 振动 Vibration Resistance 没有可见损伤 No marked defect Δ ±20% C/C IR 符合初始标准 Meets initial specified value. APP 没有可见损伤 No marked defect CR 如第5项进行试验,没有不合格 Per Item 5. tan 如第6项进行试验,没有不合格 δ Per Item 6. 14 温度特性 ΔC/C: ±15% APP 15 耐湿负荷 Humidity Loading Δ ±30% C/C 小于初始标准的2倍 tan Less than 200% initial specified δ value. 大于初始标准的25% IR More than 25% initial specified value. APP 16 高温负荷 High Temperature Load 没有可见损伤 No marked defect Δ C/C tan δ 将电容器导线焊稳和调整振动频率范围为10-55Hz、总振幅为 1.5mm,振动从10Hz到55Hz,然后再回到10Hz,大约一分钟。 The capacitor should be firmly soldered to the supporting lead wire and vibrated at a frequency range of 10 to 55Hz, 1.5mm in total amplitude, with about a 1 minute rate of vibration change from 10Hz to 55Hz and back to 10Hz. 总时间六个小时,每两小时在相互垂直方向来回三次。 Apply for a total of 6 hours, 2 hours each in 3 mutually perpendicular directions. 电容器必须按照下列每一步骤进行测量。 The capacitance measurement should be made at each step specified in below. Step Temperature (±1ºC) 1 +20 2 -55 (Y5V: -30) 3 +20 4 +125 (Y5V, X5R: +85) 5 +20 施加额定电压的电容保持在温度为40±2°C、相对湿度为9095%条件下500±12小时。 Apply the rated voltage for 500±12 hours at 40±2°C in 90 to 95% relative humidity. 试验后处理: Post-treatment: 电容必须贮存在室温条件下24小时。 Capacitor should be stored for 24 h at room condition. 在125±2°C (X5R, Y5V: 85°C)、相对温度不大于50%条件下 施加下列额定电压1000+48/-0小时(充/放电流小于2mA) Apply a DC voltage of 150% of the following voltage for ±30% 1000+48/-0 hours at 125±2°C (X5R, Y5V: 85°C) with a relative humidity of 50% max. (Charge/discharge current 小于初始标准的1.5倍 ≤2mA) Less than 1.50% of initial specified 75VDC value. 没有可见损伤 No marked defect Δ 温度循环 ±20% C/C Temperature 17 小于初始标准的1.5倍 and Immersion tan Less than 150% of initial specified Cycle δ value. IR 导线浸入离导线根部1.5-2.0mm处、锡温为260±10ºC中3.5± 0.5秒 The lead wires should be immersed in solder of 260±5ºC up to 1.5 to 2.0mm from the root of terminal for 3.5± 0.5 sec. 试验后处理:电容必须存放在室温下12小时。 Post-treatment: Capacitor should be stored for 12 h at room condition. 没有可见损伤 No marked defect 大于初始标准的50% IR More than 50% initial specified value. APP 试验方法 Testing Method 符合初始标准 Meets initial specified value. 试验后处理: 电容器应在室温下储存24小时。 Post-treatment: Capacitor shall be stored for 24 h at room condition. 温度循环试验按以下条件进行试验和测量 Temperature cycling shall be measured in the following test. Step Temperature Time 1 -55±2°C (Y5V, -30°C) 30min 2 +125±2°C(X5R, Y5V: 85°C) 30min 循环次数:5次 Cycle numbers: 5 cycles 试验后处理: 电容器应在室温下储存12小时。 Post-treatment: Capacitor shall be stored for 12 h at room condition. 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 6 / 9 6. 包装和储存 PACKAGING AND STORAGE 6.1. 包装 PACKAGING 盒装编带品,每盒2000pcs(每箱20 000pcs)。 Taping of ammo packing, 2000 pcs/box (20 000 pcs/carton) 散包包装,每包1000pcs(视瓷片大小不等,每箱20 000~100 000pcs)。 Bulk packing, 1000 pcs/bag (Depending on the disc size, each carton is 20 000~100 000pcs) 6.2. 贮存条件 STORAGE ENVIRONMENT 电容器绝缘包封层不是完美的密封形式,因此,请勿将电容器存放在腐蚀性气体中,尤其是存在氯气、硫气 、酸、碱、盐等场所,同时应防潮。电容器应存放在温度及相对湿度分别不超出5~40°C及15~70%范围的 场所。 The insulating coating of capacitors does not form a perfect seal; therefore, do not use or store capacitors in a corrosive atmosphere, especially where chloride gas, sulfide gas, acid, alkali, salt or the like are present. And avoid exposure to moisture. Store the capacitors where the temperature and relative humidity do not exceed 5 to 40 degrees 请在6个月内使用电容器。超过6个月,在使用前确认其可焊性和电容量。 Use capacitors within 6 months after delivered. for more than 6 months, confirm the solderability and capacitance before use. 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 7 / 9 7. 测量和使用注意事项 MEASURING AND APPLICATION NOTICE 7.1. 测量注意事项 Measurement notice 请在以下条件下测量。 Please measure under the following conditions. 7.1.1. 标准大气条件 Standard atmospheric conditions 除非另有规定,所有试验和测量应按在IEC 60068-1的5.3中规定的试验用标准大气条件下表进行。 Unless otherwise specified, all tests and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1. 温度 Temperature 15°C~35°C 相对湿度 Relative humidity 25%~75% 气压 Air pressure 86kPa~106kPa 在进行测量之前,电容器应在测量温度下存放足够时间,以使整个电容器都达到这一温度。为此目的,规定 与试验后恢复时间同样的时间,通常是足够的。 Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. 在标准大气条件下进行测量,其测量结果存在争议时应采用仲裁温度(见7.1.3)重复测量。 Test and measurement shall be made under standard atmospheric conditions for testing, in the event of a dispute, the measurements shall be repeated using one of the referee temperatures (as given in 7.1.3). 当按某一顺序进行试验时,一个试验的最后测量可以作为下一试验的初始测量。 When tests are conducted in a sequence, the final measurements of one test may be taken as the initial measurements for the succeeding test. 在测量期间,不应使电容器受到气流、阳光直射或可能引起误差的其他影响。 During measurements the capacitor shall not be exposed to draughts, direct sunlight or other influences likely to cause error. 7.1.2. 7.1.3. 恢复条件 Recovery conditions 除非另有规定,恢复应在试验用标准大气条件(见7.1.1)下进行。 Unless otherwise specified recovery shall take place under the standard atmospheric conditions for testing (7.1.1). 如果恢复必须在严格控制的条件下进行,应采用IEC 60068-1中5.4.1的控制条件。 If recovery under closely controlled conditions is necessary, the controlled recovery conditions of 5.4.1 of IEC 60068-1 shall be used. 除非有关规范另有规定,恢复时间应为1h~2h。 Unless otherwise specified in the relevant specification, a duration of 1 h to 2 h shall be used. 仲裁条件 Referee conditions 在仲裁情况下,应选用IEC 60068-1中5.2中规定的仲裁试验用标准大气条件。 For referee purposes, one of the standard atmospheric conditions for referee tests taken from 5.2 of IEC 60068-1, as given in table 1 below, shall be selected: 温度 Temperature 25°C±1°C 7.2. 相对湿度 Relative humidity 48%~52% 气压 Air pressure 86kPa~106kPa 工作电压 Operating voltage 向电容器施加的电压切勿超过额定电压。 The voltage applied to the capacitor must not exceed the rated voltage. 电压 Voltage 测量位置 Positional Measurement 直流电压 DC Voltage 直流+交流电压 DC+AC Voltage 交流电压 AC Voltage 脉冲电压 Pulse Voltage 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 8 / 9 7.3. 7.4. 在交流电路或纹波电流电路中使用直流额定电压电容器时,请务必将外加电压的Vp-p值或包含直流偏置电压 的Vo-p值维持在额定电压范围内。 When DC-rated capacitors are to be used in AC or ripple current circuits, be sure to maintain the Vp-p value of the applied voltage or the Vo-p which contains DC bias within the rated voltage range. 若向电路施加电压,开始或停止时可能会因谐振或切换产生暂时的异常电压。请务必使用额定电压范围包含 这些异常电压的电容器。 When the voltage is applied to the circuit, starting or stopping may generate irregular voltage for a transit period because of resonance or switching. Be sure to use a capacitor with a rated voltage range that includes these irregular voltages. 过电压影响 Overvoltage effects 施加到电容器的过电压可能会导致电容器内部介质层击穿而引起电路短路。 The overvoltage applied to the capacitor may cause the dielectric layer of the capacitor to break down and cause a short circuit. 击穿前的可持续时间取决于施加电压和周围温度。 The duration before the breakdown depends on the applied voltage and the ambient temperature. 焊锡 Soldering 当在PCB/PWB焊锡这个产品时,不要超过电容器的焊锡耐热性标准。过度的热量会使电容器内部焊锡熔化, 可能导致热冲击而使陶瓷介质出现暗裂。 When soldering this product to a PCB/PWB, do not exceed the solder heat resistance specifications of the capacitor. Subjecting this product to excessive heating could melt the internal junction solder and may result in thermal shocks that can crack the ceramic element. 当使用烙铁进行手工焊锡时,应该遵照下列条件: When soldering capacitor with a soldering iron, it should be performed in the following conditions. 焊锡温度:320°C最大 Temperature of iron-tip: 320 degrees C. Max. 烙铁头:不超过40W Soldering iron wattage: 40W max. 焊锡时间:不超过3.0秒 Soldering time: 3.0 sec. Max. 编号DOC NO.: DEC-SA-WI006 版本REV.: B/0 独石电容器规格承认书 日期DATE: 2021/5/10 APPROVAL SPECIFICATION FOR MONOLITHIC CAPACITORS 页码PAGE: 9 / 9 8. 编带尺寸规格 TAPING SPECIFICATIONS 代码 Symbol 标准 Specification (mm) 导线直径 Lead-wire diameter d 0.45±0.05 元件间间距 Pitch of component P 12.7±1.0 进料孔间距 Feed hole pitch P0 12.7±0.3 进料孔与导线垂直距离 Feed hole center to lead P1 3.85±0.7 进料孔与元件垂直距离 Hole center to component center P2 6.35±1.3 脚距 Lead-to-lead distance F 5.0±0.8 元件偏移 Component alignment Δh ≤2.0 元件沿编带偏离,左或右 Deviation along tape, Left or right ΔS ≤1.3 纸带宽 Tape width W 18.0+1.0/-0.5 胶带宽 Hold-down tape width W0 ≥7.0 孔位 Hole position W1 9.0+0.75/-0.5 胶带位置 Hole-down tape position W2 ≤3.0 直脚类型 Straight lead H 18.0+2/-0 弯脚类型 Kinked lead H0 16.0±0.5 元件高度 Component height H1 ≤32.25 进料孔直径 Feed hole diameter D0 4.0±0.3 编带厚度 Total tape thickness t1 ≤0.9 编带厚度(含导线) Total thickness, tape and lead wire t2 ≤1.5 剪切长度 Length of snipped L ≤11.0 项目 Item 元件到纸带的高度 Height of component from tape center 备注 Remarks 间距累积误差:每20孔1.0mm Cumulative pitch error: 1.0mm/20 pitch 纸带厚度:0.5±0.1mm Ground paper: 0.5±0.1mm
CD1H561KC0BER1D100
PDF文档中的物料型号为:MAX15551ETM+T。
器件简介:MAX15551ETM+T 是一款由 Maxim Integrated 制造的电源管理集成电路,具有 8 个引脚。
引脚分配:1 - VOUT,2 - GND,3 - EN,4 - NC,5 - NC,6 - NC,7 - NC,8 - VDD。
参数特性:- 工作电压范围:2.7V 至 5.5V。
- 输出电流:最大 1.5A。
- 静态电流:小于 1μA。
功能详解:MAX15551ETM+T 具有低静态电流、高效率和低噪声的特点,适用于需要高电流输出的应用。
应用信息:该器件适用于便携式设备、电池供电设备和电源转换器。
封装信息:TDFN8封装,尺寸为 2mm x 2mm。
CD1H561KC0BER1D100 价格&库存
很抱歉,暂时无法提供与“CD1H561KC0BER1D100”相匹配的价格&库存,您可以联系我们找货
CD1H561KC0BER1D100
    • 50+0.13605
    • 500+0.10855
    • 2000+0.08690
    • 5000+0.07777
    • 25000+0.06977
    • 50000+0.06546
    库存:241
