独石电容器承认书
APPROVAL SPECIFICATIONS FOR MONOLITHIC CAPACITORS
(AEC-Q200 REV.)
客户
CUSTOMER
客户料号
CUSTOMER P/N
立创商城
C3293120
规格描述
DESCRIPTION
100V/104K/F5.08/L24/X7R/0805/AEC-Q200
产品品号
PART NUMBER
CD2A104KC9IER1EZAE
日期
DATE
文件编号
DOC. NO.
2022-07-08
德尔创承认栏
APPROVED BY DERSONIC
DEC-SA-WI010
客户承认栏
APPROVED BY CUSTOMER
批 准
APPROVED BY
审核
CHECK BY
制订
FORMULATE BY
彭少雄
吴成爱
陈冬花
批 准
APPROVED BY
审核
CHECK BY
東莞市德尔创电子有限公司
DONGGUAN CITY DERSONIC ELECTRONICS CO., LTD.
广東省東莞市长安镇锦厦河南工业区锦平路 5 号
NO.5, JINGPING ROAD, JINXIA HENAN INDUSTRIAL ZONE, CHANGAN TOWN DONGGUAN CITY, PRC
TEL:86-769-8155 5686
FAX:86-0769-8155 5989
WEBSITE: HTTP://WWW.DERSONIC.COM
E-MAIL:SALES@DERSONIC.COM
DOC NO.:
FOR MONOLITHIC CAPACITORS (AEC-Q200 REV.)
DEC-SA-WI010
REV.:
A/0
DATE:
2022-07-07
PAGE:
2 / 10
1.
APPLICATION
This specification is applied to ZAE series monolithic capacitor in accordance with AEC-Q200 requirements used for
automotive electronic equipment.
ZAE series monolithic capacitor has the following characteristics:
Complies AEC-Q200 requirements
Miniature size, large capacitance, tape and reel packaging suitable for auto-placement.
Epoxy coating creates excellent performance in humidity resistance, mechanical strength and heat resistance.
Standard size, various lead configurations.
Comply with RoHS 2.0, reach, halogen-free available.
2.
PART NUMBER (RATING)
CD
2A
104
Type
Rated
voltage
Nominal
capacitance
K
C
9
I
E
R1
E
ZAE
Capacitance
tolerance
Lead
spacing
Lead
style
Lead length
or taping
Coating
Temp.
Char.
Chip
Series
Type
CD: Monolithic capacitors
Rated voltage
1H: DC50V
2J: DC630V
Nominal capacitance
The first two digits denote significant figures; the last digit denotes the multiplier of 10 in pF.
ex.) In case of 104
10× 104=100000pF=0.1µF
Capacitance tolerance
J: ± 5%
K:± 10%
Lead spacing (F)
A: 2.54mm
C: 5.08mm
2A: DC100V
3A: DC1KV
1:
9:
2E: DC250V
M:± 20%
0:
Lead style (L)
● Lead length (Bulk)
4: 3.5mm
8: 5mm
A: 8mm
I: 24mm
Lead length or taping
Coating
6: 4mm
9: 6mm
B: 10mm
M: 32mm
● Taping
T: Reel packing
P: Ammo packing
E: Epoxy coating (Blue)
Code
Temperature
characteristic
CH
C0G
Code
R1
Temperature
characteristic
X7R
Temperature
Temperature
Standard Operating temp.
range
coefficient
temperature
range
-55~25℃ 0+30/-72ppm/℃
25℃
-55~125℃
25~125℃ 0±30ppm/℃
Temperature
range
-55~125℃
Temperature characteristic
Chip
E: 0805
Series
ZAE: complies AEC-Q200 requirements
F: 1206
Capacitance
change
± 15%
temperature
range
25℃
-55~125℃
G: 1210
DOC NO.:
3.
MARKING
4.
SPECIFICATIONS LIST
Chip
Temperature
characteristic
C0G
0805
Capacitance
range
50V: 100-103
100V: 100-682
250V: 100-222
630V: 100-391
X7R
50V: 101-224
100V: 101-104
250V: 101-223
630V: 101-103
C0G
50V: 100-103
100V: 100-103
250V: 100-472
630V: 100-222
1KV: 100-102
1206
X7R
C0G
1210
X7R
50V: 151-475
100V: 151-105
250V: 101-104
630V: 101-103
50V: 100-473
100V: 100-473
250V: 100-153
630V: 100-103
1KV: 100-102
50V: 102-105
100V: 102-105
250V: 101-474
630V: 101-223
1KV: 101-103
DEC-SA-WI010
REV.:
A/0
DATE:
2022-07-07
PAGE:
3 / 10
Dimensions (mm)
Tolerance
W
max
H
max
T
max
F
± 0.8
Ød
± 0.1
Lead
style
± 5%
± 10%
4.5
3.8
3.5
2.54
5.08
1
0.47
9
± 10%
± 5%
± 10%
5.5
4.5
4.0
5.08
0.47
5.5
6.5
4.5
5.08
0.47
9
± 10%
± 5%
± 10%
± 10%
9
DOC NO.:
5.
DEC-SA-WI010
REV.:
A/0
DATE:
2022-07-07
PAGE:
4 / 10
AEC-Q200 MURATA STANDARD SPECIFICATIONS AND TEST METHODS
Test and measurement shall be made at the room condition (temperature 15 to 35℃, relative humidity 45 to 75%,
atmosphere pressure 86 to 106kPa).
Unless otherwise specified herein, If doubt occurred on the value of measurement, and measurement was requested by
customer capacitors shall be measured at the reference condition (temperature 25± 2℃, relative humidity 60 to70%,
No
Test Item
1
Pre-and Post-Stress
Electrical Test
2
High
Temperature
Exposure
(Storage)
Specification
Appearance
No defects or abnormalities.
∆C/C
C0G: Within ± 3% or ± 0.3pF
(Whichever is larger)
X7R: within ± 12.5%
DF or Q
C0G: ≥30pF, Q>350
很抱歉,暂时无法提供与“CD2A104KC9IER1EZAE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.97254
- 50+0.77987
- 150+0.68354
- 1000+0.56193
