DP-RJ45-R-32
DP-RJ45-R-32
    MENCOM
DP-RJ45-R-32 数据手册
Panel Interface Connectors Hundreds of Components and Unlimited Possibilities Port Adapters | Panel Mount Junction Blocks | Components | Accessories UL File #: E491186 Encl. Acc. A panel interface connector(PIC) is a device that typically mounts to the outside of a control panel housing a PLC, computer, or other type of programmable device. Once in place, the PIC, which houses convenient pass through connections, allows quick, easy, safe access to the controls inside the cabinet. D-sub Connectors Power Port Communication Port Benefits of PICs - The ability to quickly interface directly with the contents of the cabinet without opening the main cabinet door - With thousands of component combinations, you can easily configure your PIC to match your specific requirements Resets Data Highways Housings - Avoid potential safety hazards, such as Arc Flash, associated with opening a panel under load Variety of Options Mencom currently has well over 3,000 designs in production. Our team of engineers are designing new and custom PIC models every day. We are not limited to just what is represented in this catalog, so please contact us regarding your requirements. Low Profile Versions V Panel Interface Connectors Inside Panel Mencom Corporation | 1-770-534-4585 | www.mencom.com V-1 Panel Interface Connectors Low Profile Housings Clear Cover | Solid Construction | UL Type 4, 12 | IP65 Rating Dimensional, and Panel Cut-Out information found on page V-25 Encl. Acc. Low Profile Housings LP1 Single Cover LP2 Two Single Covers LP3 Double Cover [65] 2.6 [130] 5.1 [130] 5.1 [117.46] 4.6 Profile Comparison Latch & Lock Mechanism Low Profile Enclosure [25 mm] 1 inch Low Profile Latching vs Standard Enclosure Locking A For Additional Security Rotate Lock to Lock Closed Panel Interface Connectors Lower up to 75% [22.6 ~ 77 mm] 0.87 ~ 3 inch Standard Enclosure [47.6 ~ 102 mm] 1.87 ~ 4 inch For IP65 Rating Slide Latch to Open/Close V DETAIL A SCALE 4:3 V-2 Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Standard Metal Housings Standard Metal Housing | Panel Mount Junction Blocks | UL Type 4, 4X, 12 | IP65 Rating Dimensional, and Panel Cut-Out information found on page V-26 & V-27 Encl. Acc. Standard Metal Housings With Metal Cable Gland/ Threaded Opening NPT, PG, Metric Corrosion & Chemical Resistant Rugged Epoxy Coated Cast Aluminum Construction Customizable Label Dust and Liquid Resistant IP65 Self-Extinguishing Thermoplastic Lever Open Surface Mount Housings Page V-27 Close Panel Interface Connectors Bulkhead Mount Housings Page V-26 Unique Stainless Steel Latch Design Soft Opening and Closing Panel Mount Junction Blocks Corrosion Resistant Stainless Steel Plate M12 Connectors A-Code/D-Code No Housing Panel Mount JDC Series Page V-36 ~ V-40 Mencom Corporation Customizable Interior Termination Options | 1-770-534-4585 | V Customizable Laser Marking Ethernet Series Page V-41 ~ V-42 www.mencom.com V-3 Panel Interface Connectors 120V GFCI Recptacle to 120V Simplex Receptacle GFDP1 Power Port | Easy Access Terminal Block Wiring | IP65 Rating GFDP1 Power Port NFPA 79 Compliant GFDP1 Schematic without Circuit Breaker r IN e w Po Incoming 120V LINE Outgoing 120V GFCI Protected Power LOAD HOT GROUND HOT GROUND NEUTRAL NEUTRAL TB1 r e w Po TB2 Standard Ground Fault Circuit Interrupter Duplex Receptacle T U O Diode 1N4007 LED Resistor 47K 1/4W To additional receptacles as per local codes - 3 GFCI-protected receptacles (2 Outside & 1 Inside) - Easy and Safe TEST/RESET outside the panel - Outgoing Terminals for GFCI Protected Power Easy Access Terminal Block Wiring Terminal Block Panel Interface Connectors Finger Safe Cover Internal connections to power ports are finger safe V V-4 Mencom Corporation | 1-770-534-4585 | www.mencom.com Mencom Corporation no problems, only solutions V Panel Interface Connectors Notes: Mencom Corporation | 1-770-534-4585 | www.mencom.com V-5 Panel Interface Connectors Thousands of Components and Unlimited Possibilities Contents Part Number Matrix V-7 Popular Models Components The Most Popular Models with Images Power Ports V-22 Communication Ports V-23 Data Highway & Resets V-24 Housings V-25 ~ V-28 Extension Cables D-Sub with Guaranteed Color Code V-29 RJ45 V-30 Other Cables V-31 Accessories V-32 Port Adapters Panel Mount Junction Blocks Metal V-33 Plastic V-34 Back Mount V-35 JDC (M12) Series V-36 ~ V-40 Ethernet Series V-41 ~ V-42 Panel Interface Connectors Basic PIC Facts • • • • • V • • V-6 V-8 ~ V-15 V-16 ~ V-21 Other Popular Models UL File # E491186 Models containing an international power outlet do not carry UL. All connections are normally straight through, pin 1 to pin 1, etc. All D-Sub connectors are FEMALE EXTERIOR and MALE INTERIOR referenced to the cabinet. Other configurations such as male interior and exterior, male exterior and female interior, and female interior and exterior are available. The 9 pin and 25 pin D-Subs pin configurations are available as a break out configuration in some units. These connectors allow for the D-Sub to be separated into individual lines. This allows the user to connect to the D-Sub by way of screw terminal connections. All “mini-DIN” and circular DINS, BNC, Coax and RJs are configured FEMALE EXTERIOR and INTERIOR. The standard reset is a 3 amp to limit the power output of the unit. Other amperages are available, please consult the factory. Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Panel Interface Connectors Part Number Matrix More components available - Please consult factory - - - - Prefix = = = = = N/A Data Highway Low Profile Housing with Single Cover Low Profile Housing with Two Single Covers Low Profile Housing with Double Cover Housings 06(LS) 10(LS) 16(LS) 24(LS) 32(LS) 48(LS) P06 P10 P16 P24 P32 P48 Power Ports 120V/250V D (or Blank) DP DP1 DPT DPIG GF GFDP1 DEC DMC = = = = = = = No Power Receptacle 120V Duplex Receptacle 120V Simplex Receptacle 120V “Twist Lock” Duplex Receptacle 120V Isolated Ground Duplex Receptacle 120V GFCI Receptacle Front: 120V GFCI Receptacle Back: 120V Simplex Receptacle = 250V/15A Female Receptacle = 250V/15A Male Receptacle International EP = DIN = DUK = DAS = DCH1 = DCH2 = FR = DUN = = = = = = = = = = = = = Size 6 Bulkhead Housing Size 10 Bulkhead Housing Size 16 Bulkhead Housing Size 24 Bulkhead Housing Size 32 Bulkhead Housing Size 48 Bulkhead Housing Size 6 Surface Mount Housing Size 10 Surface Mount Housing Size 16 Surface Mount Housing Size 24 Surface Mount Housing Size 32 Surface Mount Housing Size 48 Surface Mount Housing Resets NR (or Blank) R 5R 10R 15R Continental European Receptacle India Receptacle United Kingdom Receptacle Australian Receptacle China 10 AMP China 16 AMP French Receptacle Universal Receptacle = = = = = No Reset 3 AMP Reset 5 AMP Reset 10 AMP Reset 15 AMP Reset Communication Ports Ethernet RJ45 = Ethernet Female/Female RJ11/12 = Standard Phone Female/Female RJ22 = Handset Jack Female/Female D-Sub Connectors 9 Pin DB9 DB9M MDB9 DB9F = = = = 9 Pin D-Sub Female Ext/Male Interior 9 Pin D-Sub Male Ext/Male Interior 9 Pin D-Sub Male Ext/Female Interior 9 Pin D-Sub Female Ext/Female Interior 15 Pin DB15 DB15M MDB15 DB15F DDB15 DDB15M MDDB15 DDB15F = = = = = = = = 15 Pin D-Sub Female Ext/Male Interior 15 Pin D-Sub Male Ext/Male Interior 15 Pin D-Sub Male Ext/Female Interior 15 Pin D-Sub Female Ext/Female Interior Hi-Density 15 Pin D-Sub Female Ext/Male Interior Hi-Density 15 Pin D-Sub Male Ext/Male Interior Hi-Density 15 Pin D-Sub Male Ext/Female Interior Hi-Density 15 Pin D-Sub Female Ext/Interior 25 Pin DB25 DB25M MDB25 DB25F = = = = 25 Pin D-Sub Female Ext/Male Interior 25 Pin D-Sub Male Ext/Male Interior 25 Pin D-Sub Male Ext/Female Interior 25 Pin D-Sub Female Ext/Female Interior 37 Pin DB37 DB37M MDB37 DB37F = = = = 37 Pin D-Sub Female Ext/Male Interior 37 Pin D-Sub Male Ext/Male Interior 37 Pin D-Sub Male Ext/Female Interior 37 Pin D-Sub Female Ext/Female Interior Radio-Frequency BNC = BNC Female/Female CX = Coaxial Female/Female Mini-Din 8M 6M = 8 Pin Mini-DIN Female/Female = 6 Pin Mini-DIN Female/Female USB USB = 2 USB 3.0 Form A to USB 3.0 Form A Female/Female USB-* = Form A Female to Form A Male Cable by the Foot USB-AFAF = Single USB 3.0 Form A Female to USB 3.0 Form A Female USB-AFBF = Single Form A Female to Form B Female USB-BFBF = Single Form B Female to Form B Female USB-BFAF = Single Form B Female to Form A Female * Length in feet. = Fiber Optic = High-Definition Multimedia Interface V Others FOPT HDMI Panel Interface Connectors Blank DH LP1 LP2 LP3 D-Sub to Screw Terminal Block DB9-PC9 = 9 Pin D-Sub Female to a Discrete Wire Pluggable Screw Terminal Block DB25-PC25 = 25 Pin D-Sub Female to a Discrete Wire Pluggable Screw Terminal Block Mencom Corporation | 1-770-534-4585 | www.mencom.com V-7 Panel Interface Connectors Popular PIC Models Low Profile LP1 Housing | UL Type 4, 12 | IP65 Rating Part Number Description Panel Interface Connectors V Part Number Description LP1-2DB9 2 x 9 Pin D-Sub LP1 Housing LP1-DB9-USB-* 9 Pin D-Subs USB Form A Female with Cable to USB Form A Male LP1 Housing LP1-2RJ45 2 x RJ45 LP1 Housing LP1-DCH1-RJ45-R China 10 AMP Receptacle RJ45 3 AMP Reset LP1 Housing LP1-2USB-* 2 x USB Form A Female with Cable to USB Form A Male LP1 Housing LP1-DP Duplex Receptacle LP1 Housing LP1-2USB-AFAF 2 x USB A connections LP1 Housing LP1-DP1 Single Outlet LP1 Housing LP1-2USB-BFAF 2 x USB Female Form B to Female Form A LP1 Housing LP1-DP1-2RJ45 Single Outlet 2 x RJ45 LP1 Housing LP1-4RJ45 4 x RJ45 LP1 Housing LP1-DP1-2RJ45-R Single Outlet 2 x RJ45 3 AMP Reset LP1 Housing LP1-DB25 25 Pin D-Sub LP1 Housing LP1-DP1-DB9 Single Outlet 9 Pin D-Sub LP1 Housing LP1-DB9 9 Pin D-Sub LP1 Housing LP1-DP1-DB9-RJ45 Single Outlet 9 Pin D-Sub RJ45 LP1 Housing LP1-DB9-RJ45 9 Pin D-Sub RJ45 LP1 Housing LP1-DP1-R Single Outlet 3 AMP Reset LP1 Housing Faceview * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Stainless steel UL Type 4X versions in development. Consult factory for more information. PICs with International outlets are non-UL. V-8 Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors Popular PIC Models Low Profile LP1 & LP2 Housing | UL Type 4, 12 | IP65 Rating Part Number Description LP1-DP1-RJ45-R Single Outlet RJ45 3 AMP Reset LP1 Housing LP1-RJ45 RJ45 LP1 Housing LP1-DP1-RJ45-USBAFAF-R Single Outlet RJ45 USB Female Form A to Female Form A 3 AMP Reset LP1 Housing LP1-RJ45-2USB-* RJ45 2 x USB Form A Female with Cable to USB Form A Male LP1 Housing LP1-DP1-RJ45-USBBFAF-R Single Outlet RJ45 USB Female Form B to Female Form A 3 AMP Reset LP1 Housing LP1-RJ45-USB-* RJ45 USB Form A Female with Cable to USB Form A Male LP1 Housing LP1-DP1-USB-AFAF-R Single Outlet USB Female Form A to Female Form A 3 AMP Reset LP1 Housing LP1-USB-* USB Form A Female with Cable to USB Form A Male LP1 Housing LP1-EP-R Continental European Receptacle 3 AMP Reset LP1 Housing LP1-USB-AFAF USB Female Form A to Female Form A LP 1 Housing LP1-EP-RJ45 Continental European Receptacle RJ45 LP1 Housing LP1-USB-BFAF Single Outlet USB Female Form B to Female Form A LP1 Housing LP1-EP-RJ45-R European Receptacle RJ45 3 AMP Reset LP1 Housing LP2-2GF 2 x GFCI Receptacle LP2 Housing LP1-GF GFCI Receptacle LP1 Housing LP2-8RJ45 8 x RJ45 LP2 Housing LP2-DBR-DB9-RJ452USB-AFAF-R Brazilian Receptacle 9 pin D-Sub RJ45 2xUSB A connections 3 AMP Reset LP2 Housing LP1-RJ11 Faceview RJ11 LP1 Housing Faceview Panel Interface Connectors Description V Part Number * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Stainless steel UL Type 4X versions in development. Consult factory for more information. PICs with International outlets are non-UL. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-9 Panel Interface Connectors Popular PIC Models Low Profile LP2 & LP3 Housing | UL Type 4, 12 | IP65 Rating Part Number Description Panel Interface Connectors V Part Number Description LP2-DP1-2DB9-RJ45-R Single Outlet 2 x 9 Pin D-Subs RJ45 3 AMP Reset LP2 Housing LP2-GF-RJ45S GFCI Receptacle Shielded RJ45 LP2 Housing LP2-EP-RJ45 Continental European Receptacle RJ45 LP2 Housing LP2-GF-RJ45-USBAFAF GFCI Receptacle RJ45 USB Form B Female to Form A Female LP2 Housing LP2-EP-RJ45-R Continental European Receptacle RJ45 3 AMP Reset LP2 Housing LP2-GF-RJ45-USBBFAF GFCI Receptacle RJ45 USB Female Form B to Female Form A LP2 Housing LP-EP-2 2 x Continental European Receptacle LP2 Housing LP3-DP-2RJ45-R Duplex Receptacle 2- RJ45 3 AMP Reset LP3 Housing LP2-GF-2DB9-RJ45 GFCI Receptacle 2 x 9 Pin D-Sub RJ45 LP2 Housing LP3-DP-DB9-PC9RJ45-R Duplex Receptacle 9 Pin D-Sub to Terminal Block RJ45 3 AMP Reset LP3 Housing LP2-GF-2RJ45 GFCI Receptacle 2 x RJ45 LP2 Housing LP3-DP-DB9-RJ45-R Duplex Receptacle 9 Pin D-Sub RJ45 3 AMP Reset LP3 Housing LP2-GF-2RJ45-USBBFAF GFCI Receptacle 2 x RJ45 USB Form B Female to Form A Female LP2 Housing LP3-DP-RJ11-RJ45-R Duplex Receptacle RJ11 RJ45 3 AMP Reset LP3 Housing LP2-GF-RJ45 GFCI Receptacle RJ45 LP2 Housing LP3-DP-RJ45-R Duplex Receptacle RJ45 3 AMP Reset LP3 Housing LP2-GF-RJ45-2USBAFAF GFCI Receptacle 2xUSB A connections RJ45 LP2 Housing LP3-EP-15R Continental European Receptacle 15 AMP Reset LP3 Housing Faceview * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Stainless steel UL Type 4X versions in development. Consult factory for more information. V-10 Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors Popular PIC Models Low Profile LP3 Housing | UL Type 4, 12 | IP65 Rating Part Number Description LP3-EP-2 2 x Continental European Receptacle LP3 Housing LP3-GF-DB9M-RJ45-R GFCI Receptacle 9 Pin D-Sub Male Exterior/Male Interior RJ45 3 AMP Reset LP3 Housing LP3-EP-DB9-RJ45-R Continental European Receptacle 9 Pin D-Sub RJ45 3 AMP Reset LP3 Housing LP3-GF-DB9-RJ45-R GFCI Receptacle 9 Pin D-Sub RJ45 3 AMP Reset LP3 Housing LP3-EP-RJ45-2USB-*-R Contl. European Recp. RJ45 2 x USB Form A Female with Cable to USB Form A Male 3 AMP Reset LP3 Housing LP3-GF-R GFCI Receptacle 3 AMP Reset LP3 Housing LP3-EP-RJ45-R Continental European Receptacle RJ45 3 AMP Reset LP3 Housing LP3-GF-RJ45 GFCI Receptacle RJ45 LP3 Housing LP3-GF-15R GFCI Receptacle 15 AMP Reset LP3 Housing LP3-GF-RJ45-15R GFCI Receptacle RJ45 15 AMP Reset LP3 Housing LP3-GF-2RJ45-R GFCI Receptacle 2 x RJ45 3 AMP Reset LP3 Housing LP3-GF-RJ45-R GFCI Receptacle RJ45 3 AMP Reset LP3 Housing LP3-GF-2USB-AFAF-R GFCI Receptacle 2xUSB A connections 3 AMP Reset LP3 Housing LP3-GF-RJ45S-R GFCI Receptacle Shielded RJ45 3 AMP Reset LP3 Housing LP3-GF-DB15-R GFCI Receptacle 15 Pin D-Sub 3 AMP Reset LP3 Housing LP3-GF-RJ45-USB-*-R GFCI Receptacle RJ45 USB Form A Female with Cable to USB Form A Male 3 AMP Reset LP3 Housing LP3-GF-DB9F-RJ45-R GFCI Receptacle 9 pin D-Sub Female Exterior/Female Interior RJ45 3 AMP Reset LP3 Housing LP3-GF-USB-AFAF-R GFCI Receptacle USB Form A Female to Form A Female 3 AMP Reset LP3 Housing Faceview Faceview Panel Interface Connectors Description V Part Number * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Stainless steel UL Type 4X versions in development. Consult factory for more information. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-11 Panel Interface Connectors Popular PIC Models Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Part Number Description Panel Interface Connectors V Part Number Description GF-RJ45-R-32 GFCI Receptacle RJ45 3 AMP Reset Size 32 Housing GF-DB9-RJ45-R-32 GFCI Receptacle 9 Pin D-Sub RJ45 3 AMP Reset Size 32 Housing DP1-RJ45-16LS Single Outlet RJ45 Size 16 Housing DB09-06LS 9 Pin D-Sub Size 6 Housing DP-RJ45-R-32 Duplex Receptacle RJ45 3 AMP Reset Size 32 Housing DP1-DB9-RJ45-16LS Single Outlet 9 Pin D-Sub RJ45 Size 16 Housing DP1-RJ45-R-24LS Single Outlet RJ45 3 AMP Reset Size 24 Housing EP-RJ45-R-32 European Receptacle RJ45 3 AMP Reset Size 32 Housing D-USB-*-06LS USB Form A Female with Cable to USB Form A Male Size 6 Housing RJ45-CVKIT Ethernet Kit RJ45 Size 6 Housing (Hood Incl.) GF-2-48LS 2 x GFCI Receptacle Size 48 Housing DP-USB-RJ45-32 Duplex Receptacle 2xUSB A Connections RJ45 Size 32 Housing GF-USB-RJ45-32 GFCI Receptacle 2xUSB A connections RJ45 Size 32 Housing GF-DB15-RJ45-USBBFAF-32 GFCI Receptacle 15 Pin D-Sub RJ45 USB Form B Female to Form A Female Size 32 Housing GF-RJ45-32 GFCI Receptacle RJ45 Size 32 Housing RJ45-2-10LS 2- RJ45 Size 10 Housing RJ45-06LS RJ45 Size 6 Housing DP-3USB-AFAF-32 Duplex Receptacle 3 x USB A Female to Male Connector Size 32 Housing Faceview * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. PICs with International outlets are non-UL. V-12 Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors Popular PIC Models Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Part Number Description DP-DB9-RJ45-R-32 Duplex Receptacle 9 Pin D-Sub RJ45 3 AMP Reset Size 32 Housing DP-2RJ45-R-32 Duplex Receptacle 2- RJ45 3 AMP Reset Size 32 Housing GF-RJ45-5R-32 GFCI Receptacle RJ45 5 AMP Reset Size 32 Housing DP1-2DB9-RJ45-R-32 Single Outlet 2 x 9 Pin D-Subs RJ45 3 AMP Reset Size 32 Housing DP1-DB9-USB-*-24LS Single Outlet 9 Pin D-Subs USB Form A Female with Cable to USB Form A Male Size 24 Housing GF-RJ45-10R-32 GFCI Receptacle RJ45 10 AMP Reset Size 32 Housing DP1-RJ45-R-16LS Single Outlet 3 AMP Reset RJ45 Size 16 Housing GF-2RJ45-R-32 GFCI Receptacle 2 x RJ45 3 AMP Reset Size 32 Housing DP-DB9-PC9-RJ45-R-32 Duplex Receptacle 9 Pin D-Sub to Terminal Block RJ45 3 AMP Reset Size 32 Housing DP1-RJ45-10LS Single Outlet RJ45 Size 10 Housing DP1-2RJ45-24LS Single Outlet 2 x RJ45 Size 24 Housing RJ45-2USB-*-16LS RJ45 2 x USB Form A Female with Cable to USB Form A Male Size 16 Housing DB09-RJ45-10LS 9 Pin D-Sub RJ45 Size 10 Housing DP-R-32 Duplex Receptacle 3 AMP Reset Size 32 Housing DP-R-TS Duplex Receptacle 3 AMP Reset DIN Rail Mounting GF-15R-32 GF-DB15-R-32 GFCI Receptacle 15 Pin D-Sub 3 AMP Reset Size 32 Housing DP-RJ45-5R-32 Faceview GFCI Receptacle 15 AMP Reset Size 32 Housing Duplex Receptacle RJ45 5 AMP Reset Size 32 Housing Faceview Panel Interface Connectors Description V Part Number * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-13 Panel Interface Connectors Popular PIC Models Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Part Number Description Panel Interface Connectors V Part Number Description GF-R-32 GFCI Receptacle 3 AMP Reset Size 32 Housing DP1-DB9M-16LS Single Outlet 9 Pin D-Sub Male Exterior/Male Interior Size 16 Housing GF-RJ45-USB-BFAF-32 GFCI Receptacle RJ45 USB Female Form B to Female Form A Size 32 Housing DP-RJ45S-USB-BFAFR-32 Duplex Receptacle Shielded RJ45 USB Female Form B to Female Form A 3 AMP Reset Size 32 Housing DCH1-RJ45-R-32 China 10 AMP Receptacle RJ45 3 AMP Reset Size 32 Housing D-BNC-2-10LS 2 x BNC Size 10 Housing RJ11-06LS RJ11 Size 06 Housing DP1-USB-BFAF-16LS Single Outlet USB Female Form B to Female Form A Size 16 Housing DB09-2RJ45-16LS 9 Pin D-Sub 2 x RJ45 Size 16 Housing DUK-RJ45-R-32 UK Receptacle RJ45 3 AMP Reset Size 32 Housing RJ45-2USB-*-24 RJ45 2 x USB Form A Female with Cable to USB Form A Male Size 24 Housing DP-RJ11-RJ45-R-32 Duplex Receptacle RJ11 RJ45 3 AMP Housing Size 32 Housing GF-DB9F-RJ45-R-32 GFCI Receptacle 9 pin D-Sub Female Exterior/Female Interior RJ45 3 AMP Reset Size 32 Housing RJ45-USB-*-10LS RJ45 USB Form A Female with Cable to USB Form A Male Size 10 Housing D-USB-16LS 2 x USB A connections Size 16 Housing DP1-06LS Single Outlet Size 06 Housing GF-2RJ45-5R-32 GFCI Receptacle 2 x RJ45 5 AMP Reset Size 32 Housing DP1-RJ11-2RJ45-R-32 Single Outlet RJ11 2 x RJ45 3 AMP Reset Size 32 Housing Faceview * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. PICs with International outlets are non-UL. V-14 Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors Popular PIC Models Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating DP1-DB9-16LS Single Outlet 9 Pin D-Sub Size 16 Housing Faceview Part Number Description EP-R-32 Continental European Receptacle 3 AMP Reset Size 32 Housing DB25-16LS 25 Pin D-Sub Size 16 Housing GF-RJ45-USB-AFAFR-32 GFCI Receptacle RJ45 USB Female Form A to Female Form A 3 AMP Reset Size 32 Housing DP1-RJ11-R-16 Single Outlet RJ11 3 AMP Reset Size 16 Housing GF-DB9-R-32 GFCI Receptacle 9 Pin D-Sub 3 AMP Reset Size 32 Housing DP-DB9-R-32 Duplex Receptacle 9 Pin D-Sub No Reset Size 32 Housing DCH2-RJ45-R-32 China 16 AMP Receptacle RJ45 3 AMP Reset Size 32 Housing DP-15R-P32 Duplex Receptacle 15 AMP Reset Size 32 Surface Mount Housing GF-RJ45-USB-*-R-32 GFCI Receptacle RJ45 USB Form A Female with Cable to USB Form A Male 3 AMP Reset Size 32 Housing 2 x 9 Pin D-Sub Size 10 Housing DP1-DDB15-RJ452USB-*-R-48 Single Outlet Hi-Density 15 Pin D-Sub RJ45 2 x USB Form A Female with Cable to USB Form A Male 3 AMP Reset Size 48 Housing 4 x 9 Pin D-Sub Size 24 Housing D-2USB-*-10LS 2 x USB Form A Female with Cable to USB Form A Male Size 10 Housing GF20-NR-32 20A GFCI Receptacle No Reset Size 32 Housing DP1-RJ45-USB-BFAFR-24 Single Outlet RJ45 USB Female Form B to Female Form A 3 AMP Reset Size 24 Housing DB09-2-10LS DB09-4-24LS DCH1-RJ45-32 DHDP-DB9-RJ45-R-32 China 10 AMP Receptacle RJ45 Size 32 Housing Duplex Receptacle Data Hwy DB9 RJ45 3 AMP Reset Size 32 Housing Faceview Panel Interface Connectors Description V Part Number * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. PICs with International outlets are non-UL. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-15 Panel Interface Connectors Other Popular Models Duplex Versions | Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Part Number Description DP-2-32 2 x Duplex Receptacles, Size 32 Housing DP-2DB9-32 Duplex Receptacle, 2 x 9 Pin D-Sub, Size 32 Housing DP-2RJ45-32 Duplex Receptacle, 2 x RJ45, Size 32 Housing DP-2RJ45-R-P32 Duplex Receptacle, 2 x RJ45, 3 AMP Reset, Size 32 Surface Mount Housing DP-2USB-*-2RJ45-32 Duplex Receptacle, 2 x USB Form A Female with Cable to USB Form A Male, 2 x RJ45, Size 32 Housing DP-DB9F-RJ45S-R-32 Duplex receptacle, 9 pin D-Sub Female Exterior/Female Interior, Shielded RJ45, 3 AMP reset, Size 32 housing DP-DB9-RJ45-5R-32 Duplex Receptacle, 9 Pin D-Sub, RJ45, 5 AMP Reset, Size 32 Housing DP-DB9-RJ45-NR-32 Duplex Receptacle, 9 Pin D-Sub, RJ45, No Reset, Size 32 Housing DP-DB9-USB-*-32 Duplex Receptacle, 9 Pin D-Sub, USB Form A Female with Cable to USB Form A Male, Size 32 Housing DP-DDB15-6M2-RJ45-USB-R-48 Duplex Receptacle, Hi-Density 15 Pin D-Sub, 2x6 Pin Mini-DIN, RJ45, 2xUSB Form A, 3 AMP Reset, Size 48 Housing DP-DDB15-RJ45-4USB-*-48LS Duplex Receptacle, Hi-Density 15 Pin D-Sub, RJ45, 4 x USB Form A Female with Cable to USB Form A Male, Size 48 Housing DP-RJ45-10R-32 Duplex Receptacle, RJ45, 10 AMP Reset, Size 32 Housing DP-RJ45-2USB-AFAF-R-32 Duplex Receptacle, RJ45, 2 x USB Form A Female to Female, 3 AMP Reset, Size 32 Housing DP-RJ45-2USB-AFBF-R-32 Duplex Receptacle, RJ45, 2 x USB Form A Female to Form B Female, 3 AMP Reset, Size 32 Housing DP-RJ45-NR-32 Duplex Receptacle, RJ45, No Reset, Size 32 Housing DP-RJ45-USB-*-R-32 Duplex Receptacle, RJ45, USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 32 Housing DP-RJ45-USB-BFAF-R-32 Duplex Receptacle, RJ45, USB Form B Female to Form A Female, 3 AMP Reset, Size 32 Housing DP-USB-*-NR-32 Duplex Receptacle, USB Form A Female with Cable to USB Form A Male, No Reset, Size 32 Housing * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Panel Interface Connectors V V-16 Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Other Popular Models 120V GFCI Versions | Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Description GF20 -20R-32 20A GFCI Receptacle, 20 AMP Reset, Size 32 Housing GF-2DB25-R-48 GFCI Receptacle, 2 x 25 Pin D-Sub, 3 AMP Reset, Size 48 Housing GF-2RJ45-USB-BFAF-32 GFCI Receptacle, 2 x RJ45, USB Form B Female to Form A Female, Size 32 Housing GF-DB15-RJ45-USB-BFAF-32 GFCI Receptacle, 15 Pin D-Sub, RJ45, USB Form B Female to Form A Female, Size 32 Housing GF-DB25-USB-NR-48 GFCI Receptacle, 25 Pin D-Sub, 2 x USB Form A, No Reset, Size 48 Housing GF-DB25-USB-R-48 GFCI Receptacle, 25 Pin D-Sub, 2 x USB Form A, 3 AMP Reset, Size 48 Housing GF-DB9-2RJ45-32 GFCI Receptacle, 9 Pin D-Sub, 2 x RJ45, Size 32 Housing GF-DB9-DB25-RJ45-R-48 GFCI Receptacle, 9 Pin D-Sub, 25 Pin D-Sub, RJ45, 3 AMP Reset, Size 48 Housing GF-DB9M-RJ45-R-32 GFCI Receptacle, 9 pin D-Sub Female Exterior/Male Interior, RJ45, 3 AMP Reset, Size 32 Housing GF-DB9M-RJ45-USB-*-R-48 GFCI Receptacle, 9 Pin D-Sub Female Ext./Male Int., RJ45, USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 48 Housing GF-DB9-PC9-RJ45-USB-48 GFCI Receptacle, 9 Pin D-Sub Female to a Discrete Wire Pluggable Screw Terminal Block, RJ45, 2xUSB Form A, Size 48 Housing GF-DB9-RJ45-15R-32 GFCI Receptacle, 9 Pin D-Sub, RJ45, 15 AMP Reset, Size 32 Housing GF-MDB9-RJ45-USB-AFAF-32 GFCI Receptacle, 9 Pin D-Sub Male Exterior/Female Interior, RJ45, USB Form A Female to Female, Size 32 Housing GF-NR-32 GFCI Receptacle, No Reset, Size 32 Housing GF-RJ11-RJ45-R-32 GFCI Receptacle, RJ11, RJ45, 3 AMP Reset, Size 32 Housing GF-RJ45-15R-32 GFCI Receptacle, RJ45, 15 AMP Reset, Size 32 Housing GF-RJ45-6M-USB-*-R-48 GFCI Receptacle, RJ45, 6 Pin Mini-DIN, USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 48 Housing GF-RJ45-8M-R-32 GFCI Receptacle, RJ45, 8 Pin Mini-DIN, 3 AMP Reset, Size 32 Housing GF-RJ45-NR-P32-2X8 GFCI Receptacle, RJ45, No Reset, Size 32 Surface Mount Housing with Insert for 2-8mm Cables GF-RJ45-R-P32 GFCI Receptacle, RJ45, 3 AMP Reset, Size 32 Surface Mount Housing GF-RJ45S-NR-32 GFCI Receptacle, Shielded RJ45, No Reset, Size 32 Housing GF-RJ45-USB-*-R-32 GFCI Receptacle, RJ45, USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 32 Housing GF-RJ45-USB-AFAF-32 GFCI Receptacle, RJ45, USB Form A Female to Female, Size 32 Housing GF-RJ45-USB-AFBF-R-32 GFCI Receptacle, RJ45, USB Form A Female to Form B Female, 3 AMP Reset, Size 32 Housing GF-RJ45-USB-BFAF-R-32 GFCI Receptacle, RJ45, USB Form B Female to Form A Female, 3 AMP Reset, Size 32 Housing GF-USB-BFAF-NR-32 GFCI Receptacle, USB Form B Female to Form A Female, No Reset, Size 32 Housing GF-USB-BFAF-R-32 GFCI Receptacle, USB Form B Female to Form A Female, 3 AMP Reset, Size 32 Housing GF-USB-R-32 GFCI Receptacle, 2 x USB Form A, 3 AMP Reset, Size 32 Housing V Part Number Panel Interface Connectors Encl. Acc. * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-17 Panel Interface Connectors Other Popular Models Single Outlet Versions | Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Panel Interface Connectors Part Number Description DP1-2-16LS 2 x Single Outlet, Size 16 Housing DP1-2DB9-16LS Single Outlet, 2 x 9 Pin D-Sub, Size 16 Housing DP1-2DB9-DB15-32 Single Outlet, 2 x 9 Pin D-Sub,15 Pin D-Sub, Size 32 Housing DP1-2DB9F-RJ45-R-32 Single Outlet, 2 x 9 Pin D-Sub Female Ext/Female Interior, RJ45, 3 AMP Reset, Size 32 Housing DP1-2DB9-RJ45-32 Single Outlet, 2 x 9 Pin D-Sub, RJ45, Size 32 Housing DP1-2RJ45-R-24 Single Outlet, 2 x RJ45, 2 AMP Reset, Size 32 Housing DP1-3USB-*-R-32 Single Outlet, 3 x USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 32 Housing DP1-8M-16LS Single Outlet, 8 Pin Mini-DIN, Size 16 Housing DP1-8M-R-24LS Single Outlet, 8 Pin Mini-DIN, 3 AMP Reset, Size 24 Housing DP1-DB9-R-16LS Single Outlet, 9 Pin D-Sub, 3 AMP Reset, Size 16 Housing DP1-DB9-RJ45-5R-32 Single Outlet, 9 Pin D-Sub, RJ45, 5 AMP Reset, Size 32 Housing DP1-DB9-RJ45-R-32 Single Outlet, 9 Pin D-Sub, RJ45, 3 AMP Reset, Size 32 Housing DP1-DB9-RJ45-USB-*-R-32 Single Outlet, 9 Pin D-Sub, RJ45, USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 32 Housing DP1-DDB15F-RJ45-USB-32 Single Outlet, Hi-Density 15 Pin D-Sub Female Ext./Int., RJ45, 2xUSB Form A, Size 32 Housing DP1-DDB15F-USB-R-32 Single Outlet, Hi-Density 15 Pin D-Sub Female Ext./Int., 2xUSB Form A, 3 AMP Reset, Size 32 Housing DP1-DDB15-RJ45-2USB-*-R-48 Single Outlet, Hi-Density 15 Pin D-Sub, RJ45, 2 x USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 48 Housing DP1-DDB15-USB-R-32 Single Outlet, Hi-Density 15 Pin D-Sub, RJ45, 2xUSB Form A, 3 AMP Reset, Size 32 Housing DP1-MDB9-RJ45-16LS Single Outlet, 9 Pin D-Sub Male Exterior/Female Interior, RJ45, Size 16 Housing DP1-RJ45-2USB-*-R-32 Single Outlet, RJ45, 2 x USB Form A Female with Cable to USB Form A Male, 3 AMP Reset, Size 32 Housing DP1-RJ45-USB-AFAF-R-24 Single Outlet, RJ45, USB Form A Female to Female, 3 AMP Reset, Size 24 Housing DP1-RJ45-USB-R-32 Single Outlet, RJ45, 2 x USB Form A, 3 AMP Reset, Size 32 Housing DP1-USB-*-16LS Single Outlet, USB Form A Female with Cable to USB Form A Male, Size 16 Housing DP1-USB-AFAF-16LS Single Outlet, USB Form A Female to Female, Size 16 Housing * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. V V-18 Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Other Popular Models Non-Power Versions | Standard Metal Housing | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Part Number Description DB09-2-PL10 2 x 9 Pin D-Sub, Size 10 Plate DB09-2-RJ45-24 2 x 9 Pin D-Sub, RJ45, Size 24 Housing DB09-2-RJ45-5M12-24 2 x 9 Pin D-Sub, RJ45, 5 Pole MDC(M12) Receptacle, Size 24 Housing DB09-3-16LS 3 x 9 Pin D-Sub, Size 16 Housing DB09-DDB15-USB-RJ45-6M2-32 9 Pin D-Sub, Hi-Density 15 Pin D-Sub, 2 x USB Form A, RJ45, 2 x 6 Pin Mini-Din, Size 32 Housing DB09F-PL06 9 Pin D-Sub Female Exterior/Female Interior, Size 6 Plate DB09M-06LS 9 Pin D-Sub Male Exterior/Male Interior, Size 6 Housing DB09-PL06 9 Pin D-Sub, Size 6 Plate DB09-RJ45-USB-*-24LS 9 Pin D-Sub, RJ45, USB Form A Female with Cable to USB Form A Male, Size 24 Housing DB09-USB-*-10LS 9 Pin D-Sub, USB Form A Female with Cable to USB Form A Male, Size 10 Housing DB15-DB25-PL24 15 Pin D-Sub, 25 Pin D-Sub, Size 24 Plate DB25-2-4BNC-48 2 x 25 Pin D-Sub, 4 x BNC Female/Female, Size 48 Housing DB25-RJ45-USB-32 25 Pin D-Sub, RJ45, 2 x USB Form A, Size 32 Housing DB37-16LS 37 Pin D-Sub, Size 16 Housing DB9-DB9F-DDB15-RJ45-3USB-*-32 9 Pin D-Sub, 9 Pin D-Sub Female Ext./Female Int., Hi-Density 15 Pin D-Sub, RJ45, 3 x USB Form A Female with Cable to USB Form A Male, Size 32 Housing DBM09-06LS 9 Pin D-Sub Male Exterior/Male Interior, Size 6 Housing DBM09-2RJ45-3USB-*-32 9 Pin D-Sub Male Exterior/Male Interior, 2 x RJ45, 3 x USB Form A Female with Cable to USB Form A Male, Size 32 Housing DBM09-3-16LS 3 x 9 Pin D-Sub Male Exterior/Male Interior, Size 16 Housing DDB15-USB-24 Hi-Density 15 Pin D-Sub, 2 x USB Form A, Size 24 Housing V Panel Interface Connectors * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-19 Panel Interface Connectors Other Popular Models Other Versions | Standard Metal Housing | DIN Rail | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Part Number Description DIN Rail Mounted (For Inside Panels) DB9-TS 9 Pin D-sub, DIN Rail Mount DP1-RJ45-TS Single Outlet Receptacle, RJ45, DIN Rail Mount DP-TS Duplex Receptacle, DIN Rail Mount Ethernet RJ45-4-24LS 4 x RJ45, Size 6 Housing RJ45C-2-10LS 2 x RJ45 with Punchdown, Size 10 Housing USB D-2USB-AFAF-2RJ45-24LS 2xUSB Form A Female to Female, 2 x RJ45, Size 24 Housing D-USB-*-PL06 USB Form A Female with Cable to USB Form A Male, Size 6 Plate D-USBBB-*-06LS USB Form B Female to Form B Male Cable, Size 6 Housing D-USB-RJ45-24LS 2 x USB Form A, RJ45, Size 24 Housing Others DFD-24LS-KIT Housing and Bracket for Mounting 3-1/2 Bay Unit (Floppy Drives, Zip Drives, Jazz Drives, etc.), Drives Not Included D-FOPT-12 Fiber Optic Connector, 1/2-14 NPT Shell D-HDMI-**-06LS HDMI Male/Female Cable, Size 6 Housing DMC-RJ45-R-16 C14 Male Receptacle IEC, RJ45, 3 AMP Reset, Size 16 Housing IEC-2-GF-48 2 x C13 Female Receptacles IEC with GFCI, Size 48 Housing * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. ** Length in meters. Panel Interface Connectors V V-20 Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Other Popular Models International Outlet Versions | Standard Metal Housing | Non-UL | IP65 Rating Part Number Description Australia DAS-32 Australian Outlet, Size 32 Housing DAS-DB9-RJ45-R-32 Australian Outlet, 9 Pin D-Sub, RJ45, 3 AMP Reset, Size 32 Housing DAS-RJ45-5R-32 Australian Outlet, RJ45, 5 AMP Reset, Size 32 Housing DAS-RJ45-R-32 Australian Outlet, RJ45, 3 AMP Reset, Size 32 Housing Continental Europe (German Schuko) EP-2RJ45-R-32 Continental European Receptacle, 2 x RJ45, 3 AMP Reset, Size 32 Housing EP-DB25-RJ45-32 Continental European Receptacle, 25 Pin D-Sub, RJ45, Size 32 Housing EP-DM8-NR-32 Continental European Receptacle, 8 Pin Mini-DIN, No Reset, Size 32 Housing EP-RJ45-2USB-AFAF-R-32 Continental European Receptacle, RJ45, 2xUSB Form A Female to Female, 3 AMP Reset, Size 32 Housing EP-RJ45-NR-32 Continental European Receptacle, RJ45, No Reset, Size 32 Housing EP-RJ45-USB-*-32 Continental European Receptacle, RJ45, USB Form A Female with Cable to USB Form A Male, Size 32 Housing EP-USB-*-32 Continental European Receptacle, USB Form A Female with Cable to USB Form A Male, Size 32 Housing Other International Brazilian 10 AMP Receptacle, RJ45, 3 AMP Reset, Size 32 Housing DCH1-NR-32 China 10 AMP Receptacle, No Reset, Size 32 Housing DFR-RJ45-NR-32 French Receptacle, RJ45, No Reset, Size 32 Housing DIN-RJ45-R-32 India Receptacle, RJ45, 3 AMP Reset, Size 32 Housing DUN-RJ45-32 Universal Receptacle, RJ45, Size 32 Housing DUN-RJ45-R-48 Universal Receptacle, RJ45, 3 AMP Reset, Size 32 Housing Panel Interface Connectors DBR22-10A-RJ45-R-32 V * Length in feet. Standard cable lengths are 3,6 & 10 feet. Consult factory for other lengths. PICs with International outlets are non-UL. Mencom Corporation | 1-770-534-4585 | www.mencom.com V-21 Panel Interface Connectors PIC Components 120V/250V Power Ports | International Power Ports Mencom Corporation offers a large variety of PIC configurations. Custom orders are welcome. Use the components listed below to configure a panel interface connector to fit your application. Please consult the factory at 770-534-4585 for part numbers and application compliance. 120V/250V Power Ports Code GFDP1 Description International Power Ports Faceview Front 120V GFCI Receptacle Back 120V Simplex Receptacle Front Code Description EP Continental European Receptacle Back GF 120V GFCI Receptacle DIN India Receptacle DP 120V Duplex Receptacle DUK United Kingdom Receptacle DP1 120V Simplex Receptacle DAS Australian Receptacle DCH1 China 10 AMP DPT 120V “Twist Lock” Duplex Receptacle DCH2 China 16 AMP Panel Interface Connectors V DPIG 120V Isolated Ground Duplex Receptacle DBR Brazilian Receptacle DEC 250V/15A Female Receptacle FR French Receptacle DMC 250V/15A Male Receptacle DUN Universal Receptacle (USA, European, UK, Australia, Asia, Thailand) Models containing an international power outlet do not carry UL. V-22 Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors PIC Components Communication Ports | D-Sub | Ethernet | BNC | Coaxial | Mini-Din | USB | Fiber Optic DB9 9 Pin D-Sub Female Ext/ Male Interior DB9M 9 Pin D-Sub Male Ext/ Male Interior MDB9 9 Pin D-Sub Male Ext/ Female Interior DB9F 9 Pin D-Sub Female Ext/ Female Interior DB15 15 Pin D-Sub Female Ext/ Male Interior DB15M 15 Pin D-Sub Male Ext/ Male Interior MDB15 15 Pin D-Sub Male Ext/ Female Interior DB15F 15 Pin D-Sub Female Ext/ Female Interior DDB15 Hi-Density 15 Pin D-Sub, Female Ext/Male Interior DDB15M Hi-Density 15 Pin D-Sub Male Ext/Male Interior MDDB15 Hi-Density 15 Pin D-Sub Male Ext/Female Interior DDB15F Hi-Density 15 Pin D-Sub Female Ext/Interior DB25 25 Pin D-Sub Female Ext/ Male Interior DB25M 25 Pin D-Sub Male Ext/ Male Interior MDB25 25 Pin D-Sub Male Ext/ Female Interior DB25F 25 Pin D-Sub Female Ext/ Female Interior DB37 37 Pin D-Sub Female Ext/ Male Interior DB37M 37 Pin D-Sub Male Ext/ Male Interior MDB37 37 Pin D-Sub Male Ext/ Female Interior DB37F 37 Pin D-Sub Female Ext/ Female Interior DB9-PC9 9 Pin D-Sub Female to a Discrete Wire Pluggable Screw Terminal Block DB25-PC25 25 Pin D-Sub Female to a Discrete Wire Pluggable Screw Terminal Block Faceview FRONT VIEW Description RJ45 Ethernet Female/Female RJ11/12 Standard Phone Female/ Female RJ22 Handset Jack Female/ Female BNC BNC Female/Female CX Coaxial Female/Female 8M 8 Pin Mini-Din Female/ Female 6M 6 Pin Mini-Din Female/ Female USB 2 USB 3.0 Female Form A to USB 3.0 Form A Female USB-03 3 Foot Cable, Female Form A to Male Form A USB-06 6 Foot Cable, Female Form A to Male Form A USB-10 10 Foot Cable, Female Form A to Male Form A USB-AFAF Single USB 3.0 Form A Female to USB 3.0 Form A Female USB-AFBF Single Form A Female to Form B Female USB-BFAF Single Form B Female to Form A Female HDMI High-Definition Multimedia Interface FOPT Fiber Optic Faceview BACK VIEW FRONT VIEW Mencom Corporation Code Panel Interface Connectors Description V Code BACK VIEW | 1-770-534-4585 | www.mencom.com V-23 Panel Interface Connectors PIC Components Data Highighway | Resets Data Highway Code Description DH-DB9 9 Pin D-Sub to 3 pin Pluggable Terminal Block DH-8M DH-DB9-8M Faceview FRONT VIEW BACK VIEW FRONT VIEW 8 pin Mini-Din to 3 Pin Pluggable Terminal Block 9 Pin D-Sub and 8 Pin Mini-Din in Parallel Resets Code Description NR (or Blank) No reset R 3 AMP reset 5R 5 AMP reset 10R 10 AMP reset 15R 15 AMP reset BACK VIEW FRONT VIEW BACK VIEW To specify Data Highway PICs, add “DH” Prefix in front of the part number. (e.g. DH-DB9-06LS, DHDP-DB9-R-32) Panel Interface Connectors V V-24 These communication ports are wired to a 3 pin pluggable terminal block and are designed to work with Allen Bradley’s Data Highway System (“Blue Hose”). Mencom Corporation | 1-770-534-4585 | www.mencom.com Faceview Panel Interface Connectors Low Profile PIC Housings Dimensions and Cutouts Clear Cover | Solid Construction | UL Type 4, 12 | IP65 Rating Encl. Acc. Code LP1 LP2 Description Single Cover Two Single Covers Torque [65] 2.6 [65] 2.6 [124] 4.9 Dimension[124] 4.9 [65] 2.6 [124] 4.9 Panel Cut-Out [117] 4.6 [117] 4.6 0.9 N-m (0.675 Lb-Ft) [117] 4.6 0.9 N-m (0.675 Lb-Ft) [130.2] 5.1 [130.2] 5.1 [124] 4.9 [124] 4.9 [130.2] 5.1 [124] 4.9 [117] 4.6 [117] 4.6 A1 A2 R 52mm 2.05” 91mm 3.58” 2.0mm 0.08” 117mm 4.61” 91mm 3.58 2.0mm 0.08” 117mm 4.61” 91mm 3.58 2.0mm 0.08” [117] 4.6 Double Cover 0.9 N-m (0.675 Lb-Ft) [124] 4.9 [124] 4.9 [130.2] 5.1 [124] 4.9 [117] 4.6 [117] 4.6 [117] 4.6 Information above is only to display dimensions and cutouts. A1 Specifications: Body: Nickel Plated Zinc Front Cover: Polycarbonate Latch & Lock: PBT Back Cover: Polypropylene Panel Thickness: 5.0mm max Gasket: Nitrile/UL70 Panel Cutout V A2 R Panel Interface Connectors LP3 [130.2] 5.1 [130.2] 5.1 Mencom Corporation | 1-770-534-4585 | www.mencom.com V-25 Panel Interface Connectors Standard Metal Housings Dimensions and Cutouts Bulkhead Mount Housing | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Code Description Screw Size Torque SIZE 6 06LS Size 6 Bulkhead Housing SIZE 6 M4 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) SIZE 6 [80.4] 3.2 [80.4] 3.2 [80.4] 3.2 SIZE 10 10LS 16LS 24LS Size 10 Bulkhead Housing Size 16 Bulkhead Housing Size 24 Bulkhead Housing SIZE 10 M4 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) SIZE 10 [93.5] 3.7 [93.5] 3.7 [93.5] 3.7 SIZE 16 M4 M4 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) SIZE 16 SIZE 16 [113.5] 4.5 [113.5] 4.5 [113.5] 4.5 SIZE 24 SIZE 24 SIZE 24 [142.5] 5.6 [142.5] 5.6 [142.5] 5.6 32LS Panel Interface Connectors 48LS Size 32 Bulkhead Housing M4 Size 48 Bulkhead Housing M6 Panel Cut-Out Dimension 1.2 ~ 1.8 Nm (0.9 ~ 1.3 Lb-Ft) 3.0 ~ 3.6 Nm (2.2 ~ 2.7 Lb-Ft) Aggressive environment housings available, contact the factory. Information above is only to display dimensions and cutouts. SIZE 32 SIZE 32 B1 B2 D [96] 3.8 [96] 1.8 [45.5] 1.8 52mm 2.05” 35mm 1.38” 70mm 2.76” 32mm 1.26” 4.5mm .177” 67mm 2.64” 35mm 1.37” 83mm 3.27” 32mm 1.26” 4.5mm .177” 86mm 3.39” 35mm 1.38” 103mm 4.06” 32mm 1.26” 4.5mm .177” 112mm 4.41” 35mm 1.38” 130mm 5.12” 32mm 1.26” 4.5mm .177” 88mm 3.46” 76mm 2.99” 110mm 4.33” 65mm 2.56” 4.5mm .177” 125mm 4.92” 81mm 3.19” 148mm 5.83” 70mm 2.76” 6.5 mm .256” 3.8 [96] 3.8 [45.5] 1.8 [45.5] [99] 3.9 [99] 3.9 [99] 3.9 [96] 3.8 [96] 1.8 [45.5] 1.8 3.8 [96] 3.8 [45.5] 1.8 [45.5] [99] 3.9 [99] 3.9 [99] 3.9 [96] 3.8 [96] 1.8 [45.5] 1.8 3.8 [96] 3.8 [45.5] 1.8 [45.5] [99] 3.9 [99] 3.9 [99] 3.9 [96] 3.8 [96] 3.8 [96] 3.8 [133] 5.2 [133] 5.2 [126] 5.0 [126] 5.0 SIZE 48 SIZE 48 A2 [45.5] 1.8 [45.5] [99] 3.9 [99] 3.9 [99] 3.9 A1 1.8 [45.5] 1.8 [92] 3.6 [92] 3.6 [133] 5.2 [133] 5.2 [164] 6.5 [164] 6.5 [168] 6.6 [168] 6.6 [93] 3.7 [93] 3.7 [140] 5.5 [140] 5.5 A1 V Specifications: Body: Epoxy Coated Die Cast Aluminum Gasket: Thermoplastic Elastomer Handle: Polyamide Lever: Stainless Steel Type 4 & Type 12: Any Stainless Steel Screw Type 4X : 304 or 316 Stainless Steel Screw B2 A2 Panel Cutout B1 V-26 Mencom Corporation | 1-770-534-4585 | www.mencom.com D Panel Interface Connectors Standard Metal Housings Dimensions and Cutouts Surface Mount Housing | UL Type 4, 4X, 12 | IP65 Rating Encl. Acc. Size 6 Surface Mount Housing Screw Size M5 (5/32”) Torque 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) B2 SIZE 6 B2 SIZE 6 [82] 6 SIZE 3.2 [82] 3.2 SIZE 6 B2 [82] 3.2 SIZE B2 B2 SIZE 106 [82] B2 SIZE 10 3.2 B2 P10 Size 10 Surface Mount Housing M5 (5/32”) 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) B2 B2 P16 P24 P32 P48 Size 16 Surface Mount Housing Size 24 Surface Mount Housing Size 32 Surface Mount Housing Size 48 Surface Mount Housing M5 (5/32”) M5 (5/32”) M5 (5/32”) M6 (7/32”) 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) 0.8 ~ 1.2 Nm (0.6 ~ 0.9 Lb-Ft) 1.2 ~ 1.8 Nm (0.9 ~ 1.3 Lb-Ft) 3.0 ~ 3.6 Nm (2.2 ~ 2.7 Lb-Ft) Panel Mounting Holes Dimension [45] 1.8 [45] 1.8 [45] 1.8 B2 [45] 1.8 [45] 1.8 [45] 1.8 [45] 1.8 [45] 1.8 [45] [45] 1.8 1.8 [67] 2.6 [67] 2.6 [67] 2.6 [67] [67] 2.6 2.6 [106] 4.2 [106] 4.2 [106] [106] 4.2 [106] 4.2 4.2 [82] [93.5] SIZE 3.210 3.7 [93.5] 3.7 SIZE 10 [93.5] 3.7 10 SIZE SIZE 16 [93.5] 3.7 SIZE 16 [93.5] 3.7 [117]16 SIZE 4.6 [117] SIZE 16 4.6 [117]16 SIZE 4.6 SIZE [117] 24 4.6 [117] 4.6 SIZE 24 [144]24 SIZE 5.7 [144] SIZE 24 5.7 SIZE 24 [144] 5.7 [144] [144] 5.7 5.7 SIZE 32 SIZE 32 SIZE 32 [125] SIZE3232 4.9 SIZE [125] 4.9 [125] 4.9 [125] [125] [125] 4.9 4.9 SIZE 48 SIZE 48 SIZE 48 SIZE [141] SIZE4848 5.6 [141] 5.6 [141] [141] [141] 5.6 5.6 5.6 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] [97] 3.8 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] 3.8 [97] [97] 3.8 3.8 [134] 5.3 [134] 5.3 [134] 5.3 [134] [134] 5.3 5.3 A1 A2 2.2~2.9 [57~74] 2.2~2.9 [57~74] A2 2.2~2.9A2 [57] [57~74] 2.2 2.2~2.9 [57] [57~74] 2.2 2.2~2.9 [63~81] [57] 2.5~3.2 2.2 [63~81] [57] 2.5~3.2 [63~81][57]2.2 2.5~3.2 2.2 [63~81] [57] 2.5~3.2 2.2 [63~81] [57] 2.5~3.2 2.2 [63~81] [57] 2.2 2.5~3.2 [63~81] [57] 2.5~3.2 [57]2.2 [63~81] 2.2 2.5~3.2 [63~81] [63~81] 2.5~3.2 2.5~3.2 [84] 3.3 [84] 3.3 [84] 3.3 [90] [84] [84] 3.5 3.3 3.3 [90] 3.5 [90] 3.5 [90][90] [90] 3.53.5 [99] 3.9 [99] 3.9 [99] [99] [99] 3.93.9 3.9 CAP/MAP 57mm 2.24 A2 A2A2 [53~73] 2.1~2.9 A2 [53~73] [57~74] 2.1~2.9 A2 [165.2] 6.5 [165.2] 6.5 [165.2] [165.2] 6.5 [165.2] 6.5 6.5 CHP/MHP 52mm 2.05” 82mm 3.23” A2 A2 [53~73] 2.1~2.9 [53~73] 2.1~2.9 [53~73] 2.1~2.9 A2 [120] 4.7 [120] 4.7 [120] [120] 4.7 [120] 4.7 4.7 93.5mm 3.68” CHP/MHP 52mm 2.05” CAP/MAP 57mm 2.24 B1 70mm 2.76” 82mm 3.23” B2 CHP/MHP 40mm 1.57” CAP/MAP 45mm 1.77” CHP/MHP 40mm 1.57” CAP/MAP 45mm 1.77” D 5.5mm .217” 5.5mm .217” 117mm 4.61” 57mm 2.24” 105mm 4.13” 45mm 1.77” 5.5mm .217” 144mm 5.67” 57mm 2.24” 132mm 5.20” 45mm 1.77” 5.5mm .217” 125mm 4.92” 84mm 3.31” 112mm 4.41” 67mm 2.64” 5.5mm .217” 141mm 5.55” 120mm 4.72” 111mm 4.37” 106mm 4.17” 6.5 mm .256” Aggressive environment housings available, contact the factory. Information above is only to display dimensions and cutouts. A1 Specifications: Body: Epoxy Coated Die Cast Aluminum Gasket: Thermoplastic Elastomer Handle: Polyamide Lever: Stainless Steel Type 4 & Type 12: Any Stainless Steel Screw Type 4X : 304 or 316 Stainless Steel Screw Footprint Do not Cut B2 Panel Interface Connectors P06 Description D Panel Mounting Holes A2 V Code B1 Mencom Corporation | 1-770-534-4585 | www.mencom.com V-27 Panel Interface Connectors Other PIC Housings Other Housings Code Description DFD Size 24 housing for mounting floppy drives and zip drives. Dimension [96] 3.8 TS For easy mounting inside the cabinet on DIN rails. This non-watertight version will only accommodate the size 6, 10, 16 and 24 versions. [58] 2.3 [91.5] 3.6 [105.5] 4.2 Panel Interface Connectors V V-28 Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors PIC Extension Cables D-Subminiature (D-Sub) Cables | Guaranteed Color Code This series of 9pin, 25 pin, and 37pin D-Subminiature connectors are provided with a guaranteed color code for ease when hard wiring. All of these cables come standard with 4 20AWG wires for power, and 24AWG for the remaining wires. # of Pins Male Connector Female Connector Male to Female Double Ended Connector 9 N/A DB09-FP-** DB09-MFP-** 25 DB25-MP-** DB25-FP-** DB25-MFP-** 37 N/A DB37-FP-** DB37-MFP-** ** Lengths in meters. Standard cable lengths are 2, 5 & 10 meters. Consult factory for other lengths. Oil Resistant Gray PVC Oil Resistant Gray PVC 24 & 20 AWG with foil shield; 20 AWG drain wire; last 4 wires are 20 AWG Female DB25 Cables DB37 Cables Pin # Color Code Pin # Color Code Pin # Color Code Pin # Color Code Pin # Color Code Pin # Color Code 1 Black 1 Black 14 Green 1 White 14 Violet/Red 27 Yellow/Red 2 Brown 2 Black/White 15 Green/Black 2 White/Black 15 Violet 28 Gray/Red 3 Red 3 Brown 16 Green/White 3 Green 16 Violet/Black 29 Pink/Red 4 Orange 4 Brown/White 17 Blue 4 Green/Black 17 Orange 30 Red/White 5 Yellow 5 Red 18 Blue/White 5 Yellow 18 Orange/Black 31 Light Green/Red 6 Green 6 Red/Black 19 Violet 6 Yellow/Black 19 Light Blue 32 Violet/White 7 Blue 7 Red/White 20 Violet/White 7 Gray 20 Light Blue/Black 33 Light Blue/Red 8 Violet 8 Orange/Black 21 Gray 8 Gray/Black 21 Light Green 34 Brown 9 White 9 Orange 22 Gray/Black 9 Pink 22 Light Green/Black 35 Brown/White 10 Orange/White 23 Pink 10 Pink/Black 23 Blue/Black 36 Blue 11 Yellow 24 Pink/Black 11 Red 24 Brown/Black 37 Blue/White 12 Yellow/Black 25 White 12 Red/Black 25 White/Orange 13 Light Green 13 Black 26 Green/White Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors DB09 Cables Male V Specifications: Cable Jacket: Over mold: Cable: V-29 Ethernet Series Etherlink RJ45 Cordsets PIC Extension Cables Double Ended Cordsets | 42 VDC, 1.5 amps | CAT5e/CAT6a | Strain Relief | IP20 Rating RJ45 Male to Male Plug with No Strain Relief # of Poles 8 Front View Wire AWG Rating Cable Standard 24 AWG 1 RJ45 8 42 VDC 1.5 A Cables Shield Type Jacket Color Part Number PVC N/A Gray RJ45-* PUR N/A Gray RJ45P-** Blue RJ45-IC-*-BU Red RJ45-IC-*-RD Black RJ45-IC-*-BK Gray RJ45S-IC-*-GY Blue RJ45S-IC-*-BU Blue RJ45C6-IC-*-BU CAT5e RJ45 Male to Male Plug with Over-Molded Strain Relief N/A 8 24 AWG 1 RJ45 8 CAT5e PVC Over-Molded 42 VDC 1.5 A Foil Shield to RJ45 Connectors CAT6a PVC Over-Molded N/A RJ45 Male to Male Plug with Strain Relief 4 24 AWG 1 RJ45 8 42 VDC 1.5 A Panel Interface Connectors 8 1 RJ45 N/A Teal RJ45-4MMP-** PVC Foil Shield to RJ45 Connectors Teal RJ45S-4MMP-** PUR Foil & Braided Shield to RJ45 Connectors Teal RJ45SP-4MMP-** TPE Foil & Braided Shield to RJ45 Connectors Teal RJ45SW-4MMP-** PVC N/A Teal RJ45-8MMP-** PUR N/A Teal RJ45P-8MMP-** PUR Foil & Braided Shield to RJ45 Connectors Teal RJ45SP -8MMP-** TPE Foil & Braided Shield to RJ45 Connectors Teal RJ45SW-8MMP-** CAT5e 24 AWG 42 VDC 1.5 A PVC CAT5e 8 26 AWG CAT5e PVC Blue RJ45S-8MMP-** 42 VDC 1.5 A Foil Shield to RJ45 Connectors CAT6a PVC Foil Shield to RJ45 Connectors Blue RJ45C6-8MMPS-** * Lengths in feet. Standard cable lengths are 1, 3, 7, 10, 15, 20, 25 & 50 feet. Consult factory for other lengths. ** Lengths in meters. Standard cable lengths are 1, 2, 4, 5, 6, 10 & 15 meters. Consult factory for other lengths. V RJ45 Male to Male Plug V-30 Mencom Corporation Over-Molded RJ45 Male to Male Plug | 1-770-534-4585 | RJ45 Male to Male Plug with Strain Relief www.mencom.com Panel Interface Connectors PIC Extension Cables Other Extension Cables | D-Sub | USB | Locking IEC Power Connector Body Style Female Part Number 9 Pin D-Sub DB09-MF-* 15 Pin D-Sub DB15-MF-* 25 Pin D-Sub DB25-MF-* 37 Pin D-Sub DB37-MF-* Hi Density 15 Pin D-Sub DDB15-MF-* USB style A Male to USB style A Male USBAA-* USB style A Male to USB style B Male USBAB-* USB style B Male to USB style B Male USBBB-* Locking IEC Power D-515-C13L-* Male Not guaranteed color code See page 29 for guaranteed color code part numbers. Male Male Male Male Male Male Male Male Male Male Male V * Lengths in feet. Standard cable lengths are 3, 6 & 10 feet. Consult factory for other lengths. Panel Interface Connectors Male Connector Type Mencom Corporation | 1-770-534-4585 | www.mencom.com V-31 Panel Interface Connectors PIC Accessories D-Sub Inserts & Shells | Punch & Die Sets | Locking Bar & Padlock | Screw Kits D-Sub Inserts Termination Type Solder Cup Crimp Style Male Female 9 DB09MSC DB09FSC 15 DB15MSC DB15FSC Hi-Density DB15 DDB15MSC DDB15FSC 25 DB25MSC DB25FSC 37 DB37MSC DB37FSC 9 DB09MCR DB09FCR 15 DB15MCR DB15FCR Hi-Density DB15 DDB15MCR DDB15FCR 25 DB25MCR DB25FCR 37 DB37MCR DB37FCR N/A DBMCP DBFCP Crimp Pins D-Sub Shells Part Number # of Pins # of Pins Cable O.D. Range Metal Plastic Watertight 9 5-9 mm DB09-SHELL DB09-SHELL-PA N/A 15 5-9 mm DB15-SHELL DB15-SHELL-PA N/A 25 6-10 mm DB25-SHELL DB25-SHELL-PA DB25-HOOD-WT 37 8.5-14.5 mm DB37-SHELL DB37-SHELL-PA DB37-HOOD-WT Thumb Screws included with shells. Punch & Die Sets Panel Interface Connectors V V-32 Hole Style Dimension Part Number Size 6 35 mm x 52 mm CHI-06-PUNCH Size 10 35 mm x 65 mm CHI-10-PUNCH Size 16 35 mm x 85.5 mm CHI-16-PUNCH Size 24 35 mm x 112.0 mm CHI-24-PUNCH These punches are intended to be used with Greenlee hydraulic hand tools. The punch and die set are available for size 6, 10, 16 and 24 openings only. While punching, the drill holes for fastening the connectors are marked by the die with center marks so that they can easily be drilled out afterwards. Locking Bar and Padlcok Description Size The Locking Bar and Padlock come as a kit. The bar is easily slid into the latch on the panel interface connector and the padlock is then attached through the open hole on the other end. Optional Screw Kits Part Number Size 6 D-PIC-LOCK-06 Size 10 D-PIC-LOCK-10 Size 24 D-PIC-LOCK-24 Size 16 & 32 D-PIC-LOCK Part Number Screw Size Description D-PIC-MT M4 304 Stainless Steel Screw, Platic Washer, Split Washer, Nut D-PIC48-MT M6 304 Stainless Steel Screw, Platic Washer, Split Washer, Nut Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors Port Adapters Single Port Shell | M25 Threads | Metal version | UL Type 4, 12 | IP69 Rating Our smallest Panel Interface Connectors are ideal for tight spaces. The anodized aluminum housing has a connector potted inside and can easily be mounted to a cabinet through a 1” diameter hole. A cap is supplied with each unit to make them suitable for wash down. Encl. Acc. Description Part Number Description D-USB-AFAF-M25 USB Female TYPE A to USB Female TYPE A RJ45-M25 RJ45 Jack to RJ45 Jack D-USB-AFBF-M25 USB Female TYPE A to USB Female TYPE B RJ11-M25 RJ11 Jack to RJ11 Jack D-USB-BFAF-M25 USB Female TYPE B to USB Female TYPE A RJ22-M25 RJ22 Jack to RJ22 Jack D-USB-BFBF-M25 USB Female TYPE B to USB Female TYPE B DM6-M25 6 PIN Female MINI-DIN to 6 PIN Female MINI-DIN BNC-M25 BNC Jack to BNC Jack DM8-M25 8 PIN Female MINI-DIN to 8 PIN Female MINI-DIN D-FOPT-2-M25 2 Agilent HFBR Fiber Optic Adaptors Front Back Front [23.2] .91 Cutout Back PANEL CUTOUT [25.2] Ø1.0 Standard shell is anodized aluminum, for stainless steel shell add a “-SS” suffix. For low profile nickel plated brass shell, add a “-LP” suffix. Standard Shell Low Profile Shell [114] 4.5 [22] Ø.9 12mm (0.47 in) lower [29.1] 1.15 Inside Panel [9.3] .37 [31.8] Ø1.25 [16.9] .66 M25x1.5 Tightening Torque: 6.7 N-m Max. Panel Thickness: 4 mm [14.4] R6 Sealing cap with tether supplied with each unit. NBR tether also acts as gasket for sealing to panel. 6.7 N-m 10 mm Mencom Corporation 1.125-16UN2B V Inside Panel [21.0] .83 Panel Interface Connectors Part Number | 1-770-534-4585 | www.mencom.com V-33 Panel Interface Connectors PIC Accessories Low Profile Single Port Shell | M25 Threads | UL Type 12 | IP65, IP69 Rating Encl. Acc. Mencom port adapters are available in a low profile black plastic shell with a M25 mounting thread. These port adapters have a RJ45, USB Type A, or USB Type B connector, and can easily be mounted to a cabinet through a 1” diameter hole. A cap is supplied with each unit to make them suitable for wash down. Part Number Description RJ12-M25-PA RJ45 Jack to RJ45 Jack RJ45-M25-PA RJ45 Jack to RJ45 Jack RJ45S-M25-PA RJ45 Jack to RJ45 Jack with Shield D-USB-AFAF-M25-PA USB Female TYPE A to Female TYPE A D-USB-AFBF-M25-PA USB Female TYPE A to Female TYPE B D-USB-BFBF-M25-PA USB Female TYPE B to Female TYPE B Tightening Torque: 5.0 N-m Max. Panel Thickness: 15 mm Panel Interface Connectors M25x1.5 RJ45 JACK M25x1.5 [32.0] Ø1.26 RJ45 JACK RJ45 JACK [99] 3.9 [23.8] .94 [99] 3.9 [8.5] .33 [23.8] .94 USB 3.0 TYPE A V [36.0] Ø1.42 Mencom Corporation RJ45 JACK [32.0] Ø1.26 [8.5] .33 [36.0] Ø1.42 USB Port Adapters Cutout [25.2] Ø.99 [36.0] Ø1.42 RJ45 Port Adapters Back [23.2] .91 USB Female TYPE B to Female TYPE A [36.0] Ø1.42 D-USB-BFAF-M25-PA V-34 Front USB 3.0 M25x1.5 TYPE A [32.0] Ø1.26 [99] 3.9 [32.0] Ø1.26 [8.8] .35 [28.4] 1.12 [99] 3.9 [8.8] .35 [28.4] 1.12 | 1-770-534-4585 REAR VIEW [23.0] .91 [31.9] 1.25 [23.0] .91 [31.9] 1.25 REAR VIEW USB 3.0 TYPE A REAR VIEW USB 3.0 TYPE A M25x1.5 | [32] 1.3 nom REAR VIEW [23.0] .91 [31.9] 1.25 [23.0] .91 [31.9] 1.25 [14.1] .55 [14.1] .55 [32] 1.3 nom COVER CLOSED COVER CLOSED [32] 1.3 nom. [14.1] .55 [14.1] .55 www.mencom.com [32] 1.3 nom. COVER CLOSED COVER CLOSED Panel Interface Connectors Port Adapters Single Port Shell | Back Mount | UL Type 12 | IP65, IP69 Rating Encl. Acc. Part Number USB-AFAM-BM-** Description Front Back M20 Cutout [20.2] Ø.80 USB Female TYPE A to Male TYPE A [17.6] .69 (GREENLEE 61089) ** Length in meter. Standard cable lengths are 0.5, 1, 2 & 3 meters. Consult factory for other lengths. L Tightening Torque: 3.5 N-m Max. Panel Thickness: 7.5 mm GASKET [24] [17.4] .69 .94 [22] Ø.87 USB 2.0 TYPE A FEMALE [12.5] .49 [24] Ø.94 [31.5] 1.24 USB 2.0 TYPE A MALE [85] 3.35 M20x1.5 For M20 Cutout [16] 0.63 [25] Ø 0.98 Cap (CAP-M20-PASW-M22T) included. For M22 Cutout Mencom Corporation | 1-770-534-4585 V By flipping over the included jam nut, this port adapter will fit into an M22 cutout. .4] [22 .88 0 Ø Panel Interface Connectors Specifications: Body: Black ABS Gasket Black TPE Jam nut: Black ABS | www.mencom.com V-35 Panel Interface Connectors 10 - 5 Conductor JDC (M12) Panel Mount Junction Bocks Size 32 | 3 Pin Pluggable Power Connector | 25 Pin D-Sub | 300 Volt, 3 amps Female Faceview # of Poles Rating 5 300V 3A Port # PIN # DB25 PIN # 3 PIN Pluggable PIN # ALL PORTS 1 23 & 24 V+ ALL PORTS 3 21 & 22 V- ALL PORTS 5 25 Ground J1 4 1 J1 2 2 J2 4 3 J2 2 4 J3 4 5 J3 2 6 J4 4 7 J4 2 8 J5 4 9 J5 2 10 J6 4 11 J6 2 12 J7 4 13 10 - 5 Pin Female MDC Receptacles J7 2 14 3 Pin pluggable power connector (for alternative to DB25 pins 21 - 25) J8 4 15 J8 2 16 J9 4 17 J9 2 18 J10 4 19 J10 2 20 2 5 1 3 4 D32-10MDC-DB25 M12x1 Custom Options available, please consult the factory. [124] 4.90 [110] 4.33 [90] 3.55 [14] .55 [30] 1.2 [3.5] Ø.14 [65] 2.56 Panel Interface Connectors V V-36 Wiring Part Number 25 Pin D-Sub male connector Specifications: Ratings: Plate: Inserts: Coupling Nuts: O-Ring: Contacts: Gasket: 3 A per Connector 8 A per Block Stainless Steel Polyamide Nickel Plated Brass BUNA-N Copper Alloy with Gold Plating Closed Cell PVC/NBR Mencom Corporation | 1-770-534-4585 | www.mencom.com Panel Interface Connectors 10 - 5 Conductor JDC (M12) Panel Mount Junction Blocks Size 32 | 3 Pin Pluggable Power Connector | 20 Pin Ribbon Cable | 300 Volt, 3 amps # of Poles Rating 5 300V 3A Wiring Part Number DB25 PIN # 3 PIN Pluggable PIN # Port # PIN # ALL PORTS 1 V+ ALL PORTS 3 V- ALL PORTS 5 Ground J1 4 1 J1 2 2 J2 4 3 J2 2 4 J3 4 5 J3 2 6 J4 4 7 J4 2 8 J5 4 9 J5 2 10 J6 4 11 J6 2 12 J7 4 13 10 - 5 Pin Female MDC Receptacles J7 2 14 3 Pin pluggable power connector J8 4 15 J8 2 16 J9 4 17 J9 2 18 J10 4 19 J10 2 20 2 5 1 3 4 D32-10MDC-RC20 M12x1 Custom Options available, please consult the factory. [124.4] 4.90 [110] 4.33 [90] 3.55 [39.5] 1.55 [14] .55 [3.5] Ø.14 [65] 2.56 20 Pin Ribbon Cable 3 A per Connector 8 A per Block Stainless Steel Polyamide Nickel Plated Brass BUNA-N Copper Alloy with Gold Plating Closed Cell PVC/NBR Mencom Corporation V Specifications: Ratings: Plate: Inserts: Coupling Nuts: O-Ring: Contacts: Gasket: Panel Interface Connectors Female Faceview | 1-770-534-4585 | www.mencom.com V-37 Panel Interface Connectors 10 - 5 Conductor JDC (M12) Panel Mount Junction Bocks Size 32 | 3 Pin Pluggable Power Connector | Terminal Block | 300 Volt, 3 amps Female Faceview # of Poles 2 5 1 Rating 5 3 4 Part Number 300V 3A D32-10MDC-TB23 M12x1 Custom Options available, please consult the factory. [124.4] 4.9 [26.1] 1.0 [14] .55 [110] 4.33 [3.5] Ø.14 [90] 3.55 [65] 2.56 10 - 5 Pin Female MDC Receptacles Panel Interface Connectors V V-38 23 Pin Push Button Spring-Clamp Terminal Blocks Specifications: Ratings: Plate: Inserts: Coupling Nuts: O-Ring: Contacts: Gasket: 3 A per Connector 8 A per Block Stainless Steel Polyamide Nickel Plated Brass BUNA-N Copper Alloy with Gold Plating Closed Cell PVC/NBR Mencom Corporation | Wiring Port # PIN # 3 PIN Pluggable PIN # ALL PORTS 1 V+ ALL PORTS 3 V- ALL PORTS 5 Ground J1 4 2 - J1 J1 2 3 - J1 J2 4 2 - J2 J2 2 3 -J2 J3 4 2 - J3 J3 2 3 - J3 J4 4 2 - J4 J4 2 3 - J4 J5 4 2 - J5 J5 2 3 -J5 J6 4 2 - J6 J6 2 3 - J6 J7 4 2 - J7 J7 2 3 - J7 J8 4 2 - J8 J8 2 3 - J8 J9 4 2 - J9 J9 2 3 - J9 J10 4 2 - J10 J10 2 3 - J10 1-770-534-4585 | www.mencom.com Panel Interface Connectors 4, 5 & 6 Conductor JDC (M12) Panel Mount Junction Blocks Size 32 | 8 & 10 Port 8 Port Version Female Faceview 2 3 1 4 M12x1 2 5 1 3 4 # of Poles 10 Port Version Rating Part Number 4 D32-8MDC-4FR-BM-** 3 1 4 M12x1 2 5 300V 4A D32-8MDC-5FR-BM-** 5 1 3 4 M12x1 M12x1 Female Faceview 2 300V 4A | Back Mount | Straight Wiring # of Poles Rating Part Number 4 300V 4A D32-10MDC-4FR-BM-** 5 300V 4A D32-10MDC-5FR-BM-** 6 60V 2A D32-10MDC-6FR-BM-** M12x1 6 60V 2A D32-8MDC-6FR-BM-** M12x1 ** Lengths in meters. Standard Cable lengths are 1, 2, 4, 6 & 10 meters. Consult factory for other lengths. 2~5 Pole females will have all 5 contact holes in the connector. Custom Options available, please consult the factory. [16.5] .48 L [3.5] Ø.14 [90] 3.55 [16.5] .65 [3.5] Ø.14 [90] 3.55 [65] 2.56 [65] 2.56 8 Port Version Specifications: Ratings: Plate: Inserts: [110] 4.33 10 Port Version 4 A per Connector 8 A per Block Stainless Steel Polyamide Mencom Corporation Coupling Nuts: O-Ring: Contacts: Gasket: | 1-770-534-4585 | Nickel Plated Brass BUNA-N Copper Alloy with Gold Plating Closed Cell PVC/NBR www.mencom.com L Panel Interface Connectors [110] 4.33 [124.4] 4.90 V [124.4] 4.90 V-39 Panel Interface Connectors 4, 5 & 6 Conductor JDC (M12) Panel Mount Junction Blocks Size 32 | 8 & 10 Port | Through Panel Mount | Straight Wiring 8 Port Version Female Faceview # of Poles 2 4 3 1 4 10 Port Version Rating Part Number Female Faceview 2 300V 4A D32-8MDC-4FR-TM 4 M12x1 1 Rating Part Number 4 300V 4A D32-10MDC-4FR-TM 5 300V 4A D32-10MDC-5FR-TM 6 60V 2A D32-10MDC-6FR-TM M12x1 2 5 3 1 # of Poles 5 3 4 2 300V 4A D32-8MDC-5FR-TM 5 1 3 4 M12x1 M12x1 6 M12x1 60V 2A D32-8MDC-6FR-TM M12x1 2~5 Pole females will have all 5 contact holes in the connector. Custom Options available, please consult the factory. 124.4 4.90 Panel Interface Connectors V V-40 124.4 4.90 110 4.33 12.19 .48 23.55 .93 3.5 .14 90 3.55 12.19 .48 3.5 .14 90 3.55 65 2.56 65 2.56 8 Port Version Specifications: Ratings: Plate: Inserts: 110 4.33 10 Port Version 4 A per Connector 8 A per Block Stainless Steel Polyamide Mencom Corporation Coupling Nuts: O-Ring: Contacts: Gasket: | 1-770-534-4585 | Nickel Plated Brass BUNA-N Copper Alloy with Gold Plating Closed Cell PVC/NBR www.mencom.com 23.55 .93 Panel Interface Connectors 4 & 8 Conductor Ethernet Series Panel Mount Junction Blocks Size 24 | 4 Port | MDE45 to RJ45 M12 4 Pole to RJ45 Panel Mount Adapters # of Poles Female Faceview 4 D-Coded Wiring MDE45 1 = White/Orange (+ TX) 2 = White/Green (+ RX) 3 = Orange (- TX) 4 = Green (- RX) Part Number 1 to 1 2 to 3 3 to 2 4 to 6 RJ45 Faceview 1 = White/Orange (+ TX) 2 = Orange (- TX) 3 = White/Green (+ RX) 4 = N/C 5 = N/C 6 = Green (- RX) 7 = N/C 8 = N/C D24-4MDE45-4FR-RJ45 M12 x 1 M12 8 Pole to RJ45 Panel Mount Adapters 8 1 to 5 2 to 7 3 to 8 4 to 2 5 to 3 6 to 1 7 to 4 8 to 6 1 = White/Blue 2 = White/Brown 3 = Brown 4 = Orange (-TX) 5 = White/Green (+RX) 6 = White/Orange (+TX) 7 = Blue 8 = Green (-RX) A-Coded M12 x 1 D24-4MDE45-8FR-RJ45 [52] 2.05 [32] 1.26 [52] 2.05 [32] 1.26 [5] Ø.20 [5] Ø.20 M12x1 M12x1 [140] 5.51 [130] 5.12 [130] 5.12 [14] .55 [28.4] 1.1 [16.5] .65 D24-4MDE45-4FR-RJ45 D24-4MDE45-8FR-RJ45 Specifications: Plate: Stainless Steel M12 Coupling: Nickel Plated Brass M12 Insert: Polyamide Contacts: Copper Alloy with Gold Plating O-Rings: NBR Gasket: PVC NBR RJ45 Connector: CAT5e Mounting Screws: #8 or M4 Screws Shielding: Shield connected between M12 Housing and RJ45 Connector Temperature: -40ºC to +80ºC (-40ºF to +176ºF) Mencom Corporation [24.3] 1.0 | 1-770-534-4585 V Cut-out Panel Interface Connectors [140] 5.51 1 = White/Orange (+ TX) 2 = Orange (- TX) 3 = White/Green (+ RX) 4 = N/C 5 = N/C 6 = Green (- RX) 7 = N/C 8 = N/C | www.mencom.com V-41 Panel Interface Connectors 4 Conductor Ethernet Series Panel Mount Junction Blocks Size 32 | 8 Port | MDE45 to RJ45 Female Faceview # of Poles Wiring MDE45 4 1 to 1 2 to 3 3 to 2 4 to 6 1 = White/Orange (+ TX) 2 = White/Green (+ RX) 3 = Orange (- TX) 4 = Green (- RX) D-Coded M12x1 Part Number RJ45 Faceview 1 = White/Orange (+ TX) 2 = Orange (- TX) 3 = White/Green (+ RX) 4 = N/C 5 = N/C 6 = Green (- RX) 7 = N/C 8 = N/C D32-8MDE45-4FR-RJ45 RJ45 [127] 5.0 [93] 3.7 Panel Interface Connectors Specifications: Plate: Stainless Steel M12 Coupling: Nickel Plated Brass M12 Insert: Polyamide Contacts: Copper Alloy with Gold Plating O-Rings: NBR Gasket: PVC NBR RJ45 Connector: Cat 5 Mounting Screws: #8 or M4 Screws Shielding: Shield connected between MDE45 Housing and RJ45 Connector Temperature: -40ºC to +80ºC (-40ºF to +176ºF) [112] 4.41 [6.4] Ø.25 4 PLS [99.1] 3.90 [78.7] 3.10 PANEL CUTOUT [5.8] .23 [6.4] .25 V V-42 Mencom Corporation | 1-770-534-4585 | www.mencom.com [66.6] 2.62
DP-RJ45-R-32 价格&库存
很抱歉,暂时无法提供与“DP-RJ45-R-32”相匹配的价格&库存,您可以联系我们找货
