49SMD-4MHZ-15PF-20PPM
    TKD(泰晶)
    HC-49S/SMD
    无源晶振 -20℃~+75℃
49SMD-4MHZ-15PF-20PPM 数据手册
page 1 of 7 CRYSTAL SEPECIFICATION Customer : Customer P/N : Part Name : Product Description : Issue Date : 49SMD 4M 15PF 20PPM 49SMD-4.000000M-15PF-20PPM 2017.10.20 CUSTOMER’S APPROVAL (PLEASE RETURN A COPY WITH APPOVAL Hubei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 APPROVED DESIGNER 黄祥秒 代伟 SALE:TEL :0722-3309660 FAX :0722-3309768 QCD:TEL :0722-3308231 FAX :0722-3309768 FAE:TEL :0755-27328651 FAX :0755-27328001 page 2 of 7 REV. Description of Revision History Date Designer Checked By A New revision 2015-11-25 DaiWei Huangx m page 3 of 7 CRYSTAL SEPECIFICATION 1. 2. 3. 4. 5. 6. Description: Quartz Crystal Nominal Frequency: 4.000000MHz Oscillation Mode: Fundamental Cutting Mode: AT cut Measurement Instrument: S&A 250B(Measured FL) Electrical Characteristics: [1]Operation Conditions: Item Symbol MIN. Operating Temperature Range Topt Storage Temperature Range Tstg MAX. Unit -20 75 ℃ -40 85 ℃ Load Capacitance CL Drive Level DL 0.1 Symbol MIN. Tolerance dF/Fo Stability Over Temperature Aging TYP. 15 Condition pF 100 uW MAX. Unit Condition -20 20 ppm Refer to Center Frequency@25±3℃ dF/F25 -30 30 ppm Refer to Operating Temperature dF/F25 -5 5 ppm Per Year MAX. Unit ESR 30 Ω Shunt Capacitance C0 7 pF Insulation Resistance IR [2]Frequency Stability: Item TYP. dF/Fo:Frequency Deviation Refer to Center Frequency dF/F25:Frequency Deviation Refer to 25℃ Frequency [3]Electrical Performance: Item Equivalent Series Resistance Symbol MIN. 500 TYP. MΩ Condition @Series @DC 100 Volt 7. Marking:Laser 4.00 :Nominal Frequency 4.00 page 4 of 7 8. Outline drawing (unit:mm) page 5 of 7 9. Reliability Specification Test Item Condition of test Performance Requirements Tensile Strength Termination The unit’s lead wire should withstand a tensile force applied to the termination in the direction of its draw-out axis of up to 1000g maintained as is for 10±2s There should be no abnormalities detected on the unit Solder ability The lead is immersed in a 235±5℃ solder bath within 2±0.5 seconds. A new uniform coating of solder shall cover min mun 95% of the surface being immersed. Endurance condition by a frequency sweep shall be made. The entire frequency range from 10HZ to 50HZ and return to 10HZ,shall be transverseb in 1min. Amplitude(total excursion):1.5mm this motion shall be applied for a period of 2h each of 3 mutually perpendicular axes(a total of 6h) (1).Frequency Change:±5ppm (2).Resistance:±15% Form 70cm height 3 times on 3cm hard wooden floor (1).Frequency Change:±5ppm (2).Resistance:±15% Shock Peak acceleration:981m/s2 duration of the pulse :6ms three successive shocks shall be applied in both direction of 3 mutually perpendicular axes(a total of 18 shocks) (1).Frequency Change:±5ppm (2).Resistance:±15% Damp heat The unit shall be stored at a temperature of 40±2℃with relative humidity of 90%to95% for 48h, then it shall be subjected to standard atmospheric conditions for 1 ~ 2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Dry heat The unit shall be stored at a temperature of 100℃±5℃ for 24h, then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Cold The unit shall be stored at a temperature of-40℃±5℃ for 48h, then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Aging The unit shall be stored at a temperature of 85℃±5℃ for 7d then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. Refer to specification verdict Temperature cycling The unit shall be subjected to 5 successive change of temperature cycles, each as show in table below,then it shall be subjected to standard atmospheric conditions for 1 ~ 2h after which measurement shall be made Refer to specification verdict Vibration Drop Temperature Duration 1 -40℃±3℃ 30min 2 Standard atmospheric conditions Within 30s 3 100℃±3℃ 30min 4 Standard atmospheric conditions Within 30s page 6 of 7 Test Item Sealing Condition of test The crystal filter unit shall be immersed in a industry alcohol for 5±0.5 minutes then 25±3℃ 1~2 Hr before testing Insulation Resistance>500MΩ Refer to specification Resistance to soldering heat Reflow soldering cure see the chart. Soldering iron method: Bit temperature: 350℃±10℃ Application time of soldering iron:5s Max 10. Performance Requirements Packing Desrciption verdict page 7 of 7
49SMD-4MHZ-15PF-20PPM 价格&库存
很抱歉,暂时无法提供与“49SMD-4MHZ-15PF-20PPM”相匹配的价格&库存,您可以联系我们找货
