HPS140MK2
HPS140MK2
    VELLEMAN
    VELLEMAN SA - HPS140MK2 - Product Range:-
HPS140MK2 数据手册
DATA SHEET August 2016 HANDHELD POCKET SCOPE Order code: HPS140MK2 The HPS140MK2 handheld pocket scope still holds the same power as its predecessor, the HPS140, but in a new and modern design. Although small in size, the HPS140MK2 has a bandwidth of up to 10 Mhz and packs 40 Ms / s in real time. The scope’s sensitivity can go as low as 0.1 mV and it has signal markers for amplitude and time. Tip: Add the HPS141 option and use your HPS140MK2 as a versatile component tester. Features • 40 Mega samples/sec in real time • bandwidth up to 10 MHz • full auto range option • sensitivity down to 0.1 mV • signal markers for amplitude and time • memory hold function • optional: - HPS141: component tester for pocket scope HPS140MK2 - HPSPR1: X10 measuring probe - HPSP1: Velleman Instruments pouch Specifications • • • • input range: 1 mV to 20 V / division in 14 steps input coupling: DC, AC and GND time base: 250 ns to 1 h per division readouts: DC, AC + DC,True RMS, dBm, Vpp, Min-Max. (±2.5%) HPSPR1 • white OLED display • power supply: 4 x 1.5 V AAA batteries (not incl.) • operating time: up to 8 hours (on Alkaline batteries) HPSP1 VellemanProjects HPS141 @Vel_Projects VELLEMAN nv - Legen Heirweg 33, Gavere (Belgium) vellemanprojects.com
HPS140MK2 价格&库存
很抱歉,暂时无法提供与“HPS140MK2”相匹配的价格&库存,您可以联系我们找货
