DP14MM2M
DP14MM2M
    STARTECH
    STARTECH - DP14MM2M - Audio / Video Cable Assembly, DisplayPort Plug, DisplayPort Plug, 6.6 ft, 2 m,...
DP14MM2M 数据手册
6.6 ft. (2 m) DisplayPort 1.4 Cable - VESA Certified Product ID: DP14MM2M This DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector. The DP monitor cable provides the essential final link in your audio-video setups and is ideal for: • • • • Delivering enriched presentations Displaying crisp digital signage walls Creating eye-catching visuals for photography, videography, cinematography Producing lifelike gaming VESA® Certified This DP cable is VESA certified to ensure full compliance and efficient operation of the higher link rate of HBR3. It has been tested to meet all DP 1.4 specifications to ensure quality and reliability. Experience the Latest That DisplayPort 1.4 Has to Offer This 8K DisplayPort cable supports all DP 1.4 features: www.startech.com/uk 0800 169 0408 • Resolutions up to 8K (7680x4320) @ 60Hz, backward compatible with 5K (5120x2880) @ 60Hz and • 4K(4096x2160) @ 120Hz and previous generations of DP High Bit Rate 3 (HBR3) bandwidths of 32.4Gbps • • High Dynamic Range (HDR) for higher contrast ratio and vivid colors Multi-Stream Transport (MST) for daisy-chaining multiple monitors • • • • Display Stream Compression 1.2 (DSC) Forward Error Correction 32 uncompressed digital audio channels HDCP 2.2 Flexible Cable with Latched Connectors The cable has a thinner 34 AWG construction that allows for flexible installation with minimal clutter, which is perfect for offsite assignments. Each connector features latches that provide secure connections between your devices. DP14MM2M is backed by a StarTech.com lifetime warranty. www.startech.com/uk 0800 169 0408 Certifications, Reports and Compatibility Applications • • • Deliver enriched presentations using 8K projectors Connect to multiple displays on a digital signage wall Connect computers to 8K displays: ideal for creative professionals • Connect a gaming console to an 8K UHD TV Features • Deliver high-quality connections with a VESA certified DisplayPort cable • Experience crisp DisplayPort video with resolutions of up to 8K@60Hz using this 8K DisplayPort cable Enjoy higher contrast ratios and vivid colors with HDR support Install this flexible 34 AWG DP monitor cable with minimal clutter, or bring it with you for offsite assignments Lifetime warranty and guaranteed reliability • • • www.startech.com/uk 0800 169 0408 Warranty 2 Years Cable Jacket Type PVC - Polyvinyl Chloride Cable Shield Type Aluminum-Mylar Foil with Braid Connector Plating Nickel Fire Rating VW-1 Rated Number of Conductors 19 Connector A 1 - DisplayPort (20 pin) Latching Male Connector B 1 - DisplayPort (20 pin) Latching Male Cable Length 2 m [6.6 ft] Color Black Connector Style Latching Product Height 10 mm [0.4 in] Product Length 2 m [6.6 ft] Product Weight 71 g [2.5 oz] Product Width 12 mm [0.5 in] Wire Gauge 34 AWG Packaging Information Shipping (Package) Weight 71 g [2.5 oz] What's in the Box Included in Package 1 - DisplayPort Cable Hardware Connector(s) Physical Characteristics Product appearance and specifications are subject to change without notice. www.startech.com/uk 0800 169 0408
DP14MM2M 价格&库存
很抱歉,暂时无法提供与“DP14MM2M”相匹配的价格&库存,您可以联系我们找货
DP14MM2M
  • 1+187.88645
库存:164
